first of all
(base) [arhero@arhero-hpnotebook ~]$
why does it say base, that didnt happen earlier ?
first of all
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: amdgpu v: kernel
alternate: radeon arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 0d:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 41.0 C
Device-3: Chicony HP TrueVision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 04f2:b56c
Display: x11 server: X.org v: 1.21.1.8 compositor: xfwm v: 4.18.0 driver:
X: loaded: amdgpu,modesetting alternate: fbdev,vesa dri: iris,radeonsi
gpu: i915 display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x70ec built: 2015 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
device-ID: 8086:1616 memory: 7.49 GiB unified: yes
the inxi
I dont know. Something to do with your bashrc? Or are you using zsh?
Whatever the case - its not from that package you installed.
You might have a plethora of other issues … but for now I’m gonna focus on this one:
Great you are now using amdgpu for that card.
So … how does this go:
glxinfo | grep 'renderer string'
DRI_PRIME=1 glxinfo | grep 'renderer string'
OpenGL renderer string: Mesa Intel(R) HD Graphics 5500 (BDW GT2)
OpenGL renderer string: AMD Radeon R5 M330 (hainan, LLVM 16.0.6, DRM 3.54, 6.5.5-1-MANJARO)
Hurray. Prime seems to work as expected.
Now … your next order of business should be to handle your SWAP situation.
You dont have any.
And with 8 GB of RAM … that means you will freeze or crash rather easily.
(when you hit that 8GB ceiling).
My suggestion would be to use zram.
sudo pacman -Syu zram-generator
Then create file /etc/systemd/zram-generator.conf
with content:
[zram0]
zram-size = ram / 2
compression-algorithm = zstd
swap-priority = 100
fs-type = swap
Reboot and you should see SWAP enabled. ex:
swapon
im sorry but how do i create that file ?
I would use
sudoedit /etc/systemd/zram-generator.conf
But you probably havent set the environment variables so it will default to some editor like vi
So instead lets make sure you have a sane editor:
sudo pacman -Syu micro micro-manjaro
Then you can use it:
sudo micro /etc/systemd/zram-generator.conf
nvm did it
NAME TYPE SIZE USED PRIO
/dev/zram0 partition 3.8G 0B 100
swapon output
Great. We have now solved 2 of the biggest outstanding issues:
I believe these could drastically change your operating experience.
And with prime
validated otherwise … maybe you would like to test using it more generally? Such as for your game(s)?
Extra note here: For things like steam
please do not run steam itself with PRIME, but rather add it to the game launch options, like so:
DRI_PRIME=1 %command%
another small help., how do i install yay… when i do makepkg -si, it fails
==> Making package: yay-git 12.1.3.r4.gd368f99-1 (Sunday 22 October 2023 10:51:31 AM)
==> Retrieving sources...
-> Updating yay git repo...
yay ... Skipped
==> Extracting sources...
-> Creating working copy of yay git repo...
Reset branch 'makepkg'
==> Starting pkgver()...
==> Removing existing $pkgdir/ directory...
==> Starting build()...
/opt/yay-git/PKGBUILD: line 40: make: command not found
==> ERROR: A failure occurred in build().
Aborting...
edit : I installed make from pamac, and it works now
the game crashed rather than crashing my pc, so thats something
[11:07:41] [main/INFO]: Loading Minecraft 1.20.1 with Fabric Loader 0.14.23
[11:07:41] [main/INFO]: Fabric is preparing JARs on first launch, this may take a few seconds...
[11:07:42] [main/INFO]: Dependencies overridden for minecraft, lambdynlights, fabricloader, debugify
[11:07:42] [main/WARN]: Warnings were found!
- 'Minecraft' (minecraft) 1.20.1 recommends any version after 5.4.1 of Fabulously Optimized, which is missing!
- You should install any version after 5.4.1 of Fabulously Optimized for the optimal experience.
[11:07:42] [main/INFO]: Loading 149 mods:
- advancementinfo 1.20-fabric0.83.0-1.4
- animatica 0.6+1.20
- bettermounthud 1.2.2
- borderlessmining 1.1.8+1.20.1
- capes 1.5.2+1.20
- citresewn 1.1.3+1.20
\-- citresewn-defaults 1.1.3+1.20
- cloth-config 11.1.106
\-- cloth-basic-math 0.6.1
- continuity 3.0.0-beta.4+1.20.1
- controlify 1.6.0+1.20
|-- dev_isxander_sdl2-jni 2.28.2-26
|-- org_hid4java_hid4java 0.7.0
\-- org_quiltmc_quilt-json5 1.0.3
- debugify 1.20.1+2.0
- dynamic_fps 3.2.1
- e4mc_minecraft 4.0.1
- enhancedblockentities 0.9+1.20
|-- advanced_runtime_resource_pack 0.6.7
\-- spruceui 5.0.0+1.20
- entity_model_features 1.0.2
- entity_texture_features 4.5.1
\-- org_apache_httpcomponents_httpmime 4.5.10
- entityculling 1.6.2-mc1.20.1
- fabric-api 0.90.0+1.20.1
|-- fabric-api-base 0.4.30+7abfd51577
|-- fabric-api-lookup-api-v1 1.6.35+4d8536c977
|-- fabric-biome-api-v1 13.0.12+215bbe9677
|-- fabric-block-api-v1 1.0.10+92a0d36777
|-- fabric-block-view-api-v2 1.0.0+92a0d36777
|-- fabric-blockrenderlayer-v1 1.1.40+b3afc78b77
|-- fabric-client-tags-api-v1 1.1.1+97bb207577
|-- fabric-command-api-v1 1.2.33+f71b366f77
|-- fabric-command-api-v2 2.2.12+b3afc78b77
|-- fabric-commands-v0 0.2.50+df3654b377
|-- fabric-containers-v0 0.1.63+df3654b377
|-- fabric-content-registries-v0 4.0.10+57aed33f77
|-- fabric-convention-tags-v1 1.5.4+a1a980da77
|-- fabric-crash-report-info-v1 0.2.18+aeb40ebe77
|-- fabric-data-generation-api-v1 12.3.2+d7b148e077
|-- fabric-dimensions-v1 2.1.53+8536527b77
|-- fabric-entity-events-v1 1.5.22+b3afc78b77
|-- fabric-events-interaction-v0 0.6.1+e91849a877
|-- fabric-events-lifecycle-v0 0.2.62+df3654b377
|-- fabric-game-rule-api-v1 1.0.38+b04edc7a77
|-- fabric-item-api-v1 2.1.27+b3afc78b77
|-- fabric-item-group-api-v1 4.0.11+d7b148e077
|-- fabric-key-binding-api-v1 1.0.36+fb8d95da77
|-- fabric-keybindings-v0 0.2.34+df3654b377
|-- fabric-lifecycle-events-v1 2.2.21+b3afc78b77
|-- fabric-loot-api-v2 1.2.0+96dfa95977
|-- fabric-loot-tables-v1 1.1.44+9e7660c677
|-- fabric-message-api-v1 5.1.8+d7b148e077
|-- fabric-mining-level-api-v1 2.1.49+b3afc78b77
|-- fabric-model-loading-api-v1 1.0.2+709a987177
|-- fabric-models-v0 0.4.1+9386d8a777
|-- fabric-networking-api-v1 1.3.10+eeb8eb3677
|-- fabric-networking-v0 0.3.50+df3654b377
|-- fabric-object-builder-api-v1 11.1.1+6beca84877
|-- fabric-particles-v1 1.1.1+201a23a077
|-- fabric-recipe-api-v1 1.0.20+b3afc78b77
|-- fabric-registry-sync-v0 2.3.2+4df89eb277
|-- fabric-renderer-api-v1 3.2.0+39a511ba77
|-- fabric-renderer-indigo 1.5.0+39a511ba77
|-- fabric-renderer-registries-v1 3.2.45+df3654b377
|-- fabric-rendering-data-attachment-v1 0.3.36+92a0d36777
|-- fabric-rendering-fluids-v1 3.0.27+b3afc78b77
|-- fabric-rendering-v0 1.1.48+df3654b377
|-- fabric-rendering-v1 3.0.7+b3afc78b77
|-- fabric-resource-conditions-api-v1 2.3.6+d7b148e077
|-- fabric-resource-loader-v0 0.11.9+132c48c177
|-- fabric-screen-api-v1 2.0.7+b3afc78b77
|-- fabric-screen-handler-api-v1 1.3.29+b3afc78b77
|-- fabric-sound-api-v1 1.0.12+b3afc78b77
|-- fabric-transfer-api-v1 3.3.1+195226a777
\-- fabric-transitive-access-wideners-v1 4.3.0+6c31357e77
- fabric-language-kotlin 1.10.10+kotlin.1.9.10
|-- org_jetbrains_kotlin_kotlin-reflect 1.9.10
|-- org_jetbrains_kotlin_kotlin-stdlib 1.9.10
|-- org_jetbrains_kotlin_kotlin-stdlib-jdk7 1.9.10
|-- org_jetbrains_kotlin_kotlin-stdlib-jdk8 1.9.10
|-- org_jetbrains_kotlinx_atomicfu-jvm 0.22.0
|-- org_jetbrains_kotlinx_kotlinx-coroutines-core-jvm 1.7.3
|-- org_jetbrains_kotlinx_kotlinx-coroutines-jdk8 1.7.3
|-- org_jetbrains_kotlinx_kotlinx-datetime-jvm 0.4.0
|-- org_jetbrains_kotlinx_kotlinx-serialization-cbor-jvm 1.6.0
|-- org_jetbrains_kotlinx_kotlinx-serialization-core-jvm 1.6.0
\-- org_jetbrains_kotlinx_kotlinx-serialization-json-jvm 1.6.0
- fabricloader 0.14.23
- fabricskyboxes 0.7.3+mc1.20.1
- fabrishot 1.10.0
- fadeless 1.0.1
- fastquit 3.0.0+1.20+
- ferritecore 6.0.0
- fsb-interop 1.3.6+mc1.20.1-build.50
- immediatelyfast 1.2.6+1.20.2
|-- com_github_llamalad7_mixinextras 0.2.0-rc.5
\-- net_lenni0451_reflect 1.2.4
- indium 1.0.27+mc1.20.1
- iris 1.6.10
|-- io_github_douira_glsl-transformer 2.0.0-pre13
|-- org_anarres_jcpp 1.4.14
\-- org_antlr_antlr4-runtime 4.11.1
- isxander-main-menu-credits 1.1.2
- java 17
- lambdynlights 2.3.2+1.20.1
|-- pride 1.2.0+1.19.4
- languagereload 1.5.9+1.20.1
\-- com_github_llamalad7_mixinextras 0.2.0-rc.5
- lithium 0.11.2
- memoryleakfix 1.1.2
- minecraft 1.20.1
- mixintrace 1.1.1+1.17
- modelfix 1.14
- modernfix 5.8.1+mc1.20.1
- modmenu 7.2.2
- morechathistory 1.1.1
- moreculling 1.20.1-0.19.0
\-- conditional-mixin 0.3.2
- nochatreports 1.20.1-v2.2.2
- optigui 2.1.5
|-- optiglue 2.1.5-mc.1.19.3
|-- org_apache_commons_commons-text 1.10.0
\-- org_ini4j_ini4j 0.5.4
- puzzle 1.5.2+1.20
|-- midnightlib 1.4.1
|-- puzzle-base 1.5.2+1.20
|-- puzzle-gui 1.5.2+1.20
|-- puzzle-models 1.5.2+1.20
\-- puzzle-splashscreen 1.5.2+1.20
- reeses-sodium-options 1.6.5+mc1.20.1-build.95
- rrls 3.2.0-1.20.1-fabric
- sodium 0.5.3
- sodium-extra 0.5.1+mc1.20.1-build.112
|-- caffeineconfig 1.3.0+1.17
\-- crowdin-translate 1.4+1.19.3
- yet_another_config_lib_v3 3.2.1+1.20
|-- com_twelvemonkeys_common_common-image 3.10.0-SNAPSHOT
|-- com_twelvemonkeys_common_common-io 3.10.0-SNAPSHOT
|-- com_twelvemonkeys_common_common-lang 3.10.0-SNAPSHOT
|-- com_twelvemonkeys_imageio_imageio-core 3.10.0-SNAPSHOT
|-- com_twelvemonkeys_imageio_imageio-metadata 3.10.0-SNAPSHOT
|-- com_twelvemonkeys_imageio_imageio-webp 3.10.0-SNAPSHOT
|-- org_quiltmc_parsers_gson 0.2.1
\-- org_quiltmc_parsers_json 0.2.1
- yosbr 0.1.2
- zoomify 2.11.2
|-- com_akuleshov7_ktoml-core-jvm 0.4.1
|-- dev_isxander_settxi_settxi-core 2.10.6
\-- dev_isxander_settxi_settxi-kotlinx-serialization 2.10.6
[11:07:42] [main/INFO]: Applying default options... (YOSBR)
[11:07:42] [main/INFO]: Applying default options for /config/modmenu.json from /config/yosbr/config/modmenu.json
[11:07:42] [main/INFO]: Applying default options for /config/midnightcontrols.json from /config/yosbr/config/midnightcontrols.json
[11:07:42] [main/INFO]: Applying default options for /config/fastquit.toml from /config/yosbr/config/fastquit.toml
[11:07:42] [main/INFO]: Applying default options for /config/midnightlib.json from /config/yosbr/config/midnightlib.json
[11:07:42] [main/INFO]: Applying default options for /config/puzzle.json from /config/yosbr/config/puzzle.json
[11:07:42] [main/INFO]: Applying default options for /config/moreculling.toml from /config/yosbr/config/moreculling.toml
[11:07:42] [main/INFO]: Applying default options for /config/citresewn.json from /config/yosbr/config/citresewn.json
[11:07:42] [main/INFO]: Applying default options for /config/modernfix-mixins.properties from /config/yosbr/config/modernfix-mixins.properties
[11:07:42] [main/INFO]: Applying default options for /config/controlify.json from /config/yosbr/config/controlify.json
[11:07:42] [main/INFO]: Applying default options for /config/sodium-options.json from /config/yosbr/config/sodium-options.json
[11:07:42] [main/INFO]: Applying default options for /config/NoChatReports/NCR-Common.json from /config/yosbr/config/NoChatReports/NCR-Common.json
[11:07:42] [main/INFO]: Applying default options for /config/NoChatReports/NCR-Client.json from /config/yosbr/config/NoChatReports/NCR-Client.json
[11:07:42] [main/INFO]: Applying default options for /config/NoChatReports/NCR-Encryption.json from /config/yosbr/config/NoChatReports/NCR-Encryption.json
[11:07:42] [main/INFO]: Applying default options for /config/iris.properties from /config/yosbr/config/iris.properties
[11:07:42] [main/INFO]: Applying default options for /config/dynamic_fps.json from /config/yosbr/config/dynamic_fps.json
[11:07:42] [main/INFO]: Applying default options for /config/debugify.json from /config/yosbr/config/debugify.json
[11:07:42] [main/INFO]: Applying default options for /config/cem.conf from /config/yosbr/config/cem.conf
[11:07:42] [main/INFO]: Applying default options for /config/borderlessmining.json from /config/yosbr/config/borderlessmining.json
[11:07:42] [main/INFO]: Applying default options for /config/capes.json5 from /config/yosbr/config/capes.json5
[11:07:42] [main/INFO]: Applying default options for /config/entity_texture_features.json from /config/yosbr/config/entity_texture_features.json
[11:07:42] [main/INFO]: Applying default options for /config/lambdynlights.toml from /config/yosbr/config/lambdynlights.toml
[11:07:42] [main/INFO]: Applying default options for /options.txt from /config/yosbr/options.txt
[11:07:43] [main/INFO]: SpongePowered MIXIN Subsystem Version=0.8.5 Source=file:/home/arhero/ATLauncher/libraries/net/fabricmc/sponge-mixin/0.12.5+mixin.0.8.5/sponge-mixin-0.12.5+mixin.0.8.5.jar Service=Knot/Fabric Env=CLIENT
[11:07:43] [main/INFO]: Compatibility level set to JAVA_16
[11:07:43] [main/INFO]: Compatibility level set to JAVA_17
[11:07:44] [main/INFO]: Preloading Debugify
[11:07:44] [main/WARN]: Reference map 'entity_model_features_fabric_1.20-fabric-refmap.json' for entity_model_features.mixins.json could not be read. If this is a development environment you can ignore this message
[11:07:44] [main/INFO]: Loaded configuration file for Lithium: 115 options available, 1 override(s) found
[11:07:44] [main/INFO]: Loaded configuration file for ModernFix 5.8.1+mc1.20.1: 52 options available, 1 override(s) found
[11:07:44] [main/WARN]: Option 'mixin.perf.dynamic_resources' overriden (by user configuration) to 'true'
[11:07:44] [main/INFO]: Applying Nashorn fix
[11:07:44] [main/INFO]: Loaded configuration file for Sodium: 41 options available, 3 override(s) found
[11:07:44] [main/INFO]: Loaded configuration file for Sodium Extra: 32 options available, 0 override(s) found
[11:07:44] [main/WARN]: Error loading class: de/maxhenkel/voicechat/voice/client/KeyEvents (java.lang.ClassNotFoundException: de/maxhenkel/voicechat/voice/client/KeyEvents)
[11:07:44] [main/WARN]: Error loading class: de/maxhenkel/voicechat/voice/client/PTTKeyHandler (java.lang.ClassNotFoundException: de/maxhenkel/voicechat/voice/client/PTTKeyHandler)
[11:07:45] [main/WARN]: Force disabled MC-121772 because it only applies to OS: MAC
[11:07:45] [main/WARN]: Force disabled MC-59810 because it only applies to OS: MAC
[11:07:46] [main/WARN]: Force-disabling mixin 'alloc.blockstate.StateMixin' as rule 'mixin.alloc.blockstate' (added by mods [ferritecore]) disables it and children
[11:07:46] [main/WARN]: Error loading class: net/fabricmc/fabric/impl/client/model/ModelLoadingRegistryImpl$LoaderInstance (java.lang.ClassNotFoundException: net/fabricmc/fabric/impl/client/model/ModelLoadingRegistryImpl$LoaderInstance)
[11:07:46] [main/WARN]: @Mixin target net.fabricmc.fabric.impl.client.model.ModelLoadingRegistryImpl$LoaderInstance was not found modernfix-fabric.mixins.json:perf.dynamic_resources.LoaderInstanceMixin from mod modernfix
[11:07:46] [main/WARN]: Error loading class: me/jellysquid/mods/sodium/client/render/occlusion/BlockOcclusionCache (java.lang.ClassNotFoundException: me/jellysquid/mods/sodium/client/render/occlusion/BlockOcclusionCache)
[11:07:46] [main/WARN]: Force-disabling mixin 'features.render.entity.CuboidMixin' as rule 'mixin.features.render.entity' (added by mods [iris]) disables it and children
[11:07:46] [main/WARN]: Force-disabling mixin 'features.render.entity.ModelPartMixin' as rule 'mixin.features.render.entity' (added by mods [iris]) disables it and children
[11:07:46] [main/WARN]: Force-disabling mixin 'features.render.entity.cull.EntityRendererMixin' as rule 'mixin.features.render.entity' (added by mods [iris]) disables it and children
[11:07:46] [main/WARN]: Force-disabling mixin 'features.render.entity.shadows.EntityRenderDispatcherMixin' as rule 'mixin.features.render.entity' (added by mods [iris]) disables it and children
[11:07:46] [main/WARN]: Force-disabling mixin 'features.render.gui.font.GlyphRendererMixin' as rule 'mixin.features.render.gui.font' (added by mods [iris]) disables it and children
[11:07:46] [main/WARN]: Force-disabling mixin 'features.render.world.sky.BackgroundRendererMixin' as rule 'mixin.features.render.world.sky' (added by mods [iris]) disables it and children
[11:07:46] [main/WARN]: Force-disabling mixin 'features.render.world.sky.ClientWorldMixin' as rule 'mixin.features.render.world.sky' (added by mods [iris]) disables it and children
[11:07:46] [main/WARN]: Force-disabling mixin 'features.render.world.sky.WorldRendererMixin' as rule 'mixin.features.render.world.sky' (added by mods [iris]) disables it and children
[11:07:46] [main/INFO]: [MemoryLeakFix] Will be applying 3 memory leak fixes!
