I have checked
- The file /usr/bin/firefox exists
- Firefox running normal
how to fix this?
I have checked
How is netbeans installed ?
Im using netbeans from third party snap.
i was using manjaro KDE before, and netbeans running normal.
but when try using gnome manjaro, this problem appear
I deleted a lot of other words.
To put it simply - SNAP should be containerized by default … and thus you should not expect it to automatically function the same way as other ‘regular’ packages.
