Here is the output of dmesg | less command:
[ 0.000000] microcode: microcode updated early to revision 0x21, date = 2019-02-13
[ 0.000000] Linux version 5.7.19-2-MANJARO (builduser@LEGION) (gcc version 10.2.0 (GCC), GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Fri Aug 28 20:22:12 UTC 2020
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=cb49953e-eae1-4982-9570-d02268d3470e rw
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d3ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d400-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040005000-0x000000008ffaffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008ffb0000-0x00000000913affff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000913b0000-0x000000009a3befff] usable
[ 0.000000] BIOS-e820: [mem 0x000000009a3bf000-0x000000009aebefff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000009aebf000-0x000000009afbefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000009afbf000-0x000000009affefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000009afff000-0x000000009affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000009b000000-0x000000009f9fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb00000-0x00000000feb03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffb80000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000015f5fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Dell Inc. Inspiron 3521/06X37M, BIOS A05 01/03/2013
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 1795.719 MHz processor
[ 0.002891] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.002894] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.002905] last_pfn = 0x15f600 max_arch_pfn = 0x400000000
[ 0.002911] MTRR default type: uncachable
[ 0.002912] MTRR fixed ranges enabled:
[ 0.002914] 00000-9FFFF write-back
[ 0.002915] A0000-BFFFF uncachable
[ 0.002916] C0000-E7FFF write-protect
[ 0.002917] E8000-EFFFF write-combining
[ 0.002918] F0000-FFFFF write-protect
[ 0.002919] MTRR variable ranges enabled:
[ 0.002921] 0 base 000000000 mask F80000000 write-back
[ 0.002923] 1 base 080000000 mask FE0000000 write-back
[ 0.002924] 2 base 09B000000 mask FFF000000 uncachable
[ 0.002925] 3 base 09C000000 mask FFC000000 uncachable
[ 0.002927] 4 base 0FFA00000 mask FFFE00000 write-protect
[ 0.002928] 5 base 0FFC00000 mask FFFC00000 write-protect
[ 0.002929] 6 base 100000000 mask F80000000 write-back
[ 0.002930] 7 base 15F600000 mask FFFE00000 uncachable
[ 0.002931] 8 base 15F800000 mask FFF800000 uncachable
[ 0.002933] 9 base 160000000 mask FE0000000 uncachable
[ 0.003276] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.003465] last_pfn = 0x9b000 max_arch_pfn = 0x400000000
[ 0.019149] found SMP MP-table at [mem 0x000fe1b0-0x000fe1bf]
[ 0.019533] check: Scanning 1 areas for low memory corruption
[ 0.020520] RAMDISK: [mem 0x367b5000-0x373d1fff]
[ 0.020528] ACPI: Early table checksum verification disabled
[ 0.020532] ACPI: RSDP 0x00000000000FE020 000024 (v02 DELL )
[ 0.020537] ACPI: XSDT 0x000000009AFFE210 00009C (v01 DELL CL09 00000001 01000013)
[ 0.020545] ACPI: FACP 0x000000009AFFB000 00010C (v05 DELL CL09 00000001 ASL 00040000)
[ 0.020554] ACPI: DSDT 0x000000009AFEE000 0092F2 (v01 DELL CL09 00000000 ASL 00040000)
[ 0.020558] ACPI: FACS 0x000000009AFB9000 000040
[ 0.020562] ACPI: UEFI 0x000000009AFFD000 000236 (v01 DELL CL09 00000001 ASL 00040000)
[ 0.020567] ACPI: ASF! 0x000000009AFFC000 0000A5 (v32 DELL CL09 00000001 ASL 00040000)
[ 0.020571] ACPI: HPET 0x000000009AFFA000 000038 (v01 DELL CL09 00000001 ASL 00040000)
[ 0.020575] ACPI: APIC 0x000000009AFF9000 00008C (v03 DELL CL09 00000001 ASL 00040000)
[ 0.020579] ACPI: MCFG 0x000000009AFF8000 00003C (v01 DELL CL09 00000001 ASL 00040000)
[ 0.020584] ACPI: SSDT 0x000000009AFED000 0006FE (v01 COMPAL CRV ORB 00001000 ACPI 00040000)
[ 0.020588] ACPI: BOOT 0x000000009AFEB000 000028 (v01 DELL CL09 00000001 ASL 00040000)
[ 0.020592] ACPI: ASPT 0x000000009AFE9000 000034 (v07 DELL CL09 00000001 ASL 00040000)
[ 0.020596] ACPI: DBGP 0x000000009AFE8000 000034 (v01 DELL CL09 00000001 ASL 00040000)
[ 0.020601] ACPI: FPDT 0x000000009AFE6000 000044 (v01 DELL CL09 00000001 ASL 00040000)
[ 0.020605] ACPI: SSDT 0x000000009AFE5000 0008E4 (v01 COMPAL CRV ORB 00003000 ACPI 00040000)
[ 0.020609] ACPI: SSDT 0x000000009AFE4000 000A92 (v01 COMPAL CRV ORB 00003000 ACPI 00040000)
[ 0.020613] ACPI: DMAR 0x000000009AFE3000 0000B8 (v01 DELL CL09 00000001 ASL 00040000)
[ 0.020618] ACPI: SSDT 0x000000009AFE1000 001EED (v01 COMPAL CRV ORB 00001000 ACPI 00040000)
[ 0.020631] ACPI: Local APIC address 0xfee00000
[ 0.020683] No NUMA configuration found
[ 0.020684] Faking a node at [mem 0x0000000000000000-0x000000015f5fffff]
[ 0.020689] NODE_DATA(0) allocated [mem 0x15f5fb000-0x15f5fefff]
[ 0.020723] Zone ranges:
[ 0.020724] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.020726] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.020727] Normal [mem 0x0000000100000000-0x000000015f5fffff]
[ 0.020728] Device empty
[ 0.020729] Movable zone start for each node
[ 0.020730] Early memory node ranges
[ 0.020731] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.020733] node 0: [mem 0x0000000000100000-0x000000001fffffff]
[ 0.020734] node 0: [mem 0x0000000020200000-0x0000000040003fff]
[ 0.020735] node 0: [mem 0x0000000040005000-0x000000008ffaffff]
[ 0.020736] node 0: [mem 0x00000000913b0000-0x000000009a3befff]
[ 0.020737] node 0: [mem 0x000000009afff000-0x000000009affffff]
[ 0.020738] node 0: [mem 0x0000000100000000-0x000000015f5fffff]
[ 0.021179] Zeroed struct page in unavailable ranges: 31909 pages
[ 0.021181] Initmem setup node 0 [mem 0x0000000000001000-0x000000015f5fffff]
[ 0.021183] On node 0 totalpages: 1016667
[ 0.021184] DMA zone: 64 pages used for memmap
[ 0.021185] DMA zone: 21 pages reserved
[ 0.021187] DMA zone: 3996 pages, LIFO batch:0
[ 0.021288] DMA32 zone: 9719 pages used for memmap
[ 0.021290] DMA32 zone: 622015 pages, LIFO batch:63
[ 0.037217] Normal zone: 6104 pages used for memmap
[ 0.037219] Normal zone: 390656 pages, LIFO batch:63
[ 0.046519] Reserving Intel graphics memory at [mem 0x9ba00000-0x9f9fffff]
[ 0.046710] ACPI: PM-Timer IO Port: 0x408
[ 0.046712] ACPI: Local APIC address 0xfee00000
[ 0.046734] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[ 0.046737] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.046739] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.046741] ACPI: IRQ0 used by override.
[ 0.046743] ACPI: IRQ9 used by override.