[11:07:46] [main/INFO]: [MemoryLeakFix] Currently enabled memory leak fixes: [targetEntityLeak, biomeTemperatureLeak, hugeScreenshotLeak]
[11:07:47] [main/WARN]: Error loading class: me/jellysquid/mods/sodium/client/render/occlusion/BlockOcclusionCache (java.lang.ClassNotFoundException: me/jellysquid/mods/sodium/client/render/occlusion/BlockOcclusionCache)
[11:07:47] [main/WARN]: Error loading class: org/jetbrains/annotations/ApiStatus$Internal (java.lang.ClassNotFoundException: org/jetbrains/annotations/ApiStatus$Internal)
[11:07:47] [main/INFO]: I used the json to destroy the json
[11:07:47] [main/INFO]: Searching for graphics cards...
[11:07:47] [main/INFO]: Initializing MixinExtras via com.llamalad7.mixinextras.service.MixinExtrasServiceImpl(version=0.2.0-rc.5).
[11:07:47] [main/INFO]: Found graphics card: GraphicsAdapterInfo[vendor=INTEL, name=HD Graphics 5500, version=unknown]
[11:07:49] [main/INFO]: Mixing common.MixinFriendlyByteBuf from mixins/common/nochatreports.mixins.json into net.minecraft.class_2540
[11:07:49] [main/INFO]: Renaming synthetic method lambda$onWriteJsonWithCodec$1(Ljava/lang/Object;Ljava/lang/String;)Lio/netty/handler/codec/EncoderException; to mdd21ae9$nochatreports$lambda$onWriteJsonWithCodec$1$0 in mixins/common/nochatreports.mixins.json:common.MixinFriendlyByteBuf from mod nochatreports
[11:07:49] [main/INFO]: Renaming synthetic method lambda$onReadJsonWithCodec$0(Ljava/lang/String;)Lio/netty/handler/codec/DecoderException; to mdd21ae9$nochatreports$lambda$onReadJsonWithCodec$0$1 in mixins/common/nochatreports.mixins.json:common.MixinFriendlyByteBuf from mod nochatreports
[11:07:51] [main/INFO]: Injecting BlockStateBase cache population hook into getNeighborPathNodeType from me.jellysquid.mods.lithium.mixin.ai.pathing.AbstractBlockStateMixin
[11:07:51] [main/INFO]: Injecting BlockStateBase cache population hook into getPathNodeType from me.jellysquid.mods.lithium.mixin.ai.pathing.AbstractBlockStateMixin
[11:07:51] [main/INFO]: Injecting BlockStateBase cache population hook into getAllFlags from me.jellysquid.mods.lithium.mixin.util.block_tracking.AbstractBlockStateMixin
[11:07:54] [main/INFO]: Mixing server.MixinServerGamePacketListenerImpl from mixins/common/nochatreports.mixins.json into net.minecraft.class_3244
[11:07:56] [main/WARN]: Method overwrite conflict for method_21740 in modernfix-common.mixins.json:perf.remove_biome_temperature_cache.BiomeMixin from mod modernfix, previously written by me.jellysquid.mods.lithium.mixin.world.temperature_cache.BiomeMixin. Skipping method.
[11:07:57] [main/INFO]: Vanilla bootstrap took 8010 milliseconds
[11:07:57] [Render thread/INFO]: Mixing client.MixinMinecraft from mixins/common/nochatreports.mixins.json into net.minecraft.class_310
[11:07:57] [Render thread/INFO]: Mixing client.MixinMinecraft from mixins/fabric/nochatreports-fabric.mixins.json into net.minecraft.class_310
[11:07:57] [Render thread/INFO]: Mixing client.MixinTitleScreen from mixins/common/nochatreports.mixins.json into net.minecraft.class_442
[11:07:58] [Render thread/INFO]: Mixing client.MixinChatScreen from mixins/common/nochatreports.mixins.json into net.minecraft.class_408
[11:07:58] [Render thread/INFO]: Renaming synthetic method lambda$onInit$4()Lnet/minecraft/class_2561; to mdd21ae9$nochatreports$lambda$onInit$4$3 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[11:07:58] [Render thread/INFO]: Renaming synthetic method lambda$onInit$3(Lnet/minecraft/class_4185;)V to mdd21ae9$nochatreports$lambda$onInit$3$4 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[11:07:58] [Render thread/INFO]: Renaming synthetic method lambda$onInit$2()Lnet/minecraft/class_2561; to mdd21ae9$nochatreports$lambda$onInit$2$5 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[11:07:58] [Render thread/INFO]: Renaming synthetic method lambda$onInit$1(Lnet/minecraft/class_4185;)V to mdd21ae9$nochatreports$lambda$onInit$1$6 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[11:07:58] [Render thread/INFO]: Renaming synthetic method lambda$onBeforeMessage$0(Ljava/lang/String;Lorg/spongepowered/asm/mixin/injection/callback/CallbackInfoReturnable;Lcom/aizistral/nochatreports/common/encryption/Encryptor;)V to mdd21ae9$nochatreports$lambda$onBeforeMessage$0$7 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[11:07:58] [Render thread/INFO]: Environment: authHost='https://authserver.mojang.com', accountsHost='https://api.mojang.com', sessionHost='https://sessionserver.mojang.com', servicesHost='https://api.minecraftservices.com', name='PROD'
[11:07:58] [Render thread/INFO]: Mixing client.MixinYggdrasilUserApiService from mixins/common/nochatreports.mixins.json into com.mojang.authlib.yggdrasil.YggdrasilUserApiService
[11:07:59] [Render thread/INFO]: Setting user: ARhero
[11:07:59] [Render thread/INFO]: Bypassed Mojang DFU
[11:07:59] [Render thread/INFO]: Mixing client.MixinToastComponent from mixins/common/nochatreports.mixins.json into net.minecraft.class_374
[11:07:59] [Render thread/INFO]: Saving config because the loaded bug fixes are different to stored json.
[11:07:59] [Render thread/INFO]: Saving Debugify
[11:07:59] [Render thread/INFO]: Enabled 11 bug fixes: [MC-577, MC-59810, MC-89146, MC-90683, MC-112730, MC-121772, MC-122477, MC-140646, MC-199467, MC-237493, MC-263865]
[11:07:59] [Render thread/INFO]: Successfully Debugify'd your game!
[11:08:00] [Render thread/INFO]: Fadeless is running
[11:08:00] [Render thread/INFO]: KONNICHIWA ZA WARUDO!
[11:08:00] [Render thread/INFO]: Default JVM text encoding is: UTF-8
[11:08:00] [Render thread/INFO]: Reading config file NoChatReports/NCR-Common.json...
[11:08:00] [Render thread/INFO]: Reading config file NoChatReports/NCR-Client.json...
[11:08:00] [Render thread/INFO]: Reading config file NoChatReports/NCR-ServerPreferences.json...
[11:08:00] [Render thread/INFO]: Reading config file NoChatReports/NCR-Encryption.json...
[11:08:00] [Render thread/INFO]: Writing config file NoChatReports/NCR-Common.json...
[11:08:00] [Render thread/INFO]: Writing config file NoChatReports/NCR-Client.json...
[11:08:00] [Render thread/INFO]: Writing config file NoChatReports/NCR-ServerPreferences.json...
[11:08:00] [Render thread/INFO]: Writing config file NoChatReports/NCR-Encryption.json...
[11:08:00] [Render thread/INFO]: Client initialization...
[11:08:00] [Render thread/INFO]: Mixing client.MixinClientPacketListener from mixins/common/nochatreports.mixins.json into net.minecraft.class_634
[11:08:01] [Render thread/INFO]: AdvancementInfo initialized
[11:08:01] [Render thread/INFO]: Trying to read config file...
[11:08:01] [Render thread/INFO]: A config file was found, loading it..
[11:08:01] [Render thread/INFO]: Successfully loaded config file.
[11:08:01] [Render thread/INFO]: [citresewn] Registering CIT Conditions
[11:08:01] [Render thread/INFO]: [citresewn] Registering CIT Types
[11:08:01] [Render thread/INFO]: Pre-initializing Controlify...
[11:08:01] [Render thread/INFO]: Re-caching descriptions because json doesn't match config.
[11:08:01] [Render thread/INFO]: Connecting to 'bugs.mojang.com' to cache bug descriptions!
[11:08:01] [Render thread/WARN]: Invalid config, creating new one!
[11:08:02] [Render thread/INFO]: Loading Entity Model Features, PI = 3.1415927 and you can't convince me otherwise.
[11:08:02] [Render thread/INFO]: Loading Entity Texture Features, did you know if you turn off the lights and whisper 'OptiFine' 3 times you will lose 20fps.
[11:08:02] [Render thread/INFO]: [Indigo] Different rendering plugin detected; not applying Indigo.
[11:08:02] [Render thread/INFO]: [FastQuit] Initialized
[11:08:03] [Render thread/INFO]: [LambDynLights] Initializing LambDynamicLights...
[11:08:03] [Render thread/INFO]: [LambDynLights] Configuration loaded.
[11:08:03] [Render thread/INFO]: OptiGlue initialized.
[11:08:03] [Render thread/INFO]: OptiGUI initialized.
[11:08:03] [Render thread/INFO]: Mixing client.MixinOptions from mixins/common/nochatreports.mixins.json into net.minecraft.class_315
[11:08:03] [Render thread/INFO]: Renaming synthetic method lambda$onlyShowSecureChat$0(Ljava/lang/Boolean;)V to mdd21ae9$nochatreports$lambda$onlyShowSecureChat$0$2 in mixins/common/nochatreports.mixins.json:client.MixinOptions from mod nochatreports
[11:08:04] [Render thread/INFO]: Mixing client.MixinChatComponent from mixins/common/nochatreports.mixins.json into net.minecraft.class_338
[11:08:04] [Render thread/INFO]: Renaming synthetic method lambda$modifyGUIMessage$1()V to mdd21ae9$nochatreports$lambda$modifyGUIMessage$1$0 in mixins/common/nochatreports.mixins.json:client.MixinChatComponent from mod nochatreports
[11:08:04] [Render thread/INFO]: Renaming synthetic method lambda$modifyGUIMessage$0(Lnet/minecraft/class_5348;Lnet/minecraft/class_2561;)V to mdd21ae9$nochatreports$lambda$modifyGUIMessage$0$1 in mixins/common/nochatreports.mixins.json:client.MixinChatComponent from mod nochatreports
[11:08:04] [Render thread/INFO]: Mixing client.MixinGuiMessageTagIcon from mixins/common/nochatreports.mixins.json into net.minecraft.class_7591$class_7592
[11:08:04] [Render thread/INFO]: Renaming @Invoker method create(Ljava/lang/String;IIIII)Lnet/minecraft/class_7591$class_7592; to create$nochatreports_$md$d21ae9$0 in mixins/common/nochatreports.mixins.json:client.MixinGuiMessageTagIcon from mod nochatreports
[11:08:04] [Render thread/INFO]: Backend library: LWJGL version 3.3.1 SNAPSHOT
[11:08:05] [Render thread/INFO]: Initializing ImmediatelyFast 1.2.6+1.20.2 on AMD Radeon R5 M330 (hainan, LLVM 16.0.6, DRM 3.54, 6.5.5-1-MANJARO) (AMD) with OpenGL 4.6 (Core Profile) Mesa 23.1.9-manjaro1.1
[11:08:05] [Render thread/INFO]: AMD GPU detected. Enabling coherent buffer mapping
[11:08:05] [Render thread/INFO]: Found Iris/Oculus 1.6.10. Enabling compatibility.
