Network dhcp continuous rediscover
Hardware is quartz64 model b Wireless Lan
Latest Manjaro with updates.
This network is continuously reconnecting. Can anyone see a problem? Disregard references to Wired connection 1 which is disconnected.
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.4874] device (end0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.5596] dhcp4 (end0): canceled DHCP transaction, DHCP client pid 7448
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.5598] dhcp4 (end0): activation: beginning transaction (timeout in 45 seconds)
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.5600] dhcp4 (end0): state changed no lease
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.6001] policy: auto-activating connection 'Wired connection 1' (362589d5-d3f6-3463-8ebe-776498c5feb4)
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.6150] device (end0): Activation: starting connection 'Wired connection 1' (362589d5-d3f6-3463-8ebe-776498c5feb4)
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.6164] device (end0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.6245] device (end0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.6379] device (end0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.6487] dhcp4 (end0): activation: beginning transaction (timeout in 45 seconds)
Sep 21 15:27:20 Manjaro-Quartz NetworkManager[471]: <info>  [1695275840.6679] dhcp4 (end0): dhclient started with pid 7462
Sep 21 15:27:20 Manjaro-Quartz dhclient[7462]: DHCPDISCOVER on end0 to 255.255.255.255 port 67 interval 3
Sep 21 15:27:22 Manjaro-Quartz systemd-networkd[352]: end0: Gained IPv6LL
Sep 21 15:27:23 Manjaro-Quartz dhclient[7462]: DHCPDISCOVER on end0 to 255.255.255.255 port 67 interval 4
Sep 21 15:27:27 Manjaro-Quartz dhclient[7462]: DHCPDISCOVER on end0 to 255.255.255.255 port 67 interval 11
Sep 21 15:27:38 Manjaro-Quartz dhclient[7462]: DHCPDISCOVER on end0 to 255.255.255.255 port 67 interval 14
Sep 21 15:27:52 Manjaro-Quartz dhclient[7462]: DHCPDISCOVER on end0 to 255.255.255.255 port 67 interval 9
Sep 21 15:28:01 Manjaro-Quartz dhclient[7462]: DHCPDISCOVER on end0 to 255.255.255.255 port 67 interval 10
Sep 21 15:28:05 Manjaro-Quartz NetworkManager[471]: <info>  [1695275885.4895] device (end0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Sep 21 15:28:05 Manjaro-Quartz NetworkManager[471]: <warn>  [1695275885.4926] device (end0): Activation: failed for connection 'Wired connection 1'
Sep 21 15:28:05 Manjaro-Quartz NetworkManager[471]: <info>  [1695275885.4959] device (end0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Sep 21 15:28:05 Manjaro-Quartz NetworkManager[471]: <info>  [1695275885.5689] dhcp4 (end0): canceled DHCP transaction, DHCP client pid 7462
Sep 21 15:28:05 Manjaro-Quartz NetworkManager[471]: <info>  [1695275885.5691] dhcp4 (end0): activation: beginning transaction (timeout in 45 seconds)
Sep 21 15:28:05 Manjaro-Quartz NetworkManager[471]: <info>  [1695275885.5691] dhcp4 (end0): state changed no lease
Sep 21 15:28:15 Manjaro-Quartz nmbd[1051]: [2023/09/21 15:28:15.537568,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Sep 21 15:28:15 Manjaro-Quartz nmbd[1051]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.188.110 for name WORKGROUP<1d>.
Sep 21 15:28:15 Manjaro-Quartz nmbd[1051]:   This response was from IP 192.168.188.39, reporting an IP address of 192.168.188.39.
Sep 21 15:28:17 Manjaro-Quartz dhclient[5176]: XMT: Solicit on wlan0, interval 116480ms.
Sep 21 15:28:17 Manjaro-Quartz dhclient[5176]: RCV: Advertise message on wlan0 from fe80::e228:6dff:fe9f:2be5.
Sep 21 15:28:25 Manjaro-Quartz dbus-daemon[573]: [session uid=1000 pid=573] Activating service name='org.xfce.Xfconf' requested by ':1.13' (uid=1000 pid=653 comm="xfsettingsd --display :0.0 --sm-client-id 2077368a")
Sep 21 15:28:25 Manjaro-Quartz dbus-daemon[573]: [session uid=1000 pid=573] Successfully activated service 'org.xfce.Xfconf'
  Device-1: rk3568-gmac driver: rk_gmac_dwmac v: N/A port: N/A bus-ID: N/A
    chip-ID: rockchip:fe010000 class-ID: ethernet
  IF: end0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wlan0 state: up mac: <filter>
  Kernel: 6.4.7-1-MANJARO-ARM arch: aarch64 bits: 64 compiler: gcc v: 12.1.0
    clocksource: arch_sys_counter Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36
    info: xfce4-panel wm: xfwm v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0
    Distro: Manjaro ARM base: Arch Linux
Sorry guys. I may have fixed this.
While posting I could see a lot of references to wired connection 1. In network manager I selected settings to take a closer look at this unused network connection. It had default selected, despite not being used. Once this was removed the network started behaving. Still early days but I am hopeful.
