You do not have opencl-nvidia package. Install it, otherwise you could not use D.R. Even if you are planning to use cuda, opencl-nvidia will be installed as its dependency.
it showed opencl is not installed
but i have installled opencl and rebooted
i am pretty sure that i installed the right drivers because all other apps are working
Maybe you took the wrong version of opencl. What is the output to:
nvidia-smi
pamac install opencl-nvidia
also, an inxi --full --admin --verbosity=7 --filter --no-host would be of help (and should always be provided regardless of the question you’re asking…
Erm, that’s quite hard to read for an old fart like me, so could you edit that and put 3 backticks ``` before and after the output you posted so that output looks like this.
OK, you’re on the 350.xx driver and you have a GTX1660 (TI or not? as that output has ... at the crucial point), but that’s already good!
What’s the output to pamac install opencl-nvidia? Because the first time when you install that, it will ask you:
Choose a provider for opencl-nvidia:
1: opencl-nvidia-340xx 340.108-1 extra
2: opencl-nvidia-390xx 390.132-1 extra
3: opencl-nvidia-418xx 418.113-1 extra
4: opencl-nvidia-430xx 430.64-1 extra
5: opencl-nvidia-435xx 435.21-1 extra
6: opencl-nvidia-440xx 440.100-1 extra
7: opencl-nvidia-450xx 450.57-2 extra
and if you take the wrong version there, you’re in a heap of trouble, so the output to clinfo would be appreciated as well.
thanks for taking time
my gpu is 1660 ti mobile 6gb ddr6
but i am a premere pro user
i just got into manjaro a month ago and wanted to
give a editing test so that i could stop paying for adobe
kdenlive works fine but davinci resolve 16 has some additional features
i think installing cuda will fix it
but as you have asked for clinfo i installed it and here is the output
i am sure that i have installed nvidia450 with opencl v450
i think
clinfo
Number of platforms 1
Platform Name NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 1.2 CUDA 11.0.210
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics
Platform Extensions function suffix NV
Number of devices 1
Device Name GeForce GTX 1660 Ti
Device Vendor NVIDIA Corporation
Device Vendor ID 0x10de
Device Version OpenCL 1.2 CUDA
Driver Version 450.57
Device OpenCL C Version OpenCL C 1.2
Device Type GPU
Device Topology (NV) PCI-E, 01:00.0
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 24
Max clock frequency 1590MHz
Compute Capability (NV) 7.5
Device Partition (core)
Max number of sub-devices 1
Supported partition types None
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 1024x1024x64
Max work group size 1024
Preferred work group size multiple 32
Warp size (NV) 32
Preferred / native vector sizes
char 1 / 1
short 1 / 1
int 1 / 1
long 1 / 1
half 0 / 0 (n/a)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals Yes
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Support is emulated in software No
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Address bits 64, Little-Endian
Global memory size 6233391104 (5.805GiB)
Error Correction support No
Max memory allocation 1558347776 (1.451GiB)
Unified memory for Host and Device No
Integrated memory (NV) No
Minimum alignment for any data type 128 bytes
Alignment of base address 4096 bits (512 bytes)
Global Memory cache type Read/Write
Global Memory cache size 786432 (768KiB)
Global Memory cache line size 128 bytes
Image support Yes
Max number of samplers per kernel 32
Max size for 1D images from buffer 268435456 pixels
Max 1D or 2D image array size 2048 images
Max 2D image size 32768x32768 pixels
Max 3D image size 16384x16384x16384 pixels
Max number of read image args 256
Max number of write image args 32
Local memory type Local
Local memory size 49152 (48KiB)
Registers per block (NV) 65536
Max number of constant args 9
Max constant buffer size 65536 (64KiB)
Max size of kernel argument 4352 (4.25KiB)
Queue properties
Out-of-order execution Yes
Profiling Yes
Prefer user sync for interop No
Profiling timer resolution 1000ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Kernel execution timeout (NV) Yes
Concurrent copy and kernel execution (NV) Yes
Number of async copy engines 3
printf() buffer size 1048576 (1024KiB)
Built-in kernels (n/a)
Device Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) NVIDIA CUDA
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [NV]
clCreateContext(NULL, ...) [default] Success [NV]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) Invalid device type for platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) No platform
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.12
ICD loader Profile OpenCL 2.2
Please do me a favour and add the output to the inxi in your original question so that the next person looking for a solved issue can compare its output to yours!
