Hello,
I’ve been experiencing very annoying issue for quite a while: After my PC wakes from sleep mode, it disconnects from the network and will not re-connect for about a minute. That means that if I don’t have any important work, it is actually faster to just reboot the system than to wait for the network to come back.
Here are logs of my system resuming. Note that system was resumed at 09:25:52 while network reconnected at 09:27:40.
sep 13 09:12:06 komp ModemManager[850]: <info> [sleep-monitor] system is about to suspend
sep 13 09:12:06 komp NetworkManager[821]: <info> [1599981126.0546] manager: NetworkManager state is now ASLEEP
sep 13 09:12:06 komp systemd[1]: Reached target Sleep.
sep 13 09:12:06 komp systemd[1]: Starting Suspend...
sep 13 09:12:06 komp systemd-sleep[6577]: Suspending system...
sep 13 09:12:06 komp kernel: PM: suspend entry (deep)
Author's note: System is in sleep mode at that point. I waited couple of minutes and then I turned it back on.
sep 13 09:25:52 komp kernel: Filesystems sync: 0.070 seconds
sep 13 09:25:52 komp kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
sep 13 09:25:52 komp kernel: OOM killer disabled.
sep 13 09:25:52 komp kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
sep 13 09:25:52 komp kernel: printk: Suspending console(s) (use no_console_suspend to debug)
sep 13 09:25:52 komp kernel: r8169 0000:22:00.0 enp34s0: Link is Down
sep 13 09:25:52 komp kernel: ------------[ cut here ]------------
sep 13 09:25:52 komp kernel: WARNING: CPU: 5 PID: 238 at drivers/gpu/drm/amd/amdgpu/../display/dc/dcn20/dcn20_resource.c:3194 dcn20_validate_bandwidth_fp+0x7a/0xb0 [amdgpu]
sep 13 09:25:52 komp kernel: Modules linked in: uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common rfkill snd_usb_audio snd_usbmidi_lib snd_rawmidi mousedev snd_seq_device nct6775 hwmon_vid nls_iso8859_1 nls_cp437 vfat fat fuse r8169 realtek libphy input_leds amdgpu snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi edac_mce_amd snd_hda_intel kvm_amd gpu_sched snd_intel_dspcfg i2c_algo_bit snd_hda_codec kvm ttm snd_hda_core snd_hwdep wmi_bmof drm_kms_helper irqbypass snd_pcm crct10dif_pclmul cec crc32_pclmul snd_timer ghash_clmulni_intel rc_core aesni_intel ccp snd crypto_simd cryptd syscopyarea sp5100_tco sysfillrect glue_helper sysimgblt rapl pcspkr k10temp i2c_piix4 fb_sys_fops soundcore rng_core wmi pinctrl_amd evdev gpio_amdpt mac_hid acpi_cpufreq uinput vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) drm videodev mc crypto_user agpgart ip_tables x_tables btrfs blake2b_generic libcrc32c crc32c_generic xor hid_generic usbhid hid raid6_pq crc32c_intel
sep 13 09:25:52 komp kernel: xhci_pci xhci_pci_renesas xhci_hcd
sep 13 09:25:52 komp kernel: CPU: 5 PID: 238 Comm: kworker/u64:8 Tainted: G OE 5.8.6-1-MANJARO #1
sep 13 09:25:52 komp kernel: Hardware name: Micro-Star International Co., Ltd MS-7C02/B450 TOMAHAWK MAX (MS-7C02), BIOS 3.50 11/07/2019
sep 13 09:25:52 komp kernel: Workqueue: events_unbound async_run_entry_fn
sep 13 09:25:52 komp kernel: RIP: 0010:dcn20_validate_bandwidth_fp+0x7a/0xb0 [amdgpu]
sep 13 09:25:52 komp kernel: Code: 00 7b 35 22 85 a8 1e 00 00 75 2f 31 d2 f2 0f 11 85 d8 25 00 00 48 89 ee 4c 89 e7 e8 50 f6 ff ff 89 c2 22 95 a8 1e 00 00 75 2a <0f> 0b 48 89 9d d8 25 00 00 5b 5d 41 5c c3 75 c9 48 89 9d d8 25 00
sep 13 09:25:52 komp kernel: RSP: 0018:ffffa3a00086fa80 EFLAGS: 00010246
sep 13 09:25:52 komp kernel: RAX: 0000000000000001 RBX: 4079400000000000 RCX: 000000000088e005
sep 13 09:25:52 komp kernel: RDX: 0000000000000000 RSI: 12b5fcceac019937 RDI: 00000000000311a0
sep 13 09:25:52 komp kernel: RBP: ffff8e3052500000 R08: ffff8e322bdc1000 R09: ffff8e321c280000
sep 13 09:25:52 komp kernel: R10: ffff8e322bdc1000 R11: 0000000100000001 R12: ffff8e321c280000
sep 13 09:25:52 komp kernel: R13: ffff8e31d0b33300 R14: ffff8e3231b0dc00 R15: ffff8e3052500000
sep 13 09:25:52 komp kernel: FS: 0000000000000000(0000) GS:ffff8e323e940000(0000) knlGS:0000000000000000
sep 13 09:25:52 komp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
sep 13 09:25:52 komp kernel: CR2: 00007faf8c004a66 CR3: 000000062e36c000 CR4: 0000000000340ee0
sep 13 09:25:52 komp kernel: Call Trace:
sep 13 09:25:52 komp kernel: dcn20_validate_bandwidth+0x24/0x40 [amdgpu]
sep 13 09:25:52 komp kernel: dc_validate_global_state+0x2f2/0x390 [amdgpu]
sep 13 09:25:52 komp kernel: amdgpu_dm_atomic_check+0xf5e/0x1070 [amdgpu]
sep 13 09:25:52 komp kernel: drm_atomic_check_only+0x57c/0x7f0 [drm]
sep 13 09:25:52 komp kernel: drm_atomic_commit+0x13/0x50 [drm]
sep 13 09:25:52 komp kernel: drm_atomic_helper_disable_all+0x175/0x190 [drm_kms_helper]
sep 13 09:25:52 komp kernel: drm_atomic_helper_suspend+0xaf/0x1f0 [drm_kms_helper]
sep 13 09:25:52 komp kernel: dm_suspend+0x29/0xb0 [amdgpu]
sep 13 09:25:52 komp kernel: amdgpu_device_ip_suspend_phase1+0x83/0xe0 [amdgpu]
sep 13 09:25:52 komp kernel: amdgpu_device_suspend+0x9b/0x2c0 [amdgpu]
sep 13 09:25:52 komp kernel: pci_pm_suspend+0x74/0x160
sep 13 09:25:52 komp kernel: ? pci_pm_freeze+0xb0/0xb0
sep 13 09:25:52 komp kernel: dpm_run_callback+0x4f/0x180
sep 13 09:25:52 komp kernel: __device_suspend+0x11c/0x500
sep 13 09:25:52 komp kernel: async_suspend+0x1b/0x90
sep 13 09:25:52 komp kernel: async_run_entry_fn+0x37/0x140
sep 13 09:25:52 komp kernel: process_one_work+0x1da/0x3d0
sep 13 09:25:52 komp kernel: worker_thread+0x4d/0x3d0
sep 13 09:25:52 komp kernel: ? rescuer_thread+0x410/0x410
sep 13 09:25:52 komp kernel: kthread+0x142/0x160
sep 13 09:25:52 komp kernel: ? __kthread_bind_mask+0x60/0x60
sep 13 09:25:52 komp kernel: ret_from_fork+0x22/0x30
sep 13 09:25:52 komp kernel: ---[ end trace 9b142fa81a5d04a0 ]---
sep 13 09:25:52 komp kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
sep 13 09:25:52 komp kernel: sd 0:0:0:0: [sda] Stopping disk
sep 13 09:25:52 komp kernel: [drm] free PSP TMR buffer
sep 13 09:25:52 komp kernel: ACPI: Preparing to enter system sleep state S3
