Netatalk 4.5.0 Install Error
Install script /usr/bin/dconf update failed with exit code 1
I’m trying to install the latest AUR package for Netatalk from the command line and it fails with a permissions error:
Errno 13] Permission denied: '/var/cache/private/pamac/netatalk/src/netatalk-4.5.0/build/meson-private/sanity_check_for_c.exe'.
Is this a problem with the package itself or some sort of permissions error on my end? I would assume it’s the package as the previous versions of Netatalk installed just fine.
Interestingly if I try and update from the Pamac GUI I get this error instead:
Running custom install script '/usr/bin/dconf update'
FAILED: install script '/usr/bin/dconf update' failed with exit code 1.
Any insight would be greatly appreciated.
Mod edit: Changed blockquote to code-fence. Please use the </> button, rather than ".
Mod edit:- Title changed for brevity - the overflow added to the first post as reference. Remedied at no charge.
Not a direct answer to your inquiry — although it might be related after all — but it is currently strongly advised to not install or update anything from the AUR right now, due to an ongoing infestation campaign with malware.
For details, please see the thread below. :backhand_index_pointing_down:
I did actually check a list of known infected packages and this one was not on it. I also ran the check script and I was fine. Still, point taken. Maybe I’ll wait on this.
I’ve been having this issue for the past few weeks. I believe this package predates the malware issue.
What command did you run? Never run pamac with sudo.
I just built both netatalk and it’s AUR dependency bstring in a clean chroot just fine.
Indeed, common source of such issues. :roll_eyes:
@tempest2084
If this is indeed the case, One can check with:
history | grep pamac
Well that solved one problem. I was indeed running sudo pamac update. However just running pamac update still gives me an error:
> warning: Failed to open '/etc/dconf/db/ibus': for replacement: Permission denied
> /etc/dconf/db/ibus.d: Failed to create file “/etc/dconf/db/ibus.AZUIR3”: Permission denied
> warning: Failed to open '/etc/dconf/db/local': for replacement: Permission denied
> /etc/dconf/db/local.d: Failed to create file “/etc/dconf/db/local.OSUIR3”: Permission denied
> error: failed to update at least one of the databases
> ==> ERROR: A failure occurred in package().
>     Aborting...
Mod edit:- Please present all code, commands and command output as pre-formatted text in accordance with forum guidelines. Quickly fixed for you this time (but it still looks ugly). No charge.
Only use quote tags or > for quoted normal text. :eyes:
I’d suggest removing the pamac cache and trying again:
sudo rm -rf /var/cache/private/pamac/*
Still getting the error. :frowning:
Post the full log, please. This time please use proper formatting. Using quotes for file and terminal output are not acceptable and are hard to read.
Please see [HowTo] Post command output and file content as preformatted text
Building netatalk...
==> Making package: netatalk 4.5.0-1 (Mon 15 Jun 2026 03:09:39 PM EDT)
==> Retrieving sources...
  -> Found netatalk-4.5.0.tar.xz
==> Validating source files with md5sums...
    netatalk-4.5.0.tar.xz ... Passed
==> Extracting sources...
  -> Extracting netatalk-4.5.0.tar.xz with bsdtar
==> Removing existing $pkgdir/ directory...
==> Starting build()...