[ 0.046746] Using ACPI (MADT) for SMP configuration information
[ 0.046748] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.046753] TSC deadline timer available
[ 0.046755] smpboot: Allowing 8 CPUs, 4 hotplug CPUs
[ 0.046785] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.046788] PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.046789] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.046790] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.046790] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.046793] PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
[ 0.046795] PM: hibernation: Registered nosave memory: [mem 0x40004000-0x40004fff]
[ 0.046797] PM: hibernation: Registered nosave memory: [mem 0x8ffb0000-0x913affff]
[ 0.046799] PM: hibernation: Registered nosave memory: [mem 0x9a3bf000-0x9aebefff]
[ 0.046800] PM: hibernation: Registered nosave memory: [mem 0x9aebf000-0x9afbefff]
[ 0.046801] PM: hibernation: Registered nosave memory: [mem 0x9afbf000-0x9affefff]
[ 0.046804] PM: hibernation: Registered nosave memory: [mem 0x9b000000-0x9f9fffff]
[ 0.046804] PM: hibernation: Registered nosave memory: [mem 0x9fa00000-0xdfffffff]
[ 0.046805] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.046806] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfeafffff]
[ 0.046807] PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfeb03fff]
[ 0.046808] PM: hibernation: Registered nosave memory: [mem 0xfeb04000-0xfebfffff]
[ 0.046809] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.046810] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
[ 0.046811] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[ 0.046811] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
[ 0.046812] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.046813] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.046814] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.046815] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffb7ffff]
[ 0.046816] PM: hibernation: Registered nosave memory: [mem 0xffb80000-0xffffffff]
[ 0.046818] [mem 0x9fa00000-0xdfffffff] available for PCI devices
[ 0.046820] Booting paravirtualized kernel on bare hardware
[ 0.046824] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.053603] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ 0.054005] percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u262144
[ 0.054015] pcpu-alloc: s196608 r8192 d28672 u262144 alloc=1*2097152
[ 0.054017] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.054049] Built 1 zonelists, mobility grouping on. Total pages: 1000759
[ 0.054050] Policy zone: Normal
[ 0.054052] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=cb49953e-eae1-4982-9570-d02268d3470e rw
[ 0.054446] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.054631] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.054777] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[ 0.077138] Memory: 3883912K/4066668K available (12291K kernel code, 1463K rwdata, 4596K rodata, 1632K init, 3108K bss, 182756K reserved, 0K cma-reserved)
[ 0.077147] random: get_random_u64 called from __kmem_cache_create+0x3e/0x600 with crng_init=0
[ 0.077338] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.077356] Kernel/User page tables isolation: enabled
[ 0.077379] ftrace: allocating 39785 entries in 156 pages
[ 0.099219] ftrace: allocated 156 pages with 4 groups
[ 0.099372] rcu: Preemptible hierarchical RCU implementation.
[ 0.099372] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.099374] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.099375] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.099376] Tasks RCU enabled.
[ 0.099377] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.099378] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.104419] NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
[ 0.104700] Console: colour dummy device 80x25
[ 0.104705] printk: console [tty0] enabled
[ 0.104729] ACPI: Core revision 20200326
[ 0.104929] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.104946] APIC: Switch to symmetric I/O mode setup
[ 0.104948] DMAR: Host address width 36
[ 0.104950] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.104957] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020e60262 ecap f0101a
[ 0.104958] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.104962] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap c9008020660262 ecap f0105a
[ 0.104963] DMAR: RMRR base: 0x0000009ae8c000 end: 0x0000009aeabfff
[ 0.104964] DMAR: RMRR base: 0x0000009b800000 end: 0x0000009f9fffff
[ 0.104967] DMAR-IR: IOAPIC id 0 under DRHD base 0xfed91000 IOMMU 1
[ 0.104968] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.104969] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.105579] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.105581] x2apic enabled
[ 0.105588] Switched APIC routing to cluster x2apic.
[ 0.106064] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.121617] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x19e25d84377, max_idle_ns: 440795255614 ns
[ 0.121622] Calibrating delay loop (skipped), value calculated using timer frequency.. 3592.08 BogoMIPS (lpj=5985730)
[ 0.121625] pid_max: default: 32768 minimum: 301
[ 0.121667] LSM: Security Framework initializing
[ 0.121673] Yama: becoming mindful.
[ 0.121710] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.121722] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.122098] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.122113] process: using mwait in idle threads
[ 0.122116] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 0.122117] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.122121] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.122123] Spectre V2 : Mitigation: Full generic retpoline
[ 0.122123] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.122124] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.122126] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.122127] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.122129] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.122131] SRBDS: Vulnerable: No microcode
[ 0.122132] MDS: Mitigation: Clear CPU buffers
[ 0.122471] Freeing SMP alternatives memory: 32K
[ 0.125066] smpboot: CPU0: Intel(R) Core(TM) i5-3337U CPU @ 1.80GHz (family: 0x6, model: 0x3a, stepping: 0x9)
[ 0.125228] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.125237] ... version: 3
[ 0.125238] ... bit width: 48
[ 0.125238] ... generic registers: 4
[ 0.125240] ... value mask: 0000ffffffffffff
[ 0.125240] ... max period: 00007fffffffffff
[ 0.125241] ... fixed-purpose events: 3
[ 0.125242] ... event mask: 000000070000000f
[ 0.125303] rcu: Hierarchical SRCU implementation.
[ 0.126501] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.126627] smp: Bringing up secondary CPUs ...
[ 0.126816] x86: Booting SMP configuration:
[ 0.126818] .... node #0, CPUs: #1
[ 0.128440] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.128543] #2 #3
[ 0.134239] smp: Brought up 1 node, 4 CPUs
[ 0.134239] smpboot: Max logical packages: 2
[ 0.134239] smpboot: Total of 4 processors activated (14371.32 BogoMIPS)
[ 0.135194] devtmpfs: initialized
[ 0.135194] x86/mm: Memory block size: 128MB
[ 0.135612] PM: Registering ACPI NVS region [mem 0x9aebf000-0x9afbefff] (1048576 bytes)
[ 0.135612] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.135612] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.135612] pinctrl core: initialized pinctrl subsystem
[ 0.135612] PM: RTC time: 11:35:41, date: 2020-09-23
[ 0.135612] thermal_sys: Registered thermal governor 'fair_share'
[ 0.135612] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.135612] thermal_sys: Registered thermal governor 'step_wise'
[ 0.135612] thermal_sys: Registered thermal governor 'user_space'
[ 0.135612] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.135612] NET: Registered protocol family 16
[ 0.135612] audit: initializing netlink subsys (disabled)
[ 0.135612] audit: type=2000 audit(1600860941.029:1): state=initialized audit_enabled=0 res=1
[ 0.135612] cpuidle: using governor ladder
[ 0.135612] cpuidle: using governor menu
[ 0.135612] Simple Boot Flag at 0x44 set to 0x1
[ 0.135612] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.135612] ACPI: bus type PCI registered
[ 0.135612] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.135612] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.135612] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.135612] PCI: Using configuration type 1 for base access
[ 0.135612] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.135612] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.139489] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.139489] ipmi:dmi: Base address is zero, assuming no IPMI interface
[ 0.139489] fbcon: Taking over console
[ 0.139489] ACPI: Added _OSI(Module Device)
[ 0.139489] ACPI: Added _OSI(Processor Device)
[ 0.139489] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.139489] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.139489] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.139489] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.139489] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.154225] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.157284] ACPI: Dynamic OEM Table Load:
[ 0.157296] ACPI: SSDT 0xFFFF93575A3C2000 00083B (v01 PmRef Cpu0Cst 00003001 INTL 20111123)
[ 0.158818] ACPI: Dynamic OEM Table Load:
[ 0.158826] ACPI: SSDT 0xFFFF93575A3CD400 000303 (v01 PmRef ApIst 00003000 INTL 20111123)
[ 0.160000] ACPI: Dynamic OEM Table Load:
[ 0.160006] ACPI: SSDT 0xFFFF935759EFE800 000119 (v01 PmRef ApCst 00003000 INTL 20111123)
[ 0.162573] ACPI: EC: EC started
[ 0.162574] ACPI: EC: interrupt blocked
[ 0.162783] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.162786] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[ 0.162786] ACPI: Interpreter enabled
[ 0.162823] ACPI: (supports S0 S3 S4 S5)
[ 0.162825] ACPI: Using IOAPIC for interrupt routing
[ 0.162867] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.163397] ACPI: Enabled 9 GPEs in block 00 to 3F
[ 0.174238] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.174247] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.174533] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ 0.175491] PCI host bridge to bus 0000:00
[ 0.175495] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.175497] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.175498] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.175500] pci_bus 0000:00: root bus resource [mem 0x9fa00000-0xfeafffff window]
[ 0.175502] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.175516] pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
[ 0.175651] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[ 0.175708] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.175849] pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
[ 0.175864] pci 0000:00:02.0: reg 0x10: [mem 0xc1000000-0xc13fffff 64bit]
