Netspeed monitor for Manjaro
Hi guys I am new to Manjaro and come from the Windows world.
Under Windows I use a tool “Netspeed-Monitor” which always shows me in the taskbar the current upload and download rates of my internet connection.
Is there a comparable tool for Manjaro KDE-Plasma, which gives me the information in the taskbar WITHOUT having another window open?
If so, I would appreciate any hints on how to find and install it.
Hello,
Check this Netspeed Widget - KDE Store
It can be installed also via Add Widgets from right clicking the Panel, then install new widgets from Get New Widgets on top …
KDE Plasma already ships with a System Monitor Widget you can configure to show net bandwidth.
That’s perfect. Thank you for it and your really fast response
