Hello,
I’m running manjaro with cinnamon.
I can’t find a pattern to reproduce this bug but my nemo instance is constantly crashing, or at least lagging for a very long time. It sometimes takes a few minutes to open. The only way to make it work again is to reboot the whole system.
if i run :
~ >>> nemo --debug&
[1] 13014
~ >>> ** (nemo:13014): DEBUG: 16:51:31.429: Could not register nemo as a service, trying as a remote: Unable to acquire bus name 'org.Nemo'
this is what I got. It may be a clue. I already tried to reset nemo configuration file it didn’t change anything.
Let me know wich information I should share to get some more help about this very annoying bug. i’d rather not switch to another file manager.
Thank you
Hum, I think i’m dumb, it may be related to when my phone is plugged in. I just unplugged it and it seems to work again. it’s been month since I can not figure out what could be wrong. If it’s as simple as that sorry for bothering…
I’ll keep you informed.
We need your Output of
inxi -Fanzy
and after the last crash
journalctl -r |grep nemo|more
If you’re using some add-ons, deactivate them and over time reactive 1 by 1
So I used to find some AUR Add-ons crashes on nemo
File Manager.
hi thank you !
here is the result :
~ >>> inxi -Fanzy
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e96c09be-cdaf-473e-b3ce-af78d102e285 rw quiet apparmor=1
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 82WU v: Yoga Slim 6 14IAP8
serial: <superuser required> Chassis: type: 10 v: Yoga Slim 6 14IAP8
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> part-nu: LENOVO_MT_82WU_BU_idea_FM_Yoga Slim 6
14IAP8 uuid: <superuser required> UEFI: LENOVO v: KTCN39WW date: 08/18/2023
ID-1: BAT0 charge: 58.7 Wh (97.3%) condition: 60.3/65.0 Wh (92.7%)
volts: 17.4 min: 15.5 model: Celxpert type: Li-ion serial: <filter>
status: not charging cycles: 94
Info: model: 12th Gen Intel Core i5-1240P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x430
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 530 high: 1119 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 1119 2: 400 3: 400 4: 1048
5: 400 6: 400 7: 400 8: 400 9: 570 10: 400 11: 400 12: 400 13: 400 14: 400
15: 953 16: 400 bogomips: 67600
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: IMC Networks Integrated RGB Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 13d3:5285
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2240x1400 s-dpi: 96 s-size: 592x370mm (23.31x14.57")
s-diag: 698mm (27.48")
Monitor-1: eDP-1 model: AU Optronics 0x2698 built: 2020 res: 2240x1400
hz: 60 dpi: 190 gamma: 1.2 size: 300x188mm (11.81x7.4") diag: 354mm (13.9")
ratio: 16:10 modes: 2240x1400
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 476.94 GiB used: 166.78 GiB (35.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKCD512TFK
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 1004V5LN temp: 32.9 C
scheme: GPT
ID-1: / raw-size: 294.65 GiB size: 288.97 GiB (98.07%)
used: 166.72 GiB (57.7%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 63.9 MiB (25.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.35 GiB used: 8.13 GiB (53.0%)
Processes: 366 Power: uptime: 1h 39m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.13 GiB services: csd-power,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1502 pm: pacman pkgs: 1495 libs: 491 tools: pamac,yay pm: flatpak
pkgs: 7 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.33
mars 25 17:23:18 pompinette systemd-coredump[22524]: Process 22517 (nemo-extensions) of user 1000 dumped core.
#0 0x000055b2320d222f n/a (nemo-extensions-list + 0x222f)
#3 0x000055b2320d2335 n/a (nemo-extensions-list + 0x2335)
mars 25 17:23:18 pompinette kernel: nemo-extensions[22517]: segfault at 0 ip 000055b2320d222f sp 00007ffd7bcb9840 error 4 in nemo-extensio
ns-list[55b2320d2000+1000] likely on CPU 6 (core 12, socket 0)
mars 25 17:22:17 pompinette systemd-coredump[22232]: Process 22227 (nemo-extensions) of user 1000 dumped core.