[ 0.175872] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[ 0.175877] pci 0000:00:02.0: reg 0x20: [io 0x4000-0x403f]
[ 0.176121] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[ 0.176152] pci 0000:00:14.0: reg 0x10: [mem 0xc1600000-0xc160ffff 64bit]
[ 0.176236] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.176381] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[ 0.176411] pci 0000:00:16.0: reg 0x10: [mem 0xc1614000-0xc161400f 64bit]
[ 0.176500] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.176632] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[ 0.176660] pci 0000:00:1a.0: reg 0x10: [mem 0xc1619000-0xc16193ff]
[ 0.176762] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.176898] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[ 0.176924] pci 0000:00:1b.0: reg 0x10: [mem 0xc1610000-0xc1613fff 64bit]
[ 0.177021] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.177153] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[ 0.177273] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.177416] pci 0000:00:1c.1: [8086:1e12] type 01 class 0x060400
[ 0.177530] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.177682] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.177710] pci 0000:00:1d.0: reg 0x10: [mem 0xc1618000-0xc16183ff]
[ 0.177808] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.177938] pci 0000:00:1f.0: [8086:1e59] type 00 class 0x060100
[ 0.178179] pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
[ 0.178203] pci 0000:00:1f.2: reg 0x10: [io 0x4088-0x408f]
[ 0.178212] pci 0000:00:1f.2: reg 0x14: [io 0x4094-0x4097]
[ 0.178221] pci 0000:00:1f.2: reg 0x18: [io 0x4080-0x4087]
[ 0.178231] pci 0000:00:1f.2: reg 0x1c: [io 0x4090-0x4093]
[ 0.178240] pci 0000:00:1f.2: reg 0x20: [io 0x4060-0x407f]
[ 0.178249] pci 0000:00:1f.2: reg 0x24: [mem 0xc1617000-0xc16177ff]
[ 0.178304] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.178435] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[ 0.178460] pci 0000:00:1f.3: reg 0x10: [mem 0xc1615000-0xc16150ff 64bit]
[ 0.178485] pci 0000:00:1f.3: reg 0x20: [io 0x4040-0x405f]
[ 0.178716] pci 0000:01:00.0: [1002:6601] type 00 class 0x030000
[ 0.178734] pci 0000:01:00.0: reg 0x10: [mem 0xa0000000-0xafffffff 64bit pref]
[ 0.178741] pci 0000:01:00.0: reg 0x18: [mem 0xc0000000-0xc003ffff 64bit]
[ 0.178747] pci 0000:01:00.0: reg 0x20: [io 0x3000-0x30ff]
[ 0.178756] pci 0000:01:00.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
[ 0.178761] pci 0000:01:00.0: enabling Extended Tags
[ 0.178805] pci 0000:01:00.0: supports D1 D2
[ 0.178806] pci 0000:01:00.0: PME# supported from D1 D2 D3hot
[ 0.178830] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
[ 0.179051] pci 0000:00:01.0: PCI bridge to [bus 01-06]
[ 0.179055] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.179057] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xc0ffffff]
[ 0.179061] pci 0000:00:01.0: bridge window [mem 0xa0000000-0xafffffff 64bit pref]
[ 0.179210] pci 0000:07:00.0: [10ec:8136] type 00 class 0x020000
[ 0.179342] pci 0000:07:00.0: reg 0x10: [io 0x2000-0x20ff]
[ 0.179468] pci 0000:07:00.0: reg 0x18: [mem 0xc1404000-0xc1404fff 64bit pref]
[ 0.179545] pci 0000:07:00.0: reg 0x20: [mem 0xc1400000-0xc1403fff 64bit pref]
[ 0.179996] pci 0000:07:00.0: supports D1 D2
[ 0.179998] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.180466] pci 0000:00:1c.0: PCI bridge to [bus 07]
[ 0.180470] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.180479] pci 0000:00:1c.0: bridge window [mem 0xc1400000-0xc14fffff 64bit pref]
[ 0.180608] pci 0000:08:00.0: [14e4:4365] type 00 class 0x028000
[ 0.180690] pci 0000:08:00.0: reg 0x10: [mem 0xc1500000-0xc1507fff 64bit]
[ 0.180834] pci 0000:08:00.0: enabling Extended Tags
[ 0.181028] pci 0000:08:00.0: supports D1 D2
[ 0.181030] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold
[ 0.181304] pci 0000:00:1c.1: PCI bridge to [bus 08]
[ 0.181311] pci 0000:00:1c.1: bridge window [mem 0xc1500000-0xc15fffff]
[ 0.262231] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 10 11 12 14 15) *7
[ 0.262346] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 10 *11 12 14 15)
[ 0.262458] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.262569] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 *10 11 12 14 15)
[ 0.262678] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.262788] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 10 11 12 14 15) *7
[ 0.262898] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 *10 11 12 14 15)
[ 0.263009] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 10 *11 12 14 15)
[ 0.263295] ACPI: EC: interrupt unblocked
[ 0.263296] ACPI: EC: event unblocked
[ 0.263302] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.263303] ACPI: EC: GPE=0x17
[ 0.263306] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[ 0.263307] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[ 0.263399] iommu: Default domain type: Translated
[ 0.263420] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.263420] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.263420] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.263420] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 0.263420] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.263420] vgaarb: loaded
[ 0.263420] SCSI subsystem initialized
[ 0.263420] libata version 3.00 loaded.
[ 0.263420] ACPI: bus type USB registered
[ 0.263420] usbcore: registered new interface driver usbfs
[ 0.263420] usbcore: registered new interface driver hub
[ 0.263420] usbcore: registered new device driver usb
[ 0.263420] pps_core: LinuxPPS API ver. 1 registered
[ 0.263420] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.263420] PTP clock support registered
[ 0.263420] EDAC MC: Ver: 3.0.0
[ 0.263420] PCI: Using ACPI for IRQ routing
[ 0.271751] PCI: pci_cache_line_size set to 64 bytes
[ 0.271835] e820: reserve RAM buffer [mem 0x0009d400-0x0009ffff]
[ 0.271836] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
[ 0.271838] e820: reserve RAM buffer [mem 0x8ffb0000-0x8fffffff]
[ 0.271839] e820: reserve RAM buffer [mem 0x9a3bf000-0x9bffffff]
[ 0.271840] e820: reserve RAM buffer [mem 0x9b000000-0x9bffffff]
[ 0.271842] e820: reserve RAM buffer [mem 0x15f600000-0x15fffffff]
[ 0.271991] NetLabel: Initializing
[ 0.271993] NetLabel: domain hash size = 128
[ 0.271993] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.272012] NetLabel: unlabeled traffic allowed by default
[ 0.272506] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.272512] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.274996] clocksource: Switched to clocksource tsc-early
[ 0.292928] VFS: Disk quotas dquot_6.6.0
[ 0.292950] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.293043] pnp: PnP ACPI init
[ 0.293250] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.293253] system 00:00: [io 0x1000-0x100f] has been reserved
[ 0.293255] system 00:00: [io 0xffff] has been reserved
[ 0.293257] system 00:00: [io 0xffff] has been reserved
[ 0.293259] system 00:00: [io 0x0400-0x0453] has been reserved
[ 0.293260] system 00:00: [io 0x0458-0x047f] has been reserved
[ 0.293262] system 00:00: [io 0x0500-0x057f] has been reserved
[ 0.293264] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.293266] system 00:00: [io 0xfd60-0xfd63] has been reserved
[ 0.293274] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.293311] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.293392] system 00:02: [io 0x0454-0x0457] has been reserved
[ 0.293398] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.293446] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.293486] pnp 00:04: Plug and Play ACPI device, IDs DLL05b8 PNP0f13 (active)
[ 0.371905] system 00:05: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.371907] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.371909] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.371911] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.371913] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.371915] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.371917] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.371919] system 00:05: [mem 0xff000000-0xff000fff] has been reserved
[ 0.371921] system 00:05: [mem 0xff010000-0xffffffff] could not be reserved
[ 0.371923] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.371925] system 00:05: [mem 0x9fa00000-0x9fa00fff] has been reserved
[ 0.371931] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.372572] system 00:06: [mem 0x20000000-0x201fffff] has been reserved
[ 0.372574] system 00:06: [mem 0x40004000-0x40004fff] has been reserved
[ 0.372579] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.372612] pnp: PnP ACPI: found 7 devices
[ 0.379055] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.379103] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: no compatible bridge window
[ 0.379116] pci 0000:01:00.0: BAR 6: assigned [mem 0xc0040000-0xc005ffff pref]
[ 0.379119] pci 0000:00:01.0: PCI bridge to [bus 01-06]
[ 0.379122] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.379126] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xc0ffffff]
[ 0.379129] pci 0000:00:01.0: bridge window [mem 0xa0000000-0xafffffff 64bit pref]
[ 0.379133] pci 0000:00:1c.0: PCI bridge to [bus 07]
[ 0.379136] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.379145] pci 0000:00:1c.0: bridge window [mem 0xc1400000-0xc14fffff 64bit pref]
[ 0.379153] pci 0000:00:1c.1: PCI bridge to [bus 08]
[ 0.379159] pci 0000:00:1c.1: bridge window [mem 0xc1500000-0xc15fffff]
[ 0.379170] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.379172] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.379174] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.379176] pci_bus 0000:00: resource 7 [mem 0x9fa00000-0xfeafffff window]
[ 0.379178] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.379179] pci_bus 0000:01: resource 1 [mem 0xc0000000-0xc0ffffff]
[ 0.379181] pci_bus 0000:01: resource 2 [mem 0xa0000000-0xafffffff 64bit pref]
[ 0.379183] pci_bus 0000:07: resource 0 [io 0x2000-0x2fff]
[ 0.379184] pci_bus 0000:07: resource 2 [mem 0xc1400000-0xc14fffff 64bit pref]
[ 0.379186] pci_bus 0000:08: resource 1 [mem 0xc1500000-0xc15fffff]
[ 0.379346] NET: Registered protocol family 2
[ 0.379551] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.379584] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.379693] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.379754] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.379874] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.379892] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.380001] NET: Registered protocol family 1
[ 0.380007] NET: Registered protocol family 44
[ 0.380024] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.398456] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x6d5 took 16469 usecs
[ 0.415115] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x6d5 took 16249 usecs
[ 0.415161] PCI: CLS 64 bytes, default 64
[ 0.415220] Trying to unpack rootfs image as initramfs...
