This has been fixed at archlinux but not yet in manjaro.
Details at MariaDB 10.6 prepared queries metadata cache causes breakage in mysql driver
Package Details: mythtv 31+fixes.20210401.563a05b7-1
and other sources…
and other sources…
Please see:
You can see which package versions are in which branches here:
Arch:
local/qt5-base 5.15.2+kde+r215-2 (qt qt5)
A cross-platform application and UI framework
Manjaro:
local/qt5-base 5.15.2+kde+r210-1 (qt qt5)
Arch:
[root@KISE-005 pkg]# ls -lt | grep qt5-base
-rw-r--r-- 1 root root 13632241 Aug 14 01:13 qt5-base-5.15.2+kde+r215-2-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13632326 Aug 11 15:10 qt5-base-5.15.2+kde+r214-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13632111 Aug 2 15:07 qt5-base-5.15.2+kde+r211-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13632306 Jul 13 01:52 qt5-base-5.15.2+kde+r210-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13632255 Jul 8 15:38 qt5-base-5.15.2+kde+r207-2-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13632883 Jul 1 03:14 qt5-base-5.15.2+kde+r207-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13632221 Jun 25 09:30 qt5-base-5.15.2+kde+r203-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13636292 Jun 22 08:26 qt5-base-5.15.2+kde+r200-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13635509 Jun 20 14:00 qt5-base-5.15.2+kde+r199-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13634669 Jun 19 12:09 qt5-base-5.15.2+kde+r198-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13634263 May 26 00:02 qt5-base-5.15.2+kde+r196-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13635889 May 23 00:41 qt5-base-5.15.2+kde+r195-1-x86_64.pkg.tar.zst
Manjaro:
-rw-r--r-- 1 root root 13637361 Jul 13 02:10 qt5-base-5.15.2+kde+r210-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13630817 May 26 08:43 qt5-base-5.15.2+kde+r196-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13571419 May 2 23:57 qt5-base-5.15.2+kde+r192-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13569478 Apr 21 06:54 qt5-base-5.15.2+kde+r177-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13568057 Apr 17 10:33 qt5-base-5.15.2+kde+r172-0-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 13564130 Feb 10 2021 qt5-base-5.15.2-3-x86_64.pkg.tar.zst
Check again, 5.15.2+kde+r215-1 (same as Arch’s 5.15.2+kde+r215-2) was recently pushed to unstable.
All my Linux systems (1 arch, 5 manjaro) are updated daily in the morning, before use, to current repository.
Are you suggesting only to stable is inadequate?
[2021-08-14T07:19:51-0700] [PACMAN] Running 'pacman -S -u -y --config /etc/pacman.conf --'
[2021-08-14T07:19:51-0700] [PACMAN] synchronizing package lists
[2021-08-14T07:19:55-0700] [PACMAN] starting full system upgrade
I meant check Branch Compare again.
Too sum it all up, all this activity just confirms my original post,
"This has been fixed at archlinux but not yet in manjaro.
"Details at MariaDB 10.6 prepared queries metadata cache causes breakage in mysql driver
"Package Details: mythtv 31+fixes.20210401.563a05b7-1
“and other sources…”
and all is to naught.
I switched from arch to manjaro three years ago on the media server to enjoy the simplicity.
Please review the links I posted above. The fixes are only in the unstable branch.
“You can’t have your cake and eat it too.”