Wrap files:
Wrap bstring.wrap type file in source tree: subprojects/bstring-1.1.0
+ exec meson setup --prefix /usr --libexecdir lib --sbindir bin --buildtype plain --auto-features enabled --wrap-mode nodownload -D b_pie=true -D python.bytecompile=1 . build --localstatedir /var/lib -Dwith-appletalk=true -Dwith-bdb-version=5.3 -Dwith-docs=man -Dwith-dtrace=false -Dwith-init-hooks=false -Dwith-lockfile-path=/run -Dwith-overwrite=true -Dwith-spooldir=/var/spool/netatalk
The Meson build system
Version: 1.11.1
Source dir: /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0
Build dir: /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build
Build type: native build
Project name: netatalk
Project version: 4.5.0
Host machine cpu family: x86_64
Host machine cpu: x86_64
Message: Linux distro detected: arch
Program uname found: YES (/usr/bin/uname)
Program perl found: YES (/usr/bin/perl)
Program cmark found: YES (/usr/bin/cmark)
Program cmark-gfm found: NO
Program pandoc found: NO
Program doxygen found: NO
C compiler for the host machine: cc (gcc 16.1.1 "cc (GCC) 16.1.1 20260430")
C linker for the host machine: cc ld.bfd 2.46.0
C++ compiler for the host machine: c++ (gcc 16.1.1 "c++ (GCC) 16.1.1 20260430")
C++ linker for the host machine: c++ ld.bfd 2.46.0
Library socket found: NO
Library sendfile found: NO
Library nsl found: YES
Library dl found: YES
Library m found: YES
Checking if "atomic builtins without -latomic" links: YES
Has header "acl/libacl.h" : YES
Has header "attr/xattr.h" : NO
Has header "crypt.h" : YES
Has header "dlfcn.h" : YES
Has header "iniparser/iniparser.h" : YES
Has header "langinfo.h" : YES
Has header "linux/dqblk/xfs.h" : NO
Has header "linux/xqm.h" : NO
Has header "locale.h" : YES
Has header "mntent.h" : YES
Has header "pam/pam_appl.h" : NO
Has header "security/pam_appl.h" : YES
Has header "sgtty.h" : YES
Has header "sys/attr.h" : NO
Has header "sys/ea.h" : NO
Has header "sys/extattr.h" : NO
Has header "sys/mnttab.h" : NO
Has header "sys/mount.h" : YES
Has header "sys/sysinfo.h" : YES
Has header "sys/vfs.h" : YES
Has header "sys/xattr.h" : YES
Has header "ufs/quota.h" : NO
Has header "xfs/xqm.h" : YES
Checking for function "asprintf" : YES
Checking for function "backtrace_symbols" : YES
Checking for function "dirfd" : YES
Checking for function "explicit_bzero" : YES
Checking for function "getpwnam_shadow" : NO
Checking for function "memset_explicit" : YES
Checking for function "pread" : YES
Checking for function "pselect" : YES
Checking for function "pwrite" : YES
Checking for function "rresvport" : YES
Checking for function "splice" : YES
Checking for function "strlcat" : YES
Checking for function "strlcpy" : YES
Checking for function "strnlen" : YES
Checking for function "vasprintf" : YES
Checking for function "mempcpy" : NO
Checking for function "getifaddrs" with dependency -lsocket: YES
Checking for function "openat" : YES
Checking for function "renameat" : YES
Checking for function "fstatat" : YES
Checking for function "unlinkat" : YES
Checking for type "fshare_t" : NO
Checking whether type "struct stat" has member "st_birthtimespec" : NO
Checking whether type "struct stat" has member "st_mtim" : NO
Checking whether type "struct stat" has member "st_atim" : NO
Checking whether type "struct stat" has member "st_mtimespec" : NO
Checking whether type "struct stat" has member "st_atimespec" : NO
Program file found: YES (/usr/bin/file)
Program grep found: YES (/usr/bin/grep)
Message: Searching for Berkeley DB library version 5.3
Message: Berkeley DB header found at /usr/include/db5.3/db.h
Library db-5.3 found: YES
Found pkg-config: YES (/usr/bin/pkg-config) 2.5.1
Did not find CMake 'cmake'
Found CMake: NO
Run-time dependency mysqlclient found: NO  (tried pkg-config and cmake)
Run-time dependency libmariadb found: NO  (tried pkg-config and cmake)
Run-time dependency sqlite3 found: YES 3.53.1
Checking if "bgets defined in standard C library" compiles: NO
Run-time dependency bstring found: YES 1.1.0
Run-time dependency iniparser found: YES 4.2.6
Checking if "iniparser functions accept const dictionary" with dependency iniparser compiles: YES
Run-time dependency threads found: YES
Checking for function "pthread_condattr_setclock" with dependency threads: NO
Run-time dependency libevent found: YES 2.1.12
Run-time dependency libgcrypt found: YES 1.12.2
Has header "gssapi.h" : YES
Has header "gssapi/gssapi.h" : YES
Library gss found: NO
Library gssapi found: NO
Library gssapi_krb5 found: YES
Checking for function "gss_acquire_cred" with dependency -lgssapi_krb5: YES
Library krb5 found: YES
Program krb5-config found: YES (/usr/bin/krb5-config)
Has header "krb5.h" : YES
Checking for function "krb5_free_unparsed_name" with dependency -lkrb5: YES
Checking for function "krb5_free_error_message" with dependency -lkrb5: YES
Checking for function "krb5_free_keytab_entry_contents" with dependency -lkrb5: YES
Checking for function "krb5_kt_free_entry" with dependency -lkrb5: YES
Run-time dependency avahi-client found: YES 0.9-rc4
Library dns_sd found: YES
Library system found: NO
Has header "dns_sd.h" : YES
Checking for function "DNSServiceRegister" with dependencies -ldns_sd, -lsystem: YES
Run-time dependency talloc found: YES 2.4.4
Program bison found: YES (/usr/bin/bison)
Program flex found: YES (/usr/bin/flex)
Run-time dependency tinysparql-3.0 found: YES 3.11.1
Run-time dependency tracker-sparql-3.0 found: YES 3.11.1
Run-time dependency glib-2.0 found: YES 2.88.1
Program localsearch found: YES (/usr/bin/localsearch)
