Network driver in a Thinkpad T14G1
Hi! Sorry to hijack, but I believe that I am having a similar issue, same network driver in a Thinkpad T14G1:
$ dmesg | grep -c 'Link is Down'
264
$ uptime
 11:58:42 up 2 days,  2:56,  1 user,  load average: 1.78, 0.88, 0.49
$ ethtool -i enp5s0
driver: r8169
version: 7.0.9-1-MANJARO
firmware-version: rtl8168h-2_0.0.2 02/26/15
expansion-rom-version:
bus-info: 0000:05:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
I’m testing now to see if running this command results in a more stable status:
$ sudo ethtool -s enp5s0 autoneg off speed 1000 duplex full
Thanks
@limaunion – Your post has been moved to a dedicated topic. :eyes:
I’m afraid that infringements of forum rules – with or without an apology in advance – is still an infringement of said forum rules.
The general rule is one topic per person, per issue, irrespective of apparent similarities with other topics – each case is different (hardware used; OS and environmental factors) and should be treated on it’s own merits.
Please provide your system information according to forum guidelines (See below). :point_down:
I’m sure someone will help when they are able.
inxi -zv8 (short-form)
Your privacy is respected
If it is still flapping, I would also test EEE/power saving before changing drivers. On some Realtek laptop NICs r8169 is fine but Energy Efficient Ethernet or the switch port negotiation causes repeated link down/up events.
Try once until the next reboot: sudo ethtool --set-eee enp5s0 eee off, then watch journalctl -k -f while moving some traffic. If that changes the behaviour, it is easier to make that one setting persistent than to swap to an out-of-tree driver. The inxi -Nazy output the moderator asked for would still help confirm the exact chip/revision.
In this instance the Moderator asked for the output of;
inxi -zv8
However, the OP hasn’t responded despite your helpful suggestions, and still hasn’t provided the information requested.
@limaunion
Without your further participation, I see no reason for the topic to remain open.
