Hi there,
I m noob to Linux so forgive me for asking silly doubts,i m using xfce on my machine , added the toolbar of Network monitor from panel,but its not showing any values, even though i m using internet.
``inxi --full --admin --verbosity=7 --filter --no-host
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=a12cabf8-fc33-41fc-8c30-7000d5b4ea11 ro quiet apparmor=1
security=apparmor resume=UUID=b819ff44-9b96-4f7f-854d-d89a840f392d
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire E1-431 v: V1.29 serial:
Mobo: Acer model: EA40_HC v: Type2 - Board Version serial:
UEFI [Legacy]: Insyde v: 1.29 date: 04/10/2013
ID-1: BAT1 charge: 14.4 Wh condition: 26.5/48.8 Wh (54%) volts: 12.4/11.1
model: SIMPLO AS10D73 type: Li-ion serial: status: Charging
RAM: total: 1.72 GiB used: 1.33 GiB (77.6%)
RAM Report:
Info: Dual Core model: Intel Pentium B950 bits: 64 type: MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
L2 cache: 2 MiB bogomips: 8385
Speed: 798 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 798 2: 798
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb est flush_l1d
fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni
popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_deadline_timer vme x2apic xsave
xsaveopt xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0106
Display: x11 server: xorg 1.20.10 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
v: 3.3 Mesa 20.3.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000
bus ID: 04:00.2 chip ID: 10ec:8168
IF: enp4s0f2 state: down mac:
Device-2: TP-Link TL-WN823N v2/v3 [Realtek RTL8192EU] type: USB
driver: rtl8xxxu bus ID: 2-1.2:3 chip ID: 2357:0109 serial:
IF: wlp0s29u1u2 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Local Storage: total: 298.09 GiB used: 16.27 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD3200BPVT-22JJ5T0 size: 298.09 GiB block size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s serial: rev: 1A01
ID-1: / raw size: 20 GiB size: 19.56 GiB (97.81%) used: 10.88 GiB (55.6%)
fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: a12cabf8-fc33-41fc-8c30-7000d5b4ea11
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 12 KiB (0.0%) fs: vfat dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 5096-7DDE
ID-3: /home raw size: 6.79 GiB size: 6.62 GiB (97.51%)
used: 4.86 GiB (73.4%) fs: ext4 dev: /dev/sda9 maj-min: 8:9 label: N/A
uuid: 0d3cf1a1-ce69-454b-912e-fcddea5f3d69
ID-1: swap-1 type: partition size: 2 GiB used: 539.3 MiB (26.3%)
priority: -2 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: b819ff44-9b96-4f7f-854d-d89a840f392d
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System Reserved
uuid: 52384D25384D0A05
ID-2: /dev/sda2 maj-min: 8:2 size: 40.23 GiB fs: ntfs label: Com
uuid: 58E04032E04018A0
ID-3: /dev/sda3 maj-min: 8:3 size: 100.62 GiB fs: ntfs label: Sudharsan
uuid: 9A0E5BF20E5BC643
ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs:
label: N/A uuid: N/A
ID-5: /dev/sda5 maj-min: 8:5 size: 127.84 GiB fs: ntfs label: Saravanan
uuid: 169E225C9E223521
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
speed: 480 Mb/s chip ID: 8087:0024
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.2:3 info: TP-Link TL-WN823N v2/v3 [Realtek RTL8192EU]
type: Network driver: rtl8xxxu interfaces: 1 rev: 2.1 speed: 480 Mb/s
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 190 Uptime: 1h 31m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1189 pacman: 1173 lib: 393 flatpak: 9 snap: 7
Shell: Bash v: 5.1.0 running in: xfce4-terminal inxi: 3.2.02
[sudharsanh@sudharsan-aspiree1431 ~]$ export LANG=C; inxi
CPU: Dual Core Intel Pentium B950 (-MCP-) speed/min/max: 1057/800/2100 MHz
Kernel: 5.9.16-1-MANJARO x86_64 Up: 1h 31m Mem: 1358.1/1756.5 MiB (77.3%)
Storage: 298.09 GiB (5.5% used) Procs: 190 Shell: Bash inxi: 3.2.02`emphasized textstrong text**strong text**
Try this:
go to network monitor plugin settings and enter wlp0s29u1u2 under Network device field.
Thank you
