My opening …
… hasn’t been answered ⟹
Perhaps this could be viewed as an xy- (or rather as yx-) problem, or unsolicited advertising of a “PROPER” DE, which shows open topics galore in these forums …
While I’ve stumbled over an answer for toolbar 𝑎𝑝𝑝𝑒𝑎𝑟𝑠 to be grayed out¹⁾, I’ve not been able to find, let alone to cure the reason for the coredump.
¹) I don’t remember where - but maybe in ~/.config/qt6ct - I found a weird entry for icon-theme. Setting that to Adwaita cured the appearance - but not the behavior.
⟹ So it took a little longer to configure BiT to a fairly satisfying state.
Without a user-GUI on the desktop, I resorted to using the laptop for setting up a configuration that might serve my intents, copy it to the desktop and edit/adjust it to the desktop’s users and layout.
Although ~/.config/backintime/config is basically human readable, I had some problems interpreting entries, especially for scheduled backups. … and I haven’t found any documentation re its exact format.
Moreover, the laptop didn’t create the scheduled backups. (I’d so far only used manual initiation via the GUI there.) … and BiT’s complaint …
𝐄𝐫𝐫𝐨𝐫
Cron is not running despite the crontab command being available. Scheduled backup jobs will not run. Cron might be installed but not enabled. Try the command "systemctl enable cron" or consult the support channels of your GNU/Linux distribution.
[✓OK]
… hadn’t been exactly helpful. (No Cron to be found anywhere.)
To my surprise, the desktop did produce scheduled backups, albeit at unexpected times. The former probably due to the fact that I had set Timeshift to do snapshots on schedule (while it was to do that only on demand @ the laptop) and I remembered that it took a shutdown/restart there to make that effective (which didn’t help for BiT).
Perhaps reading non-related topics in this Support forum (what I’d recommend anyway for learning Manjaro’s subtleties) pointed me to cronie instead of Cron. Installing and starting that did the trick.
Moreover, its status report seemed to shed more light on the reason for the user-GUI’s crash:
[tn@23ed538 ~]$ systemctl status cronie
● cronie.service - Command Scheduler
Loaded: loaded (/usr/lib/systemd/system/cronie.service; enabled; preset: disabled)
Active: active (running) since Wed 2025-10-29 13:35:58 CET; 20h ago
Invocation: 248f82d179d9476aad92b922ef4dffd5
Main PID: 542 (crond)
Tasks: 2 (limit: 37075)
Memory: 9.5G (peak: 12G)
CPU: 7min 30.219s
CGroup: /system.slice/cronie.service
├─ 542 /usr/sbin/crond -n
└─91435 /usr/sbin/anacron -s
Okt 30 09:45:00 23ed538 CROND[97962]: pam_unix(crond:session): session closed for user tn
Okt 30 09:45:00 23ed538 backintime[98016]: Hauptprofil(1) :: INFO: Profile "Hauptprofil" is not scheduled to run now.
Okt 30 09:45:00 23ed538 python[98032]: qt.qpa.xcb: could not connect to display :2
Okt 30 09:45:00 23ed538 python[98032]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Okt 30 09:45:00 23ed538 python[98032]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Okt 30 09:45:00 23ed538 python[98032]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: xcb, minimal, linuxfb, vkkhrdisplay, wayland, offscreen, minimalegl, eglfs, vnc, wayland-egl.
Okt 30 09:45:00 23ed538 systemd-coredump[98039]: [🡕] Process 98014 (python) of user 0 terminated abnormally without generating a coredump.
Okt 30 09:45:00 23ed538 backintime[98012]: configs@home(2) :: INFO: Profile "configs@home" is not scheduled to run now.
Okt 30 09:45:00 23ed538 systemd-coredump[98046]: [🡕] Process 98032 (python) of user 0 terminated abnormally without generating a coredump.
Okt 30 09:45:00 23ed538 backintime[98031]: data@workspace(3) :: INFO: Profile "data@workspace" is not scheduled to run now.
[tn@23ed538 ~]$
(I don’t know why meanwhile it doesn’t show these python complaints anymore - it still crashes anyway.)
So I resorted to my current work around: to use the root-GUI.
My earlier apprehension - that the backups wouldn’t be user accessible ²⁾ - did fortunately not prove true ³⁾ :
²) ↓ ·························· owned by root:root ······························ ↓ ³) ↙ owned by tn:tn
/mnt/bkp/backintime/23ed538/tn/data@workspace/20251109-111501-933/backup/…
/mnt/bkp/backintime/23ed538/tn/data@workspace/20251109-111501-933/backup/mnt/data/tn
…with all directories given d········x permissions.