Program tracker3 found: NO
Program gsettings found: YES (/usr/bin/gsettings)
Program dconf found: YES (/usr/bin/dconf)
Run-time dependency dbus-1 found: YES 1.16.2
Run-time dependency xapian-core found: NO  (tried pkg-config and cmake)
Run-time dependency libmagic found: YES 5.47
meson.build:1447: WARNING: xapian Spotlight search backend requested but one or more dependencies were not found
Run-time dependency cups found: YES 2.4.19
Program cups-config found: YES (/usr/bin/cups-config)
Library prop found: NO
Library quota found: NO
Library rpcsvc found: NO
Run-time dependency libtirpc found: YES 1.3.7
Has header "rpc/rpc.h" : NO
Has header "rpcsvc/rquota.h" : NO
meson.build:1563: WARNING: Quota support requested but required libtirpc or libquota libraries not found
Library attr found: YES
Checking for function "getxattr" with dependency -lattr: YES
Checking for function "fgetxattr" : YES
Checking for function "fsetxattr" : YES
Checking for function "getxattr" : YES
Checking for function "lgetxattr" : YES
Checking for function "listxattr" : YES
Checking for function "llistxattr" : YES
Checking for function "lremovexattr" : YES
Checking for function "lsetxattr" : YES
Checking for function "removexattr" : YES
Checking for function "setxattr" : YES
Library acl found: YES
Checking for function "acl_get_file" with dependency -lacl: YES
Checking for function "getxattr" with dependency -lattr: YES (cached)
Checking for function "acl_from_mode" with dependency -lacl: YES
Library ldap found: YES
Checking for function "ldap_initialize" with dependency -lldap: YES
Run-time dependency iconv found: YES
Library iconv found: NO
Checking if "iconv with const inbuf" compiles: NO
Library pam found: YES
Has header "security/pam_appl.h" : YES (cached)
Checking if "pam_conv with const pam_message" compiles: YES
Library crypt found: YES
Checking for function "crypt" with dependency -lcrypt: YES
Checking for function "crypt_checkpass" with dependency -lcrypt: NO
Has header "shadow.h" : YES
Checking for size of "off_t" : -1
Checking for function "sendfile" : YES
Checking for function "splice" : YES (cached)
Program dtrace found: NO
Library elf found: YES
Library crack found: YES
Library wrap found: NO
meson.build:2381: WARNING: TCP wrappers support requested but required library not found
Has header "netatalk/at.h" : YES
Configuring config.h using configuration
Program ldconfig found: YES (/usr/bin/ldconfig)
Configuring afp.conf using configuration
Configuring dbus-session.conf using configuration
Configuring netatalk using configuration
Configuring afpstats using configuration
Configuring addump using configuration
Configuring asip-status using configuration
Program make_man.sh found: YES (/var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/doc/manpages/make_man.sh)
Configuring netatalk.service using configuration
Configuring a2boot.service using configuration
Configuring atalkd.service using configuration
Configuring macipgw.service using configuration
Configuring papd.service using configuration
Configuring timelord.service using configuration
Build targets in project: 85
netatalk 4.5.0
  Build environment:
    Build directory            : /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build
    Source path                : /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0
    Download dependencies      : NO
  Directories:
    Installation prefix        : /usr
    Executable directory       : /usr/bin
    Header file directory      : /usr/include
    Library directory          : /usr/lib
    Manual page directory      : /usr/share/man
    System executable directory: /usr/bin
    Package conf directory     : /etc
    Shared state directory     : /var/lib
  Compilation:
    host CPU                   : x86_64
    host endianness            : little
    C compiler                 : gcc
    build stype                : plain
    Shared or static libraries : shared
  Configuration Summary:
    Netatalk version           : 4.5.0
    Options:
      Access control           : pam | shadow
      CNID backends            : dbd | sqlite
      Default CNID backend     : dbd
      Extended Attributes      : ad | sys
      Event loop provider      : libevent
      Init script style        : systemd
    User Authentication Methods:
      ClearTxt                 : YES
      DHX                      : YES
      DHX2                     : YES
      Guest                    : YES
      Kerberos V               : YES
      RandNum                  : YES
      SRP                      : YES
    Features:
      ACL                      : YES
      AppleTalk                : YES
      Cracklib                 : YES
      CUPS                     : YES
      dtrace probes            : NO
      FCE                      : YES
      GSSAPI                   : YES
      Kerberos                 : YES
      LDAP                     : YES
      Quota                    : NO
      Spotlight search         : YES
      Spotlight backends       : cnid | localsearch
      TCP wrapper              : NO
      Zeroconf                 : YES
      Zeroconf provider        : Avahi
    Paths:
      dbus daemon path         : /usr/bin/dbus-daemon
      init directory           : /usr/lib/systemd/system
      lockfile directory       : /run
      PAM config directory     : /etc/pam.d
      Print spool directory    : /var/spool/netatalk
      User home basedir        : /home
    Documentation:
      developer                : NO
      html manual              : NO
      man pages                : YES
