After activating Zoom in Accessibility menu, the mouse is nearly frozen, the desktop becomes sluggish.
Restarting the computer does not help.
mv ~/.config ~/.config-disabled
(in Console) and restarting does not help.
I thought user settings were in ~/.config
, apparently not, so where are they?
Restoring completely the Manjaro root partition solves the problem, which excludes a hardware breakdown.
Then, the problem can be reproduced.
Is there any way to start Gnome safely (with all custom settings disabled) from the console?
How to turn off zoom from the console or Alt F2 with gsettings
or dconf
Please excuse my superficial knowledge. I am only a hobbyist, thanks.
alba@mac2011-manjaro% inxi --full
Host: mac2011-manjaro Kernel: 6.1.69-1-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 45.2 Distro: Manjaro Linux
Type: Laptop System: Apple product: MacBookPro8,1 v: 1.0
serial: <superuser required>
Mobo: Apple model: Mac-94245B3640C91C81 v: MacBookPro8,1
serial: <superuser required> UEFI: Apple v: MBP81.88Z.0050.B00.1804101331
date: 04/10/18
ID-1: BAT0 charge: 63.3 Wh (100.0%) condition: 63.3/62.9 Wh (100.7%)
Info: dual core model: Intel Core i5-2415M bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 798 min/max: 800/2900 cores: 1: 798 2: 798 3: 798 4: 798
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
driver: i915 v: kernel
Device-2: Apple FaceTime HD Camera driver: uvcvideo type: USB
Display: x11 server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 driver:
X: loaded: modesetting dri: crocus gpu: i915 resolution: 1: 1920x1200~60Hz
2: 1280x800~60Hz
API: EGL v: 1.5 drivers: crocus,swrast
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 23.1.9-manjaro1.1
renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
driver: snd_hda_intel
API: ALSA v: k6.1.69-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
IF: enp2s0f0 state: down mac: 3c:07:54:20:0c:57
Device-2: Broadcom BCM4331 802.11a/b/g/n driver: wl
IF: wlp3s0 state: up mac: 28:cf:da:f2:ff:5c
IF-ID-1: eth0 state: down mac: 16:20:5e:3c:b9:53
Device-1: Apple Bluetooth Host Controller driver: btusb type: USB
Local Storage: total: 1.36 TiB used: 477.96 GiB (34.2%)
ID-1: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
ID-2: /dev/sdb model: Disk size: 465.76 GiB type: FireWire
ID-1: / size: 457.23 GiB used: 239.02 GiB (52.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 15.3 MiB (5.1%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 93.0 C mobo: 0.0 C
Fan Speeds (rpm): N/A
Processes: 332 Uptime: 29m Memory: total: 16 GiB available: 15.54 GiB
used: 6.84 GiB (44.0%) Shell: Zsh inxi: 3.3.31
