Hi everyone!
New Linux user here. I’m trying out Manjaro for the first time on my old Dell Studio laptop (originally was running under Win Vista) and so far liking it a lot. It got second life and is actually usable now
All essential stuff is working out of the box however I can’t figure out how to setup bluetooth so I could use my headphones with it.
When I open “Bluetooth Manager” it just shows empty window or error. Clicking on “Bluetooth Adapters” doesn’t seem to do anything either. I also wasn’t able to find anything bluetooth-related in user guide pdf.
As mentioned I’ve just started learning Linux so whilst googling did show some results - it’s all terminal-based solutions and I don’t want to blindly copy-paste various commands without clear understanding what it’ll actually do & potentially reinstall whole system.
Would appreciate any suggestions/help
Thanks!
My inxi command output
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=dca2d871-d8a3-4ae4-8d42-84415237cf26 rw quiet apparmor=1
security=apparmor resume=UUID=1336917e-4355-4c52-8419-74e48e61e9ab
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Portable System: Dell product: Studio 1537 v: A11 serial: <filter>
Mobo: Dell model: 0P132H v: A11 serial: <filter> BIOS: Dell v: A11
date: 04/14/2011
RAM: total: 1.93 GiB used: 1.33 GiB (68.9%)
Info: Dual Core model: Intel Core2 Duo P8400 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: 6 microcode: 60F cache: L2: 3 MiB
bogomips: 9047
Speed: 798 MHz min/max: 800/2267 MHz Core speeds (MHz): 1: 798 2: 798
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca mce mmx
monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti
rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2 tsc vme xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: AMD RV620/M82 [Mobility Radeon HD 3450/3470] vendor: Dell
driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:95c4 class-ID: 0300
Device-2: Ricoh Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 05ca:18a0 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3")
s-diag: 398mm (15.7")
Monitor-1: LVDS res: 1280x800 hz: 60 dpi: 98 size: 331x207mm (13.0x8.1")
diag: 390mm (15.4")
OpenGL: renderer: AMD RV620 (DRM 2.50.0 / 5.10.56-1-MANJARO LLVM 12.0.1)
v: 3.3 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
Device-1: Intel 82801I HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:293e class-ID: 0403
Device-2: AMD RV620 HDMI Audio [Radeon HD 3450/3470/3550/3570] vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 1002:aa28
class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Broadcom BCM4312 802.11b/g LP-PHY
vendor: Dell Wireless 1397 WLAN Mini-Card driver: wl v: kernel modules: ssb
port: 2000 bus-ID: 04:00.0 chip-ID: 14e4:4315 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Broadcom NetLink BCM5784M Gigabit Ethernet PCIe vendor: Dell
driver: tg3 v: kernel port: 2000 bus-ID: 08:00.0 chip-ID: 14e4:1698
class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Local Storage: total: 232.89 GiB used: 8.22 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS543225L9A300
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: C40C scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: DVD+-RW TS-T633A rev: D300
dev-links: cdrom
ID-1: / raw-size: 228.63 GiB size: 223.98 GiB (97.97%) used: 8.21 GiB (3.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: dca2d871-d8a3-4ae4-8d42-84415237cf26
ID-1: swap-1 type: partition size: 4.25 GiB used: 12.3 MiB (0.3%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 1336917e-4355-4c52-8419-74e48e61e9ab
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-6:3 info: Ricoh Integrated Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 05ca:18a0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 3-1:2
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 3-1.1:3 info: Dell Integrated Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 2mA
chip-ID: 413c:8157 class-ID: 0301
Device-2: 3-1.2:4 info: Dell Integrated Touchpad / Trackstick type: Mouse
chip-ID: 413c:8158 class-ID: 0301
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-9: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 46.0 C mobo: 46.0 C
Fan Speeds (RPM): cpu: 3242 fan-2: 3247 fan-3: 3247
Processes: 174 Uptime: 2h 38m wakeups: 5 Init: systemd v: 248
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1012 lib: 281
flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
