Need help recovering boot partition
I don’t know how it happened, I did not do anything different than usual when I shut down my pc, but I can’t boot into my manjaro installation on my pc, normally.
I have a separate windows ssd in my desktop that I rarely boot up, and haven’t recently used
when I turned on my pc it booted directly to windows, and I immediately thought, this is going to take up my day. It has, and it threatens to take more. I have since removed the windows ssd because I don’t trust it to be even present on my system. I have used SystemRestoreCD to boot into my installation, and running lsblk returns:
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda           8:0    0 931.5G  0 disk
└─sda2        8:2    0 931.4G  0 part
sdb           8:16   1  28.9G  0 disk
├─sdb1        8:17   1   737M  0 part
└─sdb2        8:18   1   1.4M  0 part
nvme0n1     259:0    0 931.5G  0 disk
└─nvme0n1p1 259:1    0 931.5G  0 part /var/lib/snapd/snap
There is no /boot partition
running sudo gdisk -l /dev/nvme0n1 returns:
GPT fdisk (gdisk) version 1.0.9.1
Caution: invalid main GPT header, but valid backup; regenerating main header
from backup!
Warning: Invalid CRC on main header data; loaded backup partition table.
Warning! Main and backup partition tables differ! Use the 'c' and 'e' options
on the recovery & transformation menu to examine the two tables.
Warning! Main partition table CRC mismatch! Loaded backup partition table
instead of main partition table!
Warning! One or more CRCs don't match. You should repair the disk!
Main header: ERROR
Backup header: OK
Main partition table: ERROR
Backup partition table: OK
Partition table scan:
  MBR: MBR only
  BSD: not present
  APM: not present
  GPT: damaged
Found valid MBR and corrupt GPT. Which do you want to use? (Using the
GPT MAY permit recovery of GPT data.)
 1 - MBR
 2 - GPT
 3 - Create blank GPT
following some other tutorials like
did not work because
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
fails and returns:
Installing for x86_64-efi platform.
grub-install: error: failed to get canonical path of `/boot/efi'.
which makes sense because that partition is not there
running uname -r returns:
6.1.30-1-lts
I also ran test disk which also failed to recover the partition, and gave off some errors.
here is what the initial output looks like when selecting the analyse function:
TestDisk 7.1, Data Recovery Utility, July 2019
Christophe GRENIER <grenier@cgsecurity.org>
https://www.cgsecurity.org
Disk /dev/nvme0n1 - 1000 GB / 931 GiB - CHS 953869 64 32
Current partition structure:
     Partition                  Start        End    Size in sectors
Bad GPT partition, invalid signature.
Trying alternate GPT
 1 P EFI System                  4096    1023998    1019903
No FAT, NTFS, ext2, JFS, Reiser, cramfs or XFS marker
 2 P MS Data                  1024000    9412606    8388607 [recovery]
 3 P Linux filesys. data      9412608  646067813  636655206
 4 P Linux Swap            1945132464 1953521070    8388607
 5 P EFI System             646067815 1945132462 1299064648 [root]
Here is what the output of a quick scan looks like:
>P Linux filesys. data         2048 1953520063 1953518016
And here is part of what a deeper scan returns because it has to finish running:
The harddisk (1000 GB / 931 GiB) seems too small! (< 2172 GB / 2023 GiB)
Check the harddisk size: HD jumper settings, BIOS detection...