[11:08:05] [Render thread/INFO]: OpenGL Vendor: AMD
[11:08:05] [Render thread/INFO]: OpenGL Renderer: AMD Radeon R5 M330 (hainan, LLVM 16.0.6, DRM 3.54, 6.5.5-1-MANJARO)
[11:08:05] [Render thread/INFO]: OpenGL Version: 4.6 (Core Profile) Mesa 23.1.9-manjaro1.1
[11:08:05] [Render thread/INFO]: Debug functionality is disabled.
[11:08:05] [Render thread/INFO]: OpenGL 4.5 detected, enabling DSA.
[11:08:05] [Render thread/INFO]: Shaders are disabled because enableShaders is set to false in iris.properties
[11:08:05] [Render thread/INFO]: ARRP register - before vanilla
[11:08:05] [Render thread/INFO]: ARRP register - after vanilla
[11:08:05] [Render thread/INFO]: ARRP register - before user
[11:08:05] [Render thread/WARN]: Method overwrite conflict for getModel in fabric-model-loading-api-v1.mixins.json:BakedModelManagerMixin from mod fabric-model-loading-api-v1, previously written by foundationgames.enhancedblockentities.mixin.BakedModelManagerMixin. Skipping method.
[11:08:06] [Render thread/INFO]: Hardware information:
[11:08:06] [Render thread/INFO]: CPU: 4x Intel(R) Core(TM) i3-5005U CPU @ 2.00GHz
[11:08:06] [Render thread/INFO]: GPU: AMD Radeon R5 M330 (hainan, LLVM 16.0.6, DRM 3.54, 6.5.5-1-MANJARO) (Supports OpenGL 4.6 (Core Profile) Mesa 23.1.9-manjaro1.1)
[11:08:06] [Render thread/INFO]: OS: Linux (6.5.5-1-MANJARO)
[11:08:06] [Finalizer/WARN]: One or more BufferBuilders have been leaked, ModernFix will attempt to correct this.
[11:08:07] [Render thread/ERROR]: Error while loading the narrator
com.mojang.text2speech.Narrator$InitializeException: Failed to load library flite
at com.mojang.text2speech.NarratorLinux$FliteLibrary.loadNative(NarratorLinux.java:69) ~[text2speech-1.17.9.jar:?]
at com.mojang.text2speech.NarratorLinux.<init>(NarratorLinux.java:18) ~[text2speech-1.17.9.jar:?]
at com.mojang.text2speech.Narrator.getNarrator(Narrator.java:41) ~[text2speech-1.17.9.jar:?]
at net.minecraft.class_333.<init>(class_333.java:19) ~[client-intermediary.jar:?]
at net.minecraft.class_310.<init>(class_310.java:640) ~[client-intermediary.jar:?]
at net.minecraft.client.main.Main.main(Main.java:211) ~[client-1.20.1.jar:?]
at net.fabricmc.loader.impl.game.minecraft.MinecraftGameProvider.launch(MinecraftGameProvider.java:468) ~[fabric-loader-0.14.23.jar:?]
at net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:74) ~[fabric-loader-0.14.23.jar:?]
at net.fabricmc.loader.impl.launch.knot.KnotClient.main(KnotClient.java:23) ~[fabric-loader-0.14.23.jar:?]
Caused by: java.lang.UnsatisfiedLinkError: Unable to load library 'flite':
libflite.so: cannot open shared object file: No such file or directory
Native library (linux-x86-64/libflite.so) not found in resource path (/home/arhero/ATLauncher/libraries/net/fabricmc/tiny-mappings-parser/0.3.0+build.17/tiny-mappings-parser-0.3.0+build.17.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/sponge-mixin/0.12.5+mixin.0.8.5/sponge-mixin-0.12.5+mixin.0.8.5.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/tiny-remapper/0.8.2/tiny-remapper-0.8.2.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/access-widener/2.1.0/access-widener-2.1.0.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm/9.6/asm-9.6.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm-analysis/9.6/asm-analysis-9.6.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm-commons/9.6/asm-commons-9.6.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm-tree/9.6/asm-tree-9.6.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm-util/9.6/asm-util-9.6.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/intermediary/1.20.1/intermediary-1.20.1.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/fabric-loader/0.14.23/fabric-loader-0.14.23.jar:/home/arhero/ATLauncher/libraries/com/github/oshi/oshi-core/6.2.2/oshi-core-6.2.2.jar:/home/arhero/ATLauncher/libraries/com/google/code/gson/gson/2.10/gson-2.10.jar:/home/arhero/ATLauncher/libraries/com/google/guava/failureaccess/1.0.1/failureaccess-1.0.1.jar:/home/arhero/ATLauncher/libraries/com/google/guava/guava/31.1-jre/guava-31.1-jre.jar:/home/arhero/ATLauncher/libraries/com/ibm/icu/icu4j/71.1/icu4j-71.1.jar:/home/arhero/ATLauncher/libraries/com/mojang/authlib/4.0.43/authlib-4.0.43.jar:/home/arhero/ATLauncher/libraries/com/mojang/blocklist/1.0.10/blocklist-1.0.10.jar:/home/arhero/ATLauncher/libraries/com/mojang/brigadier/1.1.8/brigadier-1.1.8.jar:/home/arhero/ATLauncher/libraries/com/mojang/datafixerupper/6.0.8/datafixerupper-6.0.8.jar:/home/arhero/ATLauncher/libraries/com/mojang/logging/1.1.1/logging-1.1.1.jar:/home/arhero/ATLauncher/libraries/com/mojang/patchy/2.2.10/patchy-2.2.10.jar:/home/arhero/ATLauncher/libraries/com/mojang/text2speech/1.17.9/text2speech-1.17.9.jar:/home/arhero/ATLauncher/libraries/commons-codec/commons-codec/1.15/commons-codec-1.15.jar:/home/arhero/ATLauncher/libraries/commons-io/commons-io/2.11.0/commons-io-2.11.0.jar:/home/arhero/ATLauncher/libraries/commons-logging/commons-logging/1.2/commons-logging-1.2.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-buffer/4.1.82.Final/netty-buffer-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-codec/4.1.82.Final/netty-codec-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-common/4.1.82.Final/netty-common-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-handler/4.1.82.Final/netty-handler-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-resolver/4.1.82.Final/netty-resolver-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport-classes-epoll/4.1.82.Final/netty-transport-classes-epoll-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-aarch_64.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-x86_64.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport-native-unix-common/4.1.82.Final/netty-transport-native-unix-common-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport/4.1.82.Final/netty-transport-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/it/unimi/dsi/fastutil/8.5.9/fastutil-8.5.9.jar:/home/arhero/ATLauncher/libraries/net/java/dev/jna/jna-platform/5.12.1/jna-platform-5.12.1.jar:/home/arhero/ATLauncher/libraries/net/java/dev/jna/jna/5.12.1/jna-5.12.1.jar:/home/arhero/ATLauncher/libraries/net/sf/jopt-simple/jopt-simple/5.0.4/jopt-simple-5.0.4.jar:/home/arhero/ATLauncher/libraries/org/apache/commons/commons-compress/1.21/commons-compress-1.21.jar:/home/arhero/ATLauncher/libraries/org/apache/commons/commons-lang3/3.12.0/commons-lang3-3.12.0.jar:/home/arhero/ATLauncher/libraries/org/apache/httpcomponents/httpclient/4.5.13/httpclient-4.5.13.jar:/home/arhero/ATLauncher/libraries/org/apache/httpcomponents/httpcore/4.4.15/httpcore-4.4.15.jar:/home/arhero/ATLauncher/libraries/org/apache/logging/log4j/log4j-api/2.19.0/log4j-api-2.19.0.jar:/home/arhero/ATLauncher/libraries/org/apache/logging/log4j/log4j-core/2.19.0/log4j-core-2.19.0.jar:/home/arhero/ATLauncher/libraries/org/apache/logging/log4j/log4j-slf4j2-impl/2.19.0/log4j-slf4j2-impl-2.19.0.jar:/home/arhero/ATLauncher/libraries/org/joml/joml/1.10.5/joml-1.10.5.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/slf4j/slf4j-api/2.0.1/slf4j-api-2.0.1.jar:/home/arhero/ATLauncher/libraries/net/minecraft/client/1.20.1/client-1.20.1.jar)
at com.sun.jna.NativeLibrary.loadLibrary(NativeLibrary.java:307) ~[jna-5.12.1.jar:?]
at com.sun.jna.NativeLibrary.getInstance(NativeLibrary.java:467) ~[jna-5.12.1.jar:?]
at com.sun.jna.NativeLibrary.getInstance(NativeLibrary.java:409) ~[jna-5.12.1.jar:?]
at com.mojang.text2speech.NarratorLinux$FliteLibrary.loadNative(NarratorLinux.java:67) ~[text2speech-1.17.9.jar:?]
... 8 more
Suppressed: java.lang.UnsatisfiedLinkError: libflite.so: cannot open shared object file: No such file or directory
at com.sun.jna.Native.open(Native Method) ~[jna-5.12.1.jar:?]
at com.sun.jna.NativeLibrary.loadLibrary(NativeLibrary.java:197) ~[jna-5.12.1.jar:?]
at com.sun.jna.NativeLibrary.loadLibrary(NativeLibrary.java:210) ~[jna-5.12.1.jar:?]
Suppressed: java.io.IOException: Native library (linux-x86-64/libflite.so) not found in resource path (/home/arhero/ATLauncher/libraries/net/fabricmc/tiny-mappings-parser/0.3.0+build.17/tiny-mappings-parser-0.3.0+build.17.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/sponge-mixin/0.12.5+mixin.0.8.5/sponge-mixin-0.12.5+mixin.0.8.5.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/tiny-remapper/0.8.2/tiny-remapper-0.8.2.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/access-widener/2.1.0/access-widener-2.1.0.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm/9.6/asm-9.6.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm-analysis/9.6/asm-analysis-9.6.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm-commons/9.6/asm-commons-9.6.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm-tree/9.6/asm-tree-9.6.jar:/home/arhero/ATLauncher/libraries/org/ow2/asm/asm-util/9.6/asm-util-9.6.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/intermediary/1.20.1/intermediary-1.20.1.jar:/home/arhero/ATLauncher/libraries/net/fabricmc/fabric-loader/0.14.23/fabric-loader-0.14.23.jar:/home/arhero/ATLauncher/libraries/com/github/oshi/oshi-core/6.2.2/oshi-core-6.2.2.jar:/home/arhero/ATLauncher/libraries/com/google/code/gson/gson/2.10/gson-2.10.jar:/home/arhero/ATLauncher/libraries/com/google/guava/failureaccess/1.0.1/failureaccess-1.0.1.jar:/home/arhero/ATLauncher/libraries/com/google/guava/guava/31.1-jre/guava-31.1-jre.jar:/home/arhero/ATLauncher/libraries/com/ibm/icu/icu4j/71.1/icu4j-71.1.jar:/home/arhero/ATLauncher/libraries/com/mojang/authlib/4.0.43/authlib-4.0.43.jar:/home/arhero/ATLauncher/libraries/com/mojang/blocklist/1.0.10/blocklist-1.0.10.jar:/home/arhero/ATLauncher/libraries/com/mojang/brigadier/1.1.8/brigadier-1.1.8.jar:/home/arhero/ATLauncher/libraries/com/mojang/datafixerupper/6.0.8/datafixerupper-6.0.8.jar:/home/arhero/ATLauncher/libraries/com/mojang/logging/1.1.1/logging-1.1.1.jar:/home/arhero/ATLauncher/libraries/com/mojang/patchy/2.2.10/patchy-2.2.10.jar:/home/arhero/ATLauncher/libraries/com/mojang/text2speech/1.17.9/text2speech-1.17.9.jar:/home/arhero/ATLauncher/libraries/commons-codec/commons-codec/1.15/commons-codec-1.15.jar:/home/arhero/ATLauncher/libraries/commons-io/commons-io/2.11.0/commons-io-2.11.0.jar:/home/arhero/ATLauncher/libraries/commons-logging/commons-logging/1.2/commons-logging-1.2.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-buffer/4.1.82.Final/netty-buffer-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-codec/4.1.82.Final/netty-codec-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-common/4.1.82.Final/netty-common-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-handler/4.1.82.Final/netty-handler-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-resolver/4.1.82.Final/netty-resolver-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport-classes-epoll/4.1.82.Final/netty-transport-classes-epoll-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-aarch_64.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-x86_64.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport-native-unix-common/4.1.82.Final/netty-transport-native-unix-common-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/io/netty/netty-transport/4.1.82.Final/netty-transport-4.1.82.Final.jar:/home/arhero/ATLauncher/libraries/it/unimi/dsi/fastutil/8.5.9/fastutil-8.5.9.jar:/home/arhero/ATLauncher/libraries/net/java/dev/jna/jna-platform/5.12.1/jna-platform-5.12.1.jar:/home/arhero/ATLauncher/libraries/net/java/dev/jna/jna/5.12.1/jna-5.12.1.jar:/home/arhero/ATLauncher/libraries/net/sf/jopt-simple/jopt-simple/5.0.4/jopt-simple-5.0.4.jar:/home/arhero/ATLauncher/libraries/org/apache/commons/commons-compress/1.21/commons-compress-1.21.jar:/home/arhero/ATLauncher/libraries/org/apache/commons/commons-lang3/3.12.0/commons-lang3-3.12.0.jar:/home/arhero/ATLauncher/libraries/org/apache/httpcomponents/httpclient/4.5.13/httpclient-4.5.13.jar:/home/arhero/ATLauncher/libraries/org/apache/httpcomponents/httpcore/4.4.15/httpcore-4.4.15.jar:/home/arhero/ATLauncher/libraries/org/apache/logging/log4j/log4j-api/2.19.0/log4j-api-2.19.0.jar:/home/arhero/ATLauncher/libraries/org/apache/logging/log4j/log4j-core/2.19.0/log4j-core-2.19.0.jar:/home/arhero/ATLauncher/libraries/org/apache/logging/log4j/log4j-slf4j2-impl/2.19.0/log4j-slf4j2-impl-2.19.0.jar:/home/arhero/ATLauncher/libraries/org/joml/joml/1.10.5/joml-1.10.5.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1.jar:/home/arhero/ATLauncher/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1-natives-linux.jar:/home/arhero/ATLauncher/libraries/org/slf4j/slf4j-api/2.0.1/slf4j-api-2.0.1.jar:/home/arhero/ATLauncher/libraries/net/minecraft/client/1.20.1/client-1.20.1.jar)
at com.sun.jna.Native.extractFromResourcePath(Native.java:1145) ~[jna-5.12.1.jar:?]
at com.sun.jna.NativeLibrary.loadLibrary(NativeLibrary.java:281) ~[jna-5.12.1.jar:?]
