Hi there!
A while ago my laptop started not connecting to wired ethernets anymore. The plasma-nm gui stays at “configuring interface” until the connection times out. Sometimes I get a popup stating “Incorrect password” and asking to retype it. After doing so, it goes back to “configuring interface” until asking for the password or timing out again.
I already tried connecting manually with nmcli
, but i get the same loop there.
> nmcli connection up TEST --ask
Secrets are required to access the wired network 'TEST'
Username (802-1x.identity): USERNAME
Password (802-1x.password): PASSWORD
inxi -F
Host: spc Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire A515-57 v: V1.08
serial: <superuser required>
Mobo: ADL model: Ganymede_ADU v: V1.08 serial: <superuser required>
UEFI: Insyde v: 1.08 date: 04/25/2022
Info: 10-core (2-mt/8-st) model: 12th Gen Intel Core i5-1235U bits: 64
type: MST AMCP cache: L2: 6.5 MiB
Speed (MHz): avg: 1709 min/max: 400/4400:3300 cores: 1: 2082 2: 400
3: 2955 4: 730 5: 2436 6: 2379 7: 2157 8: 628 9: 400 10: 2177 11: 1710
12: 2456
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: Chicony ACER HD User Facing driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1: 2560x1440 2: N/A
API: EGL v: 1.5 drivers: iris,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-manjaro1.1
renderer: Mesa Intel Graphics (ADL GT2)
API: Vulkan v: 1.3.279 drivers: intel surfaces: xcb,xlib
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e
IF: wlp42s0 state: up mac: 9c:2f:9d:4d:8e:53
driver: r8168
IF: enp43s0 state: down mac: 08:8f:c3:65:a8:fc
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
IF: enp0s20f0u2 state: up speed: 1000 Mbps duplex: full
mac: 00:e0:4c:71:a4:8e
IF-ID-1: br-4745a2be004e state: down mac: 02:42:82:e9:88:54
IF-ID-2: br-bcaee4fee5f3 state: down mac: 02:42:19:8b:50:b0
IF-ID-3: docker0 state: down mac: 02:42:70:95:01:60
Local Storage: total: 476.94 GiB used: 254.69 GiB (53.4%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2450 MTFDKBA512TFK
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
My only trace so far is found in the output of dmesg
dmesg -I err
integrity: Problem loading X.509 certificate -65
r8168 0000:2b:00.0: Unable to load firmware rtl_nic/rtl8168h-3.fw (-2)
r8168 0000:2b:00.0 enp43s0: Device reseting!
Bluetooth: hci0: ACL packet for unknown connection handle 3837
Some firmware of the realtek gigabit ethernet card seems to be missing.
When trying to find it in the kernel firmware (https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/rtl_nic/
) there seems to be no rtl8168h-3.fw
, only rtl8168h-1.fw
and rtl8168h-2.fw
Am I on the right path, and if so, how can I get the missing firmware -3
If these are not related, what could be the issue?
Thanks in advance!
No such firmware exists as far as I can see, so I have no idea why it’s trying to load it. Post output of modinfo r8168
. Also, is there a reason why you’re using the seperate r8168
driver instead of the kernel r8169
driver that works for most people? This is my ethernet
$ inxi -Na
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
and the r8169 driver uses rtl_nic/rtl8168h-2.fw
$ modinfo r8169 | grep rtl8168h
firmware: rtl_nic/rtl8168h-2.fw
I actually don’t know why the r8168
driver is used. I never installed it explicitly.
Here’s the output of the modinfo command:
modinfo r8168
filename: /lib/modules/6.6.32-1-MANJARO/extramodules/r8168.ko.xz
version: 8.053.00-NAPI
firmware: rtl_nic/rtl8168fp-4.fw
firmware: rtl_nic/rtl8168fp-3.fw
firmware: rtl_nic/rtl8168h-4.fw
firmware: rtl_nic/rtl8168h-3.fw
firmware: rtl_nic/rtl8168h-1.fw
firmware: rtl_nic/rtl8168ep-3.fw
firmware: rtl_nic/rtl8168ep-2.fw
firmware: rtl_nic/rtl8168ep-1.fw
firmware: rtl_nic/rtl8168g-3.fw
firmware: rtl_nic/rtl8168g-2.fw
firmware: rtl_nic/rtl8411-2.fw
firmware: rtl_nic/rtl8411-1.fw
firmware: rtl_nic/rtl8168f-2.fw
firmware: rtl_nic/rtl8168f-1.fw
firmware: rtl_nic/rtl8168e-4.fw
firmware: rtl_nic/rtl8168e-3.fw
firmware: rtl_nic/rtl8168e-2.fw
firmware: rtl_nic/rtl8168e-1.fw
firmware: rtl_nic/rtl8168d-2.fw
firmware: rtl_nic/rtl8168d-1.fw
license: GPL
description: RealTek RTL-8168 Gigabit Ethernet driver
author: Realtek and the Linux r8168 crew <netdev@vger.kernel.org>
srcversion: 5768E2ABC969ACBA42BA843
alias: pci:v00001186d00004300sv00001186sd00004B10bc*sc*i*
alias: pci:v000010ECd00002600sv*sd*bc*sc*i*
alias: pci:v000010ECd00002502sv*sd*bc*sc*i*
alias: pci:v000010ECd00008161sv*sd*bc*sc*i*
alias: pci:v000010ECd00008168sv*sd*bc*sc*i*
depends:
retpoline: Y
vermagic: 6.6.32-1-MANJARO SMP preempt mod_unload
parm: speed_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: duplex_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: autoneg_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: advertising_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: dynamic_aspm:int
parm: aspm:Enable ASPM. (int)
parm: s5wol:Enable Shutdown Wake On Lan. (int)
parm: s5_keep_curr_mac:Enable Shutdown Keep Current MAC Address. (int)
parm: use_dac:Enable PCI DAC. Unsafe on 32 bit PCI slot. (int)
parm: timer_count:Timer Interrupt Interval. (int)
parm: eee_enable:Enable Energy Efficient Ethernet. (int)
parm: hwoptimize:Enable HW optimization function. (ulong)
parm: s0_magic_packet:Enable S0 Magic Packet. (int)
parm: dynamic_aspm_packet_threshold:Dynamic ASPM packet threshold. (int)
parm: disable_wol_support:Disable PM support. (int)
parm: debug:Debug verbosity level (0=none, ..., 16=all) (int)
Somehow the driver seems to try to use not only -3
, but also -4
If it could help, how can I disable the r8168
driver, and where do I get the r8169
driver?
edit:
r8169
seems to be installed as part of the linux66 kernel drivers, so the only question remaining is:
How do I change the running driver from r8168
to r8169
blacklist the r8168 driver.
create a file, as root in /etc/modprobe.d/blacklist.conf
blacklist r8168
reboot
Or:
su -c "echo 'blacklist r8168' > /etc/modprobe.d/99-blacklist.conf"
Reboot
Thanks for your reply!
I just removed it using mhwd
before i read your answer, and now it seems to automatically us the r8169
driver.
inxi -N
driver: mt7921e
driver: r8169
Sadly, the original problem - the wired connection getting no secrets - still persist.
I now removed the connection and re-set it up again, and now it works! (didn’t change any credentials).
So I guess
the new driver works fine,
the old one was indeed the problem and
the connection just needed an additional reset.
Therefore I mark @MrLavender ’s answer as the solution.
Thanks for your help!
system
Closed
14 June 2024 22:46
7