sep 13 09:25:52 komp kernel: PM: Saving platform NVS memory
sep 13 09:25:52 komp kernel: Disabling non-boot CPUs ...
sep 13 09:25:52 komp kernel: smpboot: CPU 1 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 2 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 3 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 4 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 5 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 6 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 7 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 8 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 9 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 10 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 11 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 12 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 13 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 14 is now offline
sep 13 09:25:52 komp kernel: smpboot: CPU 15 is now offline
sep 13 09:25:52 komp kernel: ACPI: Low-level resume complete
sep 13 09:25:52 komp kernel: PM: Restoring platform NVS memory
sep 13 09:25:52 komp kernel: LVT offset 0 assigned for vector 0x400
sep 13 09:25:52 komp kernel: Enabling non-boot CPUs ...
sep 13 09:25:52 komp kernel: x86: Booting SMP configuration:
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
sep 13 09:25:52 komp kernel: microcode: CPU1: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C002: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU1 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
sep 13 09:25:52 komp kernel: microcode: CPU2: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C004: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU2 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
sep 13 09:25:52 komp kernel: microcode: CPU3: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C006: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU3 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
sep 13 09:25:52 komp kernel: microcode: CPU4: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C008: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU4 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
sep 13 09:25:52 komp kernel: microcode: CPU5: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C00A: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU5 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 6 APIC 0xc
sep 13 09:25:52 komp kernel: microcode: CPU6: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C00C: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU6 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 7 APIC 0xe
sep 13 09:25:52 komp kernel: microcode: CPU7: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C00E: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU7 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 8 APIC 0x1
sep 13 09:25:52 komp kernel: microcode: CPU8: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C001: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU8 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 9 APIC 0x3
sep 13 09:25:52 komp kernel: microcode: CPU9: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C003: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU9 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 10 APIC 0x5
sep 13 09:25:52 komp kernel: microcode: CPU10: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C005: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU10 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 11 APIC 0x7
sep 13 09:25:52 komp kernel: microcode: CPU11: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C007: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU11 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 12 APIC 0x9
sep 13 09:25:52 komp kernel: microcode: CPU12: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C009: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU12 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 13 APIC 0xb
sep 13 09:25:52 komp kernel: microcode: CPU13: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C00B: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU13 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 14 APIC 0xd
sep 13 09:25:52 komp kernel: microcode: CPU14: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C00D: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU14 is up
sep 13 09:25:52 komp kernel: smpboot: Booting Node 0 Processor 15 APIC 0xf
sep 13 09:25:52 komp kernel: microcode: CPU15: patch_level=0x08701013
sep 13 09:25:52 komp kernel: ACPI: \_PR_.C00F: Found 2 idle states
sep 13 09:25:52 komp kernel: CPU15 is up
sep 13 09:25:52 komp kernel: ACPI: Waking up from system sleep state S3
sep 13 09:25:52 komp kernel: usb usb1: root hub lost power or was reset
sep 13 09:25:52 komp kernel: usb usb2: root hub lost power or was reset
sep 13 09:25:52 komp kernel: sd 0:0:0:0: [sda] Starting disk
sep 13 09:25:52 komp kernel: nvme nvme0: Shutdown timeout set to 8 seconds
sep 13 09:25:52 komp kernel: nvme nvme0: 32/0/0 default/read/poll queues
sep 13 09:25:52 komp kernel: ata10: SATA link down (SStatus 0 SControl 300)
sep 13 09:25:52 komp kernel: ata2: SATA link down (SStatus 0 SControl 300)
sep 13 09:25:52 komp kernel: ata5: SATA link down (SStatus 0 SControl 300)
sep 13 09:25:52 komp kernel: ata9: SATA link down (SStatus 0 SControl 300)
sep 13 09:25:52 komp kernel: ata6: SATA link down (SStatus 0 SControl 300)
sep 13 09:25:52 komp kernel: usb 1-6: reset full-speed USB device number 5 using xhci_hcd
sep 13 09:25:52 komp kernel: usb 1-2: reset high-speed USB device number 13 using xhci_hcd
sep 13 09:25:52 komp kernel: usb 1-4: reset full-speed USB device number 3 using xhci_hcd
sep 13 09:25:52 komp kernel: usb 1-8: reset full-speed USB device number 8 using xhci_hcd
sep 13 09:25:52 komp kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000000000).