[11:08:07] [Render thread/INFO]: Mixing client.MixinChatListener from mixins/common/nochatreports.mixins.json into net.minecraft.class_7594
[11:08:07] [Render thread/INFO]: Invalidating pack caches
[11:08:07] [Render thread/INFO]: Reloading ResourceManager: vanilla, fabric (advanced_runtime_resource_pack, advancementinfo, animatica, bettermounthud, borderlessmining, caffeineconfig, capes, citresewn, citresewn-defaults, cloth-config, conditional-mixin, continuity, controlify, debugify, dynamic_fps, e4mc_minecraft, enhancedblockentities, entity_model_features, entity_texture_features, entityculling, fabric-api, fabric-api-base, fabric-api-lookup-api-v1, fabric-biome-api-v1, fabric-block-api-v1, fabric-block-view-api-v2, fabric-blockrenderlayer-v1, fabric-client-tags-api-v1, fabric-command-api-v1, fabric-command-api-v2, fabric-commands-v0, fabric-containers-v0, fabric-content-registries-v0, fabric-convention-tags-v1, fabric-crash-report-info-v1, fabric-data-generation-api-v1, fabric-dimensions-v1, fabric-entity-events-v1, fabric-events-interaction-v0, fabric-events-lifecycle-v0, fabric-game-rule-api-v1, fabric-item-api-v1, fabric-item-group-api-v1, fabric-key-binding-api-v1, fabric-keybindings-v0, fabric-language-kotlin, fabric-lifecycle-events-v1, fabric-loot-api-v2, fabric-loot-tables-v1, fabric-message-api-v1, fabric-mining-level-api-v1, fabric-model-loading-api-v1, fabric-models-v0, fabric-networking-api-v1, fabric-networking-v0, fabric-object-builder-api-v1, fabric-particles-v1, fabric-recipe-api-v1, fabric-registry-sync-v0, fabric-renderer-api-v1, fabric-renderer-indigo, fabric-renderer-registries-v1, fabric-rendering-data-attachment-v1, fabric-rendering-fluids-v1, fabric-rendering-v0, fabric-rendering-v1, fabric-resource-conditions-api-v1, fabric-resource-loader-v0, fabric-screen-api-v1, fabric-screen-handler-api-v1, fabric-sound-api-v1, fabric-transfer-api-v1, fabric-transitive-access-wideners-v1, fabricloader, fabricskyboxes, fabrishot, fadeless, fastquit, fsb-interop, immediatelyfast, indium, iris, lambdynlights, languagereload, lithium, midnightlib, mixintrace, modernfix, modmenu, morechathistory, moreculling, nochatreports, optigui, pride, puzzle, puzzle-base, puzzle-gui, puzzle-models, puzzle-splashscreen, reeses-sodium-options, rrls, sodium, sodium-extra, spruceui, yet_another_config_lib_v3, yosbr, zoomify), continuity:glass_pane_culling_fix, continuity:default, file/SodiumTranslations.zip, file/Mod Menu Helper.zip, file/Chat Reporting Helper.zip, file/Fast Better Grass.zip
[11:08:07] [Render thread/INFO]: closing rrp ebe:base_resources
[11:08:07] [Render thread/INFO]: ARRP register - before vanilla
[11:08:07] [Render thread/INFO]: ARRP register - after vanilla
[11:08:07] [Render thread/INFO]: Mixing client.MixinJoinMultiplayerScreen from mixins/common/nochatreports.mixins.json into net.minecraft.class_500
[11:08:07] [Render thread/INFO]: Renaming synthetic method lambda$onInit$2()Lnet/minecraft/class_2561; to mdd21ae9$nochatreports$lambda$onInit$2$0 in mixins/common/nochatreports.mixins.json:client.MixinJoinMultiplayerScreen from mod nochatreports
[11:08:07] [Render thread/INFO]: Renaming synthetic method lambda$onInit$1(Lnet/minecraft/class_4185;)V to mdd21ae9$nochatreports$lambda$onInit$1$1 in mixins/common/nochatreports.mixins.json:client.MixinJoinMultiplayerScreen from mod nochatreports
[11:08:07] [Render thread/INFO]: Renaming synthetic method lambda$onInit$0(Lnet/minecraft/class_4185;)V to mdd21ae9$nochatreports$lambda$onInit$0$2 in mixins/common/nochatreports.mixins.json:client.MixinJoinMultiplayerScreen from mod nochatreports
[11:08:08] [Render thread/ERROR]: [citresewn] Caution! Broken paths is enabled!
[11:08:08] [Render thread/INFO]: Creating pipeline for dimension NamespacedId{namespace='minecraft', name='overworld'}
[11:08:08] [Worker-ResourceReload-0/INFO]: Found unifont_all_no_pua-15.0.06.hex, loading
[11:08:08] [Render thread/INFO]: Cached all modded block culling states
[11:08:08] [Render thread/INFO]: Game entered main loop!
[11:08:21] [Worker-ResourceReload-1/INFO]: Early baking 180 models
[11:08:22] [Render thread/INFO]: Language is not set. Setting it to system language
[11:08:22] [Render thread/WARN]: Missing sound for event: minecraft:item.goat_horn.play
[11:08:22] [Render thread/WARN]: Missing sound for event: minecraft:entity.goat.screaming.horn_break
[11:08:22] [Render thread/INFO]: OpenAL initialized on device Built-in Audio Analog Stereo
[11:08:22] [Render thread/INFO]: Sound engine started
[11:08:23] [Render thread/INFO]: Created: 1024x1024x4 minecraft:textures/atlas/blocks.png-atlas
and the console log is here
[22/10/2023 10:59:41 am] Organising filesystem
[22/10/2023 10:59:41 am] ATLauncher Version: 3.4.34.2 [95cf252e7cd2b4f060c5dcaa4afeb027d0d50d01]
[22/10/2023 10:59:41 am] App Arguments: []
[22/10/2023 10:59:41 am] JVM Arguments: []
[22/10/2023 10:59:41 am] Java Version: Java 17 (17.0.8.1)
[22/10/2023 10:59:41 am] Java Path: /usr/lib/jvm/java-17-openjdk
[22/10/2023 10:59:41 am] 64 Bit Java: true
[22/10/2023 10:59:41 am] RAM Available: 7858MB
[22/10/2023 10:59:41 am] Launcher Directory: **USERSDIR**
[22/10/2023 10:59:41 am] GPU: HD Graphics 5500 (Intel Corporation (0x8086)) unknown 256MB VRAM
[22/10/2023 10:59:42 am] CPU: Intel(R) Core(TM) i3-5005U CPU @ 2.00GHz 2 cores/4 threads
[22/10/2023 10:59:42 am] Operating System: Manjaro Linux (unknown (unknown) build 6.5.5-1-MANJARO)
[22/10/2023 10:59:42 am] Bitness: 64
[22/10/2023 10:59:42 am] Uptime: 938
[22/10/2023 10:59:42 am] Manufacturer: GNU/Linux
[22/10/2023 10:59:42 am] Showing splash screen and loading everything
[22/10/2023 10:59:42 am] Checking for updated files!
[22/10/2023 10:59:52 am] Finished downloading updated files!
[22/10/2023 10:59:52 am] Launcher finished loading everything
[22/10/2023 10:59:52 am] Launcher not setup. Loading Setup Dialog
[22/10/2023 10:59:55 am] Launcher opening
[22/10/2023 10:59:55 am] Made By Bob*
[22/10/2023 10:59:55 am] *(Not Actually)
[22/10/2023 10:59:55 am] Setting up Bottom Bar
[22/10/2023 10:59:55 am] Finished Setting up Bottom Bar
[22/10/2023 10:59:55 am] Setting up Tabs
[22/10/2023 10:59:56 am] Finished Setting up Tabs
[22/10/2023 10:59:56 am] Showing Launcher
[22/10/2023 11:00:01 am] httpscdnmodrinthcomdatabxWt0XMViconjpg (of size 26974) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:01 am] httpscdnmodrinthcomdata1KVo5zzad8152911f8fd5d7e9a8c499fe89045af81fe816epng (of size 14130) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:01 am] httpscdnmodrinthcomdata1Fv3GHYS6b0593ef9e15ed98d084b72253e4275519964edfjpg (of size 38861) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdatauvlobdYFc14f84dad3fa1c1d234c387b730195211efa6c7cjpeg (of size 21886) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdata7zBMp9RO1c6a97296c851f38c00a4697c8cfbdd511ef25e7png (of size 17646) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdatach7UHY2Jcf0150ba8d6c01144974709a27b23bba93c0fc9epng (of size 2559) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdatap87Jiw2qiconpng (of size 258903) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdatamHMxXbIue7f9ee2e9d361623847853fe2ddce42f519ee64fpng (of size 5409) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdataV5Po0cpt57fa0c9bc836eb36c8bb509d73913ad9e139bb20png (of size 82335) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdatavwgtbO0ycc316288962439c7c246b3d5edbc8715fb021483png (of size 221943) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdataKPKUwUP54e633b1e5896f6b53e77fef59e4b8dc428dd2867png (of size 221695) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdataBYN9yKrVa741a66ac91132214d899ed134fc76dd4c8298edpng (of size 17544) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdataxldzprsQ411e361182e4c0643128f68af08f427f2797da59png (of size 199336) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdatafgUCZ5nU11dcbe1c82b94f810c6c612a51f91e24cdc4e4c1png (of size 514) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdataPwyu7to92825620a0853301c991b6b2a48b2d5aaf6287df1png (of size 61307) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdatapaoFU4Vl216ea22fbd1694408792ef2302f0d684fc6d2188png (of size 20133) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:03 am] httpscdnmodrinthcomdataTDM3I9Mufc7058deb885d3c0faf68d128755d0ae355ee86bpng (of size 133894) hash didn't match, but we're ignoring failures, so continuing
[22/10/2023 11:00:21 am] Added Microsoft Account ARhero
[22/10/2023 11:00:21 am] Downloading skin for ARhero
[22/10/2023 11:00:22 am] Changed account to ARhero
[22/10/2023 11:00:35 am] Started install of Fabulously Optimized version 5.4.1 for 1.20.1 (5.4.1)
[22/10/2023 11:06:24 am] Checking for updates to Modrinth instances
[22/10/2023 11:07:16 am] Preparing for launch!
[22/10/2023 11:07:25 am] Launching pack Fabulously Optimized 5.4.1 (Modrinth) for Minecraft 1.20.1
[22/10/2023 11:07:25 am] Logging into Minecraft!
[22/10/2023 11:07:25 am] Using Java runtime java-runtime-gamma (Java 17.0.3) at path **USERSDIR**/runtimes/minecraft/java-runtime-gamma/linux/java-runtime-gamma
[22/10/2023 11:07:25 am] Loader: Fabric 0.14.23
[22/10/2023 11:07:25 am] Mods:
[22/10/2023 11:07:25 am] - /borderless-mining-1.1.8+1.20.1.jar
[22/10/2023 11:07:25 am] - /moreculling-1.20.1-0.19.0.jar
[22/10/2023 11:07:25 am] - /optigui-2.1.5.jar
[22/10/2023 11:07:25 am] - /Debugify-1.20.1+2.0.jar
[22/10/2023 11:07:25 am] - /memoryleakfix-fabric-1.17+-1.1.2.jar
[22/10/2023 11:07:25 am] - /advancementinfo-1.20-fabric0.83.0-1.4.jar
[22/10/2023 11:07:25 am] - /modernfix-fabric-5.8.1+mc1.20.1.jar
[22/10/2023 11:07:25 am] - /main-menu-credits-1.1.2.jar
[22/10/2023 11:07:25 am] - /entity_texture_features_fabric_1.20-4.5.1.jar
[22/10/2023 11:07:25 am] - /morechathistory-1.19.1-1.1.1.jar
[22/10/2023 11:07:25 am] - /indium-1.0.27+mc1.20.1.jar
[22/10/2023 11:07:25 am] - /Controlify-1.6.0+1.20.jar
[22/10/2023 11:07:25 am] - /lambdynamiclights-2.3.2+1.20.1.jar
[22/10/2023 11:07:25 am] - /fabricskyboxes-0.7.3+mc1.20.1.jar
[22/10/2023 11:07:25 am] - /entityculling-fabric-1.6.2-mc1.20.1.jar
[22/10/2023 11:07:25 am] - /language-reload-1.5.9+1.20.1.jar
[22/10/2023 11:07:25 am] - /fadeless-1.0.1.jar
[22/10/2023 11:07:25 am] - /Zoomify-2.11.2.jar
[22/10/2023 11:07:25 am] - /continuity-3.0.0-beta.4+1.20.1.jar
[22/10/2023 11:07:25 am] - /entity_model_features_fabric_1.20-1.0.2.jar
[22/10/2023 11:07:25 am] - /yosbr-0.1.2.jar
[22/10/2023 11:07:25 am] - /CITResewn-1.1.3+1.20.jar
[22/10/2023 11:07:25 am] - /cloth-config-11.1.106-fabric.jar
[22/10/2023 11:07:25 am] - /fabric-language-kotlin-1.10.10+kotlin.1.9.10.jar
[22/10/2023 11:07:25 am] - /reeses_sodium_options-1.6.5+mc1.20.1-build.95.jar
[22/10/2023 11:07:25 am] - /puzzle-1.5.2+1.20.jar
[22/10/2023 11:07:25 am] - /Rrls-3.2.0-1.20.1-fabric.jar
[22/10/2023 11:07:25 am] - /fabric-api-0.90.0+1.20.1.jar
[22/10/2023 11:07:25 am] - /animatica-0.6+1.20.jar
[22/10/2023 11:07:25 am] - /modelfix-1.14-fabric.jar
[22/10/2023 11:07:25 am] - /dynamic-fps-3.2.1+minecraft-1.20.0.jar
[22/10/2023 11:07:25 am] - /bettermounthud-1.2.2.jar
[22/10/2023 11:07:25 am] - /iris-mc1.20.1-1.6.10.jar
[22/10/2023 11:07:25 am] - /mixintrace-1.1.1+1.17.jar
[22/10/2023 11:07:25 am] - /modmenu-7.2.2.jar
[22/10/2023 11:07:25 am] - /sodium-extra-0.5.1+mc1.20.1-build.112.jar
[22/10/2023 11:07:25 am] - /capes-1.5.2+1.20-fabric.jar
[22/10/2023 11:07:25 am] - /lithium-fabric-mc1.20.1-0.11.2.jar
[22/10/2023 11:07:25 am] - /sodium-fabric-mc1.20.1-0.5.3.jar
[22/10/2023 11:07:25 am] - /NoChatReports-FABRIC-1.20.1-v2.2.2.jar
[22/10/2023 11:07:25 am] - /e4mc-4.0.1+1.19.4-fabric.jar
[22/10/2023 11:07:25 am] - /fsb-interop-1.3.6+mc1.20.1-build.50.jar
[22/10/2023 11:07:25 am] - /fastquit-3.0.0+1.20+.jar
[22/10/2023 11:07:25 am] - /ferritecore-6.0.0-fabric.jar
[22/10/2023 11:07:25 am] - /fabrishot-1.10.0.jar
[22/10/2023 11:07:25 am] - /enhancedblockentities-0.9+1.20.jar
[22/10/2023 11:07:25 am] - /ImmediatelyFast-1.2.6+1.20.2.jar
[22/10/2023 11:07:25 am] - /yet-another-config-lib-fabric-3.2.1+1.20.jar
