Can not drag and drop from Virtualbox to nautilus, Archive manager to nautilus. Nautilus to nautilus across mounted smb drives. and rename wont go away by pressing ESC. These all work by rolling back prior to the 11/14 update. Gnome extensions on or off does not matter.
And every day i seem to find more problems and bugs with Gnome 43, the rename bug is just not ESC, i used to just click of of the rename window and it would close and that does not work either now, also have a problem when trying to copy folders/files that sometimes it will get stuck on the last folder i copied or just randomly pick another folder i was not trying to copy.
My current work around is to use Caja File Manager
sudo pacman -S caja
