Need Help with Error - Latest Update
Trying to install the latest update and I’m recieving this error so I can’t update:
“failed to prepare transaction target not found: electron24”
Does anyone know how to fix this?
Thank you
Run this first to update your mirrors and update your system:
sudo pacman-mirrors --geoip
sudo pacman -Syyu
If this already throws errors, please paste them here using the code function.
Thank you mithrial, that worked, fixed the issue. Everything is up to date now. Thank you.