[22/10/2023 11:07:25 am] Launching Minecraft with the following arguments (user related stuff has been removed): [env, DRI_PRIME=1, USERSDIR/runtimes/minecraft/java-runtime-gamma/linux/java-runtime-gamma/bin/java, -Xmx4096M, -XX:MetaspaceSize=256M, -Duser.language=en, -Duser.country=US, -Dfml.log.level=INFO, -Dlog4j.configurationFile=USERSDIR/assets/log_configs/client-1.12.xml, -XX:+UnlockExperimentalVMOptions, -XX:+UseG1GC, -XX:G1NewSizePercent=20, -XX:G1ReservePercent=20, -XX:MaxGCPauseMillis=50, -XX:G1HeapRegionSize=32M, -Xss1M, -Djava.library.path=USERSDIR/temp/natives-e25905473d704a61853d5da68d962b0a, -Djna.tmpdir=USERSDIR/temp/natives-e25905473d704a61853d5da68d962b0a, -Dorg.lwjgl.system.SharedLibraryExtractPath=USERSDIR/temp/natives-e25905473d704a61853d5da68d962b0a, -Dio.netty.native.workdir=USERSDIR/temp/natives-e25905473d704a61853d5da68d962b0a, -Dminecraft.launcher.brand=ATLauncher, -Dminecraft.launcher.version=3.4.34.2, -cp, USERSDIR/libraries/net/fabricmc/tiny-mappings-parser/0.3.0+build.17/tiny-mappings-parser-0.3.0+build.17.jar:USERSDIR/libraries/net/fabricmc/sponge-mixin/0.12.5+mixin.0.8.5/sponge-mixin-0.12.5+mixin.0.8.5.jar:USERSDIR/libraries/net/fabricmc/tiny-remapper/0.8.2/tiny-remapper-0.8.2.jar:USERSDIR/libraries/net/fabricmc/access-widener/2.1.0/access-widener-2.1.0.jar:USERSDIR/libraries/org/ow2/asm/asm/9.6/asm-9.6.jar:USERSDIR/libraries/org/ow2/asm/asm-analysis/9.6/asm-analysis-9.6.jar:USERSDIR/libraries/org/ow2/asm/asm-commons/9.6/asm-commons-9.6.jar:USERSDIR/libraries/org/ow2/asm/asm-tree/9.6/asm-tree-9.6.jar:USERSDIR/libraries/org/ow2/asm/asm-util/9.6/asm-util-9.6.jar:USERSDIR/libraries/net/fabricmc/intermediary/1.20.1/intermediary-1.20.1.jar:USERSDIR/libraries/net/fabricmc/fabric-loader/0.14.23/fabric-loader-0.14.23.jar:USERSDIR/libraries/com/github/oshi/oshi-core/6.2.2/oshi-core-6.2.2.jar:USERSDIR/libraries/com/google/code/gson/gson/2.10/gson-2.10.jar:USERSDIR/libraries/com/google/guava/failureaccess/1.0.1/failureaccess-1.0.1.jar:USERSDIR/libraries/com/google/guava/guava/31.1-jre/guava-31.1-jre.jar:USERSDIR/libraries/com/ibm/icu/icu4j/71.1/icu4j-71.1.jar:USERSDIR/libraries/com/mojang/authlib/4.0.43/authlib-4.0.43.jar:USERSDIR/libraries/com/mojang/blocklist/1.0.10/blocklist-1.0.10.jar:USERSDIR/libraries/com/mojang/brigadier/1.1.8/brigadier-1.1.8.jar:USERSDIR/libraries/com/mojang/datafixerupper/6.0.8/datafixerupper-6.0.8.jar:USERSDIR/libraries/com/mojang/logging/1.1.1/logging-1.1.1.jar:USERSDIR/libraries/com/mojang/patchy/2.2.10/patchy-2.2.10.jar:USERSDIR/libraries/com/mojang/text2speech/1.17.9/text2speech-1.17.9.jar:USERSDIR/libraries/commons-codec/commons-codec/1.15/commons-codec-1.15.jar:USERSDIR/libraries/commons-io/commons-io/2.11.0/commons-io-2.11.0.jar:USERSDIR/libraries/commons-logging/commons-logging/1.2/commons-logging-1.2.jar:USERSDIR/libraries/io/netty/netty-buffer/4.1.82.Final/netty-buffer-4.1.82.Final.jar:USERSDIR/libraries/io/netty/netty-codec/4.1.82.Final/netty-codec-4.1.82.Final.jar:USERSDIR/libraries/io/netty/netty-common/4.1.82.Final/netty-common-4.1.82.Final.jar:USERSDIR/libraries/io/netty/netty-handler/4.1.82.Final/netty-handler-4.1.82.Final.jar:USERSDIR/libraries/io/netty/netty-resolver/4.1.82.Final/netty-resolver-4.1.82.Final.jar:USERSDIR/libraries/io/netty/netty-transport-classes-epoll/4.1.82.Final/netty-transport-classes-epoll-4.1.82.Final.jar:USERSDIR/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-aarch_64.jar:USERSDIR/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-x86_64.jar:USERSDIR/libraries/io/netty/netty-transport-native-unix-common/4.1.82.Final/netty-transport-native-unix-common-4.1.82.Final.jar:USERSDIR/libraries/io/netty/netty-transport/4.1.82.Final/netty-transport-4.1.82.Final.jar:USERSDIR/libraries/it/unimi/dsi/fastutil/8.5.9/fastutil-8.5.9.jar:USERSDIR/libraries/net/java/dev/jna/jna-platform/5.12.1/jna-platform-5.12.1.jar:USERSDIR/libraries/net/java/dev/jna/jna/5.12.1/jna-5.12.1.jar:USERSDIR/libraries/net/sf/jopt-simple/jopt-simple/5.0.4/jopt-simple-5.0.4.jar:USERSDIR/libraries/org/apache/commons/commons-compress/1.21/commons-compress-1.21.jar:USERSDIR/libraries/org/apache/commons/commons-lang3/3.12.0/commons-lang3-3.12.0.jar:USERSDIR/libraries/org/apache/httpcomponents/httpclient/4.5.13/httpclient-4.5.13.jar:USERSDIR/libraries/org/apache/httpcomponents/httpcore/4.4.15/httpcore-4.4.15.jar:USERSDIR/libraries/org/apache/logging/log4j/log4j-api/2.19.0/log4j-api-2.19.0.jar:USERSDIR/libraries/org/apache/logging/log4j/log4j-core/2.19.0/log4j-core-2.19.0.jar:USERSDIR/libraries/org/apache/logging/log4j/log4j-slf4j2-impl/2.19.0/log4j-slf4j2-impl-2.19.0.jar:USERSDIR/libraries/org/joml/joml/1.10.5/joml-1.10.5.jar:USERSDIR/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1.jar:USERSDIR/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1-natives-linux.jar:USERSDIR/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1.jar:USERSDIR/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1-natives-linux.jar:USERSDIR/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1.jar:USERSDIR/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1-natives-linux.jar:USERSDIR/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1.jar:USERSDIR/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1-natives-linux.jar:USERSDIR/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1.jar:USERSDIR/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1-natives-linux.jar:USERSDIR/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1.jar:USERSDIR/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1-natives-linux.jar:USERSDIR/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1.jar:USERSDIR/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1-natives-linux.jar:USERSDIR/libraries/org/slf4j/slf4j-api/2.0.1/slf4j-api-2.0.1.jar:USERSDIR/libraries/net/minecraft/client/1.20.1/client-1.20.1.jar, -DFabricMcEmu= net.minecraft.client.main.Main , net.fabricmc.loader.impl.launch.knot.KnotClient, --username, REDACTED, --version, 1.20.1, --gameDir, USERSDIR/instances/FabulouslyOptimized, --assetsDir, USERSDIR/assets, --assetIndex, 5, --uuid, REDACTED, --accessToken, REDACTED, --userType, msa, --versionType, release, --width=854, --height=480]
[22/10/2023 11:07:41 am] [main/INFO] Loading Minecraft 1.20.1 with Fabric Loader 0.14.23
[22/10/2023 11:07:41 am] [main/INFO] Fabric is preparing JARs on first launch, this may take a few seconds...
[22/10/2023 11:07:42 am] [main/INFO] Dependencies overridden for minecraft, lambdynlights, fabricloader, debugify
[22/10/2023 11:07:42 am] - 'Minecraft' (minecraft) 1.20.1 recommends any version after 5.4.1 of Fabulously Optimized, which is missing!
[22/10/2023 11:07:42 am] [main/WARN] Warnings were found! - You should install any version after 5.4.1 of Fabulously Optimized for the optimal experience.
[22/10/2023 11:07:42 am] - advancementinfo 1.20-fabric0.83.0-1.4
[22/10/2023 11:07:42 am] - animatica 0.6+1.20
[22/10/2023 11:07:42 am] - bettermounthud 1.2.2
[22/10/2023 11:07:42 am] - borderlessmining 1.1.8+1.20.1
[22/10/2023 11:07:42 am] - capes 1.5.2+1.20
[22/10/2023 11:07:42 am] - citresewn 1.1.3+1.20
[22/10/2023 11:07:42 am] \-- citresewn-defaults 1.1.3+1.20
[22/10/2023 11:07:42 am] - cloth-config 11.1.106
[22/10/2023 11:07:42 am] \-- cloth-basic-math 0.6.1
[22/10/2023 11:07:42 am] - continuity 3.0.0-beta.4+1.20.1
[22/10/2023 11:07:42 am] - controlify 1.6.0+1.20
[22/10/2023 11:07:42 am] |-- dev_isxander_sdl2-jni 2.28.2-26
[22/10/2023 11:07:42 am] |-- org_hid4java_hid4java 0.7.0
[22/10/2023 11:07:42 am] \-- org_quiltmc_quilt-json5 1.0.3
[22/10/2023 11:07:42 am] - debugify 1.20.1+2.0
[22/10/2023 11:07:42 am] - dynamic_fps 3.2.1
[22/10/2023 11:07:42 am] - e4mc_minecraft 4.0.1
[22/10/2023 11:07:42 am] - enhancedblockentities 0.9+1.20
[22/10/2023 11:07:42 am] |-- advanced_runtime_resource_pack 0.6.7
[22/10/2023 11:07:42 am] \-- spruceui 5.0.0+1.20
[22/10/2023 11:07:42 am] - entity_model_features 1.0.2
[22/10/2023 11:07:42 am] - entity_texture_features 4.5.1
[22/10/2023 11:07:42 am] \-- org_apache_httpcomponents_httpmime 4.5.10
[22/10/2023 11:07:42 am] - entityculling 1.6.2-mc1.20.1
[22/10/2023 11:07:42 am] - fabric-api 0.90.0+1.20.1
[22/10/2023 11:07:42 am] |-- fabric-api-base 0.4.30+7abfd51577
[22/10/2023 11:07:42 am] |-- fabric-api-lookup-api-v1 1.6.35+4d8536c977
[22/10/2023 11:07:42 am] |-- fabric-biome-api-v1 13.0.12+215bbe9677
[22/10/2023 11:07:42 am] |-- fabric-block-api-v1 1.0.10+92a0d36777
[22/10/2023 11:07:42 am] |-- fabric-block-view-api-v2 1.0.0+92a0d36777
[22/10/2023 11:07:42 am] |-- fabric-blockrenderlayer-v1 1.1.40+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-client-tags-api-v1 1.1.1+97bb207577
[22/10/2023 11:07:42 am] |-- fabric-command-api-v1 1.2.33+f71b366f77
[22/10/2023 11:07:42 am] |-- fabric-command-api-v2 2.2.12+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-commands-v0 0.2.50+df3654b377
[22/10/2023 11:07:42 am] |-- fabric-containers-v0 0.1.63+df3654b377
[22/10/2023 11:07:42 am] |-- fabric-content-registries-v0 4.0.10+57aed33f77
[22/10/2023 11:07:42 am] |-- fabric-convention-tags-v1 1.5.4+a1a980da77
[22/10/2023 11:07:42 am] |-- fabric-crash-report-info-v1 0.2.18+aeb40ebe77
[22/10/2023 11:07:42 am] |-- fabric-data-generation-api-v1 12.3.2+d7b148e077
[22/10/2023 11:07:42 am] |-- fabric-dimensions-v1 2.1.53+8536527b77
[22/10/2023 11:07:42 am] |-- fabric-entity-events-v1 1.5.22+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-events-interaction-v0 0.6.1+e91849a877
[22/10/2023 11:07:42 am] |-- fabric-events-lifecycle-v0 0.2.62+df3654b377
[22/10/2023 11:07:42 am] |-- fabric-game-rule-api-v1 1.0.38+b04edc7a77
[22/10/2023 11:07:42 am] |-- fabric-item-api-v1 2.1.27+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-item-group-api-v1 4.0.11+d7b148e077
[22/10/2023 11:07:42 am] |-- fabric-key-binding-api-v1 1.0.36+fb8d95da77
[22/10/2023 11:07:42 am] |-- fabric-keybindings-v0 0.2.34+df3654b377
[22/10/2023 11:07:42 am] |-- fabric-lifecycle-events-v1 2.2.21+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-loot-api-v2 1.2.0+96dfa95977
[22/10/2023 11:07:42 am] |-- fabric-loot-tables-v1 1.1.44+9e7660c677
[22/10/2023 11:07:42 am] |-- fabric-message-api-v1 5.1.8+d7b148e077
[22/10/2023 11:07:42 am] |-- fabric-mining-level-api-v1 2.1.49+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-model-loading-api-v1 1.0.2+709a987177
[22/10/2023 11:07:42 am] |-- fabric-models-v0 0.4.1+9386d8a777
[22/10/2023 11:07:42 am] |-- fabric-networking-api-v1 1.3.10+eeb8eb3677
[22/10/2023 11:07:42 am] |-- fabric-networking-v0 0.3.50+df3654b377
[22/10/2023 11:07:42 am] |-- fabric-object-builder-api-v1 11.1.1+6beca84877
[22/10/2023 11:07:42 am] |-- fabric-particles-v1 1.1.1+201a23a077
[22/10/2023 11:07:42 am] |-- fabric-recipe-api-v1 1.0.20+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-registry-sync-v0 2.3.2+4df89eb277
[22/10/2023 11:07:42 am] |-- fabric-renderer-api-v1 3.2.0+39a511ba77
[22/10/2023 11:07:42 am] |-- fabric-renderer-indigo 1.5.0+39a511ba77
[22/10/2023 11:07:42 am] |-- fabric-renderer-registries-v1 3.2.45+df3654b377
[22/10/2023 11:07:42 am] |-- fabric-rendering-data-attachment-v1 0.3.36+92a0d36777
[22/10/2023 11:07:42 am] |-- fabric-rendering-fluids-v1 3.0.27+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-rendering-v0 1.1.48+df3654b377
[22/10/2023 11:07:42 am] |-- fabric-rendering-v1 3.0.7+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-resource-conditions-api-v1 2.3.6+d7b148e077
[22/10/2023 11:07:42 am] |-- fabric-resource-loader-v0 0.11.9+132c48c177
[22/10/2023 11:07:42 am] |-- fabric-screen-api-v1 2.0.7+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-screen-handler-api-v1 1.3.29+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-sound-api-v1 1.0.12+b3afc78b77
[22/10/2023 11:07:42 am] |-- fabric-transfer-api-v1 3.3.1+195226a777
[22/10/2023 11:07:42 am] \-- fabric-transitive-access-wideners-v1 4.3.0+6c31357e77
[22/10/2023 11:07:42 am] - fabric-language-kotlin 1.10.10+kotlin.1.9.10
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlin_kotlin-reflect 1.9.10
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlin_kotlin-stdlib 1.9.10
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlin_kotlin-stdlib-jdk7 1.9.10
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlin_kotlin-stdlib-jdk8 1.9.10
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlinx_atomicfu-jvm 0.22.0
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlinx_kotlinx-coroutines-core-jvm 1.7.3
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlinx_kotlinx-coroutines-jdk8 1.7.3
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlinx_kotlinx-datetime-jvm 0.4.0
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlinx_kotlinx-serialization-cbor-jvm 1.6.0
[22/10/2023 11:07:42 am] |-- org_jetbrains_kotlinx_kotlinx-serialization-core-jvm 1.6.0
[22/10/2023 11:07:42 am] \-- org_jetbrains_kotlinx_kotlinx-serialization-json-jvm 1.6.0
[22/10/2023 11:07:42 am] - fabricloader 0.14.23
[22/10/2023 11:07:42 am] - fabricskyboxes 0.7.3+mc1.20.1
[22/10/2023 11:07:42 am] - fabrishot 1.10.0
[22/10/2023 11:07:42 am] - fadeless 1.0.1
[22/10/2023 11:07:42 am] - fastquit 3.0.0+1.20+
[22/10/2023 11:07:42 am] - ferritecore 6.0.0
[22/10/2023 11:07:42 am] - fsb-interop 1.3.6+mc1.20.1-build.50
[22/10/2023 11:07:42 am] - immediatelyfast 1.2.6+1.20.2
[22/10/2023 11:07:42 am] |-- com_github_llamalad7_mixinextras 0.2.0-rc.5
[22/10/2023 11:07:42 am] \-- net_lenni0451_reflect 1.2.4
[22/10/2023 11:07:42 am] - indium 1.0.27+mc1.20.1
[22/10/2023 11:07:42 am] - iris 1.6.10
[22/10/2023 11:07:42 am] |-- io_github_douira_glsl-transformer 2.0.0-pre13
[22/10/2023 11:07:42 am] |-- org_anarres_jcpp 1.4.14
[22/10/2023 11:07:42 am] \-- org_antlr_antlr4-runtime 4.11.1
[22/10/2023 11:07:42 am] - isxander-main-menu-credits 1.1.2
[22/10/2023 11:07:42 am] - java 17
[22/10/2023 11:07:42 am] - lambdynlights 2.3.2+1.20.1
[22/10/2023 11:07:42 am] |-- pride 1.2.0+1.19.4
[22/10/2023 11:07:42 am] - languagereload 1.5.9+1.20.1
[22/10/2023 11:07:42 am] \-- com_github_llamalad7_mixinextras 0.2.0-rc.5
[22/10/2023 11:07:42 am] - lithium 0.11.2
[22/10/2023 11:07:42 am] - memoryleakfix 1.1.2
[22/10/2023 11:07:42 am] - minecraft 1.20.1
[22/10/2023 11:07:42 am] - mixintrace 1.1.1+1.17
[22/10/2023 11:07:42 am] - modelfix 1.14
[22/10/2023 11:07:42 am] - modernfix 5.8.1+mc1.20.1
[22/10/2023 11:07:42 am] - modmenu 7.2.2
[22/10/2023 11:07:42 am] - morechathistory 1.1.1
[22/10/2023 11:07:42 am] - moreculling 1.20.1-0.19.0
[22/10/2023 11:07:42 am] \-- conditional-mixin 0.3.2
[22/10/2023 11:07:42 am] - nochatreports 1.20.1-v2.2.2
[22/10/2023 11:07:42 am] - optigui 2.1.5
[22/10/2023 11:07:42 am] |-- optiglue 2.1.5-mc.1.19.3
[22/10/2023 11:07:42 am] |-- org_apache_commons_commons-text 1.10.0