[ 0.620988] Freeing initrd memory: 12404K
[ 0.645001] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.645003] software IO TLB: mapped [mem 0x963bf000-0x9a3bf000] (64MB)
[ 0.645162] check: Scanning for low memory corruption every 60 seconds
[ 0.645635] Initialise system trusted keyrings
[ 0.645646] Key type blacklist registered
[ 0.645709] workingset: timestamp_bits=41 max_order=20 bucket_order=0
[ 0.647494] zbud: loaded
[ 0.653694] Key type asymmetric registered
[ 0.653696] Asymmetric key parser 'x509' registered
[ 0.653707] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.653766] io scheduler mq-deadline registered
[ 0.653768] io scheduler kyber registered
[ 0.653801] io scheduler bfq registered
[ 0.654763] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.654858] vesafb: mode is 1366x768x32, linelength=5504, pages=0
[ 0.654859] vesafb: scrolling: redraw
[ 0.654861] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.654877] vesafb: framebuffer at 0xb0000000, mapped to 0x0000000076a9538a, using 4160k, total 4160k
[ 0.655062] Console: switching to colour frame buffer device 170x48
[ 0.750397] fb0: VESA VGA frame buffer device
[ 0.750419] intel_idle: MWAIT substates: 0x21120
[ 0.750421] intel_idle: v0.5.1 model 0x3A
[ 0.750697] intel_idle: Local APIC timer is reliable in all C-states
[ 0.750768] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input0
[ 0.750798] ACPI: Power Button [PWRB]
[ 0.750866] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.751668] ACPI: Lid Switch [LID0]
[ 0.751725] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.751941] ACPI: Power Button [PWRF]
[ 0.753082] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.754193] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.754194] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.754990] ahci 0000:00:1f.2: version 3.0
[ 0.768404] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
[ 0.768409] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 0.779423] scsi host0: ahci
[ 0.779908] scsi host1: ahci
[ 0.780331] scsi host2: ahci
[ 0.780593] scsi host3: ahci
[ 0.780746] scsi host4: ahci
[ 0.780867] scsi host5: ahci
[ 0.780922] ata1: SATA max UDMA/133 abar m2048@0xc1617000 port 0xc1617100 irq 29
[ 0.780923] ata2: DUMMY
[ 0.780926] ata3: SATA max UDMA/133 abar m2048@0xc1617000 port 0xc1617200 irq 29
[ 0.780927] ata4: DUMMY
[ 0.780927] ata5: DUMMY
[ 0.780928] ata6: DUMMY
[ 0.781009] usbcore: registered new interface driver usbserial_generic
[ 0.781016] usbserial: USB Serial support registered for generic
[ 0.781054] rtc_cmos 00:01: RTC can wake from S4
[ 0.781331] rtc_cmos 00:01: registered as rtc0
[ 0.781364] rtc_cmos 00:01: setting system clock to 2020-09-23T11:35:42 UTC (1600860942)
[ 0.781389] rtc_cmos 00:01: alarms up to one month, 242 bytes nvram, hpet irqs
[ 0.781472] intel_pstate: Intel P-state driver initializing
[ 0.781758] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.781922] drop_monitor: Initializing network drop monitor service
[ 0.782421] NET: Registered protocol family 10
[ 0.794061] Segment Routing with IPv6
[ 0.794065] RPL Segment Routing with IPv6
[ 0.794133] NET: Registered protocol family 17
[ 0.794754] RAS: Correctable Errors collector initialized.
[ 0.794870] microcode: sig=0x306a9, pf=0x10, revision=0x21
[ 0.795049] microcode: Microcode Update Driver: v2.2.
[ 0.795053] IPI shorthand broadcast: enabled
[ 0.795074] sched_clock: Marking stable (794718482, 325208)->(811131922, -16088232)
[ 0.795258] registered taskstats version 1
[ 0.795282] Loading compiled-in X.509 certificates
[ 0.799679] Loaded X.509 cert 'Build time autogenerated kernel key: 441e7a2023411efa2b6a2888e7d70ee4cdac6d83'
[ 0.800610] zswap: loaded using pool zstd/z3fold
[ 0.801078] Key type ._fscrypt registered
[ 0.801082] Key type .fscrypt registered
[ 0.801084] Key type fscrypt-provisioning registered
[ 0.807194] Key type big_key registered
[ 0.807979] PM: Magic number: 4:941:580
[ 0.808028] pci_bus 0000:01: hash matches
[ 1.098399] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.098442] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.100322] ata3.00: ATAPI: HL-DT-ST DVD+/-RW GU70N, A103, max UDMA/100
[ 1.102532] ata3.00: configured for UDMA/100
[ 1.104718] ata1.00: LPM support broken, forcing max_power
[ 1.104792] ata1.00: ATA-8: ST1000LM024 HN-M101MBB, 2AR20004, max UDMA/133
[ 1.104797] ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 32)
[ 1.111144] ata1.00: LPM support broken, forcing max_power
[ 1.111222] ata1.00: configured for UDMA/133
[ 1.122068] scsi 0:0:0:0: Direct-Access ATA ST1000LM024 HN-M 0004 PQ: 0 ANSI: 5
[ 1.122949] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.123020] sd 0:0:0:0: [sda] Write Protect is off
[ 1.123027] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.123114] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.123832] scsi 2:0:0:0: CD-ROM HL-DT-ST DVD+-RW GU70N A103 PQ: 0 ANSI: 5
[ 1.175320] sda: sda1 sda2 sda3 sda4
[ 1.177246] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.180830] Freeing unused decrypted memory: 2040K
[ 1.181694] Freeing unused kernel image (initmem) memory: 1632K
[ 1.198480] Write protecting the kernel read-only data: 20480k
[ 1.200166] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 1.201125] Freeing unused kernel image (rodata/data gap) memory: 1548K
[ 1.261993] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.261995] x86/mm: Checking user space page tables
[ 1.312183] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.312185] Run /init as init process
[ 1.312187] with arguments:
[ 1.312188] /init
[ 1.312188] with environment:
[ 1.312189] HOME=/
[ 1.312189] TERM=linux
[ 1.312190] BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
[ 1.408220] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.431228] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.431312] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.431341] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.434123] ehci-pci: EHCI PCI platform driver
[ 1.434338] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 1.434346] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.434363] ehci-pci 0000:00:1a.0: debug port 2
[ 1.438275] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 1.438316] ehci-pci 0000:00:1a.0: irq 16, io mem 0xc1619000
[ 1.451743] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.451808] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 1.451810] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.451811] usb usb1: Product: EHCI Host Controller
[ 1.451812] usb usb1: Manufacturer: Linux 5.7.19-2-MANJARO ehci_hcd
[ 1.451813] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.451965] hub 1-0:1.0: USB hub found
[ 1.451978] hub 1-0:1.0: 2 ports detected
[ 1.452170] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.452178] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.453253] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x000000000000b930
[ 1.453262] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.453461] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 1.453463] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.453464] usb usb2: Product: xHCI Host Controller
[ 1.453465] usb usb2: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 1.453466] usb usb2: SerialNumber: 0000:00:14.0
[ 1.453624] hub 2-0:1.0: USB hub found
[ 1.453639] hub 2-0:1.0: 4 ports detected
[ 1.454414] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.454420] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.454425] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.454487] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[ 1.454490] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.454491] usb usb3: Product: xHCI Host Controller
[ 1.454493] usb usb3: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 1.454495] usb usb3: SerialNumber: 0000:00:14.0
[ 1.454644] hub 3-0:1.0: USB hub found
[ 1.454657] hub 3-0:1.0: 4 ports detected
[ 1.457750] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 1.457758] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 1.457772] ehci-pci 0000:00:1d.0: debug port 2
[ 1.461685] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 1.461703] ehci-pci 0000:00:1d.0: irq 23, io mem 0xc1618000
[ 1.467197] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.467201] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.474984] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.475096] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 1.475101] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.475104] usb usb4: Product: EHCI Host Controller
[ 1.475107] usb usb4: Manufacturer: Linux 5.7.19-2-MANJARO ehci_hcd
[ 1.475109] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.475324] hub 4-0:1.0: USB hub found
[ 1.475331] hub 4-0:1.0: 2 ports detected
[ 1.477825] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 1.478710] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 1.651655] tsc: Refined TSC clocksource calibration: 1795.919 MHz
