Problem description
After every 3rd or 4th wakeup from sleep, networkctl and various other services are suspended to disk (“D” state in htop),
leaving me unable to use the network and power commands (systemctl suspend, shutdown, reboot, etc all cannot run, since
some other power realted operation hangs) and unable to kill / restart them (I assume this is because the’re waiting for something).
This only started occuring since I have bought a USB-C dock, waking the laptop up both with a usb keayboard connected to said docking station,
connected to directly to laptop, and with the power button.
Hardware description
System: Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 3.38.4 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20RA001LMC v: ThinkPad E14 serial: <filter>
Mobo: LENOVO model: 20RA001LMC v: SDK0J40697 WIN serial: <filter> UEFI: LENOVO v: R16ET29W (1.15 ) date: 12/03/2020
Battery: ID-1: BAT0 charge: 39.5 Wh (100.0%) condition: 39.5/45.7 Wh (86.4%) volts: 12.2 min: 11.1 model: Celxpert 01AV448
status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 charge: 100% (should be ignored)
status: Discharging
Memory: RAM: total: 15.32 GiB used: 3.87 GiB (25.3%)
CPU: Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP arch: Kaby Lake note: check rev: C cache:
L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36812
Speed: 600 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 600 2: 600 3: 600 4: 600 5: 600 6: 600 7: 600 8: 600
Graphics: Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Advanced Micro Devices [AMD/ATI] Lexa [Radeon 540X/550X/630 / RX 640 / E9171 MCM] vendor: Lenovo
driver: amdgpu v: kernel bus-ID: 03:00.0
Device-3: Chicony Integrated Camera (1280x720@30) type: USB driver: uvcvideo bus-ID: 1-8:3
Display: x11 server: X.org 1.20.11 driver: loaded: amdgpu,ati,intel unloaded: modesetting
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: JMTek LLC. USB PnP Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.1.1:9
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Network: Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel port: 4000 bus-ID: 00:14.3
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 2000
bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-2.3:3
IF: enp0s20f0u2u3 state: down mac: <filter>
Drives: Local Storage: total: 709.83 GiB used: 180.89 GiB (25.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZALQ512HALU-000L1 size: 476.94 GiB temp: 22.9 C
ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 117.62 GiB used: 15.21 GiB (12.9%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 511 MiB used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 341.97 GiB used: 165.68 GiB (48.4%) fs: ext4 dev: /dev/nvme0n1p4
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 57.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 324 Uptime: 34m Init: systemd Compilers: gcc: 11.1.0 Packages: 1221 Shell: Zsh v: 5.8 inxi: 3.3.04
Docking station used is “Baseus 17 in 1 Type-C HUB Adapter to Multi HD RJ45 VG”
(From aliexpress, would be great to link to it directly
Claiming to use the VMM5310 Display chip and VL817 USB hub chip.
The laptop is connected to wifi, so I assume the network chip in the docking station is not used.
I am running vanilla gnome with no extensions (since those caused more problems than they solved, also perceived speed)
Journalctl output
Jul 02 10:20:11 vpc gsd-media-keys[12160]: [12160:12160:0702/102011.689690:ERROR:shared<sub>context</sub><sub>state.cc</sub>(73)] Skia shader compilation error
Jul 02 10:20:11 vpc gsd-media-keys[12160]: -------------------–—
Jul 02 10:20:11 vpc gsd-media-keys[12160]: Errors:
Jul 02 10:20:11 vpc gsd-media-keys[12160]: [12160:12160:0702/102011.705838:ERROR:shared<sub>context</sub><sub>state.cc</sub>(73)] Skia shader compilation error
Jul 02 10:20:56 vpc gsd-media-keys[12130]: [12130:12130:0702/102056.937748:ERROR:CONSOLE(0)] “Unchecked runtime.lastError: Tabs cannot be edited right now (user may be dragging a tab).”, source: chrome-extension://jidkidbbcafjabdphckchenhfomhnfma/<sub>generated</sub><sub>background</sub><sub>page.html</sub> (0)