[22/10/2023 11:07:42 am] \-- org_ini4j_ini4j 0.5.4
[22/10/2023 11:07:42 am] - puzzle 1.5.2+1.20
[22/10/2023 11:07:42 am] |-- midnightlib 1.4.1
[22/10/2023 11:07:42 am] |-- puzzle-base 1.5.2+1.20
[22/10/2023 11:07:42 am] |-- puzzle-gui 1.5.2+1.20
[22/10/2023 11:07:42 am] [main/INFO] Applying default options... (YOSBR)
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/modmenu.json from /config/yosbr/config/modmenu.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/midnightcontrols.json from /config/yosbr/config/midnightcontrols.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/fastquit.toml from /config/yosbr/config/fastquit.toml
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/midnightlib.json from /config/yosbr/config/midnightlib.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/puzzle.json from /config/yosbr/config/puzzle.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/moreculling.toml from /config/yosbr/config/moreculling.toml
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/citresewn.json from /config/yosbr/config/citresewn.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/modernfix-mixins.properties from /config/yosbr/config/modernfix-mixins.properties
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/controlify.json from /config/yosbr/config/controlify.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/sodium-options.json from /config/yosbr/config/sodium-options.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/NoChatReports/NCR-Common.json from /config/yosbr/config/NoChatReports/NCR-Common.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/NoChatReports/NCR-Client.json from /config/yosbr/config/NoChatReports/NCR-Client.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/NoChatReports/NCR-Encryption.json from /config/yosbr/config/NoChatReports/NCR-Encryption.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/iris.properties from /config/yosbr/config/iris.properties
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/dynamic_fps.json from /config/yosbr/config/dynamic_fps.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/debugify.json from /config/yosbr/config/debugify.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/cem.conf from /config/yosbr/config/cem.conf
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/borderlessmining.json from /config/yosbr/config/borderlessmining.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/capes.json5 from /config/yosbr/config/capes.json5
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/entity_texture_features.json from /config/yosbr/config/entity_texture_features.json
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /config/lambdynlights.toml from /config/yosbr/config/lambdynlights.toml
[22/10/2023 11:07:42 am] [main/INFO] Applying default options for /options.txt from /config/yosbr/options.txt
[22/10/2023 11:07:43 am] [main/INFO] SpongePowered MIXIN Subsystem Version=0.8.5 Source=file:**USERSDIR**/libraries/net/fabricmc/sponge-mixin/0.12.5+mixin.0.8.5/sponge-mixin-0.12.5+mixin.0.8.5.jar Service=Knot/Fabric Env=CLIENT
[22/10/2023 11:07:43 am] [main/INFO] Compatibility level set to JAVA_16
[22/10/2023 11:07:43 am] [main/INFO] Compatibility level set to JAVA_17
[22/10/2023 11:07:44 am] [main/INFO] Preloading Debugify
[22/10/2023 11:07:44 am] [main/WARN] Reference map 'entity_model_features_fabric_1.20-fabric-refmap.json' for entity_model_features.mixins.json could not be read. If this is a development environment you can ignore this message
[22/10/2023 11:07:44 am] [main/INFO] Loaded configuration file for Lithium: 115 options available, 1 override(s) found
[22/10/2023 11:07:44 am] [main/INFO] Loaded configuration file for ModernFix 5.8.1+mc1.20.1: 52 options available, 1 override(s) found
[22/10/2023 11:07:44 am] [main/WARN] Option 'mixin.perf.dynamic_resources' overriden (by user configuration) to 'true'
[22/10/2023 11:07:44 am] [main/INFO] Applying Nashorn fix
[22/10/2023 11:07:44 am] [main/INFO] Loaded configuration file for Sodium: 41 options available, 3 override(s) found
[22/10/2023 11:07:44 am] [main/INFO] Loaded configuration file for Sodium Extra: 32 options available, 0 override(s) found
[22/10/2023 11:07:44 am] [main/WARN] Error loading class: de/maxhenkel/voicechat/voice/client/KeyEvents (java.lang.ClassNotFoundException: de/maxhenkel/voicechat/voice/client/KeyEvents)
[22/10/2023 11:07:44 am] [main/WARN] Error loading class: de/maxhenkel/voicechat/voice/client/PTTKeyHandler (java.lang.ClassNotFoundException: de/maxhenkel/voicechat/voice/client/PTTKeyHandler)
[22/10/2023 11:07:45 am] [main/WARN] Force disabled MC-121772 because it only applies to OS: MAC
[22/10/2023 11:07:45 am] [main/WARN] Force disabled MC-59810 because it only applies to OS: MAC
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'alloc.blockstate.StateMixin' as rule 'mixin.alloc.blockstate' (added by mods [ferritecore]) disables it and children
[22/10/2023 11:07:46 am] [main/WARN] Error loading class: net/fabricmc/fabric/impl/client/model/ModelLoadingRegistryImpl$LoaderInstance (java.lang.ClassNotFoundException: net/fabricmc/fabric/impl/client/model/ModelLoadingRegistryImpl$LoaderInstance)
[22/10/2023 11:07:46 am] [main/WARN] @Mixin target net.fabricmc.fabric.impl.client.model.ModelLoadingRegistryImpl$LoaderInstance was not found modernfix-fabric.mixins.json:perf.dynamic_resources.LoaderInstanceMixin from mod modernfix
[22/10/2023 11:07:46 am] [main/WARN] Error loading class: me/jellysquid/mods/sodium/client/render/occlusion/BlockOcclusionCache (java.lang.ClassNotFoundException: me/jellysquid/mods/sodium/client/render/occlusion/BlockOcclusionCache)
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'features.render.entity.CuboidMixin' as rule 'mixin.features.render.entity' (added by mods [iris]) disables it and children
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'features.render.entity.ModelPartMixin' as rule 'mixin.features.render.entity' (added by mods [iris]) disables it and children
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'features.render.entity.cull.EntityRendererMixin' as rule 'mixin.features.render.entity' (added by mods [iris]) disables it and children
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'features.render.entity.shadows.EntityRenderDispatcherMixin' as rule 'mixin.features.render.entity' (added by mods [iris]) disables it and children
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'features.render.gui.font.GlyphRendererMixin' as rule 'mixin.features.render.gui.font' (added by mods [iris]) disables it and children
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'features.render.world.sky.BackgroundRendererMixin' as rule 'mixin.features.render.world.sky' (added by mods [iris]) disables it and children
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'features.render.world.sky.ClientWorldMixin' as rule 'mixin.features.render.world.sky' (added by mods [iris]) disables it and children
[22/10/2023 11:07:46 am] [main/WARN] Force-disabling mixin 'features.render.world.sky.WorldRendererMixin' as rule 'mixin.features.render.world.sky' (added by mods [iris]) disables it and children
[22/10/2023 11:07:46 am] [main/INFO] [MemoryLeakFix] Will be applying 3 memory leak fixes!
[22/10/2023 11:07:46 am] [main/INFO] [MemoryLeakFix] Currently enabled memory leak fixes: [targetEntityLeak, biomeTemperatureLeak, hugeScreenshotLeak]
[22/10/2023 11:07:47 am] [main/WARN] Error loading class: me/jellysquid/mods/sodium/client/render/occlusion/BlockOcclusionCache (java.lang.ClassNotFoundException: me/jellysquid/mods/sodium/client/render/occlusion/BlockOcclusionCache)
[22/10/2023 11:07:47 am] [main/WARN] Error loading class: org/jetbrains/annotations/ApiStatus$Internal (java.lang.ClassNotFoundException: org/jetbrains/annotations/ApiStatus$Internal)
[22/10/2023 11:07:47 am] [main/INFO] I used the json to destroy the json
[22/10/2023 11:07:47 am] [main/INFO] Searching for graphics cards...
[22/10/2023 11:07:47 am] [main/INFO] Initializing MixinExtras via com.llamalad7.mixinextras.service.MixinExtrasServiceImpl(version=0.2.0-rc.5).
[22/10/2023 11:07:47 am] [main/INFO] Found graphics card: GraphicsAdapterInfo[vendor=INTEL, name=HD Graphics 5500, version=unknown]
[22/10/2023 11:07:48 am] Completely ignored arguments: []
[22/10/2023 11:07:49 am] [main/INFO] Mixing common.MixinFriendlyByteBuf from mixins/common/nochatreports.mixins.json into net.minecraft.class_2540
[22/10/2023 11:07:49 am] [main/INFO] Renaming synthetic method lambda$onWriteJsonWithCodec$1(Ljava/lang/Object;Ljava/lang/String;)Lio/netty/handler/codec/EncoderException; to mdd21ae9$nochatreports$lambda$onWriteJsonWithCodec$1$0 in mixins/common/nochatreports.mixins.json:common.MixinFriendlyByteBuf from mod nochatreports
[22/10/2023 11:07:49 am] [main/INFO] Renaming synthetic method lambda$onReadJsonWithCodec$0(Ljava/lang/String;)Lio/netty/handler/codec/DecoderException; to mdd21ae9$nochatreports$lambda$onReadJsonWithCodec$0$1 in mixins/common/nochatreports.mixins.json:common.MixinFriendlyByteBuf from mod nochatreports
[22/10/2023 11:07:51 am] [main/INFO] Injecting BlockStateBase cache population hook into getNeighborPathNodeType from me.jellysquid.mods.lithium.mixin.ai.pathing.AbstractBlockStateMixin
[22/10/2023 11:07:51 am] [main/INFO] Injecting BlockStateBase cache population hook into getPathNodeType from me.jellysquid.mods.lithium.mixin.ai.pathing.AbstractBlockStateMixin
[22/10/2023 11:07:51 am] [main/INFO] Injecting BlockStateBase cache population hook into getAllFlags from me.jellysquid.mods.lithium.mixin.util.block_tracking.AbstractBlockStateMixin
[22/10/2023 11:07:54 am] [main/INFO] Mixing server.MixinServerGamePacketListenerImpl from mixins/common/nochatreports.mixins.json into net.minecraft.class_3244
[22/10/2023 11:07:56 am] [main/WARN] Method overwrite conflict for method_21740 in modernfix-common.mixins.json:perf.remove_biome_temperature_cache.BiomeMixin from mod modernfix, previously written by me.jellysquid.mods.lithium.mixin.world.temperature_cache.BiomeMixin. Skipping method.
[22/10/2023 11:07:57 am] [main/INFO] Vanilla bootstrap took 8010 milliseconds
[22/10/2023 11:07:57 am] [Render thread/INFO] Mixing client.MixinMinecraft from mixins/common/nochatreports.mixins.json into net.minecraft.class_310
[22/10/2023 11:07:57 am] [Render thread/INFO] Mixing client.MixinMinecraft from mixins/fabric/nochatreports-fabric.mixins.json into net.minecraft.class_310
[22/10/2023 11:07:57 am] [Render thread/INFO] Mixing client.MixinTitleScreen from mixins/common/nochatreports.mixins.json into net.minecraft.class_442
[22/10/2023 11:07:58 am] [Render thread/INFO] Mixing client.MixinChatScreen from mixins/common/nochatreports.mixins.json into net.minecraft.class_408
[22/10/2023 11:07:58 am] [Render thread/INFO] Renaming synthetic method lambda$onInit$4()Lnet/minecraft/class_2561; to mdd21ae9$nochatreports$lambda$onInit$4$3 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[22/10/2023 11:07:58 am] [Render thread/INFO] Renaming synthetic method lambda$onInit$3(Lnet/minecraft/class_4185;)V to mdd21ae9$nochatreports$lambda$onInit$3$4 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[22/10/2023 11:07:58 am] [Render thread/INFO] Renaming synthetic method lambda$onInit$2()Lnet/minecraft/class_2561; to mdd21ae9$nochatreports$lambda$onInit$2$5 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[22/10/2023 11:07:58 am] [Render thread/INFO] Renaming synthetic method lambda$onInit$1(Lnet/minecraft/class_4185;)V to mdd21ae9$nochatreports$lambda$onInit$1$6 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[22/10/2023 11:07:58 am] [Render thread/INFO] Renaming synthetic method lambda$onBeforeMessage$0(Ljava/lang/String;Lorg/spongepowered/asm/mixin/injection/callback/CallbackInfoReturnable;Lcom/aizistral/nochatreports/common/encryption/Encryptor;)V to mdd21ae9$nochatreports$lambda$onBeforeMessage$0$7 in mixins/common/nochatreports.mixins.json:client.MixinChatScreen from mod nochatreports
[22/10/2023 11:07:58 am] [Render thread/INFO] Environment: authHost='https://authserver.mojang.com', accountsHost='https://api.mojang.com', sessionHost='https://sessionserver.mojang.com', servicesHost='https://api.minecraftservices.com', name='PROD'
[22/10/2023 11:07:58 am] [Render thread/INFO] Mixing client.MixinYggdrasilUserApiService from mixins/common/nochatreports.mixins.json into com.mojang.authlib.yggdrasil.YggdrasilUserApiService
[22/10/2023 11:07:59 am] [Render thread/INFO] Setting user: **MINECRAFTUSERNAME**
[22/10/2023 11:07:59 am] [Render thread/INFO] Bypassed Mojang DFU
[22/10/2023 11:07:59 am] [Render thread/INFO] Mixing client.MixinToastComponent from mixins/common/nochatreports.mixins.json into net.minecraft.class_374
[22/10/2023 11:07:59 am] [Render thread/INFO] Saving config because the loaded bug fixes are different to stored json.
[22/10/2023 11:07:59 am] [Render thread/INFO] Saving Debugify
[22/10/2023 11:07:59 am] [Render thread/INFO] Enabled 11 bug fixes: [MC-577, MC-59810, MC-89146, MC-90683, MC-112730, MC-121772, MC-122477, MC-140646, MC-199467, MC-237493, MC-263865]
[22/10/2023 11:07:59 am] [Render thread/INFO] Successfully Debugify'd your game!
[22/10/2023 11:08:00 am] [Render thread/INFO] Fadeless is running
[22/10/2023 11:08:00 am] [Render thread/INFO] KONNICHIWA ZA WARUDO!