sep 13 09:25:52 komp kernel: [drm] PSP is resuming...
sep 13 09:25:52 komp kernel: [drm] reserve 0x900000 from 0x800f400000 for PSP TMR
sep 13 09:25:52 komp kernel: usb 1-9: reset low-speed USB device number 10 using xhci_hcd
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: RAS: optional ras ta ucode is not available
sep 13 09:25:52 komp kernel: amdgpu: SMU is resuming...
sep 13 09:25:52 komp kernel: amdgpu: SMU is resumed successfully!
sep 13 09:25:52 komp kernel: WARNING: CPU: 0 PID: 248 at drivers/gpu/drm/amd/amdgpu/../display/dc/dcn10/dcn10_link_encoder.c:483 dcn10_get_dig_frontend+0x9e/0xc0 [amdgpu]
sep 13 09:25:52 komp kernel: CPU: 0 PID: 248 Comm: kworker/u64:13 Tainted: G W OE 5.8.6-1-MANJARO #1
sep 13 09:25:52 komp kernel: RIP: 0010:dcn10_get_dig_frontend+0x9e/0xc0 [amdgpu]
sep 13 09:25:52 komp kernel: Code: 45 44 89 c0 48 83 c4 10 c3 41 b8 05 00 00 00 83 f8 20 74 dd 41 b8 06 00 00 00 83 f8 40 74 d2 41 b8 04 00 00 00 83 f8 10 74 c7 <0f> 0b 41 b8 ff ff ff ff eb bd 45 31 c0 83 f8 01 74 b5 eb ec 41 b8
sep 13 09:25:52 komp kernel: RSP: 0018:ffffa3a0008bfc88 EFLAGS: 00010297
sep 13 09:25:52 komp kernel: RAX: 0000000000000000 RBX: ffff8e321c280000 RCX: 0000000000000008
sep 13 09:25:52 komp kernel: RDX: 0000000000000000 RSI: 00000000000165bc RDI: ffff8e321a560000
sep 13 09:25:52 komp kernel: RBP: ffff8e3231b0dc00 R08: 0000000000000000 R09: ffff8e3224b0d800
sep 13 09:25:52 komp kernel: R10: 0000000000000001 R11: 0000000000000006 R12: ffff8e3239d2ec00
sep 13 09:25:52 komp kernel: R13: ffff8e3239d2f000 R14: 0000000000000006 R15: ffff8e3237e32400
sep 13 09:25:52 komp kernel: FS: 0000000000000000(0000) GS:ffff8e323e800000(0000) knlGS:0000000000000000
sep 13 09:25:52 komp kernel: CR2: 00007fce38315796 CR3: 0000000644350000 CR4: 0000000000340ef0
sep 13 09:25:52 komp kernel: dcn10_init_hw+0x87c/0xb20 [amdgpu]
sep 13 09:25:52 komp kernel: dc_set_power_state+0xf5/0x140 [amdgpu]
sep 13 09:25:52 komp kernel: dm_resume+0x9f/0x560 [amdgpu]
sep 13 09:25:52 komp kernel: amdgpu_device_ip_resume_phase2+0x52/0xb0 [amdgpu]
sep 13 09:25:52 komp kernel: amdgpu_device_resume+0xb6/0x330 [amdgpu]
sep 13 09:25:52 komp kernel: ? preempt_count_add+0x68/0xa0
sep 13 09:25:52 komp kernel: ? pci_pm_restore+0xe0/0xe0
sep 13 09:25:52 komp kernel: device_resume+0xa7/0x200
sep 13 09:25:52 komp kernel: async_resume+0x19/0x30
sep 13 09:25:52 komp kernel: ---[ end trace 9b142fa81a5d04a1 ]---
sep 13 09:25:52 komp kernel: [drm] DM_MST: starting TM on aconnector: 00000000c1c35ead [id: 74]
sep 13 09:25:52 komp kernel: usb 1-2.7: reset full-speed USB device number 16 using xhci_hcd
sep 13 09:25:52 komp kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
sep 13 09:25:52 komp kernel: ata1.00: configured for UDMA/133
sep 13 09:25:52 komp kernel: usb 1-2.1: reset full-speed USB device number 17 using xhci_hcd
sep 13 09:25:52 komp kernel: r8169 0000:22:00.0 enp34s0: Link is Up - 1Gbps/Full - flow control off
sep 13 09:25:52 komp kernel: usb 1-2.6: reset full-speed USB device number 15 using xhci_hcd
sep 13 09:25:52 komp kernel: [drm] kiq ring mec 2 pipe 1 q 0
sep 13 09:25:52 komp kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
sep 13 09:25:52 komp kernel: [drm] JPEG decode initialized successfully.
