I’m having trouble with smb.conf file I can see the shared folder but when I click on it nothing happens , it should go to the mention path
here is my edit
[Share]
comment = Shared Folder
path = /mnt/d4ddebb1-76be-48bc-983d-785409b09f93/blawhi
read only = no
guest ok = yes
create mask = 0755
yes I’ve installed it from repo , I’ve successfully enabled the samba service I can also see it from my mobile and another laptop but I can’t access the path that I mentioned in smb.conf file
Are you sure the path to that folder is correct.When you open the folder blawhi on the computer samba is running and click properties is that the path it’s showing.
Actually it worked , I created the separate user using smbpasswd I deleted that and when I clicked on share by properties it created user in sambashare, it solved it. I might’ve messed up by adding a new user , I should’ve only added new smb password not new user
Thank you!!
