My Motherboard has two ethernet ports; a 2.5g and a 1000mb one. I only have one ethernet cable to my room, so if I want two devices in my room to have ethernet, I need something to act as a network switch.
I used to be able to create a “Wired Ethernet (shared)” and the nintendo would get internet just fine, but this is no longer working, or there is something set up in a way that prevents it from working properly.
I would much prefer to create a virtual bridge connection, but both for this and the shared wired ethernet it just hangs on “setting network access” in the connections menu after I select the slave and then turn it on. Eventually it times out and I get the notification "IP configuration was unavailable " for the bridge.
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=ab97410d-219d-4b6b-a11e-ecd4e63ac169 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO (WI-FI)
v: Rev X.0x serial: <filter> UEFI: American Megatrends v: 2103
date: 06/19/2020
RAM: total: 62.72 GiB used: 3.94 GiB (6.3%)
Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 6 MiB bogomips: 182125
Speed: 2381 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2381 2: 2051 3: 2194 4: 2199 5: 3580 6: 2050 7: 2053 8: 2191 9: 2195
10: 2196 11: 2144 12: 3673 13: 2055 14: 2166 15: 2194 16: 3018 17: 2082
18: 2049 19: 3597 20: 2052 21: 2162 22: 4122 23: 2132 24: 2195
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070]
vendor: PC Partner Limited / Sapphire driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 0b:00.0 chip-ID: 10de:2484
class-ID: 0300
Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2.1:4 chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 5120x1440 s-dpi: 121 s-size: 1073x302mm (42.2x11.9")
s-diag: 1115mm (43.9")
Monitor-1: DP-2 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio
vendor: PC Partner Limited / Sapphire driver: snd_hda_intel v: kernel
bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0d:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: no
Sound Server-5: PipeWire v: 0.3.38 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: d000
bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
IF-ID-1: bridge0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:5
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 6.6 TiB used: 56.79 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:5 model: PCIe SSD size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFM22.6 temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 model: PCIe SSD size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
type: SSD serial: <filter> rev: EGFM11.0 temp: 38.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
type: HDD rpm: 7200 serial: <filter> rev: CC25 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUS724040ALE641
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A5F0 scheme: GPT
ID-1: / raw-size: 166.25 GiB size: 162.64 GiB (97.83%)
used: 56.79 GiB (34.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
label: N/A uuid: ab97410d-219d-4b6b-a11e-ecd4e63ac169
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
uuid: F49E-8144
ID-1: swap-1 type: partition size: 71.92 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:8 label: N/A
uuid: fe86311b-6721-4cfd-b9bc-6676c056c68c
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: A0CEC91DCEC8ED1A
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
uuid: 10C9-47BA
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 930.88 GiB fs: ntfs label: N/A
uuid: 084EC9E74EC9CE1E
ID-5: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: externalData
uuid: 2652FC3C52FC11F3
ID-6: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ext4 label: external2
uuid: 5f9f058d-11b9-43c9-af07-0c8a1688b5b4
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 3 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-1.3:4 info: Realtek BillBoard Device type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 0bda:5418 class-ID: 1100
serial: <filter>
Hub-3: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-5.3:6 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Device-2: 1-6:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-3:2 info: Realtek Hub ports: 2 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-7: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 3-2.1:4 info: ARC Camera type: Video,Audio
power: 200mA chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Device-2: 3-5:3 info: Cooler Master AMD SR4 lamplight Control
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 2516:0051 class-ID: 0300
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-10: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-11: 5-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Hub-12: 5-2:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
Hub-13: 5-4:7 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 5-4.1:8 info: SINOWEALTH Game Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 256mA chip-ID: 258a:1007 class-ID: 0301
Device-2: 5-4.4:9 info: Microdia Redragon Mitra RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
Hub-14: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-15: 6-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
Hub-16: 6-2:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
Hub-17: 6-4:5 info: Realtek Hub ports: 4 rev: 3.1 speed: 5 Gb/s
System Temperatures: cpu: 63.6 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Processes: 454 Uptime: 22m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1356 lib: 394
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