Jul 02 10:20:56 vpc gsd-media-keys[12130]: [12130:12130:0702/102056.978172:ERROR:CONSOLE(1)] “[Shields]: Can’t request shields panel data. Error: No tab url specified”, source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/out/brave<sub>extension</sub><sub>background.bundle.js</sub> (1)
Jul 02 10:20:56 vpc gsd-media-keys[12130]: [12130:12130:0702/102056.978276:ERROR:CONSOLE(0)] “Unchecked runtime.lastError: Tabs cannot be edited right now (user may be dragging a tab).”, source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/<sub>generated</sub><sub>background</sub><sub>page.html</sub> (0)
Jul 02 10:21:00 vpc gsd-media-keys[12160]: [12160:12160:0702/102100.507887:ERROR:shared<sub>context</sub><sub>state.cc</sub>(73)] Skia shader compilation error
Jul 02 10:21:00 vpc gsd-media-keys[12160]: -------------------–—
Jul 02 10:21:00 vpc gsd-media-keys[12160]: Errors:
Jul 02 10:21:00 vpc gsd-media-keys[12160]: [12160:12160:0702/102100.607962:ERROR:shared<sub>context</sub><sub>state.cc</sub>(73)] Skia shader compilation error
Jul 02 10:21:02 vpc gsd-media-keys[12130]: [12130:12130:0702/102102.182154:ERROR:CONSOLE(0)] “Unchecked runtime.lastError: Tabs cannot be edited right now (user may be dragging a tab).”, source: chrome-extension://jidkidbbcafjabdphckchenhfomhnfma/<sub>generated</sub><sub>background</sub><sub>page.html</sub> (0)
Jul 02 10:21:02 vpc gsd-media-keys[12130]: [12130:12130:0702/102102.194850:ERROR:CONSOLE(1)] “[Shields]: Can’t request shields panel data. Error: No tab url specified”, source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/out/brave<sub>extension</sub><sub>background.bundle.js</sub> (1)
Jul 02 10:21:02 vpc gsd-media-keys[12130]: [12130:12130:0702/102102.195454:ERROR:CONSOLE(0)] “Unchecked runtime.lastError: Tabs cannot be edited right now (user may be dragging a tab).”, source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/<sub>generated</sub><sub>background</sub><sub>page.html</sub> (0)
Jul 02 10:23:21 vpc gsd-media-keys[12130]: [12130:12130:0702/102321.059341:ERROR:CONSOLE(0)] “Unchecked runtime.lastError: Tabs cannot be edited right now (user may be dragging a tab).”, source: chrome-extension://jidkidbbcafjabdphckchenhfomhnfma/<sub>generated</sub><sub>background</sub><sub>page.html</sub> (0)
Jul 02 10:23:21 vpc gsd-media-keys[12130]: [12130:12130:0702/102321.103206:ERROR:CONSOLE(1)] “[Shields]: Can’t request shields panel data. Error: No tab url specified”, source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/out/brave<sub>extension</sub><sub>background.bundle.js</sub> (1)
Jul 02 10:23:21 vpc gsd-media-keys[12130]: [12130:12130:0702/102321.104287:ERROR:CONSOLE(0)] “Unchecked runtime.lastError: Tabs cannot be edited right now (user may be dragging a tab).”, source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/<sub>generated</sub><sub>background</sub><sub>page.html</sub> (0)
Jul 02 10:25:25 vpc gsd-media-keys[12130]: [12130:13422:0702/102525.387406:ERROR:media<sub>history</sub><sub>store.cc</sub>(339)] Failed to begin the transaction.
Jul 02 10:25:25 vpc systemd[1711]: app-gnome-brave-12123.scope: Deactivated successfully.
░░ Subject: Unit succeeded
░░ Defined-By: systemd
░░ Support: <a href="https://forum.manjaro.org/c/support">https://forum.manjaro.org/c/support</a>
░░ The unit UNIT has successfully entered the ’dead’ state.
Jul 02 10:25:25 vpc systemd[1711]: app-gnome-brave-12123.scope: Consumed 26min 11.551s CPU time.
░░ Subject: Resources consumed by unit runtime
░░ The unit UNIT completed and consumed the indicated resources.
Jul 02 10:25:32 vpc systemd[1711]: Started VTE child process 13434 launched by gnome-terminal-server process 3714.
░░ Subject: A start job for unit UNIT has finished successfully
░░ A start job for unit UNIT has finished successfully.
░░ The job identifier is 600.
