/lib/nut/usbhid-ups -a aeg -DDDDDD -d 1 ✔ 41s
Network UPS Tools - Generic HID driver 0.52 (2.8.1)
USB communication driver (libusb 1.0) 0.46
Error: Section aeg not found in ups.conf
upsnotify: notify about state 4 with libsystemd: was requested, but not running as a service unit now, will not spam more about it
upsnotify: failed to notify about state 4: no notification tech defined, will not spam more about it
driver = “blazer_usb”
langid_fix=“0x409”
driver = “nutdrv_qx” //used to switch
port = “auto”
vendorid = “0001”
productid = “0000”
bus = “005”
device = “002”
busport = “002”
sudo upsdrvctl start
Network UPS Tools - UPS driver controller 2.8.1
Network UPS Tools - Megatec/Q1 protocol USB driver 0.17 (2.8.1)
Duplicate driver instance detected (PID file /run/nut/blazer_usb-megatec.pid exists)! Terminating other driver!
Broadcast message from nut@user (somewhere) (Wed Mar 13 05:51:34 2024):
Communications with UPS megatec@localhost lost
Please note that this driver is deprecated and will not receive
new development. If it works for managing your devices - fine,
but if you are running it to try setting up a new device, please
consider the newer nutdrv_qx instead, which should handle all ‘Qx’
protocol variants for NUT. (Please also report if your device works
with this driver, but nutdrv_qx would not actually support it with
any subdriver!)
Switch to NutDrv_QX
#langid_fix=“0x409”
port = “auto”
vendorid = “0001”
productid = “0000”
bus = “005”
device = “002”
busport = “002”
Network UPS Tools - Generic Q* USB/Serial driver 0.36 (2.8.1)
Can’t claim USB device [0001:0000]@0/0: Entity not found
Driver failed to start (exit status=1)
