Network devices missing after Restart
Hi,
today i started my desktop as usual everything worked fine.
Shut it down to get lunch and got back after.
Starting the desktop and my Ethernet was missing.
I connect Wlan searched for updates (non where found).
Tried a restart now my Wlan device was also missing.
Added a USB-Ethernet adapter and googled a bit without results.
Restarted again now the USB Adapter did not work anymore.
Used another USB-C Adapter and found that a recent manrajro update mentioned NetworkManager( forum.manjaro org/t/stable-update-2023-02-20-kernels-gnome-networkmanager-kde-frameworks-firefox/134573 )
But that update is marked as stable so i think it cant break a system like that ?
Anyways so i got on and found arch wiki telling me to go sudo lspci -v
And what can i tell… no network devices where listed.
After another restart even my USB C Adapter is now gone.
I have no way of connecting the Desktop to Internet anymore and its dead now.
To not have those M$ Windows problems i switched to Manajro stable …
Luckly i have a friends Laptop today (which is where i am writing from) and my boss is not having any huge tasks today. Otherwise this “Stable update” might have cost me my job.
Now to the big question:
How to fix this?
with kind regards
PS: i am no Developer i am just a normal User (and no i wont install Windows again )
//EDIT1: sorry if i am a little heated but i saved a very long time for this not even a month old setup.
And chose Manjaro cause it got advertised as stable distro. I am really scared that my setup briked :frowning:
//EDIT2: Fedora37 live saw my pcie network devices so i guess hardware is ok.
Maybe the so called ‘Networkmanager’ really is the problem
//EDIT3: Looks like deleting everything in the NetworkManager config folder (+ ofc restarts) solved the porblem. BUT as always MAKE BACKUPS first :wink: !
Since you can post, you seem to be still connected … somehow.
Provide basic hardware information - boot a live system to do it if you have to.
inxi -Fazy
(mind the formatting of the output when you post it here
use this button: </> )
so i downloaded the latest manjaro live image and either manjaro broke my hardware completely or the latest image has the same problem …
ill now download a live ubuntu to check my hardware.
If manjaro broke my new am5 board ill burst into flames :frowning:
  Kernel: 6.2.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.2-x86_64
    root=UUID=0ec87bf4-37bf-4389-bd57-2e3ba04164fb rw rootflags=subvol=@ quiet
    amd_iommu=on iommu=pt rd.driver.pre=vfio-pci kvm.ignore_msrs=1 splash
  Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Type: Desktop System: Gigabyte product: X670E AORUS MASTER v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X670E AORUS MASTER serial: <superuser required>
    UEFI: American Megatrends LLC. v: F8h date: 12/29/2022
  Info: model: AMD Ryzen 7 7700 bits: 64 type: MT MCP arch: Zen 4 gen: 5
    level: v4 note: check built: 2022 process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3019 high: 3594 min/max: 3000/5388 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3496 2: 3594
    3: 2883 4: 3000 5: 3000 6: 3000 7: 3000 8: 2870 9: 3000 10: 3000 11: 3000
    12: 3000 13: 2856 14: 2865 15: 2876 16: 2875 bogomips: 121641
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA AD103 [GeForce RTX 4080] vendor: Gigabyte driver: vfio-pci
    v: N/A alternate: nouveau non-free: 525.xx+ status: current (as of 2023-02)
    arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022-23+ pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2704
    class-ID: 0300
  Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2,HDMI-A-1 empty: DP-3
    bus-ID: 0c:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 34.0 C
  Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: PORPOISE built: 2018 res: 1920x1080 dpi: 142
    gamma: 1.2 size: 344x195mm (13.54x7.68") diag: 395mm (15.57") modes:
    max: 1920x1080 min: 720x400
  Monitor-2: DP-2 model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2020
    res: 3440x1440 dpi: 109 gamma: 1.2 size: 800x335mm (31.5x13.19")
    diag: 867mm (34.1") modes: max: 3440x1440 min: 640x480
  Monitor-3: HDMI-A-1 model: LG (GoldStar) PROJECTOR serial: <filter>
    built: 2021 res: 3840x2160 dpi: 61 gamma: 1.2 size: 1600x900mm (62.99x35.43")
    diag: 1836mm (72.3") ratio: 16:9 modes: max: 3840x2160 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Graphics (gfx1036 LLVM
    15.0.7 DRM 3.49 6.2.0-1-MANJARO) direct-render: Yes
  Device-1: NVIDIA vendor: Gigabyte driver: vfio-pci alternate: snd_hda_intel
    bus-ID: 4-5.1:4 pcie: chip-ID: 19f7:0003 class-ID: 0300 gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1
    chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
    bus-ID: 0c:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound API: ALSA v: k6.2.0-1-MANJARO running: yes
  Sound Server-1: PulseAudio v: 16.1 running: no
  Sound Server-2: PipeWire v: 0.3.65 running: yes
  Message: No PCI device data found.