[ 1.651674] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x19e31a4ce6b, max_idle_ns: 440795217410 ns
[ 1.651750] clocksource: Switched to clocksource tsc
[ 1.781672] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.804990] usb 4-1: new high-speed USB device number 2 using ehci-pci
[ 1.929099] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.929106] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.929872] hub 1-1:1.0: USB hub found
[ 1.930063] hub 1-1:1.0: 6 ports detected
[ 1.952047] usb 4-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.952053] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.952477] hub 4-1:1.0: USB hub found
[ 1.952648] hub 4-1:1.0: 6 ports detected
[ 2.211726] usb 1-1.1: new full-speed USB device number 3 using ehci-pci
[ 2.310005] random: fast init done
[ 2.312196] usb 1-1.1: New USB device found, idVendor=0a5c, idProduct=21d7, bcdDevice= 1.12
[ 2.312203] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.312207] usb 1-1.1: Product: BCM43142A0
[ 2.312211] usb 1-1.1: Manufacturer: Broadcom Corp
[ 2.312214] usb 1-1.1: SerialNumber: 9C2A70CE90EC
[ 2.384980] usb 1-1.3: new high-speed USB device number 4 using ehci-pci
[ 2.466355] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.482516] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[ 2.482522] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.482526] usb 1-1.3: Product: USB2.0-CRW
[ 2.482529] usb 1-1.3: Manufacturer: Generic
[ 2.482532] usb 1-1.3: SerialNumber: 20100201396000000
[ 2.555059] usb 1-1.4: new high-speed USB device number 5 using ehci-pci
[ 2.706998] usb 1-1.4: New USB device found, idVendor=064e, idProduct=812e, bcdDevice=27.09
[ 2.707005] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.707009] usb 1-1.4: Product: Laptop_Integrated_Webcam_HD
[ 2.707013] usb 1-1.4: Manufacturer: SuYin
[ 3.978727] random: crng init done
[ 4.160374] systemd[1]: systemd 246.4-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 4.175299] systemd[1]: Detected architecture x86-64.
[ 4.281177] systemd[1]: Set hostname to <bluestar-inspiron3521>.
[ 8.197580] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.198660] systemd[1]: Created slice system-getty.slice.
[ 8.199409] systemd[1]: Created slice system-modprobe.slice.
[ 8.200145] systemd[1]: Created slice User and Session Slice.
[ 8.200733] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 8.201496] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.202386] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.203258] systemd[1]: Reached target Local Encrypted Volumes.
[ 8.203803] systemd[1]: Reached target Login Prompts.
[ 8.204283] systemd[1]: Reached target Remote File Systems.
[ 8.204793] systemd[1]: Reached target Slices.
[ 8.205286] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 8.206208] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 8.206865] systemd[1]: Listening on LVM2 poll daemon socket.
[ 8.208887] systemd[1]: Listening on Process Core Dump Socket.
[ 8.209576] systemd[1]: Listening on Journal Audit Socket.
[ 8.210170] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.210810] systemd[1]: Listening on Journal Socket.
[ 8.211385] systemd[1]: Listening on udev Control Socket.
[ 8.211984] systemd[1]: Listening on udev Kernel Socket.
[ 8.213446] systemd[1]: Mounting Huge Pages File System...
[ 8.214918] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.216496] systemd[1]: Mounting Kernel Debug File System...
[ 8.217990] systemd[1]: Mounting Kernel Trace File System...
[ 8.218628] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[ 8.219651] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 8.221410] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 8.223410] systemd[1]: Starting Load Kernel Module drm...
[ 8.223958] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[ 8.327267] systemd[1]: Starting Set Up Additional Binary Formats...
[ 8.329299] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.462274] systemd[1]: Starting Load Kernel Modules...
[ 8.466475] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.468667] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 8.471587] systemd[1]: Starting Coldplug All udev Devices...
[ 8.473848] systemd[1]: Mounted Huge Pages File System.
[ 8.474460] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.475184] systemd[1]: Mounted Kernel Debug File System.
[ 8.475783] systemd[1]: Mounted Kernel Trace File System.
[ 8.477055] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 8.478134] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 239 (systemd-binfmt)
[ 8.479614] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 8.488215] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 8.495751] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 8.510255] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 8.524842] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 8.687051] Linux agpgart interface v0.103
[ 8.748072] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 8.749317] systemd[1]: Starting Load/Save Random Seed...
[ 8.765758] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 8.766816] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 8.782222] systemd[1]: Finished Set Up Additional Binary Formats.
[ 8.844133] systemd[1]: Finished Coldplug All udev Devices.
[ 8.924386] systemd[1]: modprobe@drm.service: Succeeded.
[ 8.925150] systemd[1]: Finished Load Kernel Module drm.
[ 8.946445] systemd[1]: Finished Load Kernel Modules.
[ 8.961021] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 8.961937] systemd[1]: Mounting Kernel Configuration File System...
[ 8.977690] systemd[1]: Starting Apply Kernel Variables...
[ 8.997469] systemd[1]: Mounted Kernel Configuration File System.
[ 9.241436] systemd[1]: Finished Load/Save Random Seed.
[ 9.289682] systemd[1]: Finished Apply Kernel Variables.
[ 9.382109] systemd[1]: Starting CLI Netfilter Manager...
[ 9.560042] systemd[1]: Finished CLI Netfilter Manager.
[ 9.647906] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 9.668409] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 9.684722] systemd[1]: Starting Journal Service...
[ 9.701290] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 10.194930] systemd[1]: Started Journal Service.
[ 10.214091] audit: type=1130 audit(1600860951.927:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.616670] audit: type=1130 audit(1600860955.330:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.640563] audit: type=1130 audit(1600860955.353:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.078554] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 14.347570] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[ 14.362074] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200326/utaddress-204)
[ 14.362082] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 14.362086] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20200326/utaddress-204)
[ 14.362091] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200326/utaddress-204)
[ 14.362095] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 14.362097] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20200326/utaddress-204)
[ 14.362101] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200326/utaddress-204)
[ 14.362105] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 14.362107] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20200326/utaddress-204)
[ 14.362111] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200326/utaddress-204)
[ 14.362115] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 14.362116] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 14.452348] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 14.696741] ACPI: AC Adapter [ACAD] (on-line)
[ 14.721788] battery: ACPI: Battery Slot [BAT1] (battery present)
[ 14.839163] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
[ 14.875150] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 14.878215] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 15.004182] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/PNP0C14:00-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input7
[ 15.095772] iTCO_vendor_support: vendor-support=0
[ 15.103190] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 15.103280] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[ 15.103507] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 15.105606] r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 15.112966] libphy: r8169: probed
[ 15.113456] r8169 0000:07:00.0 eth0: RTL8105e, 74:86:7a:10:96:8a, XID 40c, IRQ 32
[ 15.560409] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[ 15.560411] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 15.560412] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 15.560413] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[ 15.616013] psmouse serio1: synaptics: queried max coordinates: x [..5674], y [..4754]
[ 15.685020] psmouse serio1: synaptics: queried min coordinates: x [1268..], y [1098..]