Using the root-GUI I’m now able to configure my BiT-profiles.
But I still wonder why the user-GUI crashes on one machine and not on the other.
While both run BiT version 1.5.5, the kernels are Linux 66 / 616, but I won’t think that makes the difference.
Anyway, I’d highly appreciate answers to the above questions and where to find a detailed documentation re BiT’s config files, …/backintime/config, which the app pours all over the place (many more than just in ~/.config/ and ~/.local/share/).
… and because fresh system info seems to be a prime motivation for answering,
here’s the desktop’s …
[tn@23ed538 ~]$ inxi -zv8
Kernel: 6.6.107-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=d25d1a9b-c6a7-48d7-a710-98f6ca1bb234 rw quiet splash
udev.log_priority=3
Desktop: GNOME v: 48.5 tk: GTK v: 3.24.50 wm: gnome-shell
base: Arch Linux
Type: Desktop System: FUJITSU product: ESPRIMO D538 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: FUJITSU model: D3600-A1 v: S26361-D3600-A1
serial: <superuser required> uuid: <superuser required> UEFI: FUJITSU //
American Megatrends v: 5.0.0.13 R1.21.0 for D3600-A1x date: 07/04/2019
System RAM: total: 32 GiB available: 30.2 GiB used: 19.78 GiB (65.5%)
Device-1: DIMM CHA1 type: DDR4 detail: synchronous size: 16 GiB speed:
spec: 3200 MT/s actual: 2400 MT/s volts: curr: 1 width (bits): data: 64
total: 64 manufacturer: Crucial part-no: CP16G4DFRA32A.C8FF
serial: <filter>
Device-2: DIMM CHB2 type: DDR4 detail: synchronous size: 16 GiB speed:
spec: 3200 MT/s actual: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CP16G4DFRA32A.C8FF serial: <filter>
Info: model: Intel Pentium Gold G5600 bits: 64 type: MT MCP
arch: Coffee Lake level: v2 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 800 min/max: 800/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 31211
Flags: 3dnowprefetch abm acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts clflush clflushopt cmov constant_tsc cpuid
flexpriority flush_l1d fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibpb_exit_to_user ibrs intel_pt invpcid lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
vulnerable
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630]
vendor: Fujitsu Solutions driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1,HDMI-A-2
empty: DP-1, DP-2, DP-3, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e91
class-ID: 0300
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung S27D390 serial: <filter> built: 2015
res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green:
x: 0.329 y: 0.616 blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
640x480, 720x400
Monitor-2: HDMI-A-2 model: HS156PC built: 2021 res: 1920x1080 dpi: 163
gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue:
x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 345x194mm (13.58x7.64")
diag: 397mm (15.6") ratio: 5:4 modes: 1920x1080, 1600x900, 1280x1024,
1152x864, 1280x720, 1024x768, 800x600, 640x480
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e91 memory: 29.5 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xdpyinfo,xprop
Device-1: Intel Cannon Lake PCH cAVS vendor: Fujitsu Solutions
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
API: ALSA v: k6.6.107-1-MANJARO status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Fujitsu Solutions driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
driver: rtl8xxxu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-8:6 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u8 state: up mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.73 TiB used: 434.25 GiB (15.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 27.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A82 scheme: GPT
ID-1: / raw-size: 93.13 GiB size: 91.11 GiB (97.83%) used: 25.1 GiB (27.5%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: cme1t.manjaro_g
uuid: d25d1a9b-c6a7-48d7-a710-98f6ca1bb234
ID-2: /boot/efi raw-size: 954 MiB size: 952.1 MiB (99.80%)
used: 5.5 MiB (0.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: CME1T_EFI uuid: 4A16-8340
ID-3: /home raw-size: 93.13 GiB size: 91.11 GiB (97.83%)
used: 1.23 GiB (1.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: cme1t.mg_home uuid: 98bd367d-22a4-4028-906e-2f5ae44f1f17
ID-4: /mnt/bkp raw-size: 931.32 GiB size: 915.64 GiB (98.32%)
used: 231.3 GiB (25.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: wd2t.bkp