  Device-1: D-Link DUB-1312 Gigabit Ethernet Adapter type: USB
    driver: ax88179_178a bus-ID: 2-2:2 chip-ID: 2001:4a00 class-ID: ff00
    serial: <filter>
  IF: enp12s0f4u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: bridge0 state: down mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
  Local Storage: total: 2.73 TiB used: 264.32 GiB (9.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
    lanes: 4 type: SSD serial: <filter> rev: 0B2QJXD7 temp: 45.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 2TB
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: USBest
    model: Ut165 USB2FlashStorage size: 1.88 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> rev: 0.00 scheme: MBR
  ID-1: / raw-size: 681.22 GiB size: 681.22 GiB (100.00%)
    used: 264.19 GiB (38.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 681.22 GiB size: 681.22 GiB (100.00%)
  ID-4: /var/log raw-size: 681.22 GiB size: 681.22 GiB (100.00%)
  System Temperatures: cpu: 40.5 C mobo: N/A gpu: amdgpu temp: 34.0 C
  Processes: 396 Uptime: 2m wakeups: 0 Memory: 30.51 GiB used: 3.52 GiB (11.5%)
  Init: systemd v: 252 default: graphical tool: systemctl Compilers:
  gcc: 12.2.1 clang: 15.0.7 Packages: 1306 pm: pacman pkgs: 1268 libs: 323
  tools: gnome-software,pamac pm: flatpak pkgs: 38 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.25
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14d8
	Subsystem: Advanced Micro Devices, Inc. [AMD] Device 14d8
	Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Device 14d9
	Subsystem: Gigabyte Technology Co., Ltd Device d000
	Flags: bus master, fast devsel, latency 0, IRQ 26
	Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
	Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14db (prog-if 00 [Normal decode])
	Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1453
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 1
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: f000-ffff [size=4K] [16-bit]
	Memory behind bridge: fb000000-fc0fffff [size=17M] [32-bit]
	Prefetchable memory behind bridge: fcc0000000-fcd1ffffff [size=288M] [32-bit]
	Kernel driver in use: pcieport
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
	Flags: fast devsel, IOMMU group 2
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14db (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 3
	Bus: primary=00, secondary=02, subordinate=0a, sec-latency=0
	I/O behind bridge: [disabled] [32-bit]
	Memory behind bridge: fc600000-fc8fffff [size=3M] [32-bit]
	Prefetchable memory behind bridge: [disabled] [64-bit]
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14db (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 4
	Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
	Memory behind bridge: fca00000-fcafffff [size=1M] [32-bit]
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
	Flags: fast devsel, IOMMU group 5
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
	Flags: fast devsel, IOMMU group 6
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
	Flags: fast devsel, IOMMU group 7
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14dd (prog-if 00 [Normal decode])
	Subsystem: Advanced Micro Devices, Inc. [AMD] Device 14dd
	Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 8
	Bus: primary=00, secondary=0c, subordinate=0c, sec-latency=0
	I/O behind bridge: e000-efff [size=4K] [16-bit]
	Memory behind bridge: fc200000-fc5fffff [size=4M] [32-bit]
	Prefetchable memory behind bridge: fce0000000-fcf01fffff [size=258M] [32-bit]
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14dd (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 9
	Bus: primary=00, secondary=0d, subordinate=0d, sec-latency=0
	Memory behind bridge: fc900000-fc9fffff [size=1M] [32-bit]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
	Subsystem: Gigabyte Technology Co., Ltd Device 5001
	Flags: 66MHz, medium devsel, IOMMU group 10
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
	Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 10
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e0
	Flags: fast devsel, IOMMU group 11
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e3
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e7
01:00.0 VGA compatible controller: NVIDIA Corporation AD103 [GeForce RTX 4080] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: Gigabyte Technology Co., Ltd Device 40bc
	Flags: fast devsel, IRQ 255, IOMMU group 12
	Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
	Memory at fcc0000000 (64-bit, prefetchable) [size=256M]
	Memory at fcd0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at f000 [size=128]
	Expansion ROM at fc000000 [disabled] [size=512K]
	Kernel driver in use: vfio-pci
	Kernel modules: nouveau
01:00.1 Audio device: NVIDIA Corporation Device 22bb (rev a1)
	Memory at fc080000 (32-bit, non-prefetchable) [disabled] [size=16K]
	Kernel modules: snd_hda_intel
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f4 (rev 01) (prog-if 00 [Normal decode])