#0 0x000055f5ed5b922f n/a (nemo-extensions-list + 0x222f)
#3 0x000055f5ed5b9335 n/a (nemo-extensions-list + 0x2335)
mars 25 17:22:16 pompinette kernel: nemo-extensions[22227]: segfault at 0 ip 000055f5ed5b922f sp 00007ffdb001a0e0 error 4 in nemo-extensio
ns-list[55f5ed5b9000+1000] likely on CPU 4 (core 8, socket 0)
mars 25 17:14:02 pompinette sudo[19450]: puf : TTY=pts/0 ; PWD=/home/puf ; USER=root ; COMMAND=/usr/bin/nemo
mars 25 16:10:40 pompinette dbus-broker-launch[1209]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 25 16:10:40 pompinette dbus-broker-launch[1209]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
ter the D-Bus name 'org.freedesktop.FileManager1'.
mars 25 16:10:16 pompinette dbus-broker-launch[1060]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 25 16:10:16 pompinette dbus-broker-launch[1060]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 24 18:58:30 pompinette dbus-broker-launch[55092]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 24 18:58:30 pompinette dbus-broker-launch[55092]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
fter the D-Bus name 'org.freedesktop.FileManager1'.
mars 24 15:47:11 pompinette dbus-broker-launch[1273]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 24 15:47:11 pompinette dbus-broker-launch[1273]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 24 15:32:20 pompinette dbus-broker-launch[1061]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 24 15:32:20 pompinette dbus-broker-launch[1061]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 23 18:25:35 pompinette dbus-broker-launch[1186]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 23 18:25:35 pompinette dbus-broker-launch[1186]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 23 18:25:23 pompinette dbus-broker-launch[1069]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 23 18:25:23 pompinette dbus-broker-launch[1069]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 23 17:32:27 pompinette dbus-broker-launch[17423]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 23 17:32:27 pompinette dbus-broker-launch[17423]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
mars 23 16:13:02 pompinette dbus-broker-launch[1182]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 23 16:13:02 pompinette dbus-broker-launch[1182]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 23 16:12:50 pompinette dbus-broker-launch[1070]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 23 16:12:50 pompinette dbus-broker-launch[1070]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 23 02:05:48 pompinette dbus-broker-launch[1207]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 23 02:05:48 pompinette dbus-broker-launch[1207]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 23 02:04:58 pompinette dbus-broker-launch[1084]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 23 02:04:58 pompinette dbus-broker-launch[1084]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 22 13:25:55 pompinette dbus-broker-launch[61423]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 22 13:25:55 pompinette dbus-broker-launch[61423]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
mars 21 18:40:00 pompinette dbus-broker-launch[26658]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 21 18:40:00 pompinette dbus-broker-launch[26658]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
mars 21 16:22:38 pompinette dbus-broker-launch[1410]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 21 16:22:38 pompinette dbus-broker-launch[1410]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 21 16:21:15 pompinette dbus-broker-launch[1073]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 21 16:21:15 pompinette dbus-broker-launch[1073]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 20 21:58:13 pompinette dbus-broker-launch[1138]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 20 21:58:13 pompinette dbus-broker-launch[1138]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 20 21:58:08 pompinette dbus-broker-launch[1033]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 20 21:58:08 pompinette dbus-broker-launch[1033]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 20 19:51:18 pompinette dbus-broker-launch[37970]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 20 19:51:18 pompinette dbus-broker-launch[37970]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
mars 20 16:17:57 pompinette dbus-broker-launch[14839]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 20 16:17:57 pompinette dbus-broker-launch[14839]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
mars 20 14:24:21 pompinette dbus-broker-launch[1251]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 20 14:24:21 pompinette dbus-broker-launch[1251]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 20 14:24:13 pompinette dbus-broker-launch[1085]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 20 14:24:13 pompinette dbus-broker-launch[1085]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 20 12:25:22 pompinette dbus-broker-launch[1196]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 20 12:25:22 pompinette dbus-broker-launch[1196]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 20 12:24:38 pompinette dbus-broker-launch[1069]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 20 12:24:38 pompinette dbus-broker-launch[1069]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 19 21:37:20 pompinette dbus-broker-launch[1163]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 19 21:37:20 pompinette dbus-broker-launch[1163]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 19 21:37:15 pompinette dbus-broker-launch[1057]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 19 21:37:15 pompinette dbus-broker-launch[1057]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 19 15:21:27 pompinette systemd-coredump[17945]: Process 17940 (nemo-extensions) of user 1000 dumped core.