uuid: 46399e9f-c924-418b-b49e-fd610ab96b4f
ID-5: /mnt/data raw-size: 372.72 GiB size: 365.81 GiB (98.15%)
used: 167.55 GiB (45.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: cme1t.data uuid: 75b32bf9-4850-4499-94d6-cb737cc173d9
ID-1: swap-1 type: partition size: 36.32 GiB used: 9.06 GiB (25.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 8a3d6405-5b6b-4989-9631-0d94e08239f5
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 93.13 GiB fs: ext4
label: cme1t.manjaro_k uuid: d82e7bbf-2581-4d11-91fa-5cf19f5efb6d
ID-2: /dev/nvme0n1p6 maj-min: 259:6 size: 93.13 GiB fs: ext4
label: cme1t.mk_home uuid: f66763f4-5866-4c31-9e2a-793571ac5adb
ID-3: /dev/nvme0n1p8 maj-min: 259:8 size: 18.63 GiB fs: ext4
label: cme1t.mg_test uuid: db10dd45-b09e-4aa9-8e5a-c9169aad751d
ID-4: /dev/nvme0n1p9 maj-min: 259:9 size: 18.63 GiB fs: ext4
label: cme1t.mgt_home uuid: 3f28027a-6fc9-4a3e-9e23-38c4bbdae08c
ID-5: /dev/sda2 maj-min: 8:2 size: 372.9 GiB fs: ext4 label: wd2t.backup
uuid: d13f645b-d2ee-4af6-9ae7-ed84a4355e2e
ID-6: /dev/sda3 maj-min: 8:3 size: 1024 KiB fs: ext4 label: wd2t.dummy
uuid: 1d8df0e9-6028-42e1-8c69-da2e78aba055
ID-7: /dev/sda5 maj-min: 8:5 size: 558.79 GiB fs: ext4 label: wd2t.bkp.old
uuid: 0ccc4358-5553-49be-a2d5-62fcce9e24d9
Device-1: 1-2:2 info: SanDisk Ultra Fit type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 224mA chip-ID: 0781:5583 class-ID: 0806
serial: <filter>
Device-2: 1-5:14 info: YICHIP Wireless Device type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:1001 class-ID: 0301
Device-3: 1-6:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 1-7:5 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-7.1:7 info: SHARKOON GmbH [Mediatrack Edge Mini Keyboard]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 1ea7:0066 class-ID: 0301
Device-2: 1-8:6 info: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN
Adapter type: Network driver: rtl8xxxu interfaces: 1 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 40.0 C pch: 45.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1614 libs: 404
tools: gnome-software,pamac,yay
1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
2: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
3: https://manjaro.ynh.ovh/stable/$repo/$arch
Processes:
CPU top: 5 of 297
1: cpu: 20.8% command: firefox pid: 3338 mem: 2242.2 MiB (7.2%)
2: cpu: 18.2% command: gnome-shell pid: 1274 mem: 2199.3 MiB (7.1%)
3: cpu: 7.8% command: firefox pid: 495948 mem: 3181.6 MiB (10.2%)
4: cpu: 3.5% command: firefox pid: 3543 mem: 45.2 MiB (0.1%)
5: cpu: 2.0% command: firefox pid: 4117 mem: 301.8 MiB (0.9%)
Memory top: 5 of 297
1: mem: 3181.6 MiB (10.2%) command: firefox pid: 495948 cpu: 7.8%
2: mem: 2242.2 MiB (7.2%) command: firefox pid: 3338 cpu: 20.8%
3: mem: 2199.3 MiB (7.1%) command: gnome-shell pid: 1274 cpu: 18.2%
4: mem: 732.2 MiB (2.3%) command: firefox pid: 4393 cpu: 0.8%
5: mem: 427.8 MiB (1.3%) command: firefox pid: 834415 cpu: 0.3%
Processes: 297 Power: uptime: 7d 2h 31m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 7 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.07 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
running-in: gnome-terminal inxi: 3.3.39
[tn@23ed538 ~]$
and the one for the laptop:
~ inxi -zv8 ✔
Kernel: 6.16.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
root=UUID=ab46277f-9387-4ba4-a78d-c5d85119857d rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
base: Arch Linux
Type: Laptop System: FUJITSU product: CELSIUS H780 v: N/A
Mobo: FUJITSU model: FJNBB5D v: 757383-01R9500225
serial: <superuser required> part-nu: SK00 uuid: <superuser required>
UEFI: FUJITSU // Insyde v: Version 1.22 date: 11/16/2023
ID-1: BAT1 charge: 76.4 Wh (90.5%) condition: 84.5/96.5 Wh (87.6%)
volts: 16.32 min: 14.4 model: PAC CP722160-01 type: Li-ion serial: <filter>
charging: status: not charging cycles: 20
System RAM: total: 32 GiB available: 31 GiB used: 8.78 GiB (28.3%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2400 MT/s volts: curr: 1 min: 1.35 max: 1.35 width (bits): data: 64
total: 64 manufacturer: SK Hynix part-no: HMA82GS6AFR8N-UH
serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52799
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Fujitsu
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P600 Mobile] vendor: Fujitsu
driver: nvidia v: 580.82.09 alternate: nouveau,nova_core,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-08; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none empty: DP-1, DP-2, DP-3, DP-4, DP-5 bus-ID: 01:00.0