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring vcn_dec uses VM inv eng 0 on hub 1
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 1 on hub 1
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 4 on hub 1
sep 13 09:25:52 komp kernel: amdgpu 0000:28:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 1
sep 13 09:25:52 komp kernel: usb 1-2.5: reset full-speed USB device number 14 using xhci_hcd
sep 13 09:25:52 komp kernel: usb 1-2.2: reset high-speed USB device number 18 using xhci_hcd
sep 13 09:25:52 komp kernel: OOM killer enabled.
sep 13 09:25:52 komp kernel: Restarting tasks ... done.
sep 13 09:25:52 komp kernel: PM: suspend exit
sep 13 09:25:52 komp kernel: usb 1-2.4: USB disconnect, device number 19
sep 13 09:25:52 komp systemd-sleep[6577]: System resumed.
sep 13 09:25:54 komp kernel: usb 1-2.4: new full-speed USB device number 20 using xhci_hcd
sep 13 09:25:54 komp kernel: usb 1-2.4: New USB device found, idVendor=0d8c, idProduct=0012, bcdDevice= 1.00
sep 13 09:25:54 komp kernel: usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
sep 13 09:25:54 komp kernel: usb 1-2.4: Product: USB Audio Device
sep 13 09:25:54 komp kernel: usb 1-2.4: Manufacturer: C-Media Electronics Inc.
sep 13 09:25:54 komp systemd-sleep[7296]: % Total % Received % Xferd Average Speed Time Time Time Current
sep 13 09:25:54 komp systemd-sleep[7296]: Dload Upload Total Spent Left Speed
sep 13 09:25:55 komp systemd-sleep[7296]: [158B blob data]
sep 13 09:25:55 komp kernel: input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2.4/1-2.4:1.3/0003:0D8C:0012.0018/input/input26
sep 13 09:25:55 komp kernel: usb 1-6: reset full-speed USB device number 5 using xhci_hcd
sep 13 09:25:55 komp kernel: hid-generic 0003:0D8C:0012.0018: input,hidraw13: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:03:00.0-2.4/input3
sep 13 09:25:55 komp mtp-probe[7307]: checking bus 1, device 20: "/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2.4"
sep 13 09:25:55 komp mtp-probe[7307]: bus: 1, device: 20 was not an MTP device
sep 13 09:25:55 komp kernel: hid-generic 0003:2516:0051.0019: hiddev5,hidraw7: USB HID v1.11 Device [Cooler Master Technology Inc. AMD SR4 lamplight Control] on usb-0000:03:00.0-6/input1
sep 13 09:25:55 komp mtp-probe[7353]: checking bus 1, device 20: "/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2.4"
sep 13 09:25:55 komp mtp-probe[7353]: bus: 1, device: 20 was not an MTP device
sep 13 09:25:55 komp kernel: hid-generic 0003:2516:0051.001A: hiddev5,hidraw7: USB HID v1.11 Device [Cooler Master Technology Inc. AMD SR4 lamplight Control] on usb-0000:03:00.0-6/input1
sep 13 09:25:56 komp systemd-sleep[7296]: [{"attributes": {"friendly_name": "Report Media State to PC", "last_triggered": "2020-09-13T07:25:54.995443+00:00", "mode": "single"}, "context": {"id": "d1a50cab1dbf467d88661add81497abf", "parent_id": "6e98e5ef3e2a413e92e89d9ca2c3d0bb", "user_id": null}, "entity_id": "automation.report_media_state_to_pc", "last_changed": "2020-09-08T17:11:42.767933+00:00", "last_updated": "2020-09-13T07:25:54.995648+00:00", "state": "on"}]
sep 13 09:25:56 komp kernel: hid-generic 0003:2516:0051.001B: hiddev5,hidraw7: USB HID v1.11 Device [Cooler Master Technology Inc. AMD SR4 lamplight Control] on usb-0000:03:00.0-6/input1
sep 13 09:25:56 komp systemd[1]: systemd-suspend.service: Succeeded.
sep 13 09:25:56 komp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:25:56 komp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:25:56 komp systemd[1]: Finished Suspend.
sep 13 09:25:56 komp systemd[1]: Stopped target Sleep.
sep 13 09:25:56 komp systemd[1]: Reached target Suspend.
sep 13 09:25:56 komp systemd[1]: Stopped target Suspend.
sep 13 09:25:56 komp systemd-logind[824]: Operation 'sleep' finished.
sep 13 09:25:56 komp ModemManager[850]: <info> [sleep-monitor] system is resuming
sep 13 09:25:56 komp NetworkManager[821]: <info> [1599981956.2057] manager: sleep: wake requested (sleeping: yes enabled: yes)
sep 13 09:25:56 komp NetworkManager[821]: <info> [1599981956.2058] device (enp34s0): state change: activated -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
sep 13 09:25:56 komp kernel: audit: type=1130 audit(1599981956.201:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:25:56 komp kernel: audit: type=1131 audit(1599981956.201:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:25:56 komp rtkit-daemon[1673]: Supervising 8 threads of 3 processes of 1 users.
sep 13 09:25:56 komp rtkit-daemon[1673]: Successfully made thread 7360 of process 1523 owned by '1000' RT at priority 5.
sep 13 09:25:56 komp rtkit-daemon[1673]: Supervising 9 threads of 3 processes of 1 users.
sep 13 09:25:56 komp NetworkManager[821]: <info> [1599981956.2201] dhcp4 (enp34s0): canceled DHCP transaction
sep 13 09:25:56 komp NetworkManager[821]: <info> [1599981956.2201] dhcp4 (enp34s0): state changed bound -> done
sep 13 09:25:56 komp avahi-daemon[818]: Withdrawing address record for 192.168.1.2 on enp34s0.
sep 13 09:25:56 komp avahi-daemon[818]: Leaving mDNS multicast group on interface enp34s0.IPv4 with address 192.168.1.2.
sep 13 09:25:56 komp avahi-daemon[818]: Interface enp34s0.IPv4 no longer relevant for mDNS.
