Network regression for mt7922 wifi adapter after update
Hi. I had a network regression for my laptop’s mt7922 wifi adapter. After the update, it’s now reconnecting to the wifi AP every minute. This only occurs on 5GHz DFS channel so I guess most people won’t experience it. No issues with non-DFS channel which for me is too congested for reliable connectivity. Old 6.6 LTS kernel and newer 6.8 RC4 kernel experience the same issues.
Confirmed the issue with the Feb update by doing a Timeshift to a Manjaro Jan stable version, checking for the issue (non-existent) and then updating to Feb stable (verified reconnectivity afte 1 minute).
[Mar 2 15:35] wlp1s0: deauthenticating from 04:f0:21:55:fa:52 by local choice (Reason: 3=DEAUTH_LEAVING)
[ +10.519264] wlp1s0: authenticate with 04:f0:21:55:fa:52 (local address=a8:3b:76:73:25:3b)
[  +0.013423] wlp1s0: send auth to 04:f0:21:55:fa:52 (try 1/3)
[  +0.003957] wlp1s0: authenticated
[  +0.007927] wlp1s0: associate with 04:f0:21:55:fa:52 (try 1/3)
[  +0.006875] wlp1s0: RX AssocResp from 04:f0:21:55:fa:52 (capab=0x111 status=0 aid=5)
[  +0.031567] wlp1s0: associated
[  +0.087662] wlp1s0: Limiting TX power to 24 (27 - 3) dBm as advertised by 04:f0:21:55:fa:52
[Mar 2 15:36] wlp1s0: deauthenticating from 04:f0:21:55:fa:52 by local choice (Reason: 3=DEAUTH_LEAVING)
[ +10.517640] wlp1s0: authenticate with 04:f0:21:55:fa:52 (local address=a8:3b:76:73:25:3b)
[  +0.013283] wlp1s0: send auth to 04:f0:21:55:fa:52 (try 1/3)
[  +0.004043] wlp1s0: authenticated
[  +0.008699] wlp1s0: associate with 04:f0:21:55:fa:52 (try 1/3)
[  +0.006753] wlp1s0: RX AssocResp from 04:f0:21:55:fa:52 (capab=0x111 status=0 aid=5)
[  +0.030696] wlp1s0: associated
[  +0.069008] wlp1s0: Limiting TX power to 24 (27 - 3) dBm as advertised by 04:f0:21:55:fa:52
[Mar 2 15:37] wlp1s0: deauthenticating from 04:f0:21:55:fa:52 by local choice (Reason: 3=DEAUTH_LEAVING)
[ +10.529905] wlp1s0: authenticate with 04:f0:21:55:fa:52 (local address=a8:3b:76:73:25:3b)
[  +0.013785] wlp1s0: send auth to 04:f0:21:55:fa:52 (try 1/3)
[  +0.004125] wlp1s0: authenticated
[  +0.005422] wlp1s0: associate with 04:f0:21:55:fa:52 (try 1/3)
[  +0.008270] wlp1s0: RX AssocResp from 04:f0:21:55:fa:52 (capab=0x111 status=0 aid=5)
[  +0.031552] wlp1s0: associated
[  +0.070582] wlp1s0: Limiting TX power to 24 (27 - 3) dBm as advertised by 04:f0:21:55:fa:52
[Mar 2 15:38] wlp1s0: deauthenticating from 04:f0:21:55:fa:52 by local choice (Reason: 3=DEAUTH_LEAVING)
[Mar 2 15:39] wlp1s0: authenticate with 04:f0:21:55:fa:52 (local address=a8:3b:76:73:25:3b)
[  +0.013383] wlp1s0: send auth to 04:f0:21:55:fa:52 (try 1/3)
[  +0.004068] wlp1s0: authenticated
[  +0.002261] wlp1s0: associate with 04:f0:21:55:fa:52 (try 1/3)
[  +0.011472] wlp1s0: RX AssocResp from 04:f0:21:55:fa:52 (capab=0x111 status=0 aid=5)
[  +0.031890] wlp1s0: associated
[  +0.079503] wlp1s0: Limiting TX power to 24 (27 - 3) dBm as advertised by 04:f0:21:55:fa:52
[Mar 2 15:40] wlp1s0: deauthenticating from 04:f0:21:55:fa:52 by local choice (Reason: 3=DEAUTH_LEAVING)
[ +10.544291] wlp1s0: authenticate with 04:f0:21:55:fa:52 (local address=a8:3b:76:73:25:3b)
[  +0.013300] wlp1s0: send auth to 04:f0:21:55:fa:52 (try 1/3)
[  +0.004163] wlp1s0: authenticated
[  +0.004517] wlp1s0: associate with 04:f0:21:55:fa:52 (try 1/3)
[  +0.009120] wlp1s0: RX AssocResp from 04:f0:21:55:fa:52 (capab=0x111 status=0 aid=5)
[  +0.031309] wlp1s0: associated
[  +0.062654] wlp1s0: Limiting TX power to 24 (27 - 3) dBm as advertised by 04:f0:21:55:fa:52
[Mar 2 15:41] wlp1s0: deauthenticating from 04:f0:21:55:fa:52 by local choice (Reason: 3=DEAUTH_LEAVING)
[ +10.534693] wlp1s0: authenticate with 04:f0:21:55:fa:52 (local address=a8:3b:76:73:25:3b)
[  +0.013366] wlp1s0: send auth to 04:f0:21:55:fa:52 (try 1/3)
[  +0.004135] wlp1s0: authenticated
[  +0.007683] wlp1s0: associate with 04:f0:21:55:fa:52 (try 1/3)
[  +0.006184] wlp1s0: RX AssocResp from 04:f0:21:55:fa:52 (capab=0x111 status=0 aid=5)
[  +0.030879] wlp1s0: associated
[  +0.089833] wlp1s0: Limiting TX power to 24 (27 - 3) dBm as advertised by 04:f0:21:55:fa:52
Thought it was a linux firmware issue but the firmware is the same as the previous Manjaro Jan stable
ethtool -i wlp1s0         INT ✘  36s 
driver: mt7921e
version: 6.7.4-2-MANJARO
firmware-version: ____000000-20231120183441
expansion-rom-version:
bus-info: 0000:01:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
My laptop’s specs:
inxi -v7azy         ✔
  Kernel: 6.7.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
    root=UUID=08d29e7c-47c8-41b9-a6c1-cc400b844e3c rw quiet splash
    pcie_aspm.policy=powersupersave video=eDP-1:1920x1200@90 loglevel=3
    udev.log_level=3 rd.udev.log_level=3 systemd.show_status=auto
    vt.global_cursor_default=0 iomem=relaxed nmi_watchdog=0
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 82Y8 v: Yoga Pro 7 14APH8
    serial: <superuser required> Chassis: type: 10 v: Yoga Pro 7 14APH8