[ 15.685032] psmouse serio1: synaptics: Your touchpad (PNP: DLL05b8 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 15.775355] cryptd: max_cpu_qlen set to 1000
[ 15.799486] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd00123/0x840300/0x26c00/0x0, board id: 2382, fw id: 1238635
[ 15.844550] checking generic (b0000000 410000) vs hw (c1000000 400000)
[ 15.844551] checking generic (b0000000 410000) vs hw (b0000000 10000000)
[ 15.844552] fb0: switching to inteldrmfb from VESA VGA
[ 15.844630] Console: switching to colour dummy device 80x25
[ 15.844663] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 15.846629] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 15.847781] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 15.869722] [drm] Initialized i915 1.6.0 20200313 for 0000:00:02.0 on minor 0
[ 15.869991] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 15.871181] ACPI: Video Device [PEGP] (multi-head: yes rom: no post: no)
[ 15.871188] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20200326/psargs-330)
[ 15.871202] ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20200326/psparse-529)
[ 15.871257] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2b/LNXVIDEO:00/input/input8
[ 15.872474] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input6
[ 15.872507] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 15.872724] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:02/input/input9
[ 15.923079] [drm] radeon kernel modesetting enabled.
[ 15.923102] vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
[ 15.923351] ATPX version 1, functions 0x00000033
[ 15.923638] radeon 0000:01:00.0: enabling device (0000 -> 0003)
[ 15.923866] [drm] initializing kernel modesetting (OLAND 0x1002:0x6601 0x1028:0x05B8 0x00).
[ 15.923885] vga_switcheroo: enabled
[ 15.952011] ATOM BIOS: Dell/Compal
[ 15.952142] radeon 0000:01:00.0: VRAM: 2048M 0x0000000000000000 - 0x000000007FFFFFFF (2048M used)
[ 15.952144] radeon 0000:01:00.0: GTT: 2048M 0x0000000080000000 - 0x00000000FFFFFFFF
[ 15.952148] [drm] Detected VRAM RAM=2048M, BAR=256M
[ 15.952149] [drm] RAM width 128bits DDR
[ 15.952239] [TTM] Zone kernel: Available graphics memory: 1951806 KiB
[ 15.952241] [TTM] Initializing pool allocator
[ 15.952245] [TTM] Initializing DMA pool allocator
[ 15.952265] [drm] radeon: 2048M of VRAM memory ready
[ 15.952266] [drm] radeon: 2048M of GTT memory ready.
[ 15.952277] [drm] Loading oland Microcode
[ 15.969573] mousedev: PS/2 mouse device common for all mice
[ 15.986446] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 15.986472] fbcon: i915drmfb (fb0) is primary device
[ 16.100118] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3221: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 16.100121] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 16.100123] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 16.100125] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 16.100126] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 16.100128] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 16.100129] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 16.160979] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 16.161063] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 16.161144] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 16.209111] [drm] Internal thermal controller without fan control
[ 16.216803] [drm] radeon: dpm initialized
[ 16.340787] [drm] Found VCE firmware/feedback version 50.0.1 / 17!
[ 16.340824] [drm] GART: num cpu pages 524288, num gpu pages 524288
[ 16.343887] [drm] PCIE gen 2 link speeds already enabled
[ 16.352990] [drm] PCIE GART of 2048M enabled (table at 0x00000000001D6000).
[ 16.353095] radeon 0000:01:00.0: WB enabled
[ 16.353098] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0x0000000002968cf1
[ 16.353100] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04 and cpu addr 0x00000000bf717454
[ 16.353101] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08 and cpu addr 0x000000005c9f0cb6
[ 16.353102] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0x000000008771281a
[ 16.353103] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10 and cpu addr 0x00000000f90d6e5a
[ 16.353502] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18 and cpu addr 0x00000000c059e310
[ 16.415735] r8169 0000:07:00.0 enp7s0: renamed from eth0
[ 16.454581] radeon 0000:01:00.0: failed VCE resume (-110).
[ 16.454584] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 16.454586] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[ 16.454626] radeon 0000:01:00.0: radeon: using MSI.
[ 16.454650] [drm] radeon: irq initialized.
[ 16.605955] [drm] ring test on 0 succeeded in 1 usecs
[ 16.605959] [drm] ring test on 1 succeeded in 1 usecs
[ 16.605962] [drm] ring test on 2 succeeded in 1 usecs
[ 16.605968] [drm] ring test on 3 succeeded in 3 usecs
[ 16.605973] [drm] ring test on 4 succeeded in 3 usecs
[ 16.735867] Console: switching to colour frame buffer device 170x48
[ 16.755198] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[ 16.783068] [drm] ring test on 5 succeeded in 2 usecs
[ 16.783072] [drm] UVD initialized successfully.
[ 16.783258] [drm] ib test on ring 0 succeeded in 0 usecs
[ 16.783292] [drm] ib test on ring 1 succeeded in 0 usecs
[ 16.783320] [drm] ib test on ring 2 succeeded in 0 usecs
[ 16.783342] [drm] ib test on ring 3 succeeded in 0 usecs
[ 16.783376] [drm] ib test on ring 4 succeeded in 0 usecs
[ 17.200644] AVX version of gcm_enc/dec engaged.
[ 17.200646] AES CTR mode by8 optimization enabled
[ 17.210561] wl: loading out-of-tree module taints kernel.
[ 17.210566] wl: module license 'MIXED/Proprietary' taints kernel.
[ 17.210567] Disabling lock debugging due to kernel taint
[ 17.213371] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 17.248008] wlan0: Broadcom BCM4365 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 17.368417] wl 0000:08:00.0 wlp8s0: renamed from wlan0
[ 17.438453] [drm] ib test on ring 5 succeeded
[ 17.439199] [drm] Radeon Display Connectors
[ 17.450974] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 1
[ 18.250476] [drm] amdgpu kernel modesetting enabled.
[ 18.250503] vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
[ 18.250738] ATPX version 1, functions 0x00000033
[ 18.251048] CRAT table not found
[ 18.251052] Virtual CRAT table created for CPU
[ 18.251054] Parsing CRAT table with 1 nodes
[ 18.251056] Creating topology SYSFS entries
[ 18.251091] Topology: Add CPU node
[ 18.251092] Finished initializing topology
[ 18.407051] audit: type=1130 audit(1600860960.120:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.444334] audit: type=1130 audit(1600860960.157:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.825109] Adding 20479996k swap on /dev/sda3. Priority:-2 extents:1 across:20479996k FS
[ 19.227825] intel_rapl_common: Found RAPL domain package
[ 19.227828] intel_rapl_common: Found RAPL domain core
[ 19.227829] intel_rapl_common: Found RAPL domain uncore
[ 19.227834] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[ 21.736130] audit: type=1130 audit(1600860963.450:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.075589] audit: type=1130 audit(1600860963.790:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.691796] audit: type=1130 audit(1600860964.407:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.773580] audit: type=1127 audit(1600860964.487:10): pid=456 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 22.844551] audit: type=1130 audit(1600860964.557:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.397869] audit: type=1130 audit(1600860965.113:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.617661] audit: type=1131 audit(1600860965.330:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.629790] audit: type=1130 audit(1600860965.343:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.635639] audit: type=1130 audit(1600860965.350:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.657288] audit: type=1334 audit(1600860965.370:16): prog-id=7 op=LOAD
[ 23.657343] audit: type=1334 audit(1600860965.370:17): prog-id=8 op=LOAD
[ 24.720548] audit: type=1130 audit(1600860966.433:18): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=linux-module-cleanup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 24.720559] audit: type=1131 audit(1600860966.433:19): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=linux-module-cleanup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.959967] usbcore: registered new interface driver rtsx_usb
[ 26.090004] mc: Linux media interface: v0.10
[ 26.125505] videodev: Linux video capture interface: v2.00
[ 26.341711] Bluetooth: Core ver 2.22
[ 26.341733] NET: Registered protocol family 31
[ 26.341734] Bluetooth: HCI device and connection manager initialized
[ 26.341738] Bluetooth: HCI socket layer initialized
[ 26.341740] Bluetooth: L2CAP socket layer initialized
[ 26.341743] Bluetooth: SCO socket layer initialized
[ 26.850999] usbcore: registered new interface driver btusb
[ 26.963699] Bluetooth: hci0: BCM: chip id 70
[ 26.964569] Bluetooth: hci0: BCM: features 0x06
[ 26.980737] Bluetooth: hci0: BCM43142A
[ 26.981579] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0000
[ 27.564788] bluetooth hci0: Direct firmware load for brcm/BCM43142A0-0a5c-21d7.hcd failed with error -2
[ 27.564799] Bluetooth: hci0: BCM: Patch brcm/BCM43142A0-0a5c-21d7.hcd not found
[ 27.680539] audit: type=1130 audit(1600860969.393:20): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.772694] uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_HD (064e:812e)
[ 27.793745] uvcvideo 1-1.4:1.0: Entity type for entity Extension 4 was not initialized!