      readmes                  : NO
    Extras:
      afpd integration tests   : NO
      AFP testsuite            : NO
      Webmin module            : NO
  User defined options
    auto_features              : enabled
    b_pie                      : true
    buildtype                  : plain
    libexecdir                 : lib
    localstatedir              : /var/lib
    prefix                     : /usr
    python.bytecompile         : 1
    sbindir                    : bin
    with-appletalk             : true
    with-bdb-version           : 5.3
    with-docs                  : man
    with-dtrace                : false
    with-init-hooks            : false
    with-lockfile-path         : /run
    with-overwrite             : true
    with-spooldir              : /var/spool/netatalk
    wrap_mode                  : nodownload
Found ninja-1.13.2 at /usr/bin/ninja
INFO: autodetecting backend as ninja
INFO: calculating backend command to run: /usr/bin/ninja -C /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build
ninja: Entering directory `/var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build'
[25/318] Compiling C object libatalk/adouble/libadouble.a.p/ad_open.c.o
../libatalk/adouble/ad_open.c: In function ‘ad_mkrf’:
../libatalk/adouble/ad_open.c:962:24: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
  962 |     if (NULL == (slash = strrchr(path, '/'))) {
../libatalk/adouble/ad_open.c: In function ‘ad_dir’:
../libatalk/adouble/ad_open.c:2100:11: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
 2100 |     slash = strrchr(path, '/');
[70/318] Compiling C object libatalk/util/libutil.a.p/netatalk_conf.c.o
../libatalk/util/netatalk_conf.c: In function ‘volxlate’:
../libatalk/util/netatalk_conf.c:491:12: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
  491 |     if ((p = strchr(src, '$')) == NULL) { /* nothing to do */
../libatalk/util/netatalk_conf.c:595:29: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
  595 |                     && (sep = strchr(obj->username, obj->options.ntseparator[0])) != NULL) {
../libatalk/util/netatalk_conf.c:627:11: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
  627 |         p = strchr(src, '$');
../libatalk/util/netatalk_conf.c: In function ‘getextmap’:
../libatalk/util/netatalk_conf.c:2127:35: warning: assignment discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
 2127 |     if (!Extmap_cnt || NULL == (p = strrchr(path, '.'))) {
[156/318] Compiling C object etc/afpd/libafpd.a.p/afp_dsi.c.o
../etc/afpd/afp_dsi.c: In function ‘sigpipe_notify’:
../etc/afpd/afp_dsi.c:140:11: warning: ignoring return value of ‘write’ declared with attribute ‘warn_unused_result’ [-Wunused-result]
  140 |     (void)write(sigpipe_fd[1], &c, 1);
[171/318] Compiling C object etc/afpd/libafpd.a.p/ofork.c.o
../etc/afpd/ofork.c: In function ‘of_closefork’:
../etc/afpd/ofork.c:676:15: warning: argument 1 null where non-null expected [-Wnonnull]
  676 |         (void)unlink(bdata(forkpath));
In file included from /usr/include/bits/sigstksz.h:24,
                 from /usr/include/signal.h:328,
                 from /usr/include/sys/param.h:28,
                 from ../etc/afpd/ofork.c:14:
/usr/include/unistd.h:858:12: note: in a call to function ‘unlink’ declared ‘nonnull’
  858 | extern int unlink (const char *__name) __THROW __nonnull ((1));
[172/318] Compiling C object etc/afpd/libafpd.a.p/mangle.c.o
../etc/afpd/mangle.c: In function ‘mangle_extension’:
../etc/afpd/mangle.c:33:15: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
   33 |     char *p = strrchr(uname, '.');
[291/318] Linking target libatalk/libatalk.so.20.0.0
../libatalk/util/server_ipc.c: In function ‘hint_flush_pending’:
../libatalk/util/server_ipc.c:635:35: warning: ‘write’ reading between 4092 and 2147483646 bytes from a region of size 2816 [-Wstringop-overread]
  635 |                     ssize_t ret = write(child->afpch_hint_fd,
../libatalk/util/server_ipc.c:612:10: note: source object ‘write_buf’ of size 2816
  612 |     char write_buf[HINT_BUF_SIZE * (IPC_HEADERLEN +
/usr/include/unistd.h:378:16: note: in a call to function ‘write’ declared with attribute ‘access (read_only, 2, 3)’
  378 | extern ssize_t write (int __fd, const void *__buf, size_t __n) __wur
[318/318] Linking target etc/afpd/afpd
../etc/afpd/file.c:448:21: warning: type of ‘AfpErr2name’ does not match original declaration [-Wlto-type-mismatch]
  448 |                     LOG(log_error, logtype_afpd,
../include/atalk/afp_util.h:11:20: note: return value type mismatch
   11 | extern const char *AfpErr2name(int err);
../include/atalk/afp_util.h:11:20: note: ‘AfpErr2name’ was previously declared here
../include/atalk/afp_util.h:11:20: note: code may be misoptimized unless ‘-fno-strict-aliasing’ is used
==> Entering fakeroot environment...
==> Starting package()...
ninja: no work to do.
Installing libatalk/libatalk.so.20.0.0 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib
