Hello everyone
I believe Neovim version 0.5 is released, but I do not get that version when I try sudo pacman -S neovim
even though I updated the package list with sudo pacman -Syy
What am I missing?
Hello everyone
What am I missing?
You must be on stable
branch. It is in unstable
and testing
- so the next stable
update should bring it to you, see Manjaro - Branch Compare.
Please don’t do that as it could lead to problems (partial updates) when installing packages later via pacman -S ..
Always initiate the update as well:
$ sudo pacman -Syu
If you just want to check for updates:
$ checkupdates
doesn’t interfere and only checks for and lists the available updates.
Thank you @freggel.doe. I shall use pacman -Syu
going forward.
How long does it typically take for a package to move to stable?
The stable
updates are accompanied by announcements, which are posted in #announcements:stable-updates . The frequency of updates varies sometimes (at the moment we are seeing one of the longest stretches), it’s usually every 2 weeks give or take a few days.
The latest was two days ago or depending on time zone.
