Yup, it does seem like the move luckily I was able to find a wireless mouse tooā¦ wasnāt sure I had a spare anywhere.
Thanks for your help!
Unfortunately the battery is completely dead, so that should be fun with a magnetic charger hahaha
I may still mess around with the older machine tho. I unmarked the thread as āsolveā on the off chance someone has the secret to getting the older machine to work, otherwise the thread would lock and even marked as solved no one will give it a look.
The desire for that sweet, sweet hit of nostalgia is strongā¦ thereās just something about those old PowerBook / PowerBook-looking machines that is just so cool to me.
Ah, but some simply swap the innards for something more Intel-compatible - quite popular for a while, too, as those machines were typically available for $100-$200 on eBay.
That sounds like an absolute project lmaoā¦ Iāll admit it would be neat tho. Iāve seen folks do it with the old PowerMacs, but never a laptop. That would be wild.
I think, first, I will worry about swapping the innards of my Thinkpad with inndards that work
And as a little bonus, I found a 1TB WD drive in the newer Macā¦ I may put that into the old one and do a proper install over the weekend (after all the other things I need to get done)
Neofetch is no longer being updated. Fastfetch seems to be the current goto (itās in the repoās) - you might like to switch to that (after all the other things).
Cheers.
Yeah, thatās a thing. I may check it out, but neofetch is just bash script so it should keep working for quite a while. Iām so used to typing it that Iāll probably keep using it until it stops working
I feel like Iām so close to getting the older Macbook to boot. I found a tool called Super Grub2 (SG2), which has a 32bit version. I flash that onto a USB stick and boot from that. Now hereās where things get a bit tricky.
SG2 finds all the .efi files on the ESP partition, however none of them boot. SG2 also allows me to decrypt the LUKS drive, at which point it is able to see my grub.cfg (this being on the encrypted root partition). If I try to boot the āManjaroā entry, the proper Manjaro GRUB screen appears (this is already far more than I was able to achieve previously), but things go wrong when it tries to set the encrypted drive as root and boot from itā¦ My assumption here is that this is because the drives are already encrypted, where as when booting normally they would still be encrypted at this point.
So Iām thinking that I either need to manually edit the menuentry so that it will work with the already unencrypted drives, or I can get to a grub rescue prompt via a 32bit .efi file I dropped on the drive (however this will not pick up the grub.cfg file for some reason) and maybe figure out how to boot from thereā¦ tho I have no idea how to use the grub rescue prompt, and from the searches Iāve done so far, I have not been successful.
I think my next move will be to copy my grub.cfg file to a partition that SG2 can read before decrypting and seeing if that āManjaroā entry shows upā¦
Again, always open to othersā insight and experience
SG2 also displays all the individual kernel files it finds, but those will not booth either.
EDIT: I got one of these kernel entries to ābootā by adding nomodesetting, but by that I mean it got to āwaiting for drive ā and just sat there after loading up some udev events
These might be of interest (and more likely to be successful); except using Debian (or Arch) rather than Manjaro (for the Old Mac):
I suggest these only for the old Mac project rather than for your current Manjaro disk.
Cheers.
