I’ve noticed that qt5ct is not preinstalled by Manjaro, only qtconfig-qt4. Is this intended to be like this?
Note that qt5ct would suggest to add QT_QPA_PLATFORMTHEME=qt5ct to /etc/environment
Maybe I don’t need to change that and don’t install qt5ct?
That is needed only on non Qt Desktop … Like Gnome, XFCE, Cinnamon, Mate … etc. KDE Plasma has the Settings > Appearance to deal with Qt Widgets and Style …
If by chance you are running wayland session then you can make use of
I think I’m on x11 not wayland, I’m using the defualt Manjaro values:
$ echo $XDG_SESSION_TYPE
x11
Change the SDDM theme to Breeze and now the login screen looks fine.
However if I disable Force font DPI text keeps being too big, if I set it to 96 then it looks fine. Isn’t 96 the default value already?
How can I check that my default font dpi is not messed up? I made the Manjaro install some time ago so looks like some configuration file is not right.
This is the value with both Force font DPI disabled or set to 96:
$ xdpyinfo | grep resolution
resolution: 128x130 dots per inch
