Regardless of Adwaita or Matcha theme, the right-click compress popup in Nautilus looks broken to me. When going for the drop-down menu, the popup to select the type of compression doesn’t fully display.
I just checked two things:
- The issue also occurs in the current minimal iso live system for Manjaro GNOME, so this seems to be a general issue and not just a misconfiguration on my side.
- I’ve also checked the current GNOME OS nightly, where with Nautilus 42.alpha the dropdown doesn’t go to the left but to the bottom instead.
Is there anything I can do at this point? Is this a known bug for Manjaro already? It looks like reporting to GNOME/Files is not useful because there’s already a rework of this menu in discussion and the alpha has it fixed with the old dropdown menu.