chip-ID: 10de:1cbc class-ID: 0300
Device-3: Chicony FJ Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b3b4
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0630 built: 2016 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.584 y: 0.365 green: x: 0.349 y: 0.580
blue: x: 0.161 y: 0.141 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
GT2) device-ID: 8086:3e9b memory: 30.27 GiB unified: yes display-ID: :2.0
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xdpyinfo,xprop
Device-1: Intel Cannon Lake PCH cAVS vendor: Fujitsu driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio vendor: Fujitsu
driver: snd_hda_intel v: kernel alternate: nova_core pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.16.8-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Fujitsu driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wwp0s20f0u4i12 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 476.94 GiB used: 71.43 GiB (15.0%)
model: MZVLB512HAJQ-00007 size: 476.94 GiB block-size: physical: 512 B
fw-rev: EXA7302Q temp: 29.9 C scheme: GPT
ID-1: / raw-size: 46.57 GiB size: 45.53 GiB (97.78%) used: 21.84 GiB (48.0%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: sme_5.ManjaroGNM
uuid: ab46277f-9387-4ba4-a78d-c5d85119857d
ID-2: /boot/efi raw-size: 477 MiB size: 476 MiB (99.80%)
used: 432 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SME_5_EFI uuid: 407C-EF8F
ID-3: /home raw-size: 9.31 GiB size: 9.07 GiB (97.38%)
used: 5.99 GiB (66.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: sme_5.MG_home uuid: 81135bcb-ea8f-40df-a191-f9f889f914e7
ID-4: /mnt/bkp raw-size: 176.59 GiB size: 172.76 GiB (97.83%)
used: 24.77 GiB (14.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: sme_5.MG_backup uuid: c36ae656-eb75-4218-8828-26090d9b1dec
ID-5: /mnt/data raw-size: 149.01 GiB size: 145.61 GiB (97.72%)
used: 18.84 GiB (12.9%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: sme_5.data uuid: fae9353f-dda4-4b69-9f6e-5179fa11200c
ID-1: swap-1 type: partition size: 39.12 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: sme_5.swap
uuid: 136dda25-3200-4c4d-8cd7-dce0de17bdd8
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 46.57 GiB fs: ext4
label: sme_5.ManjaroKDE uuid: 25f5f5ad-49fe-495c-861f-513c2bb77042
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 9.31 GiB fs: ext4
label: sme_5.MK_home uuid: 2f771f65-7d0a-4dc7-9b37-decd655d959f
Device-1: 1-2:2 info: Areson Corp Elecom MR-K013 Multicard Reader
chip-ID: 25a7:fa61 class-ID: 0301
Device-2: 1-4:3 info: Sierra Wireless EM7455 type: communication,CDC-data
driver: cdc_mbim interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1199:9075 class-ID: 0a00
serial: <filter>
Device-3: 1-7:4 info: Chicony FJ Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b3b4 class-ID: 0e02 serial: <filter>
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
System Temperatures: cpu: 44.0 C pch: 47.0 C mobo: N/A
Packages: pm: pacman pkgs: 1452 libs: 387 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0
1: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
3: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
4: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
5: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
6: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
7: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
8: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 440
1: cpu: 43.1% command: localsearch-extractor-3 pid: 432750
mem: 37.6 MiB (0.1%)
2: cpu: 3.8% command: gnome-shell pid: 3083 mem: 546.4 MiB (1.7%)
3: cpu: 0.4% command: firefox pid: 219569 mem: 970.7 MiB (3.0%)
4: cpu: 0.1% command: gnome-shell pid: 1629 mem: 302.8 MiB (0.9%)
5: cpu: 0.1% command: gjs pid: 3794 mem: 87.5 MiB (0.2%)
Memory top: 5 of 440
1: mem: 1058.5 MiB (3.3%) command: firefox pid: 221203 cpu: 0.1%
2: mem: 975.5 MiB (3.0%) command: firefox pid: 219917 cpu: 0.0%
3: mem: 974.2 MiB (3.0%) command: firefox pid: 227227 cpu: 0.0%
4: mem: 970.7 MiB (3.0%) command: firefox pid: 219569 cpu: 0.4%
5: mem: 936.0 MiB (2.9%) command: firefox pid: 226742 cpu: 0.0%
Processes: 440 Power: uptime: 11d 2h 33m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 6 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.34 GiB services: gsd-power,
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.39
~ ✔ 4s