Installing bin/afppasswd/afppasswd to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/dbd/dbd to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/misc/fce_listen to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/misc/afpldaptest to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/nad/nad to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/aecho/aecho to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/getzones/getzones to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/nbp/nbplkup to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/nbp/nbprgstr to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/nbp/nbpunrgstr to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/pap/pap to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/pap/papstatus to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing bin/rtmpqry/rtmpqry to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing etc/afpd/afpd to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing etc/netatalk/netatalk to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing etc/uams/uams_guest.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_passwd.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_randnum.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_dhx_passwd.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_dhx2_passwd.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_srp.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_dhx_pam.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_dhx2_pam.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_pam.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/uams/uams_gss.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk
Installing etc/cnid_dbd/cnid_dbd to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing etc/cnid_dbd/cnid_metad to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing etc/atalkd/atalkd to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing etc/papd/papd to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing contrib/a2boot/a2boot to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing contrib/timelord/timelord to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing contrib/macipgw/macipgw to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing doc/manpages/man1/afpldaptest.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/afppasswd.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/afpstats.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/addump.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/asip-status.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/dbd.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/fce_listen.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/nad.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/aecho.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/getzones.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/nbplkup.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/nbprgstr.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/pap.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man1/rtmpqry.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing doc/manpages/man5/afp_signature.conf.5 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man5
Installing doc/manpages/man5/afp_voluuid.conf.5 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man5
Installing doc/manpages/man5/afp.conf.5 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man5
Installing doc/manpages/man5/extmap.conf.5 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man5
Installing doc/manpages/man5/atalkd.conf.5 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man5
Installing doc/manpages/man5/papd.conf.5 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man5
Installing doc/manpages/man8/afpd.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/netatalk.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/cnid_dbd.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/cnid_metad.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/a2boot.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/atalkd.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/macipgw.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/papd.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/papstatus.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing doc/manpages/man8/timelord.8 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man8
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/acl.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/adouble.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/aep.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/afp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/afp_util.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/asp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/atp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/cnid.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/constant_time.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/ddp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/ea.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/globals.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/hash.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/iniparser_util.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/list.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/logger.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/netatalk_conf.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/nbp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/netddp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/pap.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/queue.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/rtmp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/uam.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/unicode.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/unix.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/util.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/vfs.