[ 27.793756] uvcvideo 1-1.4:1.0: Entity type for entity Extension 3 was not initialized!
[ 27.793761] uvcvideo 1-1.4:1.0: Entity type for entity Processing 2 was not initialized!
[ 27.793765] uvcvideo 1-1.4:1.0: Entity type for entity Camera 1 was not initialized!
[ 27.794197] input: Laptop_Integrated_Webcam_HD: In as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input13
[ 27.794767] usbcore: registered new interface driver uvcvideo
[ 27.794777] USB Video Class driver (1.1.1)
[ 29.598402] Bluetooth: hci0: command 0x1003 tx timeout
[ 29.602622] Bluetooth: hci0: unexpected event for opcode 0x1003
[ 29.750991] audit: type=1130 audit(1600860971.463:21): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.755238] audit: type=1130 audit(1600860971.470:22): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.757090] audit: type=1130 audit(1600860971.470:23): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.758793] audit: type=1130 audit(1600860971.473:24): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.943268] audit: type=1130 audit(1600860971.657:25): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 30.371986] audit: type=1334 audit(1600860972.087:26): prog-id=9 op=LOAD
[ 30.372190] audit: type=1334 audit(1600860972.087:27): prog-id=10 op=LOAD
[ 30.428804] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 30.428806] Bluetooth: BNEP filters: protocol multicast
[ 30.428811] Bluetooth: BNEP socket layer initialized
[ 30.577201] NET: Registered protocol family 38
[ 30.842515] audit: type=1130 audit(1600860972.557:28): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.095088] audit: type=1130 audit(1600860972.810:29): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.445679] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 31.456160] [drm] PCIE GART of 2048M enabled (table at 0x00000000001D6000).
[ 31.456257] radeon 0000:01:00.0: WB enabled
[ 31.456261] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0x0000000002968cf1
[ 31.456262] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04 and cpu addr 0x00000000bf717454
[ 31.456263] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08 and cpu addr 0x000000005c9f0cb6
[ 31.456265] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0x000000008771281a
[ 31.456266] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10 and cpu addr 0x00000000f90d6e5a
[ 31.456666] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18 and cpu addr 0x00000000c059e310
[ 31.557729] radeon 0000:01:00.0: failed VCE resume (-110).
[ 31.705582] [drm] ring test on 0 succeeded in 2 usecs
[ 31.705586] [drm] ring test on 1 succeeded in 1 usecs
[ 31.705590] [drm] ring test on 2 succeeded in 1 usecs
[ 31.705596] [drm] ring test on 3 succeeded in 3 usecs
[ 31.705601] [drm] ring test on 4 succeeded in 3 usecs
[ 31.882687] [drm] ring test on 5 succeeded in 2 usecs
[ 31.882691] [drm] UVD initialized successfully.
[ 31.882729] [drm] ib test on ring 0 succeeded in 0 usecs
[ 31.882758] [drm] ib test on ring 1 succeeded in 0 usecs
[ 31.882786] [drm] ib test on ring 2 succeeded in 0 usecs
[ 31.882814] [drm] ib test on ring 3 succeeded in 0 usecs
[ 31.882841] [drm] ib test on ring 4 succeeded in 0 usecs
[ 32.558498] [drm] ib test on ring 5 succeeded
[ 33.284354] audit: type=1131 audit(1600860974.997:30): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.692244] RTL8208 Fast Ethernet r8169-700:00: attached PHY driver [RTL8208 Fast Ethernet] (mii_bus:phy_addr=r8169-700:00, irq=IGNORE)
[ 34.937885] r8169 0000:07:00.0 enp7s0: Link is Down
[ 36.011550] kauditd_printk_skb: 3 callbacks suppressed
[ 36.011558] audit: type=1130 audit(1600860977.723:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 37.607755] loop: module loaded
[ 37.711604] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 38.306594] audit: type=1130 audit(1600860980.020:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.473057] audit: type=1130 audit(1600860980.187:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.231817] audit: type=1130 audit(1600860980.947:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 43.280953] IPv6: ADDRCONF(NETDEV_CHANGE): wlp8s0: link becomes ready
[ 43.479804] audit: type=1131 audit(1600860985.193:38): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 44.054017] audit: type=1131 audit(1600860985.767:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.715086] audit: type=1130 audit(1600860987.430:40): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.907745] audit: type=1130 audit(1600860987.620:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 46.382829] audit: type=1103 audit(1600860988.100:42): pid=947 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 46.672712] audit: type=1130 audit(1600860988.387:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.081706] audit: type=1101 audit(1600860988.797:44): pid=954 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.081986] audit: type=1103 audit(1600860988.797:45): pid=954 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 47.082355] audit: type=1006 audit(1600860988.797:46): pid=954 uid=0 old-auid=4294967295 auid=969 tty=(none) old-ses=4294967295 ses=1 res=1
[ 47.184882] audit: type=1105 audit(1600860988.900:47): pid=954 uid=0 auid=969 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 50.037060] fuse: init (API version 7.31)
[ 56.010597] kauditd_printk_skb: 5 callbacks suppressed
[ 56.010600] audit: type=1131 audit(1600860997.723:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.812784] audit: type=1100 audit(1600861001.527:54): pid=1007 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="bluestar" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 59.814196] audit: type=1101 audit(1600861001.527:55): pid=1007 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="bluestar" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 59.986087] audit: type=1106 audit(1600861001.700:56): pid=947 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 59.986458] audit: type=1104 audit(1600861001.700:57): pid=947 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 59.993220] audit: type=1103 audit(1600861001.707:58): pid=1007 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="bluestar" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 59.993463] audit: type=1006 audit(1600861001.707:59): pid=1007 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 60.022114] audit: type=1130 audit(1600861001.737:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.030199] audit: type=1101 audit(1600861001.743:61): pid=1018 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="bluestar" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.030241] audit: type=1103 audit(1600861001.743:62): pid=1018 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="bluestar" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 61.078468] kauditd_printk_skb: 7 callbacks suppressed
[ 61.078474] audit: type=1131 audit(1600861002.793:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 61.272664] audit: type=1334 audit(1600861002.987:71): prog-id=10 op=UNLOAD
[ 61.272670] audit: type=1334 audit(1600861002.987:72): prog-id=9 op=UNLOAD
[ 69.917057] audit: type=1130 audit(1600861011.124:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 70.180406] audit: type=1131 audit(1600861011.388:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 70.190492] audit: type=1131 audit(1600861011.398:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 74.326589] audit: type=1334 audit(1600861015.534:76): prog-id=13 op=LOAD
[ 74.326697] audit: type=1334 audit(1600861015.534:77): prog-id=14 op=LOAD
[ 75.841274] audit: type=1130 audit(1600861017.048:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 75.962750] Bluetooth: RFCOMM TTY layer initialized
[ 75.962766] Bluetooth: RFCOMM socket layer initialized
[ 75.962784] Bluetooth: RFCOMM ver 1.11
[ 78.128232] audit: type=1130 audit(1600861019.334:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 88.887616] audit: type=1130 audit(1600861030.094:80): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 89.798957] audit: type=1130 audit(1600861031.008:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 118.378187] audit: type=1131 audit(1600861059.760:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 144.223191] audit: type=1100 audit(1600861085.435:83): pid=1478 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 144.224717] audit: type=1101 audit(1600861085.438:84): pid=1478 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 144.253738] audit: type=1105 audit(1600861085.465:85): pid=1475 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[ 149.885741] capability: warning: `Thread Pool Wor' uses 32-bit capabilities (legacy support in use)
[ 155.306561] audit: type=1325 audit(1600861096.490:86): table=filter family=2 entries=0
[ 155.340620] audit: type=1325 audit(1600861096.527:87): table=filter family=10 entries=0
[ 155.397536] audit: type=1325 audit(1600861096.584:88): table=mangle family=2 entries=0
[ 155.397885] audit: type=1325 audit(1600861096.584:89): table=mangle family=2 entries=6
[ 155.443983] audit: type=1325 audit(1600861096.630:90): table=nat family=2 entries=0
[ 155.444370] audit: type=1325 audit(1600861096.630:91): table=nat family=2 entries=5
[ 155.493275] audit: type=1325 audit(1600861096.683:92): table=filter family=2 entries=4
[ 155.501066] audit: type=1325 audit(1600861096.690:93): table=mangle family=10 entries=0
[ 155.501392] audit: type=1325 audit(1600861096.690:94): table=mangle family=10 entries=6
[ 155.504818] audit: type=1325 audit(1600861096.693:95): table=nat family=10 entries=0
[ 165.504715] tun: Universal TUN/TAP device driver, 1.6