	Subsystem: ASMedia Technology Inc. Device 3328
	Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 13
	Bus: primary=02, secondary=03, subordinate=0a, sec-latency=0
03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01) (prog-if 00 [Normal decode])
	Subsystem: Device 3328:3328
	Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 14
	Bus: primary=03, secondary=04, subordinate=04, sec-latency=0
	Memory behind bridge: fc800000-fc8fffff [size=1M] [32-bit]
03:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 15
	Bus: primary=03, secondary=05, subordinate=05, sec-latency=0
	Memory behind bridge: [disabled] [32-bit]
03:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 16
	Bus: primary=03, secondary=06, subordinate=06, sec-latency=0
03:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 17
	Bus: primary=03, secondary=07, subordinate=07, sec-latency=0
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 18
	Bus: primary=03, secondary=08, subordinate=08, sec-latency=0
03:0c.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 19
	Bus: primary=03, secondary=09, subordinate=09, sec-latency=0
	I/O behind bridge: [disabled] [16-bit]
	Memory behind bridge: fc700000-fc7fffff [size=1M] [32-bit]
03:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 20
	Bus: primary=03, secondary=0a, subordinate=0a, sec-latency=0
	Memory behind bridge: fc600000-fc6fffff [size=1M] [32-bit]
04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961/SM963 (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd SM963 2.5" NVMe PCIe SSD
	Flags: bus master, fast devsel, latency 0, IRQ 255, IOMMU group 14
	Memory at fc800000 (64-bit, non-prefetchable) [size=16K]
	Kernel modules: nvme
09:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43f7 (rev 01) (prog-if 30 [XHCI])
	Subsystem: ASMedia Technology Inc. Device 1142
	Memory at fc700000 (64-bit, non-prefetchable) [size=32K]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
0a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43f6 (rev 01) (prog-if 01 [AHCI 1.0])
	Subsystem: ASMedia Technology Inc. Device 1062
	Flags: bus master, fast devsel, latency 0, IRQ 39, IOMMU group 20
	Memory at fc680000 (32-bit, non-prefetchable) [size=1K]
	Expansion ROM at fc600000 [disabled] [size=512K]
	Kernel driver in use: ahci
0b:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a80c (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd Device a801
	Flags: bus master, fast devsel, latency 0, IRQ 24, NUMA node 0, IOMMU group 21
	Memory at fca00000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: nvme
0c:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Raphael (rev c5) (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 22
	Memory at fce0000000 (64-bit, prefetchable) [size=256M]
	Memory at fcf0000000 (64-bit, prefetchable) [size=2M]
	I/O ports at e000 [size=256]
	Memory at fc500000 (32-bit, non-prefetchable) [size=512K]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
0c:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt Radeon High Definition Audio Controller
	Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt Radeon High Definition Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 95, IOMMU group 23
	Memory at fc588000 (32-bit, non-prefetchable) [size=16K]
	Kernel driver in use: snd_hda_intel
0c:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] VanGogh PSP/CCP
	Subsystem: Advanced Micro Devices, Inc. [AMD] VanGogh PSP/CCP
	Flags: bus master, fast devsel, latency 0, IRQ 91, IOMMU group 24
	Memory at fc400000 (32-bit, non-prefetchable) [size=1M]
	Memory at fc58c000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: ccp
	Kernel modules: ccp
0c:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b6 (prog-if 30 [XHCI])
	Subsystem: Gigabyte Technology Co., Ltd Device 5007
	Flags: bus master, fast devsel, latency 0, IRQ 49, IOMMU group 25
	Memory at fc300000 (64-bit, non-prefetchable) [size=1M]
0c:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b7 (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 26
	Memory at fc200000 (64-bit, non-prefetchable) [size=1M]
0c:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
	DeviceName: Realtek ALC1220
	Subsystem: Gigabyte Technology Co., Ltd Device a0d2
	Flags: bus master, fast devsel, latency 0, IRQ 96, IOMMU group 27
	Memory at fc580000 (32-bit, non-prefetchable) [size=32K]
0d:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b8 (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 28
	Memory at fc900000 (64-bit, non-prefetchable) [size=1M]
To me it looks like this:
  • this is not taken from an Ubuntu live ISO boot
  • the file system is BTRFS - and everything is (essentially) completely full - no space left
    not good
  • IF-ID-2: virbr0 state: down mac …
    also does not look like a live system booted from an Ubuntu ISO
But if this is not the machine that has got the problems
the inxi output is … useless - to diagnosing the actual affected system
Please clarify what you provided here.
