Hi.
Strange issue this morning, my network was ok until about 11 AM when I went out, coming back about 1 hour later.
There, no network anymore.
I also couldn’t use my android shared connection.
eno1 & wlo1 desperately down the former was using 8169
This until I rebooted on the 6.1 kernel.
There I did this
And network is back on 6.4
The odd thing is that I was totally up to date and did no update today…
What may have happened ?
➜ ~ inxi -Fazy
Kernel: 6.4.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
root=UUID=78fe8df9-a5da-4f7c-9ec3-52993d393e57 rw quiet
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel, plank
wm: xfwm v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: Victus by HP Laptop 16-e0xxx v: N/A
Mobo: HP model: 8934 v: 80.72 serial: <superuser required> UEFI: AMI
v: F.13 date: 02/14/2022
ID-1: BAT0 charge: 66.0 Wh (99.7%) condition: 66.2/66.2 Wh (100.0%)
volts: 16.8 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: not charging cycles: 58
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1565 high: 3300 min/max: 1200/4280 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3300 2: 1200
3: 1198 4: 1386 5: 1200 6: 3300 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200
12: 1200 bogomips: 79080
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:7340
class-ID: 0380
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1
bus-ID: 09:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 41.0 C
Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0408:5425
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: xfwm v: 4.18.0 driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1606 built: 2019
res: 1920x1080 hz: 60 dpi: 137 gamma: 1.2 size: 355x199mm (13.98x7.83")
diag: 407mm (16") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.9-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 10 HDMI Audio vendor: Hewlett-Packard
bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.4.9-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Hewlett-Packard driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8852
class-ID: 0280
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vethf714311 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:2852
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 1.38 TiB used: 753.8 GiB (53.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Crucial model: CT1000P5SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P4CR311 temp: 37.9 C
scheme: GPT
ID-1: / raw-size: 376.3 GiB size: 369.32 GiB (98.15%) used: 94.62 GiB (25.6%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 86.9 MiB (34.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 659.09 GiB (72.0%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:7
Kernel: swappiness: 5 (default 60) cache-pressure: 50 (default 100)
zswap: yes compressor: zstd max-pool: 20%
ID-1: swap-1 type: file size: 16 GiB used: 256 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 51.9 C mobo: N/A
Fan Speeds (rpm): fan-1: 2207 fan-2: 2401
GPU: device: amdgpu temp: 41.0 C device: amdgpu temp: 39.0 C mem: 0.0 C
fan: 65535 watts: 4.00
Processes: 420 Uptime: 7m wakeups: 4 Memory: total: 16 GiB note: est.
available: 14.97 GiB used: 9.48 GiB (63.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 2966 pm: pacman pkgs: 2865 libs: 514 tools: pamac,yay pm: flatpak
pkgs: 101 Shell: Zsh v: 5.9 running-in: xfce4-terminal inxi: 3.3.29
