Hello friends, is there a way to use both wireless and ethernet at the same time? Here at my place the wireless signal is very strong and not many people use it, I’m using a cable and I want to also use wireless at the same time to increase speed.
But keep in mind that it does not automatically make your network faster.
If you download a file with one connection, it is only as fast as your Ethernet or WiFi link. And of course if you download form the internet only as fast as your internet provider allows.
If you download multiple files or split a file download in multiple connections, it can be faster but only if the source and your internet speed is as fast as your ethernet plus wifi.
