Hi all
Lately, after I get an updates notification, I need to use the update pamac command twice because AUR fails to sync and I get a message saying waiting for another package manager to quit.
I did see a similar topic on the forum but my problem happens frequently. The second time I enter sudo pamac update it works.
Please can someone advise.
Thank you for your time.
[manupc@manupc-2 ~]$ sudo pamac update
[sudo] password for manupc:
Preparing...
Failed to synchronize AUR database
Resolving dependencies...
Checking inter-conflicts...
To upgrade (3):
libpamac 11.7.3-1 (11.7.2-2.1) extra 887.8 kB
libpamac-flatpak-plugin 11.7.3-1 (11.7.2-2.1) extra 30.3 kB
libpamac-snap-plugin 11.7.3-1 (11.7.2-2.1) extra 26.5 kB
Total download size: 944.6 kB
Apply transaction ? [y/N] y
Waiting for another package manager to quit...
Preparing...
To upgrade (3):
Download of libpamac-snap-plugin (11.7.3-1) started
Download of libpamac-flatpak-plugin (11.7.3-1) finished
Download of libpamac-snap-plugin (11.7.3-1) finished
Download of libpamac (11.7.3-1) finished
Checking keyring... [3/3]
Checking integrity... [3/3]
Loading packages files... [3/3]
Checking file conflicts... [3/3]
Checking available disk space... [3/3]
Running pre-transaction hooks...
Creating Timeshift snapshot before upgrade... [1/1]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Upgrading libpamac (11.7.2-2.1 -> 11.7.3-1)... [1/3]
Upgrading libpamac-flatpak-plugin (11.7.2-2.1 -> 11.7.3-1)... [2/3]
Upgrading libpamac-snap-plugin (11.7.2-2.1 -> 11.7.3-1)... [3/3]
Reloading system manager configuration... [1/5]
Restarting marked services... [2/5]
Arming ConditionNeedsUpdate... [3/5]
Updating the MIME type database... [4/5]
Reloading system bus configuration... [5/5]
manupc@manupc-2 ~]$ inxi --full --admin --filter --width
Kernel: 6.6.75-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1adc77d4-359c-4d50-8e77-204cccc1b265 rw quiet apparmor=1
security=apparmor udev.log_priority=3 ibt=off
Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: Micro-Star model: PRO B660M-E DDR4 (MS-7D46) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 2.00 date: 12/27/2021
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x37
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB
desc: 6x1.2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 800 min/max: 800/4400 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 59916
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA GK208B [GeForce GT 730] vendor: ASUSTeK driver: nvidia
v: 470.256.02 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler-2 code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:1287
class-ID: 0300
Display: x11 server: X.Org v: 21.1.15 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: Unknown-1 mapped: HDMI-0 res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 102 size: 476x268mm (18.74x10.55") modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Info: Tools: de: xfce4-display-settings gpu: nvidia-settings,nvidia-smi
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 2
speed: 5 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
API: ALSA v: k6.6.75-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