[ 165.548589] kauditd_printk_skb: 2 callbacks suppressed
[ 165.548592] audit: type=1130 audit(1600861106.728:98): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 176.050939] audit: type=1131 audit(1600861117.221:99): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 838.196514] audit: type=1334 audit(1600861779.428:100): prog-id=15 op=LOAD
[ 838.196585] audit: type=1334 audit(1600861779.428:101): prog-id=16 op=LOAD
[ 839.503290] audit: type=1130 audit(1600861780.734:102): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 869.543180] audit: type=1131 audit(1600861810.774:103): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 869.682463] audit: type=1334 audit(1600861810.914:104): prog-id=16 op=UNLOAD
[ 869.682507] audit: type=1334 audit(1600861810.914:105): prog-id=15 op=UNLOAD
[ 934.672774] audit: type=1130 audit(1600861875.909:106): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 934.672786] audit: type=1131 audit(1600861875.909:107): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1846.264752] audit: type=1334 audit(1600862787.602:108): prog-id=17 op=LOAD
[ 1846.264885] audit: type=1334 audit(1600862787.602:109): prog-id=18 op=LOAD
[ 1846.649078] audit: type=1130 audit(1600862787.986:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1876.694501] audit: type=1131 audit(1600862818.036:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1876.799733] audit: type=1334 audit(1600862818.143:112): prog-id=18 op=UNLOAD
[ 1876.799758] audit: type=1334 audit(1600862818.143:113): prog-id=17 op=UNLOAD
[ 1895.590821] audit: type=1100 audit(1600862836.936:114): pid=6539 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=? acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 1897.807514] audit: type=1100 audit(1600862839.152:115): pid=6539 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=? acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed'
[ 1932.159617] audit: type=1100 audit(1600862873.507:116): pid=6618 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 1932.161375] audit: type=1101 audit(1600862873.507:117): pid=6618 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 1932.162068] audit: type=1110 audit(1600862873.507:118): pid=6618 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 1932.165057] audit: type=1105 audit(1600862873.510:119): pid=6618 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 1932.243452] audit: type=1106 audit(1600862873.590:120): pid=6618 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 1932.243672] audit: type=1104 audit(1600862873.590:121): pid=6618 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[ 2014.837597] device-mapper: uevent: version 1.0.3
[ 2014.837688] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[ 2015.375415] FAT-fs (dm-0): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 2903.674021] audit: type=1334 audit(1600863844.938:122): prog-id=19 op=LOAD
[ 2903.674181] audit: type=1334 audit(1600863844.938:123): prog-id=20 op=LOAD
[ 2904.388119] audit: type=1130 audit(1600863845.652:124): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2957.851123] audit: type=1131 audit(1600863899.117:125): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2957.924923] audit: type=1334 audit(1600863899.194:126): prog-id=20 op=UNLOAD
[ 2957.924929] audit: type=1334 audit(1600863899.194:127): prog-id=19 op=UNLOAD
[ 3654.464994] audit: type=1130 audit(1600864595.637:128): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3691.649530] audit: type=1100 audit(1600864632.817:129): pid=11099 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 3691.684909] audit: type=1101 audit(1600864632.854:130): pid=11099 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 4029.006324] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 4029.017225] [drm] PCIE GART of 2048M enabled (table at 0x00000000001D6000).
[ 4029.017321] radeon 0000:01:00.0: WB enabled
[ 4029.017324] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0x0000000002968cf1
[ 4029.017326] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04 and cpu addr 0x00000000bf717454
[ 4029.017327] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08 and cpu addr 0x000000005c9f0cb6
[ 4029.017328] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0x000000008771281a
[ 4029.017329] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10 and cpu addr 0x00000000f90d6e5a
[ 4029.017730] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18 and cpu addr 0x00000000c059e310
[ 4029.118823] radeon 0000:01:00.0: failed VCE resume (-110).
[ 4029.268280] [drm] ring test on 0 succeeded in 1 usecs
[ 4029.268285] [drm] ring test on 1 succeeded in 1 usecs
[ 4029.268288] [drm] ring test on 2 succeeded in 1 usecs
[ 4029.268294] [drm] ring test on 3 succeeded in 3 usecs
[ 4029.268300] [drm] ring test on 4 succeeded in 3 usecs
[ 4029.445412] [drm] ring test on 5 succeeded in 2 usecs
[ 4029.445416] [drm] UVD initialized successfully.
[ 4029.445453] [drm] ib test on ring 0 succeeded in 0 usecs
[ 4029.445483] [drm] ib test on ring 1 succeeded in 0 usecs
[ 4029.445511] [drm] ib test on ring 2 succeeded in 0 usecs
[ 4029.445539] [drm] ib test on ring 3 succeeded in 0 usecs
[ 4029.445566] [drm] ib test on ring 4 succeeded in 0 usecs
[ 4030.108560] [drm] ib test on ring 5 succeeded
[ 4487.206289] audit: type=1100 audit(1600865428.537:131): pid=86888 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 4487.646504] audit: type=1101 audit(1600865428.977:132): pid=86888 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 5119.347045] audit: type=1100 audit(1600866060.618:133): pid=116098 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 5119.672539] audit: type=1101 audit(1600866060.944:134): pid=116098 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 5618.313512] audit: type=1100 audit(1600866559.619:135): pid=144611 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 5618.392319] audit: type=1101 audit(1600866559.699:136): pid=144611 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 5816.478441] audit: type=1100 audit(1600866757.801:137): pid=147214 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5816.481615] audit: type=1101 audit(1600866757.804:138): pid=147214 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5816.543190] audit: type=1110 audit(1600866757.864:139): pid=147214 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5816.618187] audit: type=1105 audit(1600866757.941:140): pid=147214 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5850.311068] audit: type=1106 audit(1600866791.636:141): pid=147214 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5850.311322] audit: type=1104 audit(1600866791.636:142): pid=147214 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5896.467624] audit: type=1101 audit(1600866837.799:143): pid=149160 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5896.468018] audit: type=1110 audit(1600866837.799:144): pid=149160 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5896.472585] audit: type=1105 audit(1600866837.802:145): pid=149160 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5913.658776] audit: type=1106 audit(1600866855.003:146): pid=149160 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 5913.658990] audit: type=1104 audit(1600866855.003:147): pid=149160 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 6526.878098] FAT-fs (dm-0): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6539.621274] audit: type=1334 audit(1600867480.965:148): prog-id=21 op=LOAD
[ 6539.621347] audit: type=1334 audit(1600867480.965:149): prog-id=22 op=LOAD
[ 6540.152992] audit: type=1130 audit(1600867481.499:150): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6570.280706] audit: type=1131 audit(1600867511.626:151): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6570.372238] audit: type=1334 audit(1600867511.719:152): prog-id=22 op=UNLOAD
[ 6570.372257] audit: type=1334 audit(1600867511.719:153): prog-id=21 op=UNLOAD
[ 6908.792113] audit: type=1100 audit(1600867850.144:154): pid=153329 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 6908.834684] audit: type=1101 audit(1600867850.188:155): pid=153329 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 6908.935625] audit: type=1110 audit(1600867850.288:156): pid=153329 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 6909.009879] audit: type=1105 audit(1600867850.361:157): pid=153329 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 6909.106159] audit: type=1106 audit(1600867850.458:158): pid=153329 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 6909.106420] audit: type=1104 audit(1600867850.458:159): pid=153329 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 7159.757463] audit: type=1101 audit(1600868101.116:160): pid=153891 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 7159.757702] audit: type=1110 audit(1600868101.116:161): pid=153891 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 7159.763147] audit: type=1105 audit(1600868101.123:162): pid=153891 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 7159.783583] audit: type=1106 audit(1600868101.143:163): pid=153891 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 7159.783681] audit: type=1104 audit(1600868101.143:164): pid=153891 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 7371.623710] audit: type=1101 audit(1600868312.983:165): pid=154392 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="bluestar" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 7371.624001] audit: type=1110 audit(1600868312.983:166): pid=154392 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 7371.626116] audit: type=1105 audit(1600868312.987:167): pid=154392 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
