Nach Update kein Kontact mehr (akonadi)
Hi, ich habe gerade ein Update gemacht und nach einem reboot startet kontact nicht mehr. Diese Fehlermeldung erhalte ich bei der akonadiconsole bei Server neustarten für den mysql-server.
>  mysql.err.old
>  1   2025-09-01 13:30:53 0 [Note] Starting MariaDB 12.0.2-MariaDB source revision aab83aecdca15738d114cf5a2f223f1d12e4e6bd server_uid vE4fXkAicQ2RybjyQY4pAHxfAps= as process 3038
>    1 2025-09-01 13:30:53 0 [Warning] --innodb-file-per-table is deprecated and will be removed in a future release
>    2 2025-09-01 13:30:53 0 [Warning] option 'innodb-log-buffer-size': unsigned value 1048576 adjusted to 2097152
>    3 2025-09-01 13:30:53 0 [Note] InnoDB: Compressed tables use zlib 1.3.1
>    4 2025-09-01 13:30:53 0 [Note] InnoDB: Number of transaction pools: 1
>    5 2025-09-01 13:30:53 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
>    6 2025-09-01 13:30:53 0 [Note] InnoDB: Using io_uring
>    7 2025-09-01 13:30:53 0 [Note] InnoDB: innodb_buffer_pool_size_max=128m, innodb_buffer_pool_size=128m
>    8 2025-09-01 13:30:53 0 [Note] InnoDB: Initialized memory pressure event listener
>    9 2025-09-01 13:30:53 0 [Note] InnoDB: Completed initialization of buffer pool
>   10 2025-09-01 13:30:53 0 [Note] InnoDB: Buffered log writes (block size=512 bytes)
>   11 2025-09-01 13:30:53 0 [Note] InnoDB: Resetting space id's in the doublewrite buffer
>   12 2025-09-01 13:30:53 0 [Note] InnoDB: End of log at LSN=2392098508
>   13 2025-09-01 13:30:53 0 [Note] InnoDB: Opened 3 undo tablespaces
>   14 2025-09-01 13:30:53 0 [Note] InnoDB: 128 rollback segments in 3 undo tablespaces are active.
>   15 2025-09-01 13:30:53 0 [Note] InnoDB: Setting file './ibtmp1' size to 12.000MiB. Physically writing the file full; Please wait ...
>   16 2025-09-01 13:30:53 0 [Note] InnoDB: File './ibtmp1' size is now 12.000MiB.
>   17 2025-09-01 13:30:53 0 [Note] InnoDB: log sequence number 2392098508; transaction id 859652
>   18 2025-09-01 13:30:53 0 [Note] InnoDB: Loading buffer pool(s) from /home/sgo/.local/share/akonadi/db_data/ib_buffer_pool
>   19 2025-09-01 13:30:53 0 [Note] Plugin 'wsrep-provider' is disabled.
>   20 2025-09-01 13:30:53 0 [Note] InnoDB: Buffer pool(s) load completed at 250901 13:30:53
>   21 2025-09-01 13:30:57 0 [Note] /usr/bin/mysqld: ready for connections.
>   22 Version: '12.0.2-MariaDB'  socket: '/run/user/1000/akonadi/mysql.socket'  port: 0  Arch Linux
>   23 2025-09-01 13:53:26 0 [Note] /usr/bin/mysqld (initiated by: unknown): Normal shutdown
>   24 2025-09-01 13:53:26 0 [Note] InnoDB: FTS optimize thread exiting.
>   25 2025-09-01 13:53:26 0 [Note] InnoDB: Starting shutdown...
>   26 2025-09-01 13:53:26 0 [Note] InnoDB: Dumping buffer pool(s) to /home/sgo/.local/share/akonadi/db_data/ib_buffer_pool
>   27 2025-09-01 13:53:26 0 [Note] InnoDB: Restricted to 2028 pages due to innodb_buf_pool_dump_pct=25
>   28 2025-09-01 13:53:26 0 [Note] InnoDB: Buffer pool(s) dump completed at 250901 13:53:26
>   29 2025-09-01 13:53:26 0 [Note] InnoDB: Removed temporary tablespace data file: "./ibtmp1"
>   30 2025-09-01 13:53:26 0 [Note] InnoDB: Shutdown completed; log sequence number 2392100490; transaction id 859680
>   31 2025-09-01 13:53:26 0 [Note] /usr/bin/mysqld: Shutdown complete
> 2025-09-01 14:01:32 0 [Note] Starting MariaDB 12.0.2-MariaDB source revision aab83aecdca15738d114cf5a2f223f1d12e4e6bd server_uid vE4fXkAicQ2RybjyQY4pAHxfAps= as process 3824
> 2025-09-01 14:01:32 0 [Warning] --innodb-file-per-table is deprecated and will be removed in a future release
> 2025-09-01 14:01:32 0 [Warning] option 'innodb-log-buffer-size': unsigned value 1048576 adjusted to 2097152
> 2025-09-01 14:01:32 0 [Note] InnoDB: Compressed tables use zlib 1.3.1
> 2025-09-01 14:01:32 0 [Note] InnoDB: Number of transaction pools: 1
> 2025-09-01 14:01:32 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
> 2025-09-01 14:01:32 0 [Note] InnoDB: Using io_uring
> 2025-09-01 14:01:32 0 [Note] InnoDB: innodb_buffer_pool_size_max=128m, innodb_buffer_pool_size=128m
> 2025-09-01 14:01:32 0 [Note] InnoDB: Initialized memory pressure event listener
> 2025-09-01 14:01:32 0 [Note] InnoDB: Completed initialization of buffer pool
> 2025-09-01 14:01:32 0 [Note] InnoDB: Buffered log writes (block size=512 bytes)
> 2025-09-01 14:01:32 0 [Note] InnoDB: Resetting space id's in the doublewrite buffer
> 2025-09-01 14:01:32 0 [Note] InnoDB: End of log at LSN=2392100490
> 2025-09-01 14:01:32 0 [Note] InnoDB: Opened 3 undo tablespaces
> 2025-09-01 14:01:32 0 [Note] InnoDB: 128 rollback segments in 3 undo tablespaces are active.
> 2025-09-01 14:01:32 0 [Note] InnoDB: Setting file './ibtmp1' size to 12.000MiB. Physically writing the file full; Please wait ...
> 2025-09-01 14:01:32 0 [Note] InnoDB: File './ibtmp1' size is now 12.000MiB.
> 2025-09-01 14:01:32 0 [Note] InnoDB: log sequence number 2392100490; transaction id 859681
> 2025-09-01 14:01:32 0 [Note] InnoDB: Loading buffer pool(s) from /home/sgo/.local/share/akonadi/db_data/ib_buffer_pool
> 2025-09-01 14:01:32 0 [Note] Plugin 'wsrep-provider' is disabled.
> 2025-09-01 14:01:32 0 [Note] InnoDB: Buffer pool(s) load completed at 250901 14:01:32
> 2025-09-01 14:01:33 0 [Note] /usr/bin/mysqld: ready for connections.
> 2025-09-01 14:05:43 10 [Warning] Aborted connection 10 to db: 'akonadi' user: 'sgo' host: '' (Got an error reading communication packets)
Ich weiß nun gar nicht so recht, wo ich überhaupt sonst noch anfangen soll zu suchen. Hat jemand einen Tip?
Danke.
Mod edit:- Please use preformatted text boxes.
See How to Post Command Output as Preformatted Text :eyes:
