Nemo - No Templates Found
I’ve recently noticed that my right click option in Nemo to “Create New Document” shows a greyed out “No templates installed”.
This has been working fine for a while, but there’s been a big update flurry lately.
My Templates are under a symlink that goes to a cloud synchronised folder that’s located elsewhere (so I can share my templates across my various machines and installs). In order to rule that out as causing some weirdness I tried removing it and manually copying the content over to a new Templates directory but that didn’t work either.
Does the “Templates” directory work purely by the virtue that it’s a directory in Home called “Templates” or is there a defined variable that makes it behave in a certain way, perhaps?
What does xdg say?
systemctl --user status xdg-user-dirs-update
xdg-user-dir TEMPLATES
cat ~/.config/user-dirs.dirs
Can’t reproduce.
Yes.
That’s it!
Thanks @cscs
XDG_DESKTOP_DIR="$HOME/Desktop"
XDG_DOWNLOAD_DIR="$HOME/"
XDG_TEMPLATES_DIR="$HOME/"
XDG_PUBLICSHARE_DIR="$HOME/Public"
XDG_DOCUMENTS_DIR="$HOME/Documents"
XDG_MUSIC_DIR="$HOME/Music/"
XDG_PICTURES_DIR="$HOME/Pictures/"
XDG_VIDEOS_DIR="$HOME/Videos/"
Looks like my templates and downloads directory paths are shot.
I suspect that this was updated at some point when I shifted the Downloads path (as that moved) - Quite why Templates got hosed at the same time I know not, but it would explain things.
I edited the config/user-dirs.dirs file and now all is well.