sep 13 09:25:56 komp avahi-daemon[818]: Withdrawing address record for fe80::dabc:3b80:d45c:1d14 on enp34s0.
sep 13 09:25:56 komp avahi-daemon[818]: Leaving mDNS multicast group on interface enp34s0.IPv6 with address fe80::dabc:3b80:d45c:1d14.
sep 13 09:25:56 komp avahi-daemon[818]: Interface enp34s0.IPv6 no longer relevant for mDNS.
sep 13 09:25:56 komp NetworkManager[821]: <info> [1599981956.2222] manager: NetworkManager state is now CONNECTED_GLOBAL
sep 13 09:25:56 komp kernel: r8169 0000:22:00.0 enp34s0: Link is Down
sep 13 09:25:56 komp NetworkManager[821]: <info> [1599981956.2408] manager: NetworkManager state is now DISCONNECTED
sep 13 09:25:56 komp rtkit-daemon[1673]: Successfully made thread 7365 of process 1523 owned by '1000' RT at priority 5.
sep 13 09:25:56 komp rtkit-daemon[1673]: Supervising 10 threads of 3 processes of 1 users.
sep 13 09:25:56 komp NetworkManager[821]: <info> [1599981956.2413] device (enp34s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
sep 13 09:25:56 komp dbus-daemon[820]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=821 comm="/usr/bin/NetworkManager --no-daemon ")
sep 13 09:25:56 komp systemd[1]: Starting Network Manager Script Dispatcher Service...
sep 13 09:25:56 komp dbus-daemon[820]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
sep 13 09:25:56 komp systemd[1]: Started Network Manager Script Dispatcher Service.
sep 13 09:25:56 komp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:25:56 komp kernel: audit: type=1130 audit(1599981956.248:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:25:56 komp kernel: Generic FE-GE Realtek PHY r8169-2200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-2200:00, irq=IGNORE)
sep 13 09:25:58 komp ModemManager[850]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:20:01.0/0000:22:00.0': not supported by any plugin
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6243] device (enp34s0): carrier: link connected
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6245] device (enp34s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6253] policy: auto-activating connection 'Wired connection 1' (c71e2d8f-69a3-374d-97a9-1b8b9e402b99)
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6257] device (enp34s0): Activation: starting connection 'Wired connection 1' (c71e2d8f-69a3-374d-97a9-1b8b9e402b99)
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6258] device (enp34s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6261] manager: NetworkManager state is now CONNECTING
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6263] device (enp34s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
sep 13 09:25:59 komp kernel: r8169 0000:22:00.0 enp34s0: Link is Up - 1Gbps/Full - flow control off
sep 13 09:25:59 komp kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp34s0: link becomes ready
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6267] device (enp34s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
sep 13 09:25:59 komp NetworkManager[821]: <info> [1599981959.6270] dhcp4 (enp34s0): activation: beginning transaction (timeout in 45 seconds)
sep 13 09:25:59 komp avahi-daemon[818]: Joining mDNS multicast group on interface enp34s0.IPv6 with address fe80::dabc:3b80:d45c:1d14.
sep 13 09:25:59 komp avahi-daemon[818]: New relevant interface enp34s0.IPv6 for mDNS.
sep 13 09:25:59 komp avahi-daemon[818]: Registering new address record for fe80::dabc:3b80:d45c:1d14 on enp34s0.*.
sep 13 09:26:06 komp systemd[1]: NetworkManager-dispatcher.service: Succeeded.
sep 13 09:26:06 komp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:26:06 komp kernel: audit: type=1131 audit(1599981966.724:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:26:35 komp rtkit-daemon[1673]: Supervising 10 threads of 3 processes of 1 users.
sep 13 09:26:44 komp NetworkManager[821]: <warn> [1599982004.7333] dhcp4 (enp34s0): request timed out
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7334] dhcp4 (enp34s0): state changed unknown -> timeout
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7334] device (enp34s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7338] manager: NetworkManager state is now DISCONNECTED
sep 13 09:26:44 komp NetworkManager[821]: <warn> [1599982004.7344] device (enp34s0): Activation: failed for connection 'Wired connection 1'
sep 13 09:26:44 komp avahi-daemon[818]: Withdrawing address record for fe80::dabc:3b80:d45c:1d14 on enp34s0.
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7346] device (enp34s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
sep 13 09:26:44 komp avahi-daemon[818]: Leaving mDNS multicast group on interface enp34s0.IPv6 with address fe80::dabc:3b80:d45c:1d14.
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7355] dhcp4 (enp34s0): canceled DHCP transaction
sep 13 09:26:44 komp avahi-daemon[818]: Interface enp34s0.IPv6 no longer relevant for mDNS.
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7355] dhcp4 (enp34s0): state changed timeout -> done
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7370] policy: auto-activating connection 'Wired connection 1' (c71e2d8f-69a3-374d-97a9-1b8b9e402b99)
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7379] device (enp34s0): Activation: starting connection 'Wired connection 1' (c71e2d8f-69a3-374d-97a9-1b8b9e402b99)
sep 13 09:26:44 komp dbus-daemon[820]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=821 comm="/usr/bin/NetworkManager --no-daemon ")
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7385] device (enp34s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7389] manager: NetworkManager state is now CONNECTING
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7392] device (enp34s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7396] device (enp34s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
sep 13 09:26:44 komp NetworkManager[821]: <info> [1599982004.7398] dhcp4 (enp34s0): activation: beginning transaction (timeout in 45 seconds)
sep 13 09:26:44 komp systemd[1]: Starting Network Manager Script Dispatcher Service...
sep 13 09:26:44 komp avahi-daemon[818]: Joining mDNS multicast group on interface enp34s0.IPv6 with address fe80::dabc:3b80:d45c:1d14.
