is there a way to install the drivers for a netgear a6100 wifi adapter without having to connect to ethernet in any way?
Its not theoretically possible. You would have to download the files somehow. That being said if you use another computer to download the files, place them on a thumb drive, and then use those files, its possible. It will be very difficult. You might want to figure out some way to connect, perhaps tethering your phone.
thats a good idea, I’ll just put the drivers on my phone and connect it via usb then transfer the files onto my computer
just use tethering from your phone and install the drivers normally
