Hey y’all! I bought a EDUP usb wifi card off amazon and, at first, it worked. I restarted my computer after an update today and now the wifi isn’t working at all.
I had rtl88x2bu-dkms-git from the AUR downloaded and I’ve tried redownloading that a few times. Whenever it tries to use dkms it gets this error message
==> dkms install --no-depmod -m rtl88x2bu -v 5.8.7.4.r129.15c214d -k 5.11.19-1-MANJARO
Error! Bad return status for module build on kernel: 5.11.19-1-MANJARO (x86_64)
Consult /var/lib/dkms/rtl88x2bu/5.8.7.4.r129.15c214d/build/make.log for more information.
==> Warning,dkms install --no-depmod -m rtl88x2bu -v 5.8.7.4.r129.15c214d -k 5.11.19-1-MANJARO' returned 10 ==> dkms install --no-depmod -m rtl88x2bu -v 5.8.7.4.r129.15c214d -k 5.9.16-1-MANJARO Error! Bad return status for module build on kernel: 5.9.16-1-MANJARO (x86_64) Consult /var/lib/dkms/rtl88x2bu/5.8.7.4.r129.15c214d/build/make.log for more information. ==> Warning,
dkms install --no-depmod -m rtl88x2bu -v 5.8.7.4.r129.15c214d -k 5.9.16-1-MANJARO’ returned 10
==> depmod 5.9.16-1-MANJARO
==> depmod 5.11.19-1-MANJARO
and then just finishes.
I’m really confused by this. I’ve rechecked a bunch with lsusb and yeah it’s realtek rtl8810bu. If anyone has any idea let me know. I tried searching on the forum but didn’t find anything. Thank you!!