sep 13 09:26:44 komp avahi-daemon[818]: New relevant interface enp34s0.IPv6 for mDNS.
sep 13 09:26:44 komp avahi-daemon[818]: Registering new address record for fe80::dabc:3b80:d45c:1d14 on enp34s0.*.
sep 13 09:26:44 komp kdeconnectd[2998]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/2"
sep 13 09:26:44 komp dbus-daemon[820]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
sep 13 09:26:44 komp systemd[1]: Started Network Manager Script Dispatcher Service.
sep 13 09:26:44 komp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:26:44 komp kernel: audit: type=1130 audit(1599982004.741:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:26:54 komp systemd[1]: NetworkManager-dispatcher.service: Succeeded.
sep 13 09:26:54 komp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:26:54 komp kernel: audit: type=1131 audit(1599982014.728:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:27:12 komp audit[7955]: USER_AUTH pid=7955 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="matej" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp dbus-daemon[820]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.728' (uid=0 pid=7955 comm="sudo journalctl --since=today ")
sep 13 09:27:12 komp audit[7955]: USER_ACCT pid=7955 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="matej" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp audit[7955]: CRED_REFR pid=7955 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp kernel: audit: type=1100 audit(1599982032.628:60): pid=7955 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="matej" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp kernel: audit: type=1101 audit(1599982032.628:61): pid=7955 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="matej" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp kernel: audit: type=1110 audit(1599982032.628:62): pid=7955 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp dbus-daemon[820]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
sep 13 09:27:12 komp sudo[7955]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
sep 13 09:27:12 komp sudo[7955]: matej : TTY=pts/0 ; PWD=/home/matej/Downloads ; USER=root ; COMMAND=/usr/bin/journalctl --since=today
sep 13 09:27:12 komp sudo[7955]: pam_unix(sudo:session): session opened for user root(uid=0) by matej(uid=0)
sep 13 09:27:12 komp audit[7955]: USER_START pid=7955 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp kernel: audit: type=1105 audit(1599982032.631:63): pid=7955 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp sudo[7955]: pam_unix(sudo:session): session closed for user root
sep 13 09:27:12 komp audit[7955]: USER_END pid=7955 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp audit[7955]: CRED_DISP pid=7955 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp kernel: audit: type=1106 audit(1599982032.671:64): pid=7955 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:12 komp kernel: audit: type=1104 audit(1599982032.671:65): pid=7955 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
sep 13 09:27:14 komp dbus-daemon[820]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.736' (uid=1000 pid=7988 comm="/usr/lib/electron7/electron --no-sandbox /usr/lib/")
sep 13 09:27:14 komp systemd[1]: Condition check resulted in Bluetooth service being skipped.
sep 13 09:27:29 komp NetworkManager[821]: <warn> [1599982049.7340] dhcp4 (enp34s0): request timed out
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7340] dhcp4 (enp34s0): state changed unknown -> timeout
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7341] device (enp34s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7345] manager: NetworkManager state is now DISCONNECTED
sep 13 09:27:29 komp NetworkManager[821]: <warn> [1599982049.7353] device (enp34s0): Activation: failed for connection 'Wired connection 1'
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7356] device (enp34s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
sep 13 09:27:29 komp avahi-daemon[818]: Withdrawing address record for fe80::dabc:3b80:d45c:1d14 on enp34s0.
sep 13 09:27:29 komp avahi-daemon[818]: Leaving mDNS multicast group on interface enp34s0.IPv6 with address fe80::dabc:3b80:d45c:1d14.
sep 13 09:27:29 komp avahi-daemon[818]: Interface enp34s0.IPv6 no longer relevant for mDNS.
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7370] dhcp4 (enp34s0): canceled DHCP transaction
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7370] dhcp4 (enp34s0): state changed timeout -> done
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7386] policy: auto-activating connection 'Wired connection 1' (c71e2d8f-69a3-374d-97a9-1b8b9e402b99)
sep 13 09:27:29 komp dbus-daemon[820]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=821 comm="/usr/bin/NetworkManager --no-daemon ")
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7401] device (enp34s0): Activation: starting connection 'Wired connection 1' (c71e2d8f-69a3-374d-97a9-1b8b9e402b99)
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7402] device (enp34s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7407] manager: NetworkManager state is now CONNECTING
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7409] device (enp34s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7417] device (enp34s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
sep 13 09:27:29 komp NetworkManager[821]: <info> [1599982049.7420] dhcp4 (enp34s0): activation: beginning transaction (timeout in 45 seconds)
sep 13 09:27:29 komp systemd[1]: Starting Network Manager Script Dispatcher Service...
sep 13 09:27:29 komp avahi-daemon[818]: Joining mDNS multicast group on interface enp34s0.IPv6 with address fe80::dabc:3b80:d45c:1d14.
sep 13 09:27:29 komp avahi-daemon[818]: New relevant interface enp34s0.IPv6 for mDNS.
sep 13 09:27:29 komp avahi-daemon[818]: Registering new address record for fe80::dabc:3b80:d45c:1d14 on enp34s0.*.
sep 13 09:27:29 komp kdeconnectd[2998]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/3"
sep 13 09:27:29 komp dbus-daemon[820]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
sep 13 09:27:29 komp systemd[1]: Started Network Manager Script Dispatcher Service.
sep 13 09:27:29 komp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:27:29 komp kernel: audit: type=1130 audit(1599982049.741:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:27:39 komp dbus-daemon[820]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
sep 13 09:27:39 komp systemd[1]: NetworkManager-dispatcher.service: Succeeded.