Jul 02 10:25:40 vpc audit[13478]: USER<sub>AUTH</sub> pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:authentication grantors=pam<sub>unix</sub> acct=“v” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:40 vpc kernel: audit: type=1100 audit(1625214340.641:171): pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:authentication grantors=pam<sub>unix</sub> acct=“v” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:40 vpc kernel: audit: type=1101 audit(1625214340.644:172): pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:accounting grantors=pam<sub>unix,pam</sub><sub>permit,pam</sub><sub>time</sub> acct=“v” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:40 vpc kernel: audit: type=1110 audit(1625214340.644:173): pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:setcred grantors=pam<sub>unix</sub> acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:40 vpc kernel: audit: type=1105 audit(1625214340.644:174): pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:session<sub>open</sub> grantors=pam<sub>limits,pam</sub><sub>unix,pam</sub><sub>permit</sub> acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:40 vpc audit[13478]: USER<sub>ACCT</sub> pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:accounting grantors=pam<sub>unix,pam</sub><sub>permit,pam</sub><sub>time</sub> acct=“v” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:40 vpc audit[13478]: CRED<sub>REFR</sub> pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:setcred grantors=pam<sub>unix</sub> acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:40 vpc audit[13478]: USER<sub>START</sub> pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:session<sub>open</sub> grantors=pam<sub>limits,pam</sub><sub>unix,pam</sub><sub>permit</sub> acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:40 vpc dbus-daemon[505]: [system] Activating via systemd: service name=’org.freedesktop.home1’ unit=’dbus-org.freedesktop.home1.service’ requested by ’:1.123’ (uid=0 pid=13478 comm=“sudo pacman -Syu ”)
Jul 02 10:25:40 vpc dbus-daemon[505]: [system] Activation via systemd failed for unit ’dbus-org.freedesktop.home1.service’: Unit dbus-org.freedesktop.home1.service not found.
Jul 02 10:25:40 vpc sudo[13478]: pam<sub>systemd</sub><sub>home</sub>(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jul 02 10:25:40 vpc sudo[13478]: v : TTY=pts/2 ; PWD=/home/v ; USER=root ; COMMAND=/usr/bin/pacman -Syu
Jul 02 10:25:40 vpc sudo[13478]: pam<sub>unix</sub>(sudo:session): session opened for user root(uid=0) by (uid=1000)
Jul 02 10:25:41 vpc sudo[13478]: pam<sub>unix</sub>(sudo:session): session closed for user root
Jul 02 10:25:41 vpc audit[13478]: USER<sub>END</sub> pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:session<sub>close</sub> grantors=pam<sub>limits,pam</sub><sub>unix,pam</sub><sub>permit</sub> acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:41 vpc audit[13478]: CRED<sub>DISP</sub> pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:setcred grantors=pam<sub>unix</sub> acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:41 vpc kernel: audit: type=1106 audit(1625214341.611:175): pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:session<sub>close</sub> grantors=pam<sub>limits,pam</sub><sub>unix,pam</sub><sub>permit</sub> acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:41 vpc kernel: audit: type=1104 audit(1625214341.611:176): pid=13478 uid=1000 auid=1000 ses=4 msg=’op=PAM:setcred grantors=pam<sub>unix</sub> acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Jul 02 10:25:43 vpc ModemManager[623]: <info> [sleep-monitor] system is about to suspend
Jul 02 10:25:43 vpc NetworkManager[509]: <info> [1625214343.0191] manager: sleep: sleep requested (sleeping: no enabled: yes)
Jul 02 10:25:43 vpc NetworkManager[509]: <info> [1625214343.0192] device (enp4s0): state change: unavailable -> unmanaged (reason ’sleeping’, sys-iface-state: ’managed’)
Jul 02 10:25:43 vpc kernel: usb 2-2.3: reset SuperSpeed Gen 1 USB device number 5 using xhci<sub>hcd</sub>
Jul 02 10:25:43 vpc upowerd[1314]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2.3
Jul 02 10:25:48 vpc systemd-logind[513]: Delay lock is active (UID 0/root, PID 509/NetworkManager) but inhibitor timeout is reached.
Jul 02 10:25:48 vpc systemd[1]: Reached target Sleep.
░░ Subject: A start job for unit sleep.target has finished successfully
░░ A start job for unit sleep.target has finished successfully.
░░ The job identifier is 3325.
Jul 02 10:25:48 vpc systemd[1]: Starting Suspend…
░░ Subject: A start job for unit systemd-suspend.service has begun execution
░░ A start job for unit systemd-suspend.service has begun execution.
░░ The job identifier is 3324.
Jul 02 10:27:18 vpc systemd-sleep[13487]: Suspending system…
░░ Subject: System sleep state suspend entered
░░ The system has now entered the suspend sleep state.