The following partitions can't be recovered:
>  Linux filesys. data    128558911 1976179884 1847620974
   Mac HFS                384999568 4243760017 3858760450
   Mac HFS                821847179 2149409932 1327562754 [lambda_1>@?1???$GetNodeOBB@~F ~T
   Linux filesys. data    973342736 2926860751 1953518016
   Linux filesys. data    973342792 2926860807 1953518016
   Linux filesys. data    973342904 2926860919 1953518016
   Linux filesys. data    973342976 2926860991 1953518016
   Linux filesys. data    973343184 2926861199 1953518016
   Linux filesys. data    973343272 2926861287 1953518016
   Linux filesys. data    973343384 2926861399 1953518016
[ Continue ]
LUKS 83 (Data size unknown), 945 GB / 881 GiB
then the next page:
>D Linux filesys. data         2046 1953520061 1953518016
 D Linux filesys. data         2048 1953520063 1953518016
 D Mac HFS                 62845489   62847604       2116
 D Mac HFS                 62847601   62849716       2116
 D Linux filesys. data     73416393   74788376    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data     73416394   74788377    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data     78528201   79900184    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data     78528202   79900185    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data     85507785   86879768    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data     85507786   86879769    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data     89579209   90951192    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data     89579210   90951193    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    104627913  105999896    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    104627914  105999897    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    111533769  112905752    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    111533770  112905753    1371984 [GWM-9M-$ث݊M-= b~^dS
 D EFI System             137727408  137730287       2880 [EFI System Partition] [EFISECTOR]
 D MS Data                137732107  137738280       6174
 D MS Data                137738280  137744453       6174 [Boot]
 D EFI System             139528612  139536803       8192 [EFI System Partition] [NO NAME]
 D Linux filesys. data    152977097  154349080    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    152977098  154349081    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    192560841  193932824    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    192560842  193932825    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    223215305  224587288    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    223215306  224587289    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Mac HFS                260743896  765371097  504627202
 D MS Data                271495168  376246271  104751104
 D MS Data                272579506  376242176  103662671
 D Linux filesys. data    274947785  276319768    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    274947786  276319769    1371984 [GWM-9M-$ث݊M-= b~^dS
 D MS Data                376127489  376229888     102400
 D MS Data                376133632  376236031     102400
 D MS Data                376229888  376332287     102400
 D MS Data                376236031  376338430     102400
 D MS Data                376242176  479904846  103662671
 D MS Data                376246271  480997374  104751104
 D MS Data                382484571  382490744       6174
 D MS Data                382490744  382496917       6174 [Boot]
 D EFI System             382503216  382506095       2880 [EFI System Partition] [EFISECTOR]
 D MS Data                382982187  382988360       6174
 D MS Data                382988360  382994533       6174 [Boot]
 D MS Data                383412371  383418544       6174
 D MS Data                383414475  383420648       6174
 D MS Data                383418544  383424717       6174
 D MS Data                383420648  383426821       6174
 D EFI System             383424808  383427687       2880 [EFI System Partition] [EFISECTOR]
 D Mac HFS                383990598  920927046  536936449
 D Linux filesys. data    505347785  506719768    1371984 [GWM-9M-$ث݊M-= b~^dS
 D Linux filesys. data    505347786  506719769    1371984 [GWM-9M-$ث݊M-= b~^dS
Structure: Ok.  Use Up/Down Arrow keys to select partition.
Use Left/Right Arrow keys to CHANGE partition characteristics:
                P=Primary  D=Deleted
Keys A: add partition, L: load backup, T: change type, P: list files,
     Enter: to continue
I have tried to follow along some other tutorials and forum posts but failed because they are often very specific to the poster’s scenario and do not match up with mine. I am out of ideas
Thank you for your time
Some theories I have on why or how this happened:
I don’t think that this is nearly as important as getting the ability to use my computer back, but, I find it interesting and I would like to have this not happen again.
I don’t know much about how windows can screw with your linux install, but I thought it was unable to directly access another disk, but when poking around in bios settings I found a setting called windows uefi firmware update, which looking back on probably has nothing to do with all of this, and secure boot was turned back on, when I am very sure that it was off. So maybe windows, through an update, screwed with my boot partition on an separate drive, and turned on secure boot as a final screw you. I sure would love this to be the case, because that would mean that removing the windows drive from my machine would keep this from happening again. But I don’t think windows can even do that? The most I have seen it affect other drives is by marking my data hard drives as read only and reserving them for windows, not screwing with bios settings and other drives partitions.
I am not sure what actually worked because I screwed up and had my boot order wrong, I had usb above my linux drive, but i forgot I just did that today, and had been using it booting to the live cd as a sign it was still not working and I had tried a bunch of things between now and then, but I think that this guide had done it
https://askubuntu.com/questions/1394708/accidentally-deleted-efi-partition-system-is-still-running