sep 13 09:27:39 komp audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:27:39 komp kernel: audit: type=1131 audit(1599982059.728:67): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:27:40 komp kernel: ------------[ cut here ]------------
sep 13 09:27:40 komp kernel: NETDEV WATCHDOG: enp34s0 (r8169): transmit queue 0 timed out
sep 13 09:27:40 komp kernel: WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:442 dev_watchdog+0x26d/0x280
sep 13 09:27:40 komp kernel: Modules linked in: uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common rfkill snd_usb_audio snd_usbmidi_lib snd_rawmidi mousedev snd_seq_device nct6775 hwmon_vid nls_iso8859_1 nls_cp437 vfat fat fuse r8169 realtek libphy input_leds amdgpu snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi edac_mce_amd snd_hda_intel kvm_amd gpu_sched snd_intel_dspcfg i2c_algo_bit snd_hda_codec kvm ttm snd_hda_core snd_hwdep wmi_bmof drm_kms_helper irqbypass snd_pcm crct10dif_pclmul cec crc32_pclmul snd_timer ghash_clmulni_intel rc_core aesni_intel ccp snd crypto_simd cryptd syscopyarea sp5100_tco sysfillrect glue_helper sysimgblt rapl pcspkr k10temp i2c_piix4 fb_sys_fops soundcore rng_core wmi pinctrl_amd evdev gpio_amdpt mac_hid acpi_cpufreq uinput vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) drm videodev mc crypto_user agpgart ip_tables x_tables btrfs blake2b_generic libcrc32c crc32c_generic xor hid_generic usbhid hid raid6_pq crc32c_intel
sep 13 09:27:40 komp kernel: xhci_pci xhci_pci_renesas xhci_hcd
sep 13 09:27:40 komp kernel: CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W OE 5.8.6-1-MANJARO #1
sep 13 09:27:40 komp kernel: Hardware name: Micro-Star International Co., Ltd MS-7C02/B450 TOMAHAWK MAX (MS-7C02), BIOS 3.50 11/07/2019
sep 13 09:27:40 komp kernel: RIP: 0010:dev_watchdog+0x26d/0x280
sep 13 09:27:40 komp kernel: Code: 48 32 75 ff eb 85 4c 89 f7 c6 05 65 79 e8 00 01 e8 08 af fa ff 44 89 e9 4c 89 f6 48 c7 c7 70 59 1f a9 48 89 c2 e8 a9 0c 7e ff <0f> 0b e9 63 ff ff ff 66 66 2e 0f 1f 84 00 00 00 00 00 90 0f 1f 44
sep 13 09:27:40 komp kernel: RSP: 0018:ffffa3a000003e90 EFLAGS: 00010286
sep 13 09:27:40 komp kernel: RAX: 0000000000000000 RBX: ffff8e322d7aa200 RCX: 0000000000000000
sep 13 09:27:40 komp kernel: RDX: 0000000000000103 RSI: ffffffffa9174dba RDI: 00000000ffffffff
sep 13 09:27:40 komp kernel: RBP: ffff8e321f9623dc R08: 000000000000062d R09: 0000000000000004
sep 13 09:27:40 komp kernel: R10: 0000000000000000 R11: 0000000000000001 R12: ffff8e321f962480
sep 13 09:27:40 komp kernel: R13: 0000000000000000 R14: ffff8e321f962000 R15: ffff8e322d7aa280
sep 13 09:27:40 komp kernel: FS: 0000000000000000(0000) GS:ffff8e323e800000(0000) knlGS:0000000000000000
sep 13 09:27:40 komp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
sep 13 09:27:40 komp kernel: CR2: 000001955295efe0 CR3: 0000000644a74000 CR4: 0000000000340ef0
sep 13 09:27:40 komp kernel: Call Trace:
sep 13 09:27:40 komp kernel: <IRQ>
sep 13 09:27:40 komp kernel: ? pfifo_fast_init+0x110/0x110
sep 13 09:27:40 komp kernel: call_timer_fn+0x2d/0x160
sep 13 09:27:40 komp kernel: __run_timers+0x193/0x290
sep 13 09:27:40 komp kernel: run_timer_softirq+0x2b/0x50
sep 13 09:27:40 komp kernel: __do_softirq+0xff/0x340
sep 13 09:27:40 komp kernel: asm_call_on_stack+0x12/0x20
sep 13 09:27:40 komp kernel: </IRQ>
sep 13 09:27:40 komp kernel: do_softirq_own_stack+0x5f/0x80
sep 13 09:27:40 komp kernel: irq_exit_rcu+0xcb/0x120
sep 13 09:27:40 komp kernel: sysvec_apic_timer_interrupt+0x46/0xe0
sep 13 09:27:40 komp kernel: asm_sysvec_apic_timer_interrupt+0x12/0x20
sep 13 09:27:40 komp kernel: RIP: 0010:cpuidle_enter_state+0xb6/0x420
sep 13 09:27:40 komp kernel: Code: 90 91 a1 57 e8 4b 56 8d ff 49 89 c7 0f 1f 44 00 00 31 ff e8 7c 64 8d ff 80 7c 24 0f 00 0f 85 06 02 00 00 fb 66 0f 1f 44 00 00 <45> 85 e4 0f 88 e9 01 00 00 49 63 d4 4c 2b 7c 24 10 48 8d 04 52 48
sep 13 09:27:40 komp kernel: RSP: 0018:ffffffffa9403e40 EFLAGS: 00000246
sep 13 09:27:40 komp kernel: RAX: ffff8e323e800000 RBX: ffff8e3235baf800 RCX: 000000000000001f
sep 13 09:27:40 komp kernel: RDX: 0000000000000000 RSI: ffffffffa9174dba RDI: ffffffffa9154c29
sep 13 09:27:40 komp kernel: RBP: ffffffffa94cf3a0 R08: 00000042b68a8c0a R09: 0000000000000018
sep 13 09:27:40 komp kernel: R10: 0000000000000b6d R11: 00000000000002f4 R12: 0000000000000001
sep 13 09:27:40 komp kernel: R13: ffff8e3235baf800 R14: 0000000000000001 R15: 00000042b68a8c0a
sep 13 09:27:40 komp kernel: cpuidle_enter+0x29/0x40
sep 13 09:27:40 komp kernel: do_idle+0x1fb/0x2c0
sep 13 09:27:40 komp kernel: cpu_startup_entry+0x19/0x20
sep 13 09:27:40 komp kernel: start_kernel+0x85b/0x880
sep 13 09:27:40 komp kernel: secondary_startup_64+0xb6/0xc0
sep 13 09:27:40 komp kernel: ---[ end trace 9b142fa81a5d04a2 ]---
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3094] dhcp4 (enp34s0): option dhcp_lease_time => '86400'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option domain_name_servers => '192.168.1.1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option expiry => '1600068459'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option host_name => 'KOMP'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option ip_address => '192.168.1.2'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option next_server => '192.168.1.1'
sep 13 09:27:40 komp avahi-daemon[818]: Joining mDNS multicast group on interface enp34s0.IPv4 with address 192.168.1.2.