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/volume.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/include/atalk/zip.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/atalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/sys/netatalk/aarp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/netatalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/sys/netatalk/at_var.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/netatalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/sys/netatalk/ddp.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/netatalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/sys/netatalk/ddp_var.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/netatalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/sys/netatalk/endian.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/netatalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/sys/netatalk/phase2.h to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/include/netatalk
Installing new directory /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc/dconf/db
Installing new directory /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/var/spool/netatalk
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/config/afp.conf to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/config/dconf/netatalk to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc/dconf/profile
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/config/dbus-session.conf to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/config/extmap.conf to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/config/atalkd.conf to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/config/macipgw.conf to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/config/papd.conf to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/config/README to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/var/lib/netatalk/CNID
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/config/pam/netatalk to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/etc/pam.d
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/contrib/bin_utils/afpstats to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/contrib/bin_utils/addump to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/contrib/bin_utils/asip-status to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/bin
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/doc/manpages/man1/nbp.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/doc/manpages/man1/nbpunrgstr.1 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man1
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/doc/manpages/man5/macipgw.conf.5 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/share/man/man5
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/distrib/initscripts/netatalk.service to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/systemd/system
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/distrib/initscripts/a2boot.service to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/systemd/system
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/distrib/initscripts/atalkd.service to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/systemd/system
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/distrib/initscripts/macipgw.service to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/systemd/system
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/distrib/initscripts/papd.service to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/systemd/system
Installing /var/tmp/pamac-build-tempest/netatalk/src/netatalk-4.5.0/build/distrib/initscripts/timelord.service to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/systemd/system
Installing symlink pointing to libatalk.so.20.0.0 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/libatalk.so.20
Installing symlink pointing to libatalk.so.20 to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/libatalk.so
Installing symlink pointing to uams_pam.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk/uams_clrtxt.so
Installing symlink pointing to uams_dhx_pam.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk/uams_dhx.so
Installing symlink pointing to uams_dhx2_pam.so to /var/tmp/pamac-build-tempest/netatalk/pkg/netatalk/usr/lib/netatalk/uams_dhx2.so
/etc/dconf/db/ibus.d: Failed to create file “/etc/dconf/db/ibus.7G96Q3”: Permission denied
/etc/dconf/db/local.d: Failed to create file “/etc/dconf/db/local.5S96Q3”: Permission denied
    Aborting...
I had no issues building it on my Testing branch system with pamac build netatalk:
Installing /var/tmp/pamac-build-scotty/netatalk/src/netatalk-4.5.0/build/distrib/initscripts/timelord.service to /var/tmp/pamac-build-scotty/netatalk/pkg/netatalk/usr/lib/systemd/system
Installing symlink pointing to libatalk.so.20.0.0 to /var/tmp/pamac-build-scotty/netatalk/pkg/netatalk/usr/lib/libatalk.so.20
Installing symlink pointing to libatalk.so.20 to /var/tmp/pamac-build-scotty/netatalk/pkg/netatalk/usr/lib/libatalk.so
Installing symlink pointing to uams_pam.so to /var/tmp/pamac-build-scotty/netatalk/pkg/netatalk/usr/lib/netatalk/uams_clrtxt.so
Installing symlink pointing to uams_dhx_pam.so to /var/tmp/pamac-build-scotty/netatalk/pkg/netatalk/usr/lib/netatalk/uams_dhx.so
Installing symlink pointing to uams_dhx2_pam.so to /var/tmp/pamac-build-scotty/netatalk/pkg/netatalk/usr/lib/netatalk/uams_dhx2.so
Skipping custom install script because DESTDIR is set '/usr/bin/ldconfig -v'
==> Tidying install...
