NetworkManager is not running
NetworkManager is not running in my laptop
KDE Plasma Version: 5.27.9
KDE Frameworks Version: 5.112.0
Qt Version: 5.15.11
Kernel Version: 6.6.1-1-MANJARO (64-bit) / by the way. why it is showing here 6.6.1 while in kernel panel it shows that the version installed and running is 6.6.3?
Graphics Platform: X11
Processors: 4 × Intel® Core™ i5-6300U CPU @ 2.40GHz
Memory: 7,6 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 520
Manufacturer: Dell Inc.
Product Name: Latitude 7480
-----logs:
systemctl start NetworkManager
Job for NetworkManager.service failed because the control process exited with error code.
See "systemctl status NetworkManager.service" and "journalctl -xeu NetworkManager.service" for details.
systemctl status NetworkManager.service         1 ✘  4s 
× NetworkManager.service - Network Manager
     Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
     Active: failed (Result: exit-code) since Sat 2023-12-16 05:34:22 CET; 31s ago
   Duration: 334ms
       Docs: man:NetworkManager(8)
    Process: 11028 ExecStart=/usr/bin/NetworkManager --no-daemon (code=exited, status=1/FAILURE)
   Main PID: 11028 (code=exited, status=1/FAILURE)
        CPU: 155ms
december 16 05:34:22 Manaro systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 5.
december 16 05:34:22 Manaro systemd[1]: NetworkManager.service: Start request repeated too quickly.
december 16 05:34:22 Manaro systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
december 16 05:34:22 Manaro systemd[1]: Failed to start Network Manager.
-----journalctl -xeu NetworkManager.service
journalctl -xeu NetworkManager.service         3 ✘
░░ An ExecStart= process belonging to unit NetworkManager.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
december 16 05:34:21 Manaro systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ Defined-By: systemd
░░ The unit NetworkManager.service has entered the 'failed' state with result 'exit-code'.
december 16 05:34:21 Manaro systemd[1]: Failed to start Network Manager.
░░ Subject: A start job for unit NetworkManager.service has failed
░░ A start job for unit NetworkManager.service has finished with a failure.
░░ The job identifier is 12168 and the job result is failed.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit NetworkManager.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
░░ The job identifier is 12284 and the job result is failed.
journalctl -b -u NetworkManager         INT ✘
december 14 16:12:28 Manaro systemd[1]: Starting Network Manager...
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.0371] NetworkManager (version 1.44.2-3) is starting... (boot:e135ddd9-5698-40ae-8bb4-aeed>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.0372] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.0720] manager[0x562ecd68e6a0]: monitoring kernel firmware directory '/lib/firmware'.
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.2754] hostname: hostname: using hostnamed
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.2755] hostname: static hostname changed from (none) to "Manaro"
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.2758] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.2773] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/platform/dell-laptop/rfkill/>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.2944] manager[0x562ecd68e6a0]: rfkill: Wi-Fi hardware radio set enabled
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.2949] manager[0x562ecd68e6a0]: rfkill: WWAN hardware radio set enabled
december 14 16:12:29 Manaro systemd[1]: Started Network Manager.
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3146] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.44.2-3/libnm-device->
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3170] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.44.2-3/libnm-device->
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3182] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.44.2-3/libnm-device->
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3198] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.44.2-3/libnm-device>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3445] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.44.2-3/libnm-device-p>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3499] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.44.2-3/libnm-device-p>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3503] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3504] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3504] manager: Networking is enabled by state file
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3515] settings: Loaded settings plugin: keyfile (internal)
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3708] dhcp: init: Using DHCP client 'internal'
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3711] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3770] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', s>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3775] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed'>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3785] device (lo): Activation: starting connection 'lo' (80256f52-55b9-49be-bd4f-9a10dbb2>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3795] manager: (enp0s31f6): new Ethernet device (/org/freedesktop/NetworkManager/Devices/>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3811] settings: (enp0s31f6): created default wired connection 'Wired connection 1'
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.3812] device (enp0s31f6): state change: unmanaged -> unavailable (reason 'managed', sys-i>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.5879] device (wlp2s0): driver supports Access Point (AP) mode
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.5895] manager: (wlp2s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices>
december 14 16:12:29 Manaro NetworkManager[375]: <error> [1702566749.5963] bus-manager: fatal failure to acquire D-Bus service "org.freedesktop.NetworkManager>
december 14 16:12:29 Manaro NetworkManager[375]: <info>  [1702566749.6112] exiting (error)
december 14 16:12:29 Manaro systemd[1]: NetworkManager.service: Main process exited, code=exited, status=1/FAILURE
december 14 16:12:29 Manaro systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
december 14 16:12:29 Manaro systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 1.