[22/10/2023 11:08:00 am] [Render thread/INFO] Default JVM text encoding is: UTF-8
[22/10/2023 11:08:00 am] [Render thread/INFO] Reading config file NoChatReports/NCR-Common.json...
[22/10/2023 11:08:00 am] [Render thread/INFO] Reading config file NoChatReports/NCR-Client.json...
[22/10/2023 11:08:00 am] [Render thread/INFO] Reading config file NoChatReports/NCR-ServerPreferences.json...
[22/10/2023 11:08:00 am] [Render thread/INFO] Reading config file NoChatReports/NCR-Encryption.json...
[22/10/2023 11:08:00 am] [Render thread/INFO] Writing config file NoChatReports/NCR-Common.json...
[22/10/2023 11:08:00 am] [Render thread/INFO] Writing config file NoChatReports/NCR-Client.json...
[22/10/2023 11:08:00 am] [Render thread/INFO] Writing config file NoChatReports/NCR-ServerPreferences.json...
[22/10/2023 11:08:00 am] [Render thread/INFO] Writing config file NoChatReports/NCR-Encryption.json...
[22/10/2023 11:08:00 am] [Render thread/INFO] Client initialization...
[22/10/2023 11:08:00 am] [Render thread/INFO] Mixing client.MixinClientPacketListener from mixins/common/nochatreports.mixins.json into net.minecraft.class_634
[22/10/2023 11:08:01 am] [Render thread/INFO] AdvancementInfo initialized
[22/10/2023 11:08:01 am] [Render thread/INFO] Trying to read config file...
[22/10/2023 11:08:01 am] [Render thread/INFO] A config file was found, loading it..
[22/10/2023 11:08:01 am] [Render thread/INFO] Successfully loaded config file.
[22/10/2023 11:08:01 am] [Render thread/INFO] [citresewn] Registering CIT Conditions
[22/10/2023 11:08:01 am] [Render thread/INFO] [citresewn] Registering CIT Types
[22/10/2023 11:08:01 am] [Render thread/INFO] Pre-initializing Controlify...
[22/10/2023 11:08:01 am] [Render thread/INFO] Re-caching descriptions because json doesn't match config.
[22/10/2023 11:08:01 am] [Render thread/INFO] Connecting to 'bugs.mojang.com' to cache bug descriptions!
[22/10/2023 11:08:01 am] [Render thread/WARN] Invalid config, creating new one!
[22/10/2023 11:08:02 am] [Render thread/INFO] Loading Entity Model Features, PI = 3.1415927 and you can't convince me otherwise.
[22/10/2023 11:08:02 am] [Render thread/INFO] Loading Entity Texture Features, did you know if you turn off the lights and whisper 'OptiFine' 3 times you will lose 20fps.
[22/10/2023 11:08:02 am] [Render thread/INFO] [Indigo] Different rendering plugin detected; not applying Indigo.
[22/10/2023 11:08:02 am] [Render thread/INFO] [FastQuit] Initialized
[22/10/2023 11:08:03 am] [Render thread/INFO] [LambDynLights] Initializing LambDynamicLights...
[22/10/2023 11:08:03 am] [Render thread/INFO] [LambDynLights] Configuration loaded.
[22/10/2023 11:08:03 am] [Render thread/INFO] OptiGlue initialized.
[22/10/2023 11:08:03 am] [Render thread/INFO] OptiGUI initialized.
[22/10/2023 11:08:03 am] [Render thread/INFO] Mixing client.MixinOptions from mixins/common/nochatreports.mixins.json into net.minecraft.class_315
[22/10/2023 11:08:03 am] [Render thread/INFO] Renaming synthetic method lambda$onlyShowSecureChat$0(Ljava/lang/Boolean;)V to mdd21ae9$nochatreports$lambda$onlyShowSecureChat$0$2 in mixins/common/nochatreports.mixins.json:client.MixinOptions from mod nochatreports
[22/10/2023 11:08:04 am] [Render thread/INFO] Mixing client.MixinChatComponent from mixins/common/nochatreports.mixins.json into net.minecraft.class_338
[22/10/2023 11:08:04 am] [Render thread/INFO] Renaming synthetic method lambda$modifyGUIMessage$1()V to mdd21ae9$nochatreports$lambda$modifyGUIMessage$1$0 in mixins/common/nochatreports.mixins.json:client.MixinChatComponent from mod nochatreports
[22/10/2023 11:08:04 am] [Render thread/INFO] Renaming synthetic method lambda$modifyGUIMessage$0(Lnet/minecraft/class_5348;Lnet/minecraft/class_2561;)V to mdd21ae9$nochatreports$lambda$modifyGUIMessage$0$1 in mixins/common/nochatreports.mixins.json:client.MixinChatComponent from mod nochatreports
[22/10/2023 11:08:04 am] [Render thread/INFO] Mixing client.MixinGuiMessageTagIcon from mixins/common/nochatreports.mixins.json into net.minecraft.class_7591$class_7592
[22/10/2023 11:08:04 am] [Render thread/INFO] Renaming @Invoker method create(Ljava/lang/String;IIIII)Lnet/minecraft/class_7591$class_7592; to create$nochatreports_$md$d21ae9$0 in mixins/common/nochatreports.mixins.json:client.MixinGuiMessageTagIcon from mod nochatreports
[22/10/2023 11:08:04 am] [Render thread/INFO] Backend library: LWJGL version 3.3.1 SNAPSHOT
[22/10/2023 11:08:05 am] [Render thread/INFO] Initializing ImmediatelyFast 1.2.6+1.20.2 on AMD Radeon R5 M330 (hainan, LLVM 16.0.6, DRM 3.54, 6.5.5-1-MANJARO) (AMD) with OpenGL 4.6 (Core Profile) Mesa 23.1.9-manjaro1.1
[22/10/2023 11:08:05 am] [Render thread/INFO] AMD GPU detected. Enabling coherent buffer mapping
[22/10/2023 11:08:05 am] [Render thread/INFO] Found Iris/Oculus 1.6.10. Enabling compatibility.
[22/10/2023 11:08:05 am] [Render thread/INFO] OpenGL Vendor: AMD
[22/10/2023 11:08:05 am] [Render thread/INFO] OpenGL Renderer: AMD Radeon R5 M330 (hainan, LLVM 16.0.6, DRM 3.54, 6.5.5-1-MANJARO)
[22/10/2023 11:08:05 am] [Render thread/INFO] OpenGL Version: 4.6 (Core Profile) Mesa 23.1.9-manjaro1.1
[22/10/2023 11:08:05 am] [Render thread/INFO] Debug functionality is disabled.
[22/10/2023 11:08:05 am] [Render thread/INFO] OpenGL 4.5 detected, enabling DSA.
[22/10/2023 11:08:05 am] [Render thread/INFO] Shaders are disabled because enableShaders is set to false in iris.properties
[22/10/2023 11:08:05 am] [Render thread/INFO] ARRP register - before vanilla
[22/10/2023 11:08:05 am] [Render thread/INFO] ARRP register - after vanilla
[22/10/2023 11:08:05 am] [Render thread/INFO] ARRP register - before user
[22/10/2023 11:08:05 am] [ALSOFT] (EE) Failed to set real-time priority for thread: Operation not permitted (1)
[22/10/2023 11:08:05 am] [Render thread/WARN] Method overwrite conflict for getModel in fabric-model-loading-api-v1.mixins.json:BakedModelManagerMixin from mod fabric-model-loading-api-v1, previously written by foundationgames.enhancedblockentities.mixin.BakedModelManagerMixin. Skipping method.
[22/10/2023 11:08:06 am] [Render thread/INFO] Hardware information:
[22/10/2023 11:08:06 am] [Render thread/INFO] CPU: 4x Intel(R) Core(TM) i3-5005U CPU @ 2.00GHz
[22/10/2023 11:08:06 am] [Render thread/INFO] GPU: AMD Radeon R5 M330 (hainan, LLVM 16.0.6, DRM 3.54, 6.5.5-1-MANJARO) (Supports OpenGL 4.6 (Core Profile) Mesa 23.1.9-manjaro1.1)
[22/10/2023 11:08:06 am] [Render thread/INFO] OS: Linux (6.5.5-1-MANJARO)
[22/10/2023 11:08:06 am] [Finalizer/WARN] One or more BufferBuilders have been leaked, ModernFix will attempt to correct this.
[22/10/2023 11:08:07 am] at com.mojang.text2speech.NarratorLinux$FliteLibrary.loadNative(NarratorLinux.java:69)
[22/10/2023 11:08:07 am] at com.mojang.text2speech.NarratorLinux.<init>(NarratorLinux.java:18)
[22/10/2023 11:08:07 am] at com.mojang.text2speech.Narrator.getNarrator(Narrator.java:41)
[22/10/2023 11:08:07 am] at net.minecraft.class_333.<init>(class_333.java:19)
[22/10/2023 11:08:07 am] at net.minecraft.class_310.<init>(class_310.java:640)
[22/10/2023 11:08:07 am] at net.minecraft.client.main.Main.main(Main.java:211)
[22/10/2023 11:08:07 am] at net.fabricmc.loader.impl.game.minecraft.MinecraftGameProvider.launch(MinecraftGameProvider.java:468)
[22/10/2023 11:08:07 am] at net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:74)
[22/10/2023 11:08:07 am] at net.fabricmc.loader.impl.launch.knot.KnotClient.main(KnotClient.java:23)
[22/10/2023 11:08:07 am] Caused by: java.lang.UnsatisfiedLinkError: Unable to load library 'flite':
[22/10/2023 11:08:07 am] libflite.so: cannot open shared object file: No such file or directory
[22/10/2023 11:08:07 am] Native library (linux-x86-64/libflite.so) not found in resource path (**USERSDIR**/libraries/net/fabricmc/tiny-mappings-parser/0.3.0+build.17/tiny-mappings-parser-0.3.0+build.17.jar:**USERSDIR**/libraries/net/fabricmc/sponge-mixin/0.12.5+mixin.0.8.5/sponge-mixin-0.12.5+mixin.0.8.5.jar:**USERSDIR**/libraries/net/fabricmc/tiny-remapper/0.8.2/tiny-remapper-0.8.2.jar:**USERSDIR**/libraries/net/fabricmc/access-widener/2.1.0/access-widener-2.1.0.jar:**USERSDIR**/libraries/org/ow2/asm/asm/9.6/asm-9.6.jar:**USERSDIR**/libraries/org/ow2/asm/asm-analysis/9.6/asm-analysis-9.6.jar:**USERSDIR**/libraries/org/ow2/asm/asm-commons/9.6/asm-commons-9.6.jar:**USERSDIR**/libraries/org/ow2/asm/asm-tree/9.6/asm-tree-9.6.jar:**USERSDIR**/libraries/org/ow2/asm/asm-util/9.6/asm-util-9.6.jar:**USERSDIR**/libraries/net/fabricmc/intermediary/1.20.1/intermediary-1.20.1.jar:**USERSDIR**/libraries/net/fabricmc/fabric-loader/0.14.23/fabric-loader-0.14.23.jar:**USERSDIR**/libraries/com/github/oshi/oshi-core/6.2.2/oshi-core-6.2.2.jar:**USERSDIR**/libraries/com/google/code/gson/gson/2.10/gson-2.10.jar:**USERSDIR**/libraries/com/google/guava/failureaccess/1.0.1/failureaccess-1.0.1.jar:**USERSDIR**/libraries/com/google/guava/guava/31.1-jre/guava-31.1-jre.jar:**USERSDIR**/libraries/com/ibm/icu/icu4j/71.1/icu4j-71.1.jar:**USERSDIR**/libraries/com/mojang/authlib/4.0.43/authlib-4.0.43.jar:**USERSDIR**/libraries/com/mojang/blocklist/1.0.10/blocklist-1.0.10.jar:**USERSDIR**/libraries/com/mojang/brigadier/1.1.8/brigadier-1.1.8.jar:**USERSDIR**/libraries/com/mojang/datafixerupper/6.0.8/datafixerupper-6.0.8.jar:**USERSDIR**/libraries/com/mojang/logging/1.1.1/logging-1.1.1.jar:**USERSDIR**/libraries/com/mojang/patchy/2.2.10/patchy-2.2.10.jar:**USERSDIR**/libraries/com/mojang/text2speech/1.17.9/text2speech-1.17.9.jar:**USERSDIR**/libraries/commons-codec/commons-codec/1.15/commons-codec-1.15.jar:**USERSDIR**/libraries/commons-io/commons-io/2.11.0/commons-io-2.11.0.jar:**USERSDIR**/libraries/commons-logging/commons-logging/1.2/commons-logging-1.2.jar:**USERSDIR**/libraries/io/netty/netty-buffer/4.1.82.Final/netty-buffer-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-codec/4.1.82.Final/netty-codec-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-common/4.1.82.Final/netty-common-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-handler/4.1.82.Final/netty-handler-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-resolver/4.1.82.Final/netty-resolver-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-transport-classes-epoll/4.1.82.Final/netty-transport-classes-epoll-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-aarch_64.jar:**USERSDIR**/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-x86_64.jar:**USERSDIR**/libraries/io/netty/netty-transport-native-unix-common/4.1.82.Final/netty-transport-native-unix-common-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-transport/4.1.82.Final/netty-transport-4.1.82.Final.jar:**USERSDIR**/libraries/it/unimi/dsi/fastutil/8.5.9/fastutil-8.5.9.jar:**USERSDIR**/libraries/net/java/dev/jna/jna-platform/5.12.1/jna-platform-5.12.1.jar:**USERSDIR**/libraries/net/java/dev/jna/jna/5.12.1/jna-5.12.1.jar:**USERSDIR**/libraries/net/sf/jopt-simple/jopt-simple/5.0.4/jopt-simple-5.0.4.jar:**USERSDIR**/libraries/org/apache/commons/commons-compress/1.21/commons-compress-1.21.jar:**USERSDIR**/libraries/org/apache/commons/commons-lang3/3.12.0/commons-lang3-3.12.0.jar:**USERSDIR**/libraries/org/apache/httpcomponents/httpclient/4.5.13/httpclient-4.5.13.jar:**USERSDIR**/libraries/org/apache/httpcomponents/httpcore/4.4.15/httpcore-4.4.15.jar:**USERSDIR**/libraries/org/apache/logging/log4j/log4j-api/2.19.0/log4j-api-2.19.0.jar:**USERSDIR**/libraries/org/apache/logging/log4j/log4j-core/2.19.0/log4j-core-2.19.0.jar:**USERSDIR**/libraries/org/apache/logging/log4j/log4j-slf4j2-impl/2.19.0/log4j-slf4j2-impl-2.19.0.jar:**USERSDIR**/libraries/org/joml/joml/1.10.5/joml-1.10.5.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/slf4j/slf4j-api/2.0.1/slf4j-api-2.0.1.jar:**USERSDIR**/libraries/net/minecraft/client/1.20.1/client-1.20.1.jar)
[22/10/2023 11:08:07 am] at com.sun.jna.NativeLibrary.loadLibrary(NativeLibrary.java:307)
[22/10/2023 11:08:07 am] at com.sun.jna.NativeLibrary.getInstance(NativeLibrary.java:467)
[22/10/2023 11:08:07 am] at com.sun.jna.NativeLibrary.getInstance(NativeLibrary.java:409)
[22/10/2023 11:08:07 am] at com.mojang.text2speech.NarratorLinux$FliteLibrary.loadNative(NarratorLinux.java:67)
[22/10/2023 11:08:07 am] ... 8 more
[22/10/2023 11:08:07 am] Suppressed: java.lang.UnsatisfiedLinkError: libflite.so: cannot open shared object file: No such file or directory
[22/10/2023 11:08:07 am] at com.sun.jna.Native.open(Native Method)
[22/10/2023 11:08:07 am] at com.sun.jna.NativeLibrary.loadLibrary(NativeLibrary.java:197)
[22/10/2023 11:08:07 am] ... 11 more
[22/10/2023 11:08:07 am] at com.sun.jna.NativeLibrary.loadLibrary(NativeLibrary.java:210)