i thought i should go into manjaro and do your command (which is what i did.) than copied the result to a usb and posted it here.
As i wrote i now try to get into a live ubuntu to check if my hardware is broken.
If my English is bad i am sorry.
So:
this inxi was from the actual system - not from Ubuntu live ISO
still:
the issue seems to be that all the filesystems seem to be 100% filled up
which could very well be the source of the issue
I do not know how to deal with BTRFS - I have never used it.
It’s quite different to “normal” filesystems - different tools and procedures to deal with issues, too.
Someone else might know - I surely don’t.
yes
and if i understand the outpot correctly even there all network devices from my motherboard which where present today morning are missing now :frowning: no pcie ehternet and not pcie wlan. even the pcie network card which i use for my vm is missing :frowning:
the filesystem has over 444gb free space according to disk usage analyzer
… not according to your inxi output, though
BTRFS is a different animal - different tools, different procedures …
I do not know either way - I simply do not know the first thing about managing BTRFS. :man_shrugging:
@andreas85 seems to be very knowledgeable on this …
i dont get where you see anything “full”
not even 40% are used from system drive even according to the output i posted here
also i dont get how a full usb or non system disk should cause missing pcie network devices …
right
misinterpretation on my part
sorry!
Let’s see then whether the network devices show up when booted from the Ubuntu iso
There only seems to be this one:
Kernel 6.2 is a release candidate and most likely might not have all modules available, maybe try a long term release kernel like 6.1 or 5.15.
installing this kernel was a last resort i tired after i had the problem.
at today morning i had 6.1.12 LTS
5.15 does not even support X670E / AM5 as far as i know :confused:
EDIT: i know got a Fedora live USB up and running (ubuntu did not work and i atm dont have a nerve to troubleshoot) but at least fedora can see and use my PCIe Network devices… so there is hope that the hardware is not bricked and it is a software problem (which calms me down a little).
but it still would be nice if it would be fixable… (and ofc wont have happend on a stable update)
i dont even have anything special.
Network from Motherboard with a vpn and a pcie addincard for my windows vm which is bridged.
no fancy bonding no vlan or anything unusual
We are currently updating networkmanager as 1.42.0 had some regressions …
that sounds like a possible culprit.
is there a rough eta on for the fix?
i can get another usb to network adapter from work and hope a system upgrade would fix the problem
Having a better look at your device USB3 devices sometimes have issues working on a USB3 port, did you try to connect it on a USB2 port?
the usb device is just a workaround. (which did work)
i need the pcie network devices to work :wink:
Can you paste the output of those commands bellow, the output above only has your usb adapter.
lspci | grep “Network”
sudo lshw -class network
it is empty the system does not see the devices any longer :frowning:
as soon as i use a new device it works until used. When used + restart it the whole pcie devices seems to disappear o.o
i read in the archforums that you can delete some config files.
I now have a old network card in and syncing my backups.
After that ill try deleting the config files in hope that the regeneration on restart will fix my problems
(if not i am really running out of network devices -.-)
You can try commands bellow, if you get nothing, make sure your device is visible in the bios, if is not then its not well connected or is a hardware issue.
lspci -v | grep Network
sudo dmesg | grep “failed to load”
sudo dmesg | grep “error”
Can you try without your PCI-Passthrough setup?
Most likely your devices are being used for passthrough and thus unavailable to your host system…
