i installed nbfc from yay - S nbfc
everything worked well first time i launched it.
Then, at reboot i try to launch it again and i get : connection refused.
systemctl status nbfc ✔ 3s
● nbfc.service - NoteBook FanControl service
Loaded: loaded (/etc/systemd/system/nbfc.service; enabled; vendor preset: >
Active: active (running) since Thu 2021-10-21 09:12:29 CEST; 12min ago
Main PID: 742 (mono)
Tasks: 12 (limit: 28689)
Memory: 38.5M
CPU: 7.056s
CGroup: /system.slice/nbfc.service
└─742 /usr/bin/mono /usr/lib/mono/4.5/mono-service.exe -l:/run/nbf>
oct. 21 09:12:29 manjaro systemd[1]: Starting NoteBook FanControl service...
oct. 21 09:12:29 manjaro systemd[1]: nbfc.service: Can't open PID file /run/nbf>
oct. 21 09:12:29 manjaro systemd[1]: Started NoteBook FanControl service.
oct. 21 09:12:30 manjaro mono[742]: NbfcService: Service NoteBookFanControlServ>
thank for moving the post and for your response. I think it isn’t the same problem, what i don’t understand is that if i remove nbfc with yay -R nbfc and reinstall it, it will works:
sudo systemctl enable nbfc --now ✔ 10s
Created symlink /etc/systemd/system/multi-user.target.wants/nbfc.service → /etc/systemd/system/nbfc.service.
~ nbfc config --apply "Asus Zenbook UX410UQ" ✔
~ nbfc status -a ✔
Service enabled : True
Read-only : False
Selected config name : Asus Zenbook UX410UQ
Temperature : 36
Fan display name : Fan #1
Auto control enabled : True
Critical mode enabled : False
Current fan speed : 0.00
Target fan speed : 0.00
Fan speed steps : 8
when i reboot and try to launch nbfc again it will fail with: “connection refused”
if I run ‘mono /opt/nbfc/nbfc.exe status -a’ (or 'bash -c ‘nbfc status -a’ to get rid of the fish shell caused problem) I get the following error: “Connection refused” (I also tried with sudo, but got the same.) Any help is appreciated.