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
    serial: <superuser required> part-nu: LENOVO_MT_82Y8_BU_idea_FM_Yoga Pro 7
    14APH8 uuid: <superuser required> UEFI: LENOVO v: MLCN26WW date: 01/14/2024
  ID-1: BAT0 charge: 25.9 Wh (35.6%) condition: 72.7/73.0 Wh (99.6%)
    power: 4.5 W volts: 15.2 min: 15.5 model: Sunwoda L22D4PF4 type: Li-poly
    serial: <filter> status: discharging cycles: 19
  System RAM: total: 32 GiB available: 27.1 GiB used: 3.72 GiB (13.7%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Micron Technology
    part-no: MT62F2G32D4DS-026 WT serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 7840HS with Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
    microcode: 0xA704104
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 649 high: 1397
    min/max: 400/5137:6080:5449:5293:5764:5924:5608 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 1397 3: 1397
    4: 400 5: 400 6: 400 7: 1395 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
    14: 400 15: 1397 16: 400 bogomips: 121421
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
    avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fxsr fxsr_opt gfni
    ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm
    mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes
    vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Phoenix1 vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-3
    code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
    HDMI-A-1 bus-ID: 63:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 34.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 174f:181d
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 168 s-size: 387x241mm (15.24x9.49")
    s-diag: 456mm (17.95")
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x7aa7 built: 2022
    res: 2560x1600 dpi: 208 gamma: 1.2 size: 312x195mm (12.28x7.68")
    diag: 368mm (14.5") ratio: 16:10 modes: max: 2560x1600 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch10.1
    gfx1103_r1 LLVM 16.0.6 DRM 3.57 6.7.4-2-MANJARO) device-ID: 1002:15bf
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.3.276 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV GFX1103_R1) driver: mesa radv v: 24.0.2-arch10.1
    device-ID: 1002:15bf surfaces: xcb,xlib
  Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 63:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 63:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 63:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.7.4-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp1s0 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai Bluetooth Adapter driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0489:e0d8
  Device-1: luks-8103d106-ac22-45c2-ad69-b4a482ee3072 maj-min: 254:0
    type: LUKS dm: dm-0 size: 871.56 GiB
  Components:
  p-1: nvme0n1p8 maj-min: 259:8 size: 871.56 GiB
  Local Storage: total: 953.87 GiB used: 251.45 GiB (26.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL2
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EL1QGXA7 temp: 39.9 C
    scheme: GPT
  ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 12.02 GiB (30.8%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: Root
    uuid: 08d29e7c-47c8-41b9-a6c1-cc400b844e3c
    used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 2FA9-9779
  ID-3: /home raw-size: 871.56 GiB size: 856.81 GiB (98.31%)
    used: 239.43 GiB (27.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-8103d106-ac22-45c2-ad69-b4a482ee3072 label: Home
    uuid: 2c7d257a-3ebb-4c02-82ad-5bf76743121c
  ID-4: /home/HDD raw-size: N/A size: 292.35 GiB used: 174.04 GiB (59.5%)
    fs: cifs dev: /dev/HDD
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 3eb9f6e9-cf11-41d2-ad32-f9fa1b1155e2
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 6200-52B9
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 39.2 GiB fs: ntfs label: N/A
    uuid: 8CBE0E0EBE0DF20E
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 505 MiB fs: ntfs label: N/A
    uuid: FCFA038EFA03447C
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-5:2 info: Foxconn / Hon Hai Bluetooth Adapter type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: Syntek Integrated Camera type: video driver: uvcvideo
    interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 174f:181d class-ID: fe01 serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 37.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
  Fan Speeds (rpm): N/A
  Processes: 329 Power: uptime: 41m states: freeze,mem,disk suspend: s2idle
    image: 10.83 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1232 libs: 356 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
    running-in: konsole inxi: 3.3.33
Downgrading the wireless-regdb package to the previous 2023.09.01-1 version fixes the regression until it’s solved upstream.