Jul 02 10:27:18 vpc kernel: PM: suspend entry (deep)
Jul 02 10:27:18 vpc kernel: Filesystems sync: 0.016 seconds
Jul 02 10:48:07 vpc systemd-timesyncd[479]: Initial synchronization to time server 82.113.53.41:123 (0.manjaro.pool.ntp.org).
Jul 02 10:50:45 vpc gsd-power[1970]: Error calling suspend action: GDBus.Error:org.freedesktop.login1.OperationInProgress: There’s already a shutdown or sleep operation in progress
Jul 02 11:25:01 vpc mullvad-daemon[546]: [mullvad<sub>daemon</sub>::relays][DEBUG] Relay list is up-to-date
Jul 02 11:58:27 vpc gdm-password][13891]: gkr-pam: unlocked login keyring
Jul 02 11:58:27 vpc kernel: audit: type=1100 audit(1625219907.311:177): pid=13891 uid=0 auid=1000 ses=3 msg=’op=PAM:authentication grantors=pam<sub>shells,pam</sub><sub>faillock,pam</sub><sub>permit,pam</sub><sub>faillock,pam</sub><sub>gnome</sub><sub>keyring</sub> acct=“v” exe=“/usr/lib/gdm-session-worker” hostname=vpc addr=? terminal=/dev/tty1 res=success’
Jul 02 11:58:27 vpc kernel: audit: type=1101 audit(1625219907.311:178): pid=13891 uid=0 auid=1000 ses=3 msg=’op=PAM:accounting grantors=pam<sub>access,pam</sub><sub>unix,pam</sub><sub>permit,pam</sub><sub>time</sub> acct=“v” exe=“/usr/lib/gdm-session-worker” hostname=vpc addr=? terminal=/dev/tty1 res=success’
Jul 02 11:58:27 vpc kernel: audit: type=1110 audit(1625219907.311:179): pid=13891 uid=0 auid=1000 ses=3 msg=’op=PAM:setcred grantors=pam<sub>shells,pam</sub><sub>faillock,pam</sub><sub>permit,pam</sub><sub>faillock,pam</sub><sub>gnome</sub><sub>keyring</sub> acct=“v” exe=“/usr/lib/gdm-session-worker” hostname=vpc addr=? terminal=/dev/tty1 res=success’
Jul 02 11:58:27 vpc audit[13891]: USER<sub>AUTH</sub> pid=13891 uid=0 auid=1000 ses=3 msg=’op=PAM:authentication grantors=pam<sub>shells,pam</sub><sub>faillock,pam</sub><sub>permit,pam</sub><sub>faillock,pam</sub><sub>gnome</sub><sub>keyring</sub> acct=“v” exe=“/usr/lib/gdm-session-worker” hostname=vpc addr=? terminal=/dev/tty1 res=success’
Jul 02 11:58:27 vpc audit[13891]: USER<sub>ACCT</sub> pid=13891 uid=0 auid=1000 ses=3 msg=’op=PAM:accounting grantors=pam<sub>access,pam</sub><sub>unix,pam</sub><sub>permit,pam</sub><sub>time</sub> acct=“v” exe=“/usr/lib/gdm-session-worker” hostname=vpc addr=? terminal=/dev/tty1 res=success’
Jul 02 11:58:27 vpc audit[13891]: CRED<sub>REFR</sub> pid=13891 uid=0 auid=1000 ses=3 msg=’op=PAM:setcred grantors=pam<sub>shells,pam</sub><sub>faillock,pam</sub><sub>permit,pam</sub><sub>faillock,pam</sub><sub>gnome</sub><sub>keyring</sub> acct=“v” exe=“/usr/lib/gdm-session-worker” hostname=vpc addr=? terminal=/dev/tty1 res=success’
Jul 02 11:58:27 vpc dbus-daemon[505]: [system] Activating via systemd: service name=’org.freedesktop.home1’ unit=’dbus-org.freedesktop.home1.service’ requested by ’:1.126’ (uid=0 pid=13891 comm=“gdm-session-worker [pam/gdm-password] ”)
Jul 02 11:58:27 vpc dbus-daemon[505]: [system] Activation via systemd failed for unit ’dbus-org.freedesktop.home1.service’: Unit dbus-org.freedesktop.home1.service not found.