[22/10/2023 11:08:07 am] Suppressed: java.io.IOException: Native library (linux-x86-64/libflite.so) not found in resource path (**USERSDIR**/libraries/net/fabricmc/tiny-mappings-parser/0.3.0+build.17/tiny-mappings-parser-0.3.0+build.17.jar:**USERSDIR**/libraries/net/fabricmc/sponge-mixin/0.12.5+mixin.0.8.5/sponge-mixin-0.12.5+mixin.0.8.5.jar:**USERSDIR**/libraries/net/fabricmc/tiny-remapper/0.8.2/tiny-remapper-0.8.2.jar:**USERSDIR**/libraries/net/fabricmc/access-widener/2.1.0/access-widener-2.1.0.jar:**USERSDIR**/libraries/org/ow2/asm/asm/9.6/asm-9.6.jar:**USERSDIR**/libraries/org/ow2/asm/asm-analysis/9.6/asm-analysis-9.6.jar:**USERSDIR**/libraries/org/ow2/asm/asm-commons/9.6/asm-commons-9.6.jar:**USERSDIR**/libraries/org/ow2/asm/asm-tree/9.6/asm-tree-9.6.jar:**USERSDIR**/libraries/org/ow2/asm/asm-util/9.6/asm-util-9.6.jar:**USERSDIR**/libraries/net/fabricmc/intermediary/1.20.1/intermediary-1.20.1.jar:**USERSDIR**/libraries/net/fabricmc/fabric-loader/0.14.23/fabric-loader-0.14.23.jar:**USERSDIR**/libraries/com/github/oshi/oshi-core/6.2.2/oshi-core-6.2.2.jar:**USERSDIR**/libraries/com/google/code/gson/gson/2.10/gson-2.10.jar:**USERSDIR**/libraries/com/google/guava/failureaccess/1.0.1/failureaccess-1.0.1.jar:**USERSDIR**/libraries/com/google/guava/guava/31.1-jre/guava-31.1-jre.jar:**USERSDIR**/libraries/com/ibm/icu/icu4j/71.1/icu4j-71.1.jar:**USERSDIR**/libraries/com/mojang/authlib/4.0.43/authlib-4.0.43.jar:**USERSDIR**/libraries/com/mojang/blocklist/1.0.10/blocklist-1.0.10.jar:**USERSDIR**/libraries/com/mojang/brigadier/1.1.8/brigadier-1.1.8.jar:**USERSDIR**/libraries/com/mojang/datafixerupper/6.0.8/datafixerupper-6.0.8.jar:**USERSDIR**/libraries/com/mojang/logging/1.1.1/logging-1.1.1.jar:**USERSDIR**/libraries/com/mojang/patchy/2.2.10/patchy-2.2.10.jar:**USERSDIR**/libraries/com/mojang/text2speech/1.17.9/text2speech-1.17.9.jar:**USERSDIR**/libraries/commons-codec/commons-codec/1.15/commons-codec-1.15.jar:**USERSDIR**/libraries/commons-io/commons-io/2.11.0/commons-io-2.11.0.jar:**USERSDIR**/libraries/commons-logging/commons-logging/1.2/commons-logging-1.2.jar:**USERSDIR**/libraries/io/netty/netty-buffer/4.1.82.Final/netty-buffer-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-codec/4.1.82.Final/netty-codec-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-common/4.1.82.Final/netty-common-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-handler/4.1.82.Final/netty-handler-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-resolver/4.1.82.Final/netty-resolver-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-transport-classes-epoll/4.1.82.Final/netty-transport-classes-epoll-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-aarch_64.jar:**USERSDIR**/libraries/io/netty/netty-transport-native-epoll/4.1.82.Final/netty-transport-native-epoll-4.1.82.Final-linux-x86_64.jar:**USERSDIR**/libraries/io/netty/netty-transport-native-unix-common/4.1.82.Final/netty-transport-native-unix-common-4.1.82.Final.jar:**USERSDIR**/libraries/io/netty/netty-transport/4.1.82.Final/netty-transport-4.1.82.Final.jar:**USERSDIR**/libraries/it/unimi/dsi/fastutil/8.5.9/fastutil-8.5.9.jar:**USERSDIR**/libraries/net/java/dev/jna/jna-platform/5.12.1/jna-platform-5.12.1.jar:**USERSDIR**/libraries/net/java/dev/jna/jna/5.12.1/jna-5.12.1.jar:**USERSDIR**/libraries/net/sf/jopt-simple/jopt-simple/5.0.4/jopt-simple-5.0.4.jar:**USERSDIR**/libraries/org/apache/commons/commons-compress/1.21/commons-compress-1.21.jar:**USERSDIR**/libraries/org/apache/commons/commons-lang3/3.12.0/commons-lang3-3.12.0.jar:**USERSDIR**/libraries/org/apache/httpcomponents/httpclient/4.5.13/httpclient-4.5.13.jar:**USERSDIR**/libraries/org/apache/httpcomponents/httpcore/4.4.15/httpcore-4.4.15.jar:**USERSDIR**/libraries/org/apache/logging/log4j/log4j-api/2.19.0/log4j-api-2.19.0.jar:**USERSDIR**/libraries/org/apache/logging/log4j/log4j-core/2.19.0/log4j-core-2.19.0.jar:**USERSDIR**/libraries/org/apache/logging/log4j/log4j-slf4j2-impl/2.19.0/log4j-slf4j2-impl-2.19.0.jar:**USERSDIR**/libraries/org/joml/joml/1.10.5/joml-1.10.5.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-glfw/3.3.1/lwjgl-glfw-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-jemalloc/3.3.1/lwjgl-jemalloc-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-openal/3.3.1/lwjgl-openal-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-opengl/3.3.1/lwjgl-opengl-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-stb/3.3.1/lwjgl-stb-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl-tinyfd/3.3.1/lwjgl-tinyfd-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1.jar:**USERSDIR**/libraries/org/lwjgl/lwjgl/3.3.1/lwjgl-3.3.1-natives-linux.jar:**USERSDIR**/libraries/org/slf4j/slf4j-api/2.0.1/slf4j-api-2.0.1.jar:**USERSDIR**/libraries/net/minecraft/client/1.20.1/client-1.20.1.jar)
[22/10/2023 11:08:07 am] at com.sun.jna.Native.extractFromResourcePath(Native.java:1145)
[22/10/2023 11:08:07 am] at com.sun.jna.NativeLibrary.loadLibrary(NativeLibrary.java:281)
[22/10/2023 11:08:07 am] [Render thread/ERROR] Error while loading the narrator
[22/10/2023 11:08:07 am] [Render thread/INFO] Mixing client.MixinChatListener from mixins/common/nochatreports.mixins.json into net.minecraft.class_7594
[22/10/2023 11:08:07 am] [Render thread/INFO] Invalidating pack caches
[22/10/2023 11:08:07 am] [Render thread/INFO] Reloading ResourceManager: vanilla, fabric (advanced_runtime_resource_pack, advancementinfo, animatica, bettermounthud, borderlessmining, caffeineconfig, capes, citresewn, citresewn-defaults, cloth-config, conditional-mixin, continuity, controlify, debugify, dynamic_fps, e4mc_minecraft, enhancedblockentities, entity_model_features, entity_texture_features, entityculling, fabric-api, fabric-api-base, fabric-api-lookup-api-v1, fabric-biome-api-v1, fabric-block-api-v1, fabric-block-view-api-v2, fabric-blockrenderlayer-v1, fabric-client-tags-api-v1, fabric-command-api-v1, fabric-command-api-v2, fabric-commands-v0, fabric-containers-v0, fabric-content-registries-v0, fabric-convention-tags-v1, fabric-crash-report-info-v1, fabric-data-generation-api-v1, fabric-dimensions-v1, fabric-entity-events-v1, fabric-events-interaction-v0, fabric-events-lifecycle-v0, fabric-game-rule-api-v1, fabric-item-api-v1, fabric-item-group-api-v1, fabric-key-binding-api-v1, fabric-keybindings-v0, fabric-language-kotlin, fabric-lifecycle-events-v1, fabric-loot-api-v2, fabric-loot-tables-v1, fabric-message-api-v1, fabric-mining-level-api-v1, fabric-model-loading-api-v1, fabric-models-v0, fabric-networking-api-v1, fabric-networking-v0, fabric-object-builder-api-v1, fabric-particles-v1, fabric-recipe-api-v1, fabric-registry-sync-v0, fabric-renderer-api-v1, fabric-renderer-indigo, fabric-renderer-registries-v1, fabric-rendering-data-attachment-v1, fabric-rendering-fluids-v1, fabric-rendering-v0, fabric-rendering-v1, fabric-resource-conditions-api-v1, fabric-resource-loader-v0, fabric-screen-api-v1, fabric-screen-handler-api-v1, fabric-sound-api-v1, fabric-transfer-api-v1, fabric-transitive-access-wideners-v1, fabricloader, fabricskyboxes, fabrishot, fadeless, fastquit, fsb-interop, immediatelyfast, indium, iris, lambdynlights, languagereload, lithium, midnightlib, mixintrace, modernfix, modmenu, morechathistory, moreculling, nochatreports, optigui, pride, puzzle, puzzle-base, puzzle-gui, puzzle-models, puzzle-splashscreen, reeses-sodium-options, rrls, sodium, sodium-extra, spruceui, yet_another_config_lib_v3, yosbr, zoomify), continuity:glass_pane_culling_fix, continuity:default, file/SodiumTranslations.zip, file/Mod Menu Helper.zip, file/Chat Reporting Helper.zip, file/Fast Better Grass.zip
[22/10/2023 11:08:07 am] [Render thread/INFO] closing rrp ebe:base_resources
[22/10/2023 11:08:07 am] [Render thread/INFO] ARRP register - before vanilla
[22/10/2023 11:08:07 am] [Render thread/INFO] ARRP register - after vanilla
[22/10/2023 11:08:07 am] [Render thread/INFO] Mixing client.MixinJoinMultiplayerScreen from mixins/common/nochatreports.mixins.json into net.minecraft.class_500
[22/10/2023 11:08:07 am] [Render thread/INFO] Renaming synthetic method lambda$onInit$2()Lnet/minecraft/class_2561; to mdd21ae9$nochatreports$lambda$onInit$2$0 in mixins/common/nochatreports.mixins.json:client.MixinJoinMultiplayerScreen from mod nochatreports
[22/10/2023 11:08:07 am] [Render thread/INFO] Renaming synthetic method lambda$onInit$1(Lnet/minecraft/class_4185;)V to mdd21ae9$nochatreports$lambda$onInit$1$1 in mixins/common/nochatreports.mixins.json:client.MixinJoinMultiplayerScreen from mod nochatreports
[22/10/2023 11:08:07 am] [Render thread/INFO] Renaming synthetic method lambda$onInit$0(Lnet/minecraft/class_4185;)V to mdd21ae9$nochatreports$lambda$onInit$0$2 in mixins/common/nochatreports.mixins.json:client.MixinJoinMultiplayerScreen from mod nochatreports
[22/10/2023 11:08:08 am] [Render thread/ERROR] [citresewn] Caution! Broken paths is enabled!
[22/10/2023 11:08:08 am] [Render thread/INFO] Creating pipeline for dimension NamespacedId{namespace='minecraft', name='overworld'}
[22/10/2023 11:08:08 am] [Worker-ResourceReload-0/INFO] Found unifont_all_no_pua-15.0.06.hex, loading
[22/10/2023 11:08:08 am] [Render thread/INFO] Cached all modded block culling states
[22/10/2023 11:08:08 am] [Render thread/INFO] Game entered main loop!
[22/10/2023 11:08:21 am] [Worker-ResourceReload-1/INFO] Early baking 180 models
[22/10/2023 11:08:22 am] [Render thread/INFO] Language is not set. Setting it to system language
[22/10/2023 11:08:22 am] [Render thread/WARN] Missing sound for event: minecraft:item.goat_horn.play
[22/10/2023 11:08:22 am] [Render thread/WARN] Missing sound for event: minecraft:entity.goat.screaming.horn_break
[22/10/2023 11:08:22 am] [ALSOFT] (EE) Failed to set real-time priority for thread: Operation not permitted (1)
[22/10/2023 11:08:22 am] [Render thread/INFO] OpenAL initialized on device Built-in Audio Analog Stereo
[22/10/2023 11:08:22 am] [Render thread/INFO] Sound engine started
[22/10/2023 11:08:23 am] [Render thread/INFO] Created: 1024x1024x4 minecraft:textures/atlas/blocks.png-atlas
[22/10/2023 11:08:35 am] amdgpu: The CS has been rejected (-125), but the context isn't robust.
[22/10/2023 11:08:35 am] amdgpu: The process will be terminated.
[22/10/2023 11:08:35 am] Oh no. Minecraft crashed. Please check the logs for any errors and provide these logs when asking for support.
[22/10/2023 11:08:35 am] Checking for updated files!
[22/10/2023 11:08:35 am] Checking for updates to Modrinth instances
[22/10/2023 11:10:41 am]
You are missing the prerequisites for using the AUR.
sudo pacman -Syu base-devel git
And what about the game ?
The game doesn’t launch with wrapper option env=DRI_PRIME=1
How are you launching the thing exactly?
I use ATLauncher… In the instance settings, there’s is a wrapper command text box, where I write env= DRI_PRIME=1
It should only be DRI_PRIME=1
env
is a command. by default it lists all variables.
env=ENV=var
is not the proper syntax for variables.
Generally we just use ENV=VAR
or ENVVAR
lemme try that , but thats how its told on the website i referred to
also its env DRI_PRIME=1, not env= …
If you are referring to some other documentation then please link it.
cant include links in my post
https://alphonso-javier.medium.com/how-to-use-dedicated-radeon-gpu-on-minecraft-for-linux-ubuntu-6e86a058985
[22/10/2023 12:48:04 pm] java.io.IOException: Cannot run program "DRI_PRIME=1" (in directory "**USERSDIR**/instances/FabulouslyOptimized"): error=2, No such file or directory
[22/10/2023 12:48:04 pm] at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1143)
[22/10/2023 12:48:04 pm] at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1073)
[22/10/2023 12:48:04 pm] at com.atlauncher.mclauncher.MCLauncher.launch(MCLauncher.java:100)
[22/10/2023 12:48:04 pm] at com.atlauncher.mclauncher.MCLauncher.launch(MCLauncher.java:69)
[22/10/2023 12:48:04 pm] at com.atlauncher.data.Instance.lambda$launch$24(Instance.java:1108)
[22/10/2023 12:48:04 pm] at java.base/java.lang.Thread.run(Thread.java:833)
[22/10/2023 12:48:04 pm] Caused by: java.io.IOException: error=2, No such file or directory
[22/10/2023 12:48:04 pm] at java.base/java.lang.ProcessImpl.forkAndExec(Native Method)
[22/10/2023 12:48:04 pm] at java.base/java.lang.ProcessImpl.<init>(ProcessImpl.java:314)
[22/10/2023 12:48:04 pm] at java.base/java.lang.ProcessImpl.start(ProcessImpl.java:244)
[22/10/2023 12:48:04 pm] at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1110)
[22/10/2023 12:48:04 pm] ... 5 more
... 5 more
it didnt even launch any window this time
Ah, that makes more sense. Use that then.
Back to the situation at hand…
That guide is for Mint and is about 2 years old … while I dont have first-hand knowledge on the subject of Minecraft/ATLauncher … I would guess that the guide is not up to date, if not incompatible.
The section on java for example;
Our packages dont look like that exactly … and default java versions are handled by archlinux-java
with the current version being 21 (and you seem to be using 17?).
Of course theres lots of info here, but seemingly nothing about your issue:
https://wiki.archlinux.org/title/Minecraft
Umm, so what should I do now ?
I use java 17 cuz thats what I use for my college projects, and that runs my minecraft properly, when using igpu
Bro it’s stuck on booting again