  -> Removing libtool files...
  -> Removing static library files...
  -> Purging unwanted files...
  -> Stripping unneeded symbols from binaries and libraries...
  -> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "netatalk"...
  -> Generating .PKGINFO file...
  -> Generating .BUILDINFO file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: netatalk 4.5.0-1 (Tue 16 Jun 2026 07:10:27)
==> Cleaning up...
Checking keyring...        [1/1]
Checking integrity...        [1/1]
Loading packages files...        [1/1]
Checking file conflicts...        [1/1]
Checking available disk space...        [1/1]
Installing netatalk (4.5.0-1)...        [1/1]
Reloading system manager configuration...        [1/2]
Arming ConditionNeedsUpdate...        [2/2]
The difference I noticed between our outputs at the point where you encounter the error is that you have this line:
While I have this line:
Although that could be due to your desktop environment. You haven’t mentioned which DE you use, and it isn’t in your profile.
I do believe that dconf is Gnome-related (I run Plasma), so I am a litle hesitant to provide any further advice as I would not want to recommend any action which may mess up your system.
If you could please confirm which desktop environment you are using, then hopefully someone with knowledge of that DE, and dconf specifically, will be able to step in with further advice.
I’m sorry, yes I’m running Gnome.
Please provide your system information. :point_down:
inxi -zv8 (short-form)
Your privacy is respected
Sorry for the late reply, here’s the output of inxi:
  Kernel: 6.18.33-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=55594bba-ae18-4e54-ad2e-ce5506f12ebb rw quiet splash apparmor=1
  Desktop: GNOME v: 50.1 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 50.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: EVGA model: 131-GT-E767 v: Tylersburg
    serial: <superuser required> uuid: <superuser required> Firmware: BIOS
    vendor: Phoenix v: 6.00 PG date: 10/26/2010
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
    status: discharging
  System RAM: total: 12 GiB available: 11.67 GiB used: 2.52 GiB (21.6%)
  Array-1: capacity: 12 GiB note: est. slots: 6 modules: 6 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: A0 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    volts: N/A width (bits): data: 1 total: 65484 manufacturer: N/A part-no: N/A
    serial: N/A
  Device-2: A1 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-3: A2 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-4: A3 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-5: A4 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-6: A5 type: DDR2 detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Info: model: Intel Core i7 960 bits: 64 type: MT MCP arch: Nehalem
    gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
    model-id: 0x1A (26) stepping: 5 microcode: 0x1D
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1596 min/max: 1596/2660 scaling: driver: acpi-cpufreq
    governor: schedutil cores: 1: 1596 2: 1596 3: 1596 4: 1596 5: 1596 6: 1596
    7: 1596 8: 1596 bogomips: 42452
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
    cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flush_l1d fpu fxsr ht ibpb
    ibrs lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
    pbe pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good sep ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc vme xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape status: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Bonaire XTX [Radeon R7 260X/360]
    vendor: XFX Pine driver: radeon v: kernel alternate: amdgpu arch: GCN-2
    code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 2
    speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-1
    empty: DVI-D-1,DVI-I-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:6658
    class-ID: 0300 temp: 37.0 C
    compositor: gnome-shell driver: gpu: radeon display-ID: 0
  Monitor-1: DP-1 model: Dell G2724D serial: <filter> built: 2024
    res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.659 y: 0.329 green:
    x: 0.286 y: 0.631 blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
    size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9
    modes: 2560x1440, 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.1.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: (radeonsi bonaire ACO DRM 2.51
    6.18.33-1-MANJARO) device-ID: 1002:6658 memory: 1000 MiB unified: no
    display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 82801JI HD Audio driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Tobago HDMI Audio [Radeon R7
    360 / R9 OEM] vendor: XFX Pine driver: snd_hda_intel v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
