Need help installing new? nvidia drivers
So my end goal is to get Blender to recognize my graphics card. I thought changing the drivers from nouveau to nvidia would help with that. But in the process I have gotten a bit lost and I’m not sure what to do next.
I took help from the manjaro wiki and Here’s what I have done so far:
  1. I checked what drivers I was running by doing:
inxi -G
It showed me that my Nvidia Graphics card was running nouveau driver.
  1. I installed the nvidia drivers by doing:
sudo mhwd -a pci nonfree 0300
  1. Then I rebooted the system and ran:
mhwd -li
and the result is:
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2020.11.30               false            PCI
           video-linux            2018.05.04                true            PCI
I also ran inxi -G again and it shows the following output:
Graphics:  Device-1: Intel Haswell-ULT Integrated Graphics driver: i915 v: kernel
           Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] driver: N/A
           Display: x11 server: X.Org 1.20.10 driver: modesetting unloaded: intel resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.3.1
Which shows that the nvidia driver hasn’t been installed.
Now from a post on the forum, I see that there are new 450 drivers instead of 300 (which I have installed if I’m not wrong).
Please guide me through this.
You did everything right. In the next step you should remove video-linux driver or add nouveau driver to blacklist – now your system probably doesn’t know which driver should use so doesn’t use any.
mhwd should’ve already done that.
I think the problem might be that your GPU is not supported by the latest NVIDIA drivers. And for some reason mhwd incorrectly thought that it was supported. Find the PCI device ID of the NVIDIA GPU using lspci -nn, and then check this list and determine if the device ID is before or after the
Below are the legacy GPUs that are no longer supported in the unified driver. These GPUs will continue to be maintained through the special legacy NVIDIA GPU driver releases.
The 390.xx driver supports the following set of GPUs:
text. If it’s after, then you’ll need to remove video-hybrid-intel-nvidia-prime by running sudo mhwd -r pci video-hybrid-intel-nvidia-prime, and then install video-hybrid-intel-nvidia-390xx-bumblebee using sudo mhwd -i pci video-hybrid-intel-nvidia-390xx-bumblebee.
So here’s what I have done so far:
  1. Blacklisted nouveau by doing:
sudo bash -c "echo blacklist nouveau > /etc/modprobe.d/blacklist-nvidia-nouveau.conf"
sudo bash -c "echo options nouveau modeset=0 >> /etc/modprobe.d/blacklist-nvidia-nouveau.conf"
  1. Checked my device ID of the GPU. It is GeForce GT 720M which is listed as a legacy driver which is supported by the 390.xx drivers. So I removed video-hybrid-intel-nvidia-prime by running:
  1. Installed the 390.xx drivers by doing:
But even after that, when i run:
inxi -G
I still get:
           Display: x11 server: X.Org 1.20.10 driver: intel resolution: 1366x768~60Hz
If I run mhwd -li, I get:
video-hybrid-intel-nvidia-390xx-bumblebee            2020.11.30               false            PCI
  1. I tried configuring the settings by doing: sudo nvidia-setting and got a message that “You do not appear to be using the NVIDIA X driver. Please edit your X configuration file by running nvidia-xconfig as root, and restart the X servver.”
So I ran:
sudo nvidia-xconfig
which gave me this message:
WARNING: Unable to locate/open X configuration file.
New X configuration file written to '/etc/X11/xorg.conf'
The file looks like this:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 390.138  (buildmeister@swio-display-x64-rhel04-01)  Thu May 14 05:09:33 PDT 2020
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
  1. Then I rebooted my system and now when I run sudo nvidia-settings it still displays the same error message that I need to edit my X config. It also displays the following message in the console:
ERROR: NVIDIA driver is not loaded
ERROR: Error querying enabled displays on GPU 0 (Missing Extension).
ERROR: Error querying connected displays on GPU 0 (Missing Extension).
ERROR: nvidia-settings could not find the registry key file. This file should have been installed along with this driver at
       /usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be
       prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions.
Is there an additional step I’m missing? Does the driver need to be turned on in some way before its useable? Please guide me.
Thanks
This is unnecessary as mhwd already does this. Please undo these modifications.
Do not create any Xorg configuration files unless you need it.
The first thing I’d suggest is removing /etc/X11/xorg.conf and /etc/X11/xorg.conf.d/90-mhwd.conf (if it exists). Then reboot.
Okay, I have deleted the /etc/modprobe.d/blacklist-nvidia-nouveau.conf file.
Also done. Rebooted. But still the no driver being recognized.
Output of inxi -G is:
           Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting resolution: 1366x768~60Hz
and output of mhwd -li is:
What happens if you run nvidia-modprobe, then inxi -Gazy?
Running nvidia-modprobe gives no visual output.
Running inxi -Gazy gives me this:
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
  driver: N/A alternate: nouveau, nvidia_drm, nvidia bus ID: 03:00.0
  chip ID: 10de:1140
  Display: x11 server: X.Org 1.20.10 compositor: picom v: git-dac85
  driver: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
  screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  v: 4.5 Mesa 20.3.1 compat-v: 3.0 direct render: Yes
What about lsmod | grep nvidia?
It returns nothing. So that means it doesn’t recognize the drivers…Right?
If you run sudo modprobe nvidia, then lsmod | grep nvidia?
Okay so now it gives me this:
nvidia              15835136  0
ipmi_msghandler        73728  2 ipmi_devintf,nvidia
Output of inxi -G now is:
           Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] driver: nvidia v: 390.138
So the drivers are installed. :star_struck:
Well, Blender still won’t recognize my graphics cards.
And after rebooting the system, the output of inxi -G again shows no drivers installed for the graphics card:
I think you need to install CUDA 9.1: cuda-9.1 from the AUR.
The driver is installed on the system, it’s just not loaded for some reason.
What’s the output of sudo dmesg | egrep -i '(nvidia|nouveau)'?
Okay I have installed it. Btw why cuda-9.1 and not some other version?
It doesn’t give any output.
I’m unsure why the driver not loaded automatically. Can you run sudo modprobe nvidia, then sudo modprobe nvidia_uvm?
Running sudo modprobe nvidia gives no output.
Running sudo modprobe nvidia_uvm gives:
modprobe: FATAL: Module nvidia_uvm not found in directory /lib/modules/5.10.2-2-MANJARO
It seems the 5.10 kernel won’t work if you want to use CUDA, so you probably need to switch (e.g.) 5.4.
So I switched to 5.4 and initially it didn’t pickup the driver but then I ran both sudo modprobe nvidia and sudo modprobe nvidia_uvm again. There was no output. But now when i do lsmod | grep nvidia, I get this:
nvidia_uvm            929792  0
nvidia              15835136  1 nvidia_uvm
ipmi_msghandler        69632  2 ipmi_devintf,nvidia
So that means that nvidia_uvm is now also running.
But still, blender does not pick up the graphic card. Could it be that I haven’t installed cuda correctly?
Can you install clinfo and run it to see if at least OpenCL works?