Jul 02 11:58:27 vpc gdm-password][13891]: pam<sub>systemd</sub><sub>home</sub>(gdm-password:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jul 02 11:58:27 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activating service name=’org.gnome.Shell.CalendarServer’ requested by ’:1.19’ (uid=1000 pid=1815 comm=“/usr/bin/gnome-shell ”)
Jul 02 11:58:27 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activated service ’org.gnome.Shell.CalendarServer’ failed: Process org.gnome.Shell.CalendarServer exited with status 127
Jul 02 11:58:27 vpc org.gnome.Shell.CalendarServer[13897]: /usr/lib/gnome-shell-calendar-server: error while loading shared libraries: libecal-2.0.so.1: cannot open shared object file: No such file or directory
Jul 02 11:58:27 vpc gnome-shell[1815]: Error loading calendars: Error calling StartServiceByName for org.gnome.Shell.CalendarServer: Process org.gnome.Shell.CalendarServer exited with status 127
Jul 02 11:58:27 vpc gnome-shell[1815]: JS ERROR: Error getting systemd inhibitor: Gio.IOErrorEnum: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
_promisify/proto[asyncFunc]/</<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:418:45
### Promise created here: ###
inhibit@resource:///org/gnome/shell/misc/loginManager.js:196:35
_syncInhibitor@resource:///org/gnome/shell/ui/screenShield.js:203:32
_setActive@resource:///org/gnome/shell/ui/screenShield.js:157:14
_completeDeactivate@resource:///org/gnome/shell/ui/screenShield.js:565:14
onComplete@resource:///org/gnome/shell/ui/screenShield.js:542:36
_makeEaseCallback/<@resource:///org/gnome/shell/ui/environment.js:85:13
_easeActor/<@resource:///org/gnome/shell/ui/environment.js:168:64
Jul 02 12:01:34 vpc /usr/lib/gdm-x-session[1730]: (EE) client bug: timer event17 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activating service name=’org.gnome.ControlCenter.SearchProvider’ requested by ’:1.19’ (uid=1000 pid=1815 comm=“/usr/bin/gnome-shell ”)
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activating service name=’org.gnome.Nautilus’ requested by ’:1.19’ (uid=1000 pid=1815 comm=“/usr/bin/gnome-shell ”)
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activating service name=’org.manjaro.pamac.manager’ requested by ’:1.19’ (uid=1000 pid=1815 comm=“/usr/bin/gnome-shell ”)
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activating service name=’org.gnome.Calculator.SearchProvider’ requested by ’:1.19’ (uid=1000 pid=1815 comm=“/usr/bin/gnome-shell ”)
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activating service name=’org.gnome.Epiphany.SearchProvider’ requested by ’:1.19’ (uid=1000 pid=1815 comm=“/usr/bin/gnome-shell ”)
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Successfully activated service ’org.gnome.ControlCenter.SearchProvider’
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Successfully activated service ’org.gnome.Nautilus’
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Successfully activated service ’org.gnome.Calculator.SearchProvider’
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Successfully activated service ’org.gnome.Epiphany.SearchProvider’
Jul 02 12:11:00 vpc nautilus[13995]: Connecting to org.freedesktop.Tracker3.Miner.Files
Jul 02 12:11:00 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Successfully activated service ’org.manjaro.pamac.manager’
Jul 02 12:11:00 vpc systemd[1711]: Started Application launched by gnome-shell.
░░ The job identifier is 608.
Jul 02 12:11:34 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activating service name=’org.gnome.Nautilus’ requested by ’:1.19’ (uid=1000 pid=1815 comm=“/usr/bin/gnome-shell ”)
Jul 02 12:11:34 vpc dbus-daemon[1757]: [session uid=1000 pid=1757] Activating service name=’org.manjaro.pamac.manager’ requested by ’:1.19’ (uid=1000 pid=1815 comm=“/usr/bin/gnome-shell ”)
I suspect that the JS error in gnome shell is to blame, since on occasions when this doesn’t happen, I itsn’t appearing.
What Have I tried
- Switching kernels between 5.4, 5.9 and 5.10, each LTS
- Enabling and disabling Wake on LAN (incl. Wake on Wlan)
- Connecting the keyboard straight to laptop USB ports
- Disabling USB wake and using power button only
Questions
- How can I get more debug info about what the docking station is doing?
- How can I isolate, which process is causing networkmanager to hang?
- Could this be a bug in GDM?
- What could be the possible cause for this to happen every 3rd time or so?
Thank you for any help, this is the first time in 4 years that I had a problem with Manjaro frustrating enough to post on the forum.
