There are no icons present for any file
Also if there is a photo in the clipboard nautilus crashes
What icon theme are you using? Try Papirus Icon Theme:
I just had that screenshot in the clipboard and Nautilus did not crash for me.
Ok that worked some issue with my icon pack
My icon pack decided to change its name
But screenshot in the clipboard still crashes nautilus
Will mark this as solved
