I’ve been checking both the official repos and the AUR but there is nothing there. how can i install ndiswrapper on manjaro?
uname --kernel-release
5.10.89-1-MANJARO
5.10.89-1-MANJARO
Hi @overclock351,
Searching for “ndis” reveals:
$ pamac search ndis
Platform agnostic UI, NanoVG imitating the Blender 2.5, single C header file.
linux54-ndiswrapper 1.63-138 extra
Module for NDIS (Windows Network Drivers) drivers supplied by vendors.
ndiswrapper-utils 1.62-13 extra
Utils for NDIS (Windows Network Drivers) drivers supplied by vendors.
that it seems not to be available for you kernel (5.10``) (yet)
So try downgrading to kernel 5.4 first, then installing it.
Hope this helps!
The project isn’t maintained anymore:
I don’t think anything is planned at this point. There is not much interest for ndiswrapper, as the Linux driver support for the recent WiFi hardware got much better.
So as @Mirdarthos suggested either you can use kernel 5.4 or apply this patch for kernel 5.10 as suggested here (the patch is originally for 5.8 but will work for 5.10):
Any alternatives? i need something that acts as a wrapper to windows drivers
thanks for the patch. will try!
The patch worked! thanks
