Nautilus does not show syncing services (google, nextcloud) in the sidebar even though I’ve logged in and activated syncing in gnome-settings → online accounts.
I’m not quite sure how and when that happen, it used to work before. I’ve tried to log out and log back in but the issue still persists. I’m sure the issue is somehow related to nautilus as other apps like calendar and contacts sync without any issues.
This issue is related but as you can see it has not been solved for five years.
System info
$ inxi -v7azy
Kernel: 5.18.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=b1fc74e5-d9ba-4f03-a7d7-c543e7b8b686 rw audit=0 quiet splash
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: HUAWEI product: MACH-WX9 v: M12
serial: <superuser required>
Mobo: HUAWEI model: MACH-WX9 v: M12 serial: <superuser required>
UEFI: HUAWEI v: 1.28 date: 03/15/2019
ID-1: BAT0 charge: 28.1 Wh (83.1%) condition: 33.8/56.3 Wh (60.0%)
volts: 8.1 min: 7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
serial: <filter> status: charging cycles: 12
RAM: total: 15.38 GiB used: 4.13 GiB (26.9%)
RAM Report:
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3947 high: 4002 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3887 2: 3853 3: 4001
4: 3894 5: 4000 6: 4000 7: 3940 8: 4002 bogomips: 32012
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Huawei driver: i915 v: kernel
arch: Gen9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Huawei driver: nvidia
v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d12 class-ID: 0302
Device-3: Cheng Uei Precision Industry (Foxlink) HD Camera type: USB
driver: uvcvideo bus-ID: 1-7:3 chip-ID: 05c8:03c0 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model-id: JDI 0x422a built: 2017 res: 3000x2000 dpi: 260
gamma: 1.2 size: 293x196mm (11.54x7.72") diag: 353mm (13.9") ratio: 3:2
modes: 3000x2000
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Huawei
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.18.5-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wireless 8265 / 8275 vendor: Huawei driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3c:00.0
chip-ID: 8086:24fd class-ID: 0280
IF: wlp60s0 state: up mac: <filter>
bus-ID: 1-5:2 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 195.83 GiB (41.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 type: SSD serial: <filter> rev: AAXA4103 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 232.64 GiB size: 227.93 GiB (97.97%)
used: 195.79 GiB (85.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: b1fc74e5-d9ba-4f03-a7d7-c543e7b8b686
ID-2: /boot/efi raw-size: 300 MiB size: 98.4 MiB (32.82%)
used: 39.8 MiB (40.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: D547-F07B
ID-1: swap-1 type: partition size: 4 GiB used: 280 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: swap
uuid: 800e57d7-ef68-4a56-bcf1-e153ccfab98e
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: ext4 label: N/A
uuid: 9ea901f4-edaa-4de0-b311-506906d90038
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 123.57 GiB fs: ntfs label: N/A
uuid: 2C96186096182CB8
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 116.42 GiB fs: ext4 label: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-7:3 info: Cheng Uei Precision Industry (Foxlink) HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03c0 class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 63.0 C pch: 48.0 C mobo: N/A
Processes: 287 Uptime: 19h 10m wakeups: 30 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1286 pacman: 1204 lib: 297 flatpak: 82 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.19
Logs
$ nautilus .
** (org.gnome.Nautilus:41730): WARNING **: 14:18:15.153: Unable to initialize tag manager: SQL logic error
Relevant packages
$ pacman -Q | grep "nautilus\|gnome"
gnome-autoar 0.4.3-2
gnome-bluetooth-3.0 42.1-1
gnome-calculator 42.1-1
gnome-calendar 42.1-1
gnome-characters 42.0-1
gnome-clocks 42.0-1
gnome-color-manager 3.36.0+r25+g4aab8b59-1
gnome-contacts 42.0-1
gnome-control-center 42.2-1
gnome-desktop 1:42.2-1
gnome-desktop-4 1:42.2-1
gnome-desktop-common 1:42.2-1
gnome-disk-utility 42.0-1
gnome-firmware 42.2-1
gnome-font-viewer 42.0-1
gnome-keyring 1:42.1-1
gnome-logs 42.0-1
gnome-menus 3.36.0-1
gnome-online-accounts 3.44.0-1
gnome-screenshot 41.0+r25+g45f08f0-1
gnome-session 42.0-1
gnome-settings-daemon 42.2-1
gnome-shell 1:42.2-1
gnome-shell-extension-pop-shell 1.2.0+268+g811201b-1
gnome-software 42.2-1
gnome-system-monitor 42.0-1
gnome-terminal-transparency 3.44.1-1
gnome-themes-extra 3.28+r6+g45b1d457-1
gnome-tweaks 42beta+r9+gc66d8c3-1
gnome-user-share 3.34.0-2
gnome-wallpapers 20201020-1
gnome-weather 42.0-1
libgnomekbd 1:3.26.1+r5+g54da436-1
libnautilus-extension 42.2-1
lighter-gnome 20211216-1
manjaro-gnome-settings 20220606-1
nautilus 42.2-1
nautilus-admin 1.1.9+5+ga51885e-1
nautilus-empty-file 1.2-2
polkit-gnome 0.105-9
python-nautilus 1.2.3-7
qgnomeplatform-qt5 0.8.4-3
qgnomeplatform-qt6 0.8.4-3
xdg-desktop-portal-gnome 42.1-1
Edit:
After doing some thinking I could have just run pacman -Si gnome-online-accounts nautilus and looked for optional dependencies
. And installed packages @Yochanan mentioned.
