Hello everyone!
I am going to buy a Network Card - Cudy WU1300S WLAN 867 Mbit/s Dual Band such as my MediaTek 7902 not working. Does anyone know will Cudy WU1300S work on Manjaro?
Because I googled this question and some sources says that this card will work at the same time as another that it doesn’t work on Linux. And unfortunately I can’t find info about chip, but ai said that it has a Realtek RTL8812BU. I don’t trust ai)
My crystal ball tells me it should work.
//EDIT: seems like some drivers ready to install here AUR (en) - rtl88x2bu-dkms-git (from this repository GitHub - RinCat/RTL88x2BU-Linux-Driver: Realtek RTL88x2BU WiFi USB Driver for Linux some more info and explanation there)
Wow, that is very helpful information. Thank you)
Alfa Networks provides USB devices that work OOB on Manjaro Linux with kernel 6.15.
Example https://alfa-network.eu/wi-fi/kali-linux-compatible/awus036acs
0bda:0811 Realtek Semiconductor Corp. Realtek 8812AU/8821AU 802.11ac WLAN Adapter [USB Wireless Dual-Band Adapter 2.4/5Ghz]
With kernel 6.12 you will need to use AUR to build a driver package.