#0 0x0000562f2d8c422f n/a (nemo-extensions-list + 0x222f)
#3 0x0000562f2d8c4335 n/a (nemo-extensions-list + 0x2335)
mars 19 15:21:27 pompinette kernel: nemo-extensions[17940]: segfault at 0 ip 0000562f2d8c422f sp 00007ffdfb5e6cf0 error 4 in nemo-extensio
ns-list[562f2d8c4000+1000] likely on CPU 1 (core 0, socket 0)
mars 19 14:46:27 pompinette systemd-coredump[4806]: Process 4801 (nemo-extensions) of user 1000 dumped core.
#0 0x000056238655322f n/a (nemo-extensions-list + 0x222f)
#3 0x0000562386553335 n/a (nemo-extensions-list + 0x2335)
mars 19 14:46:27 pompinette kernel: nemo-extensions[4801]: segfault at 0 ip 000056238655322f sp 00007ffeff855ff0 error 4 in nemo-extension
s-list[562386553000+1000] likely on CPU 6 (core 12, socket 0)
mars 19 14:42:39 pompinette sudo[3729]: puf : TTY=pts/0 ; PWD=/home/puf ; USER=root ; COMMAND=/usr/bin/nano /home/puf/.config/nemo
mars 19 14:39:11 pompinette dbus-broker-launch[1219]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 19 14:39:11 pompinette dbus-broker-launch[1219]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 19 14:38:56 pompinette dbus-broker-launch[1107]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 19 14:38:56 pompinette dbus-broker-launch[1107]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 19 13:37:43 pompinette dbus-broker-launch[1402]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 19 13:37:43 pompinette dbus-broker-launch[1402]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 19 13:37:01 pompinette dbus-broker-launch[1048]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 19 13:37:01 pompinette dbus-broker-launch[1048]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 20:58:16 pompinette dbus-broker-launch[1194]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 20:58:16 pompinette dbus-broker-launch[1194]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 20:58:09 pompinette dbus-broker-launch[1084]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 20:58:09 pompinette dbus-broker-launch[1084]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 16:12:41 pompinette dbus-broker-launch[1203]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 16:12:41 pompinette dbus-broker-launch[1203]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 16:12:35 pompinette dbus-broker-launch[1095]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 16:12:35 pompinette dbus-broker-launch[1095]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 15:58:17 pompinette cinnamon-session[1166]: CRITICAL: t+398.10228s: Unable to start session: A program required by the session fai
led to start. App ID: 'nemo-autostart.desktop'. Startup ID: '10127688bc9503b913171068709852020200000011660002'.
mars 17 15:58:17 pompinette cinnamon-session[1166]: WARNING: t+398.10201s: App 'nemo-autostart.desktop' respawning too quickly
mars 17 15:52:40 pompinette sudo[2705]: puf : TTY=pts/0 ; PWD=/home/puf ; USER=root ; COMMAND=/usr/bin/xed /usr/share/applications/ne
mo.desktop
mars 17 15:51:38 pompinette dbus-broker-launch[1158]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 15:51:38 pompinette dbus-broker-launch[1158]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 15:51:33 pompinette dbus-broker-launch[1063]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 15:51:33 pompinette dbus-broker-launch[1063]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 15:48:58 pompinette sudo[2767]: puf : TTY=pts/0 ; PWD=/home/puf ; USER=root ; COMMAND=/usr/bin/xed /usr/share/applications/ne
mo.desktop
mars 17 15:48:18 pompinette dbus-broker-launch[1212]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 15:48:18 pompinette dbus-broker-launch[1212]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 15:47:59 pompinette dbus-broker-launch[1083]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 15:47:59 pompinette dbus-broker-launch[1083]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 15:43:54 pompinette sudo[41031]: puf : TTY=pts/2 ; PWD=/home/puf ; USER=root ; COMMAND=/usr/bin/xed /usr/share/applications/n
emo.desktop
mars 17 15:42:54 pompinette sudo[40610]: puf : TTY=pts/2 ; PWD=/home/puf ; USER=root ; COMMAND=/usr/bin/nano /usr/share/applications/
nemo.desktop
mars 17 15:42:02 pompinette cinnamon-session[1150]: CRITICAL: t+5976.21964s: Unable to start session: A program required by the session fa
iled to start. App ID: 'nemo-autostart.desktop'. Startup ID: '1033e726323a543239171068054589464600000011500002'.
