On some applications - if I open something that require to select a file from the disk, it opens NEMO instead of dolphin.
I don’t want this, and I don’t see why this happend.
For example: Brave Browser, Signal-Messenger Client.
The default-apps for filemanager are set to dolphin, even like inode/directory in the file-assignments.
Right, bad idea to install ‘nemo-run-with-nvidia-prime-run’ from AUR on a plasma desktop.
All you need to do is execute ‘prime-run’ in front of the app you want to run with Nvidia… in Dolphin, you could hit F4 to get Konsole and type that before the name of what you want to launch.