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option requested_broadcast_address => '1'
sep 13 09:27:40 komp avahi-daemon[818]: New relevant interface enp34s0.IPv4 for mDNS.
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option requested_domain_name => '1'
sep 13 09:27:40 komp avahi-daemon[818]: Registering new address record for 192.168.1.2 on enp34s0.IPv4.
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option requested_domain_name_servers => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option requested_domain_search => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option requested_host_name => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option requested_interface_mtu => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3095] dhcp4 (enp34s0): option requested_ms_classless_static_routes => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_nis_domain => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_nis_servers => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_ntp_servers => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_rfc3442_classless_static_routes => '1'
sep 13 09:27:40 komp dbus-daemon[820]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=821 comm="/usr/bin/NetworkManager --no-daemon ")
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_root_path => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_routers => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_static_routes => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_subnet_mask => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_time_offset => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option requested_wpad => '1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option routers => '192.168.1.1'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3096] dhcp4 (enp34s0): option subnet_mask => '255.255.255.0'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3097] dhcp4 (enp34s0): option wpad => '
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3097] dhcp4 (enp34s0): state changed unknown -> bound
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3110] device (enp34s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
sep 13 09:27:40 komp systemd[1]: Starting Network Manager Script Dispatcher Service...
sep 13 09:27:40 komp dbus-daemon[820]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
sep 13 09:27:40 komp systemd[1]: Started Network Manager Script Dispatcher Service.
sep 13 09:27:40 komp audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3189] device (enp34s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3191] device (enp34s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3195] manager: NetworkManager state is now CONNECTED_LOCAL
sep 13 09:27:40 komp kernel: audit: type=1130 audit(1599982060.315:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3203] manager: NetworkManager state is now CONNECTED_SITE
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3203] policy: set 'Wired connection 1' (enp34s0) as default for IPv4 routing and DNS
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3210] device (enp34s0): Activation: successful, device activated.
sep 13 09:27:40 komp NetworkManager[821]: <info> [1599982060.3755] manager: NetworkManager state is now CONNECTED_GLOBAL
sep 13 09:27:50 komp systemd[1]: NetworkManager-dispatcher.service: Succeeded.
System specs:
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.8-x86_64
root=UUID=1535d461-fb75-46f3-ba82-3e58e1f6e6a7 rw rootflags=subvol=@
resume=UUID=7943d4fd-db87-4476-a637-faedabc46eec udev.log_priority=3 profile
Desktop: i3 4.18.2 info: polybar dm: startx Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <filter> UEFI: American Megatrends v: 3.50 date: 11/07/2019
Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701013
L2 cache: 4096 KiB
bogomips: 115232
Speed: 3648 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3906 2: 2081 3: 2126 4: 2157 5: 2200 6: 2199 7: 2200 8: 2200 9: 2151
10: 2101 11: 2200 12: 2199 13: 2200 14: 2200 15: 4241 16: 2174
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 28:00.0
chip ID: 1002:731f
Device-2: HTC (High Tech ) Vive type: USB driver: uvcvideo bus ID: 1-2.2:18
chip ID: 0bb4:2c87
Display: server: X.Org 1.20.9 compositor: picom v: git-e553e
driver: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: DisplayPort-1 res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
Monitor-2: DisplayPort-3 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.38.0 5.8.6-1-MANJARO
LLVM 10.0.1)
v: 4.6 Mesa 20.1.7 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 28:00.1 chip ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 2a:00.4 chip ID: 1022:1487
Device-3: C-Media VRC type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-2.4:20 chip ID: 0d8c:0012
Device-4: Logitech USB Headset type: USB driver: snd-usb-audio bus ID: 1-8:8
chip ID: 046d:0a01
Sound Server: ALSA v: k5.8.6-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 22:00.0
chip ID: 10ec:8168
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.36 TiB used: 1.01 TiB (74.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD1003FZEX-00MK2A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw size: 447.89 GiB size: 447.89 GiB (100.00%)
used: 339.70 GiB (75.8%) fs: btrfs dev: /dev/nvme0n1p3
ID-2: /home raw size: 447.89 GiB size: 447.89 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2
System Temperatures: cpu: 59.5 C mobo: 38.0 C gpu: amdgpu temp: 68 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1582 fan-3: 1030 fan-4: 0 fan-5: 872
fan-6: 925 gpu: amdgpu fan: 881
Processes: 402 Uptime: 33m Memory: 31.38 GiB used: 5.88 GiB (18.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: apt: 0 pacman: 1692
lib: 427 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.05
(I’ve noticed there are couple of AMD gpu related errors in the logs. Will report those in the separate ticket).
Any idea what could cause the network issues and how to resolve them?
Thanks.