    bus-ID: 03:00.1 chip-ID: 1002:aac0 class-ID: 0403
  API: ALSA v: k6.18.33-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.5 status: active with: 1: pipewire-pulse
    vendor: EVGA driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: be00 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 6-2:2 chip-ID: 2357:0604
  Local Storage: total: 2.05 TiB used: 1.32 TiB (64.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EADX-22TDHB0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 4D77
    scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q
  Optical-1: /dev/sr0 vendor: ASUS model: DRW-24B1ST j rev: 1.11
    dev-links: cdrom
    rw: cd-r,cd-rw,dvd-r state: running
  ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 255.1 GiB (55.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 55594bba-ae18-4e54-ad2e-ce5506f12ebb
  ID-2: /mnt/Backups raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 384.68 GiB (84.1%) fs: ext4 dev: /dev/sdd maj-min: 8:48 label: Backups
    uuid: ab3a709b-e0f4-431f-9716-210b2d5b2c63
  ID-3: /mnt/Storage raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 714.43 GiB (78.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Storage
    uuid: 4e39a9bb-f6a3-4f4a-83d5-1aeaca074caa
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/sdc1 maj-min: 8:33 size: 232.05 GiB fs: ntfs label: Windows
    uuid: E2C8BB34C8BB05B7
  ID-2: /dev/sdc2 maj-min: 8:34 size: 853 MiB fs: ntfs label: N/A
    uuid: 5A82C48282C463DB
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Device-1: 2-1:2 info: Alcor Micro Flash Card Reader/Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 250mA
    chip-ID: 058f:6362 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-4: 4-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Device-1: 6-2:2 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-8: 8-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Device-1: 8-2:2 info: Dell KB216 Wired Keyboard type: keyboard,HID
    chip-ID: 413c:2113 class-ID: 0300
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 9-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Hub-10: 10-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: radeon temp: 37.0 C
  Fan Speeds (rpm): N/A
  Packages: 1619 pm: dpkg pkgs: 0 pm: pacman pkgs: 1586 libs: 418
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 33
    1: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    3: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    4: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    5: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    6: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    7: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    8: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 309
  1: cpu: 57.9% command: firefox pid: 8016 mem: 684.5 MiB (5.7%)
  2: cpu: 22.0% command: firefox pid: 8386 mem: 465.7 MiB (3.8%)
  3: cpu: 18.3% command: firefox pid: 8470 mem: 290.1 MiB (2.4%)
  4: cpu: 12.3% command: localsearch-3 pid: 4366 mem: 50.0 MiB (0.4%)
  5: cpu: 9.9% command: gnome-shell pid: 4040 mem: 368.1 MiB (3.0%)
  Memory top: 5 of 309
  1: mem: 684.5 MiB (5.7%) command: firefox pid: 8016 cpu: 57.9%
  2: mem: 465.7 MiB (3.8%) command: firefox pid: 8386 cpu: 22.0%
  3: mem: 446.4 MiB (3.7%) command: thunderbird pid: 5204 cpu: 9.1%
  4: mem: 368.1 MiB (3.0%) command: gnome-shell pid: 4040 cpu: 9.9%
  5: mem: 290.1 MiB (2.4%) command: firefox pid: 8470 cpu: 18.3%
  Processes: 309 Power: uptime: 7m states: freeze,standby,mem,disk
    suspend: s2idle avail: shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 4.64 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 260
  Compilers: gcc: 16.1.1 Shell: Bash v: 5.3.9 running-in: gnome-terminal
    inxi: 3.3.40
There’s a new comment on the package page, so hopefully they’re aware of the issue now and will fix it.
Mod edit: added link to the AUR page comment
It seems that if dconf is already installed on the build system, package() fails with:
/etc/dconf/db/ibus.d: Failed to create file “/etc/dconf/db/ibus.U660Q3”: Permission denied
probably because the meson install assumes it’s installing directly into the system and not for packaging. Meson shouldn’t be running such post-install scripts in this situation and leave dconf update to pacman’s hooks.
Mod edit:- Please avoid consecutive posts. If there has been no response since your last post, and you wish to add more content, edit that post instead of creating a new one.
All tools needed are available beneath every post - Click the ellipsis (the three dots) if you don’t see the icon/button you need. Posts merged. No charge.
Looks like the latest package fixed the issue.
Mod edit: Consecutive posts merged (again).
