NETDEV WATCHDOG Ethernet doesn't work after restart
I have stumbled upon error which I have not experienced in Debian Buster on the same hardware and same kernel series.
Description: After PC restart, ethernet doesn’t work. Only solution to restore it, is to turn off PC completely and start again, or suspend to RAM and start again.
dmesg is catching NETDEV WATCHDOG exception and says:
    [   16.236686] ------------[ cut here ]------------
    [   16.236696] NETDEV WATCHDOG: eno1 (r8169): transmit queue 0 timed out
    [   16.236711] WARNING: CPU: 10 PID: 0 at net/sched/sch_generic.c:442 dev_watchdog+0x26d/0x280
    [   16.236713] Modules linked in: fuse squashfs rfkill loop uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common snd_usb_audio videodev snd_usbmidi_lib snd_rawmidi snd_seq_device joydev input_leds mousedev mc amdgpu snd_hda_codec_realtek nls_iso8859_1 nls_cp437 vfat snd_hda_codec_generic gpu_sched ledtrig_audio snd_hda_codec_hdmi i2c_algo_bit fat snd_hda_intel snd_intel_dspcfg edac_mce_amd ttm kvm_amd snd_hda_codec wmi_bmof drm_kms_helper kvm snd_hda_core cec irqbypass rc_core snd_hwdep crct10dif_pclmul crc32_pclmul snd_pcm ghash_clmulni_intel r8169 aesni_intel syscopyarea sysfillrect realtek snd_timer mdio_devres crypto_simd sysimgblt of_mdio cryptd sp5100_tco glue_helper rapl fb_sys_fops i2c_piix4 ccp pcspkr snd k10temp fixed_phy soundcore libphy rng_core wmi pinctrl_amd gpio_amdpt evdev mac_hid acpi_cpufreq uinput drm msr sg crypto_user agpgart ip_tables x_tables btrfs blake2b_generic libcrc32c crc32c_generic xor hid_generic usbhid hid raid6_pq crc32c_intel xhci_pci
    [   16.236753]  sr_mod xhci_hcd cdrom
    [   16.236760] CPU: 10 PID: 0 Comm: swapper/10 Not tainted 5.9.11-3-MANJARO #1
    [   16.236763] Hardware name: Gigabyte Technology Co., Ltd. AB350-Gaming 3/AB350-Gaming 3-CF, BIOS F51b 07/02/2020
    [   16.236766] RIP: 0010:dev_watchdog+0x26d/0x280
    [   16.236770] Code: 98 99 77 ff eb 85 4c 89 f7 c6 05 4e 91 eb 00 01 e8 48 a9 fa ff 44 89 e9 4c 89 f6 48 c7 c7 58 e7 20 ad 48 89 c2 e8 33 f5 15 00 <0f> 0b e9 63 ff ff ff 66 66 2e 0f 1f 84 00 00 00 00 00 90 0f 1f 44
    [   16.236772] RSP: 0018:ffffabbc404a8e90 EFLAGS: 00010286
    [   16.236775] RAX: 0000000000000000 RBX: ffff9ab1b42f8a00 RCX: 0000000000000000
    [   16.236777] RDX: 0000000000000103 RSI: ffffffffad1896e2 RDI: 00000000ffffffff
    [   16.236779] RBP: ffff9ab1aa28a3dc R08: 00000000000004b7 R09: 0000000000000001
    [   16.236781] R10: 0000000000000000 R11: 0000000000000001 R12: ffff9ab1aa28a480
    [   16.236783] R13: 0000000000000000 R14: ffff9ab1aa28a000 R15: ffff9ab1b42f8a80
    [   16.236786] FS:  0000000000000000(0000) GS:ffff9ab1bea80000(0000) knlGS:0000000000000000
    [   16.236789] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
    [   16.236791] CR2: 00007f48dc000010 CR3: 00000003b855e000 CR4: 00000000003506e0
    [   16.236793] Call Trace:
    [   16.236796]  <IRQ>
    [   16.236801]  ? pfifo_fast_init+0x110/0x110
    [   16.236804]  ? pfifo_fast_init+0x110/0x110
    [   16.236808]  call_timer_fn+0x2d/0x160
    [   16.236811]  ? pfifo_fast_init+0x110/0x110
    [   16.236814]  __run_timers+0x1ec/0x280
    [   16.236819]  run_timer_softirq+0x2b/0x50
    [   16.236823]  __do_softirq+0xff/0x344
    [   16.236827]  asm_call_irq_on_stack+0x12/0x20
    [   16.236829]  </IRQ>
    [   16.236834]  do_softirq_own_stack+0x5d/0x80
    [   16.236838]  irq_exit_rcu+0xd8/0x120
    [   16.236841]  sysvec_apic_timer_interrupt+0x47/0xe0
    [   16.236845]  asm_sysvec_apic_timer_interrupt+0x12/0x20
    [   16.236850] RIP: 0010:cpuidle_enter_state+0xcc/0x3c0
    [   16.236853] Code: ba f4 a4 53 e8 c5 2f 90 ff 49 89 c7 0f 1f 44 00 00 31 ff e8 c6 3d 90 ff 80 7c 24 0f 00 0f 85 11 02 00 00 fb 66 0f 1f 44 00 00 <45> 85 e4 0f 88 53 01 00 00 49 63 d4 4c 2b 3c 24 48 8d 04 52 48 8d
    [   16.236855] RSP: 0018:ffffabbc4019fea0 EFLAGS: 00000246
    [   16.236858] RAX: ffff9ab1bea80000 RBX: ffff9ab1b8860800 RCX: 000000000000001f
    [   16.236860] RDX: 0000000000000000 RSI: ffffffffad1896e2 RDI: ffffffffad1690b1
    [   16.236862] RBP: ffffffffad4d43c0 R08: 00000003c7c7ff2c R09: 0000000000000020
    [   16.236864] R10: 0000000000003109 R11: 0000000000006d88 R12: 0000000000000002
    [   16.236866] R13: ffffffffad4d44a8 R14: 0000000000000002 R15: 00000003c7c7ff2c
    [   16.236873]  cpuidle_enter+0x29/0x40
    [   16.236877]  do_idle+0x1ed/0x280
    [   16.236881]  cpu_startup_entry+0x19/0x20
    [   16.236885]  secondary_startup_64+0xb6/0xc0
    [   16.236889] ---[ end trace 6c48f10f30359db1 ]---
    [   16.248753] r8169 0000:04:00.0 eno1: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
    [   16.752105] audit: type=1130 audit(1609091216.915:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   17.978301] audit: type=1131 audit(1609091218.141:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   21.368703] r8169 0000:04:00.0 eno1: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
    [   30.758544] usb 1-1: USB disconnect, device number 2
    [   31.395530] r8169 0000:04:00.0 eno1: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
I am using freshly installed (yesterday) Manjaro KDE, everything is in default state. My hardware:
$ inxi -MNnS
    System:    Host: pioruns-ab350gaming3 Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.4
               Distro: Manjaro Linux
    Machine:   Type: Desktop System: Gigabyte product: AB350-Gaming 3 v: N/A serial: <superuser/root required>
               Mobo: Gigabyte model: AB350-Gaming 3-CF v: x.x serial: <superuser/root required> UEFI: American Megatrends v: F51b
               date: 07/02/2020
    Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
               IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 1c:1b:0d:e6:c3:40
Any suggestions?
