Nautilus repeatedly freezing with no apparent reason. How to debug or reset?
Hello!
Lately I’m having issues on my Manjaro GNOME installation, and I can’t find a solution. I have searched for similar issues but they are different or old and were solved with updates.
The issue: Nautilus works fine for a while and then it freezes with no message in the terminal.
The problem shows:
  • Sometimes, when trying to search.
  • Sometimes, just with no apparent reason nor action from my side.
Usually I just kill it and it restarts without issue, but sometimes it won’t open anymore, showing this message when trying from the terminal:
Failed to register: timeout was reached
I’m using Manjaro GNOME (41.5) on X11.
As launching it from the terminal is not providing a lot of info, is there another way I could debug this to find out what the issue is?
I was also considering “resetting” the application, cleaning preferences and reinstalling or something like that, but I’m not sure it’s the correct thing to do.
Hi @eldelacajita, and welcome!
I don’t use Gnome, so not Nautilus either. But after some searching, I came across this page, that states:
Here is a solution I found from the GNOME website. Simply set the environmental variables before launching nautilus, i.e.:
G_DEBUG="all" NAUTILUS_DEBUG="All" nautilus
Logs can be captured from the terminal output.
So try that and see?
That is not the Gnome Website, but the Ubuntu Wiki. Also it is the old way.
This is used on newer nautilus:
nautilus -q; G_MESSAGES_DEBUG="all" NAUTILUS_DEBUG="all"  nautilus 2>&1 | tee nautilus.log
Be ready for a long trash log to discover.
Also see https://wiki.gnome.org/Projects/Tracker/Documentation/Debugging for handling tracker issues.
systemctl --user stop tracker-miner-fs-3.service
systemctl --user stop tracker-extract-3.service
systemctl --user stop tracker-miner-rss-3.service
tracker3 reset --rss --filesystem
systemctl --user start tracker-miner-fs-3.service
systemctl --user status tracker-miner-fs-3.service
You’ll notice that it’s a quote from the AskUbuntu page. :wink:
And thanks. As I mentioned, I don’t use 'em, so that’s only what I could find.
Thanks a lot, @megavolt and @Mirdarthos!
I will try that and see if I can find anything useful in the output.