december 14 16:12:29 Manaro systemd[1]: Starting Network Manager...
december 14 16:12:30 Manaro NetworkManager[444]: <info>  [1702566750.0492] NetworkManager (version 1.44.2-3) is starting... (after a restart, boot:e135ddd9-56>
december 14 16:12:30 Manaro NetworkManager[444]: <info>  [1702566750.0493] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
i have tried to re-install the networkmanager from the pacmanager and after reinstalling it the same problem appears
i dont know how to fix it, i hope that you can help
Do you have other network services running at the same time?
systemd-networkd maybe?
If networkmanager is failing, how are you typing this? xD
systemd-networkd: command not found
i’m using another laptop to write this topic
sudo systemctl status systemd-networkd.service
And while you are at it, run:
sudo systemctl status systemd-resolved.service
Edit
Oh well, I’m going to go :joystick: so I might not be available for a while.
But look into those things, or if you have some other network manager running.
https://wiki.archlinux.org/title/Network_configuration#Network_managers
https://wiki.archlinux.org/title/Systemd-resolved
Maybe this will give some insight:
https://bbs.archlinux.org/viewtopic.php?id=274569
According to the log file, your network manager crashes.
Could you please also try to look into:
  • /etc/NetworkManager/NetworkManager.conf
    :footprints:
sudo systemctl status systemd-networkd.service  :heavy_check_mark:
[sudo] password for pc:
○ systemd-networkd.service - Network Configuration
Loaded: loaded (/usr/lib/systemd/system/systemd-networkd.service; disabled; preset: enabled)
Active: inactive (dead)
TriggeredBy: ○ systemd-networkd.socket
Docs: man:systemd-networkd.service(8)
man:org.freedesktop.network1(5)
FD Store: 0 (limit: 512)
sudo systemctl status systemd-resolved.service  3 ✘
○ systemd-resolved.service - Network Name Resolution
Loaded: loaded (/usr/lib/systemd/system/systemd-resolved.service; disabled; preset: enabled)
Docs: man:systemd-resolved.service(8)
man:org.freedesktop.resolve1(5)
writing-network-configuration-managers
writing-resolver-clients
when i hover the mouse cursor on top of the networks icon in the bottom bar it showd: networkmanager 0.9.8 required, found .
that file is empty
i tried to change the name of /etc/NetworkManager/ to networkmanager1
then i re installed the networkmanager and it creaded a new NetworkManager folder. and the result is the same
can you show us the output of:
cat /etc/NetworkManager/NetworkManager.conf
Maybe take also a look into
whether it shows similarities or whether the links there will help you.
mine is not empty :innocent:
# Configuration file for NetworkManager.
# See "man 5 NetworkManager.conf" for details.
None of them is up to date :wink:
mhwd-kernel -li
cat /etc/NetworkManager/NetworkManager.conf                                             ✔
i cant update the kernel without wifi now
that article helped me a liitle:
i find that i have installed ConnMan
so i think there may be a conflict between connman and networkmanager? how to figure that this is the case? and how do i connect to the net with connman instead of networkmanager? do i need to delete one of theme?
that topic have a similare problem:
https://forums.gentoo.org/viewtopic-t-1087700-start-0.html
it says: It appears DBus is rejecting access to NetworkManager:
Problem fixed
i removed connman and restarted and now the wifi is working again.
so, if i want to use connman so what do i need to do?
from ARCH-Wiki :smiling_face_with_three_hearts:
Before [enabling](https://wiki.archlinux.org/title/Enabling) `connman.service`, ensure any existing [network configuration](https://wiki.archlinux.org/title/Network_configuration) is disabled.
ConnMan comes with the [connmanctl(1)](https://man.archlinux.org/man/connmanctl.1) CLI, there are various [#Front-ends](https://wiki.archlinux.org/title/ConnMan#Front-ends) available.
Category:Network managers - ArchWiki :point_up_2:
So next time please share with us what you tried to do before it broke :wink:
:footprints:
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