mars 17 15:42:02 pompinette cinnamon-session[1150]: WARNING: t+5976.21935s: App 'nemo-autostart.desktop' respawning too quickly
mars 17 15:33:26 pompinette sudo[36239]: puf : TTY=pts/1 ; PWD=/home/puf ; USER=root ; COMMAND=/usr/bin/nano /usr/share/applications/
nemo.desktop
mars 17 15:32:50 pompinette sudo[36077]: puf : TTY=pts/1 ; PWD=/home/puf ; USER=root ; COMMAND=/usr/bin/nano /usr/share/applications/
nemo.desktop
mars 17 14:02:25 pompinette dbus-broker-launch[1142]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 14:02:25 pompinette dbus-broker-launch[1142]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 14:02:15 pompinette dbus-broker-launch[1044]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 14:02:15 pompinette dbus-broker-launch[1044]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 10:07:18 pompinette dbus-broker-launch[1151]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 10:07:18 pompinette dbus-broker-launch[1151]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 17 10:07:13 pompinette dbus-broker-launch[1055]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 17 10:07:13 pompinette dbus-broker-launch[1055]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 16 23:34:18 pompinette dbus-broker-launch[1161]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 16 23:34:18 pompinette dbus-broker-launch[1161]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 16 23:34:14 pompinette dbus-broker-launch[1065]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 16 23:34:14 pompinette dbus-broker-launch[1065]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 15 13:18:42 pompinette dbus-broker-launch[17628]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 15 13:18:42 pompinette dbus-broker-launch[17628]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
mars 15 12:40:23 pompinette dbus-broker-launch[1177]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 15 12:40:23 pompinette dbus-broker-launch[1177]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 15 12:40:18 pompinette dbus-broker-launch[1070]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 15 12:40:18 pompinette dbus-broker-launch[1070]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 15 12:18:44 pompinette dbus-broker-launch[43594]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 15 12:18:44 pompinette dbus-broker-launch[43594]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
mars 15 09:23:11 pompinette dbus-broker-launch[1168]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 15 09:23:11 pompinette dbus-broker-launch[1168]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 15 09:21:30 pompinette dbus-broker-launch[1057]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 15 09:21:30 pompinette dbus-broker-launch[1057]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 14 17:30:11 pompinette dbus-broker-launch[1165]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 14 17:30:11 pompinette dbus-broker-launch[1165]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 14 17:30:02 pompinette dbus-broker-launch[1068]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 14 17:30:02 pompinette dbus-broker-launch[1068]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 13 19:58:04 pompinette dbus-broker-launch[1213]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 13 19:58:04 pompinette dbus-broker-launch[1213]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 13 19:57:59 pompinette dbus-broker-launch[1117]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 13 19:57:59 pompinette dbus-broker-launch[1117]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 11 05:21:14 pompinette dbus-broker-launch[1185]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 11 05:21:14 pompinette dbus-broker-launch[1185]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 11 05:21:03 pompinette dbus-broker-launch[1071]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 11 05:21:03 pompinette dbus-broker-launch[1071]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 10 01:03:21 pompinette dbus-broker-launch[1215]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 10 01:03:21 pompinette dbus-broker-launch[1215]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 10 01:02:58 pompinette dbus-broker-launch[1040]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 10 01:02:58 pompinette dbus-broker-launch[1040]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 08 19:03:11 pompinette dbus-broker-launch[68603]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bu
s name 'org.Nemo'.
mars 08 19:03:11 pompinette dbus-broker-launch[68603]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named a
mars 08 14:50:37 pompinette dbus-broker-launch[1161]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 08 14:50:37 pompinette dbus-broker-launch[1161]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 08 14:50:30 pompinette dbus-broker-launch[1042]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 08 14:50:30 pompinette dbus-broker-launch[1042]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
mars 08 14:25:48 pompinette dbus-broker-launch[1230]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus
name 'org.Nemo'.
mars 08 14:25:48 pompinette dbus-broker-launch[1230]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named af
It’s look like there could be does Extensions.
Deactivate them all, and see how it’s go after a while, if everything is doing well activate one and test it.
Then post your journal log again, direct after a crash.
By finding one that lead’s to crashes, it could be because does are not on the same Version with your nemo
At that point make the choice if you really need them or wait and check if they got updated.
One more points you could do to gain performance, in special if you’re doing some recursive file search in nemo
, is to sacrifice some of your disk space for swapfile
To your 16 GB Ram.
https://wiki.archlinux.org/title/Swap#Swap_file
