I need help… yes sry. the start, but I can’t see how to do it.
I know crontab and know I can add something like
0 10 * * * root /etc/systemd/shutdown -r now
And then my linux will restart every day at 10.
But I can’t see how Manjaro is using crontab, and I can’t see how I make the same “restart” in cronie without making a lot of .sh files and so on.
Have looked at “kshutdown” but here I can only restart once and not daily at 10.
Can someone try to learn an old fox, how to make a simple daily restart at 10, like on crontab? THX alot.
I have never used the crontab in Manjaro but I use it in Debian on my RPi. I don’t think you need the /etc/systemd/ just shutdown -r now should suffice.
yes, but that file is totally empty, no info at all.
And if I add my schedule “code” to the file and save/restart, it’s not working like in debian or rashbian…
