Need support for installing Finger Print Driver and Keyboard Central Nub point tracker for Asus Expertbook P2451FB
I have tried several options like fprint and nub sensepoint or track point. the hardware model is expertbook p2451fb
I have also tried fingerprint GUI and have some missing package metadata error and corrupted package even after compiling the git repository. I have also tried scanning the hardware but no results in fingerprint id. As per the windows drivers, I was able to look into it and the device seemed to be elan micro-technologies. Please help
  Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=9107f7ee-cff6-4d83-b1d7-78cdaabee8ee rw quiet splash apparmor=1
  Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
  Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK P2451FB_P2451FB v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: P2451FB v: 1.0 serial: <filter> UEFI: ASUSTeK
  v: P2451FB.301 date: 05/22/2020
  ID-1: BAT0 charge: 27.4 Wh (56.0%) condition: 48.9/48.0 Wh (101.8%)
  volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Discharging cycles: 2
  RAM: total: 7.62 GiB used: 3.67 GiB (48.2%)
  Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
  microcode: DE cache: L2: 8 MiB bogomips: 36799
  Speed: 700 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
  4: 700 5: 700 6: 700 7: 700 8: 700
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
  ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Type: srbds mitigation: TSX disabled
  Device-1: Intel UHD Graphics vendor: ASUSTeK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce MX110] vendor: ASUSTeK driver: nvidia
  v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
  chip-ID: 10de:174e class-ID: 0302
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-5:4 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.3
  direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  chip-ID: 8086:02c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: yes
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
  port: 4000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
  port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
  IF: eno2 state: down mac: <filter>
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
  chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 931.51 GiB used: 19.65 GiB (2.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
  rotation: 7200 rpm serial: <filter> rev: SDM1 scheme: GPT
  ID-1: / raw-size: 884.47 GiB size: 869.51 GiB (98.31%)
  used: 19.64 GiB (2.3%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
  uuid: 9107f7ee-cff6-4d83-b1d7-78cdaabee8ee
  ID-2: /boot/efi raw-size: 62 MiB size: 61.9 MiB (99.78%)
  used: 15.1 MiB (24.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 0FD8-96FE
  ID-1: /dev/sda2 maj-min: 8:2 size: 1024 KiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 42.98 GiB fs: ext4 label: ostree
  uuid: 71332f69-5902-4cac-89ff-819cb0c0e748
  ID-3: /dev/sda4 maj-min: 8:4 size: 4 GiB fs: ntfs label: DRIVERS
  uuid: 6E88E39488E3595B
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-4:3 info: Realtek RTS5129 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
  class-ID: ff00 serial: <filter>
  Device-2: 1-5:4 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-3: 1-10:5 info: Intel type: Bluetooth driver: btusb interfaces: 2
  rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2000
  Processes: 347 Uptime: 1h 01m wakeups: 2 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 Packages: 1239 pacman: 1216 lib: 302
  flatpak: 0 snap: 23 Shell: Zsh v: 5.8 running-in: gnome-terminal
  inxi: 3.3.04
Your inxi output doesn’t even show any fingerprint reader, so:
  • Try kernels 5.13 Stable and 5.14 RC-6 (:warning: 5.14 is an “experimental” kernel!!!)
  • If the fingerprint reader still doesn’t show up, contact your hardware manufacturer for the correct Linux drivers.
:sob:
I have upgraded kernel to the stable version, but the sensor isn’t picking up any data, I have shared the screenshot. will be waiting for next stable release.
I have a P2451FA Expertbook with the very same issues.
In addition, the laptop also has dedicated left- and right-click buttons above the touchpad area, and they do not work either. Below is the output of xinput list. The sensepoint nub (trackpoint device in the middle of the keyboard) is not even recognized…
⎡ Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ ASUE1201:00 04F3:3148 Mouse               id=10   [slave  pointer  (2)]
⎜   ↳ ASUE1201:00 04F3:3148 Touchpad            id=9    [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Power Button                              id=8    [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=12   [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Asus WMI hotkeys                          id=11   [slave  keyboard (3)]
    ↳ USB2.0 HD UVC WebCam: USB2.0 HD           id=13   [slave  keyboard (3)]
Hope the New kernel release would be able to fix this
Hi Fabby,
I tried to search for the elantech, but they do not have any means of communication for the support the get the insights for the assembly set for further instructions.
