i need an idiots guide to installing this wifi adapter, lol. i was unable to find anything that could help me online. closest i could find was a kali linux video. thanks in advance.
iirc that uses the rtl8812au
driver. You can install rtl8812au-dkms-git
from AUR.
pamac build rtl8812au-dkms-git
that sort of worked… i had to install some header stuff… then once the drivers were installed, i tried to play a game and it kept getting disconnected, same on discord, everything kept cutting out. i also did a speed test, and it was a good speed. now if i connect to the same network on windows, its flawless. so maybe the drivers aren’t quite right… idk
