Need help with removing windows boot manager
Long story short I recently reinstalled Windows 11 on my pc on a different drive. During the partition stage I selected the drive and hit install.. but windows only created One partition and hijacked efi bootloader from manjaro..
So the only way for me to access manjaro or its bootloader by going bios (by F11) and selecting the hard disk as below picture indicate WD_750
(UEFI WD_750) selecting that will loads me in to manjaro bootloader
Also I did check for efi bootloader
Also I did end up deleting windows 11 from the other drive..
Could someone help me please :folded_hands: :cry:
Thank you
This is not a Windows support forum. If you need help booting Manjaro, please edit the topic title to reflect what you actually need help with.
I had exactly the same problem and this guy found solution and helped me to remove windows boot manager, easy to follow.
